[GRASS-SVN] r59626 - grass/trunk/lib/db/dbmi_base
Mon Apr 7 03:44:45 PDT 2014
Author: martinl
Date: 2014-04-07 03:44:44 -0700 (Mon, 07 Apr 2014)
New Revision: 59626
   grass/trunk/lib/db/dbmi_base/connect.c
dbmi: fix db_get_connection() to get info about user/passwd
Modified: grass/trunk/lib/db/dbmi_base/connect.c
--- grass/trunk/lib/db/dbmi_base/connect.c	2014-04-07 09:45:27 UTC (rev 59625)
+++ grass/trunk/lib/db/dbmi_base/connect.c	2014-04-07 10:44:44 UTC (rev 59626)
@@ -64,24 +64,33 @@
   \param[out] connection pointer to dbConnection to be modified
   \return DB_OK
+  \return DB_FAILED
 int db_get_connection(dbConnection * connection)
-  /* TODO: add checks and return DB_* error code if needed */
     G_zero(connection, sizeof(dbConnection));
     connection->driverName = (char *)G__getenv2("DB_DRIVER", G_VAR_MAPSET);
     connection->databaseName = (char *)G__getenv2("DB_DATABASE", G_VAR_MAPSET);
+    if (connection->driverName == NULL ||
+        connection->databaseName == NULL)
+        return DB_FAILED;
     connection->schemaName = (char *)G__getenv2("DB_SCHEMA", G_VAR_MAPSET);
     connection->group = (char *)G__getenv2("DB_GROUP", G_VAR_MAPSET);
-    /* below commented due to new mechanism:
+    /* below commented due to new mechanism: see db_get_login()
        connection->hostName = G__getenv("DB_HOST");
        connection->location = G__getenv("DB_LOCATION");
        connection->user = G__getenv("DB_USER");
        connection->password = G__getenv("DB_PASSWORD");
+    /* try to get user/password */
+    db_get_login(connection->driverName, connection->databaseName,
+                 (const char **) &(connection->user),
+                 (const char **) &(connection->password));
     return DB_OK;
