[GRASS-SVN] r59615 - grass/trunk/vector/v.out.svg
svn_grass at osgeo.org
Sun Apr 6 15:04:07 PDT 2014
Author: neteler
Date: 2014-04-06 15:04:06 -0700 (Sun, 06 Apr 2014)
New Revision: 59615
grass/trunk/vector/v.out.svg/main.c
v.out.svg: fix msg string format
Modified: grass/trunk/vector/v.out.svg/main.c
--- grass/trunk/vector/v.out.svg/main.c 2014-04-06 22:03:56 UTC (rev 59614)
+++ grass/trunk/vector/v.out.svg/main.c 2014-04-06 22:04:06 UTC (rev 59615)
@@ -214,7 +214,7 @@
/* extract areas if any or requested */
if (type == TYPE_POLY) {
if (Vect_get_num_areas(&In) == 0) {
- G_warning(_("No areas found, skipping %"), "type=poly");
+ G_warning(_("No areas found, skipping %s"), "type=poly");
else {
int nareas;
