[GRASS-SVN] r59648 - in grass/branches/releasebranch_6_4: . db/drivers/dbf db/drivers/sqlite display/d.text.new imagery/i.ortho.photo/i.photo.elev imagery/i.ortho.photo/i.photo.init imagery/i.pca lib/db/dbmi_client lib/external/shapelib lib/gis lib/ogsf lib/vector/vedit misc/m.cogo raster/r.carve raster/r.in.xyz raster/r.out.gdal raster/r.report raster/r.stats vector/v.type
svn_grass at osgeo.org
Tue Apr 8 13:34:08 PDT 2014
Author: mmetz
Date: 2014-04-08 13:34:08 -0700 (Tue, 08 Apr 2014)
New Revision: 59648
grass/branches/releasebranch_6_4/INSTALL
grass/branches/releasebranch_6_4/db/drivers/dbf/dbfexe.c
grass/branches/releasebranch_6_4/db/drivers/sqlite/execute.c
grass/branches/releasebranch_6_4/display/d.text.new/main.c
grass/branches/releasebranch_6_4/imagery/i.ortho.photo/i.photo.elev/mod_elev.c
grass/branches/releasebranch_6_4/imagery/i.ortho.photo/i.photo.init/main.c
grass/branches/releasebranch_6_4/imagery/i.pca/local_proto.h
grass/branches/releasebranch_6_4/imagery/i.pca/support.c
grass/branches/releasebranch_6_4/lib/db/dbmi_client/delete_tab.c
grass/branches/releasebranch_6_4/lib/external/shapelib/shpopen.c
grass/branches/releasebranch_6_4/lib/gis/closecell.c
grass/branches/releasebranch_6_4/lib/gis/color_write.c
grass/branches/releasebranch_6_4/lib/gis/gdal.c
grass/branches/releasebranch_6_4/lib/ogsf/GVL2.c
grass/branches/releasebranch_6_4/lib/ogsf/gs.c
grass/branches/releasebranch_6_4/lib/ogsf/gsd_objs.c
grass/branches/releasebranch_6_4/lib/ogsf/gsds.c
grass/branches/releasebranch_6_4/lib/ogsf/gv.c
grass/branches/releasebranch_6_4/lib/vector/vedit/render.c
grass/branches/releasebranch_6_4/misc/m.cogo/main.c
grass/branches/releasebranch_6_4/raster/r.carve/main.c
grass/branches/releasebranch_6_4/raster/r.carve/support.c
grass/branches/releasebranch_6_4/raster/r.in.xyz/local_proto.h
grass/branches/releasebranch_6_4/raster/r.out.gdal/export_band.c
grass/branches/releasebranch_6_4/raster/r.report/header.c
grass/branches/releasebranch_6_4/raster/r.stats/main.c
grass/branches/releasebranch_6_4/vector/v.type/main.c
sync to debr6
Modified: grass/branches/releasebranch_6_4/INSTALL
--- grass/branches/releasebranch_6_4/INSTALL 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/INSTALL 2014-04-08 20:34:08 UTC (rev 59648)
@@ -53,7 +53,7 @@
repository (http://svn.osgeo.org/grass/) or as a snapshot
(*.tar.gz package) of that SVN repository. The SVN snapshot name
contains the date when the snapshot was created (checked out from
- the SVN repository), e.g. grass-6.4.0svn_src_snapshot_2008_12_20.tar.gz
+ the SVN repository), e.g. grass-6.4.svn_src_snapshot_2014_04_05.tar.gz
Further instructions at http://trac.osgeo.org/grass/wiki/DownloadSource
Modified: grass/branches/releasebranch_6_4/db/drivers/dbf/dbfexe.c
--- grass/branches/releasebranch_6_4/db/drivers/dbf/dbfexe.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/db/drivers/dbf/dbfexe.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -468,6 +468,7 @@
/* Comparison of 2 rows */
static int cur_cmp_table;
static int cur_cmp_ocol;
static int cmp_row_asc(const void *pa, const void *pb)
int *row1 = (int *)pa;
Modified: grass/branches/releasebranch_6_4/db/drivers/sqlite/execute.c
--- grass/branches/releasebranch_6_4/db/drivers/sqlite/execute.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/db/drivers/sqlite/execute.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -82,11 +82,6 @@
return DB_FAILED;
- if ( rest )
- G_free ( rest );
return DB_OK;
Modified: grass/branches/releasebranch_6_4/display/d.text.new/main.c
--- grass/branches/releasebranch_6_4/display/d.text.new/main.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/display/d.text.new/main.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -333,7 +333,7 @@
if (bg_color == 0) /* ie color="none" */
do_background = 0;
} else
- do_background = 0;
+ do_background = 0;
set_color(opt.fgcolor->answer);
orig_x = orig_y = 0;
Modified: grass/branches/releasebranch_6_4/imagery/i.ortho.photo/i.photo.elev/mod_elev.c
--- grass/branches/releasebranch_6_4/imagery/i.ortho.photo/i.photo.elev/mod_elev.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/imagery/i.ortho.photo/i.photo.elev/mod_elev.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -21,7 +21,7 @@
V_clear();
V_line(1, "Please check the elevation data convention:");
V_line(3,
- "ELEV_DATA = CELL FILE [MAPSET in LOCATION] [MATH EXPERSION][UNITS]");
+ "ELEV_DATA = CELL FILE [MAPSET in LOCATION] [MATH EXPRESSION][UNITS]");
V_line(6, "CELL FILE : ");
V_line(7, "MAPSET : ");
Modified: grass/branches/releasebranch_6_4/imagery/i.ortho.photo/i.photo.init/main.c
--- grass/branches/releasebranch_6_4/imagery/i.ortho.photo/i.photo.init/main.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/imagery/i.ortho.photo/i.photo.init/main.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -73,13 +73,13 @@
- /* get initial camera exposure infor */
+ /* get initial camera exposure info */
if (I_find_initial(group.name)) {
have_old = 1;
I_get_init_info(group.name, &group.camera_exp);
- /* modifiy infor */
+ /* modify info */
mod_init_info(have_old, &group.camera_exp);
/* save info */
Modified: grass/branches/releasebranch_6_4/imagery/i.pca/local_proto.h
--- grass/branches/releasebranch_6_4/imagery/i.pca/local_proto.h 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/imagery/i.pca/local_proto.h 2014-04-08 20:34:08 UTC (rev 59648)
@@ -2,6 +2,6 @@
#define __LOCAL_PROTO_H__
/* support.c */
-int write_support(int, char *, double **, double *);
+void write_support(int, char *, double **, double *);
#endif
Modified: grass/branches/releasebranch_6_4/imagery/i.pca/support.c
--- grass/branches/releasebranch_6_4/imagery/i.pca/support.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/imagery/i.pca/support.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -4,7 +4,7 @@
/* function prototypes */
-static int write_history(int, char *, double **, double *);
+static void write_history(int, char *, double **, double *);
void write_support(int bands, char *outname, double **eigmat, double *eigval)
@@ -30,7 +30,7 @@
-static int write_history(int bands, char *outname, double **eigmat, double *eigval)
+static void write_history(int bands, char *outname, double **eigmat, double *eigval)
int i, j;
static int first_map = TRUE; /* write to stderr? */
@@ -40,7 +40,7 @@
G_short_history(outname, "raster", &hist);
sprintf(hist.edhist[0], "Eigen values, (vectors), and [percent importance]:");
- if(first_map)
+ if (first_map)
G_message(_("Eigen values, (vectors), and [percent importance]:"));
for (i = 0; i < bands; i++)
Modified: grass/branches/releasebranch_6_4/lib/db/dbmi_client/delete_tab.c
--- grass/branches/releasebranch_6_4/lib/db/dbmi_client/delete_tab.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/lib/db/dbmi_client/delete_tab.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -29,31 +29,22 @@
int db_delete_table(const char *drvname, const char *dbname, const char *tblname)
dbDriver *driver;
- dbHandle handle;
dbString sql;
G_debug(3, "db_delete_table(): driver = %s, db = %s, table = %s\n",
drvname, dbname, tblname);
- db_init_handle(&handle);
- db_init_string(&sql);
/* Open driver and database */
- driver = db_start_driver(drvname);
+ driver = db_start_driver_open_database(drvname, dbname);
if (driver == NULL) {
- G_warning(_("Unable to open driver <%s>"), drvname);
+ G_warning(_("Unable open database <%s> by driver <%s>"), dbname,
+ drvname);
return DB_FAILED;
- db_set_handle(&handle, dbname, NULL);
- if (db_open_database(driver, &handle) != DB_OK) {
- G_warning(_("Unable to open database <%s> by driver <%s>"),
- dbname, drvname);
- db_shutdown_driver(driver);
- return DB_FAILED;
/* Delete table */
/* TODO test if the tables exist */
+ db_init_string(&sql);
db_set_string(&sql, "drop table ");
db_append_string(&sql, tblname);
G_debug(3, db_get_string(&sql));
@@ -61,13 +52,11 @@
if (db_execute_immediate(driver, &sql) != DB_OK) {
G_warning(_("Unable to drop table: '%s'"),
- db_close_database(driver);
+ db_close_database_shutdown_driver(driver);
return DB_FAILED;
return DB_OK;
Modified: grass/branches/releasebranch_6_4/lib/external/shapelib/shpopen.c
--- grass/branches/releasebranch_6_4/lib/external/shapelib/shpopen.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/lib/external/shapelib/shpopen.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -846,6 +846,8 @@
if( fpSHP == NULL )
psHooks->Error( "Failed to create file .shp file." );
+ free( pszFullname );
+ free( pszBasename );
return( NULL );
@@ -854,6 +856,8 @@
if( fpSHX == NULL )
psHooks->Error( "Failed to create file .shx file." );
return( NULL );
Modified: grass/branches/releasebranch_6_4/lib/gis/closecell.c
--- grass/branches/releasebranch_6_4/lib/gis/closecell.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/lib/gis/closecell.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -57,14 +57,6 @@
* See Raster_Map_Layer_Support_Routines for routines which write
* raster support files.
- * \param fd
- * \return int
- * \brief
* If the map is a new floating point, move the
* <tt>.tmp</tt> file into the <tt>fcell</tt> element, create an empty file in the
* <tt>cell</tt> directory; write the floating-point range file; write a default
@@ -73,6 +65,7 @@
* (for backwards compatibility). Move the <tt>.tmp</tt> NULL-value bitmap file to
* the <tt>cell_misc</tt> directory.
+ * \param fd
* \return int
@@ -269,7 +262,6 @@
fcb->mapset);
remove(path);
strcpy(CELL_DIR, "cell");
- close(fd);
} /* ok */
/* NOW CLOSE THE FILE DESCRIPTOR */
Modified: grass/branches/releasebranch_6_4/lib/gis/color_write.c
--- grass/branches/releasebranch_6_4/lib/gis/color_write.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/lib/gis/color_write.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -121,7 +121,7 @@
fprintf(fd, "%% %s %s\n", str1, str2);
if (colors->shift) {
- sprintf(str2, "%.17g", (double)colors->shift);
+ sprintf(str2, "%.15g", (double)colors->shift);
G_trim_decimal(str2);
fprintf(fd, "shift:%s\n", str2);
@@ -169,7 +169,7 @@
if (rule->low.value == dmin)
format_min(str, (double)rule->low.value);
else {
- sprintf(str, "%.17g", (double)rule->low.value);
+ sprintf(str, "%.15g", (double)rule->low.value);
G_trim_decimal(str);
fprintf(fd, "%s:%d", str, (int)rule->low.red);
@@ -180,7 +180,7 @@
if (rule->high.value == dmax)
format_max(str, (double)rule->high.value);
else {
- sprintf(str, "%.17g", (double)rule->high.value);
+ sprintf(str, "%.15g", (double)rule->high.value);
fprintf(fd, " %s:%d", str, (int)rule->high.red);
@@ -246,16 +246,16 @@
double dtmp;
- sprintf(str, "%.17g", dval);
+ sprintf(str, "%.15g", dval);
/* Note that G_trim_decimal() does not trim e.g. 1.0000000e-20 */
sscanf(str, "%lf", &dtmp);
if (dtmp != dval) { /* if no zeros after decimal point were trimmed */
/* lower dval by GRASS_EPSILON fraction */
if (dval > 0)
- sprintf(str, "%.17g", dval * (1 - GRASS_EPSILON));
+ sprintf(str, "%.15g", dval * (1 - GRASS_EPSILON));
else
- sprintf(str, "%.17g", dval * (1 + GRASS_EPSILON));
+ sprintf(str, "%.15g", dval * (1 + GRASS_EPSILON));
return 0;
@@ -265,16 +265,16 @@
double dtmp;
/* increase dval by by GRASS_EPSILON fraction */
if (dval > 0)
else
return 0;
Modified: grass/branches/releasebranch_6_4/lib/gis/gdal.c
--- grass/branches/releasebranch_6_4/lib/gis/gdal.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/lib/gis/gdal.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -91,6 +91,7 @@
"libgdal1.7.0.so",
# endif
# ifdef _WIN32
+ "gdal110.dll",
"gdal19.dll",
"gdal18.dll",
"gdal17.dll",
Modified: grass/branches/releasebranch_6_4/lib/ogsf/GVL2.c
--- grass/branches/releasebranch_6_4/lib/ogsf/GVL2.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/lib/ogsf/GVL2.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -301,7 +301,7 @@
G_debug(3, "GVL_get_dims() id=%d, rows=%d, cols=%d, depths=%d",
gvl->gvol_id, gvl->rows, gvl->cols, gvl->depths);
return;
Modified: grass/branches/releasebranch_6_4/lib/ogsf/gs.c
--- grass/branches/releasebranch_6_4/lib/ogsf/gs.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/lib/ogsf/gs.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -711,8 +711,7 @@
\param desc attribute id (descriptor)
\param type buffer type (based on raster map type)
- \return -1 on error
- \return pointer to typbuff (casted)
+ \return 1 on success, -1 on failure
int gs_malloc_att_buff(geosurf * gs, int desc, int type)
Modified: grass/branches/releasebranch_6_4/lib/ogsf/gsd_objs.c
--- grass/branches/releasebranch_6_4/lib/ogsf/gsd_objs.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/lib/ogsf/gsd_objs.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -1246,7 +1246,7 @@
\return 1
int gsd_scalebar_v2(float *pos, float len, GLuint fontbase,
- unsigned long bar_clr, unsigned long text_clr)
+ unsigned long bar_clr, unsigned long text_clr)
float base[6][3];
float Ntop[] = { 0.0, 0.0, 1.0 };
Modified: grass/branches/releasebranch_6_4/lib/ogsf/gsds.c
--- grass/branches/releasebranch_6_4/lib/ogsf/gsds.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/lib/ogsf/gsds.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -481,7 +481,8 @@
int gsds_alloc_typbuff(int id, int *dims, int ndims, int type)
dataset *ds;
- int i, siz = 1;
+ int i;
+ size_t siz = 1;
if ((ds = get_dataset(id))) {
@@ -596,7 +597,7 @@
"gsds_alloc_typbuff(): %f Kbytes allocated, current total = %f",
siz / 1000., Tot_mem / 1000.);
- return (siz);
+ return (1);
return (-1);
Modified: grass/branches/releasebranch_6_4/lib/ogsf/gv.c
--- grass/branches/releasebranch_6_4/lib/ogsf/gv.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/lib/ogsf/gv.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -184,7 +184,7 @@
if (!gv) {
return (-1);
G_debug(5, "gv_set_defaults() id=%d", gv->gvect_id);
gv->filename = NULL;
Modified: grass/branches/releasebranch_6_4/lib/vector/vedit/render.c
--- grass/branches/releasebranch_6_4/lib/vector/vedit/render.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/lib/vector/vedit/render.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -135,6 +135,9 @@
list_obj->nitems *
sizeof(struct robject *));
+ G_debug(1, "Vedit_render_map(): -> nitems = %d",
+ list_obj->nitems);
Vect_destroy_list(list);
return list_obj;
@@ -461,6 +464,7 @@
/* get area's boundary */
Vect_get_area_points(Map, area, state.Points);
robj = robj_alloc(TYPE_AREA, state.Points->n_points);
+ robj->fid = centroid;
robj_points(robj, state.Points);
list_append(list, robj);
@@ -473,6 +477,7 @@
Vect_get_isle_points(Map, isle, ipoints);
robj = robj_alloc(TYPE_ISLE, ipoints->n_points);
+ robj->fid = -1;
robj_points(robj, ipoints);
Modified: grass/branches/releasebranch_6_4/misc/m.cogo/main.c
--- grass/branches/releasebranch_6_4/misc/m.cogo/main.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/misc/m.cogo/main.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -49,29 +49,29 @@
-static void print_coordinates(FILE * outfile, struct survey_record *in)
+static void print_coordinates(FILE *outfile, struct survey_record *in)
if (in->haslabel == YES)
- fprintf(outfile, "%f %f %s\n", in->x, in->y, in->label);
+ fprintf(outfile, "%.15g %.15g %s\n", in->x, in->y, in->label);
else
- fprintf(outfile, "%f %f\n", in->x, in->y);
+ fprintf(outfile, "%.15g %.15g\n", in->x, in->y);
-static void print_cogo(FILE * outfile, struct survey_record *in)
+static void print_cogo(FILE *outfile, struct survey_record *in)
- fprintf(outfile, "%s %s %d:%d:%.3f %s %f\n",
+ fprintf(outfile, "%s %s %02d:%02d:%02.9g %s %.13g\n",
in->label, in->n_s, in->deg, in->min, in->sec,
in->e_w, in->dist);
else
- fprintf(outfile, "%s %d:%d:%.3f %s %f\n",
+ fprintf(outfile, "%s %02d:%02d:%02.9g %s %.13g\n",
in->n_s, in->deg, in->min, in->sec, in->e_w, in->dist);
-static const char *next_line(FILE * infile)
+static const char *next_line(FILE *infile)
static char line[512];
const char *cptr;
@@ -210,12 +210,14 @@
struct Flag *format;
struct Flag *quiet;
struct Flag *reverse;
+ struct Flag *close;
struct GModule *module;
FILE *infile, *outfile;
- struct survey_record record;
+ struct survey_record record, first_record;
const char *cptr;
char *ss;
- int verbose = 1, linenum = 0;
+ int verbose = TRUE;
+ unsigned long linenum = 0, dataline = 0;
int (*parse_line) (const char *, struct survey_record *);
void (*print_func) (FILE *, struct survey_record *);
@@ -240,6 +242,11 @@
reverse->description =
_("Convert from coordinates to bearing and distance");
+ close = G_define_flag();
+ close->key = 'c';
+ close->description =
+ _("Repeat the starting coordinate at the end to close a loop");
input = G_define_standard_option(G_OPT_F_INPUT);
input->required = NO;
input->answer = "-";
@@ -288,7 +295,7 @@
if (quiet->answer)
- verbose = 0;
+ verbose = FALSE;
if (reverse->answer) {
parse_line = parse_reverse;
@@ -324,9 +331,19 @@
G_warning(_("Input parse error on line %d"), linenum);
continue;
+ dataline++;
+ if (dataline == 1)
+ first_record = record;
print_func(outfile, &record);
+ if (close->answer)
+ print_func(outfile, &first_record);
if (infile != stdin)
fclose(infile);
if (outfile != stdout)
Modified: grass/branches/releasebranch_6_4/raster/r.carve/main.c
--- grass/branches/releasebranch_6_4/raster/r.carve/main.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/raster/r.carve/main.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -9,7 +9,7 @@
* PURPOSE: Takes vector stream data, converts it to 3D raster and
* subtracts a specified depth
- * COPYRIGHT: (C) 2006-2013 by the GRASS Development Team
+ * COPYRIGHT: (C) 2006, 2010 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
Modified: grass/branches/releasebranch_6_4/raster/r.carve/support.c
--- grass/branches/releasebranch_6_4/raster/r.carve/support.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/raster/r.carve/support.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -38,8 +38,10 @@
G_short_history(parm->outrast->answer, "raster", &hist);
sprintf(hist.edhist[0], "%s version %.2f", G_program_name(), APP_VERSION);
sprintf(hist.edhist[1], "stream width: %.2f", parm->swidth * 2);
- sprintf(hist.datsrc_1, "raster elevation file: %s", parm->inrast->answer);
- sprintf(hist.datsrc_2, "vector stream file: %s", parm->invect->answer);
+ G_snprintf(hist.datsrc_1, RECORD_LEN, "raster elevation map: %s",
+ parm->inrast->answer);
+ G_snprintf(hist.datsrc_2, RECORD_LEN, "vector stream map: %s",
+ parm->invect->answer);
hist.edlinecnt = 2;
G_command_history(&hist);
Modified: grass/branches/releasebranch_6_4/raster/r.in.xyz/local_proto.h
--- grass/branches/releasebranch_6_4/raster/r.in.xyz/local_proto.h 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/raster/r.in.xyz/local_proto.h 2014-04-08 20:34:08 UTC (rev 59648)
@@ -21,7 +21,7 @@
#include <grass/gis.h>
-#define BUFFSIZE 256
+#define BUFFSIZE 1024
#define METHOD_N 1
#define METHOD_MIN 2
Modified: grass/branches/releasebranch_6_4/raster/r.out.gdal/export_band.c
--- grass/branches/releasebranch_6_4/raster/r.out.gdal/export_band.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/raster/r.out.gdal/export_band.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -190,7 +190,7 @@
(int)nodataval, nodatakey);
else
G_important_message(_("Input raster map contains cells with NULL-value (no-data). "
- "The value %f will be used to represent no-data values in the input map. "
+ "The value %g will be used to represent no-data values in the input map. "
"You can specify a nodata value with the %s option."),
Modified: grass/branches/releasebranch_6_4/raster/r.report/header.c
--- grass/branches/releasebranch_6_4/raster/r.report/header.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/raster/r.report/header.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -72,8 +72,6 @@
divider("|");
- label = nlayers > 1 ? "MAPS:" : "MAP:";
mask = maskinfo();
label = "MASK:";
len1 = strlen(label) + 1;
Modified: grass/branches/releasebranch_6_4/raster/r.stats/main.c
--- grass/branches/releasebranch_6_4/raster/r.stats/main.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/raster/r.stats/main.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -199,9 +199,11 @@
flag.i->key = 'i';
flag.i->description = _("Read fp map as integer (use map's quant rules)");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
name = option.output->answer;
if (name != NULL && strcmp(name, "-") != 0) {
if (NULL == freopen(name, "w", stdout)) {
@@ -240,7 +242,7 @@
with_coordinates = flag.g->answer;
with_xy = flag.x->answer;
if (with_coordinates || with_xy)
- raw_data = 1;
+ raw_data = TRUE;
/* get field separator */
strcpy(fs, " ");
@@ -276,6 +278,7 @@
fd[nfiles] = G_open_cell_old(name, mapset);
if (fd[nfiles] < 0)
exit(1);
if (!as_int)
is_fp[nfiles] = G_raster_map_is_fp(name, mapset);
else {
Modified: grass/branches/releasebranch_6_4/vector/v.type/main.c
--- grass/branches/releasebranch_6_4/vector/v.type/main.c 2014-04-08 19:47:26 UTC (rev 59647)
+++ grass/branches/releasebranch_6_4/vector/v.type/main.c 2014-04-08 20:34:08 UTC (rev 59648)
@@ -15,9 +15,6 @@
* for details.
-#ifdef FOR_GRASS7
-#include <string.h>
-#endif
#include <stdlib.h>
@@ -32,16 +29,10 @@
int type;
char *mapset;
-#ifdef FOR_GRASS7
- struct Option *in_opt, *out_opt, *to_opt, *from_opt;
- int from_type, to_type;
-#else
int i, j;
struct Option *in_opt, *out_opt, *type_opt;
int types[100]; /* array of input,output types */
int ntypes; /* number of types (number of pairs * 2) */
-#endif
module = G_define_module();
module->keywords = _("vector, geometry");
@@ -50,27 +41,6 @@
in_opt = G_define_standard_option(G_OPT_V_INPUT);
out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
-#ifdef FOR_GRASS7
- from_opt = G_define_option();
- from_opt->type = TYPE_STRING;
- from_opt->key = "from";
- from_opt->key_desc = "type";
- from_opt->options = "point,line,boundary,centroid,face,kernel";
- from_opt->answer = "boundary";
- from_opt->required = YES;
- from_opt->multiple = NO;
- from_opt->description = _("Feature type to convert from");
- to_opt = G_define_option();
- to_opt->type = TYPE_STRING;
- to_opt->key = "to";
- to_opt->key_desc = "type";
- to_opt->options = "point,line,boundary,centroid,face,kernel";
- to_opt->answer = "line";
- to_opt->required = YES;
- to_opt->multiple = NO;
- to_opt->description = _("Feature type to convert to");
-#else
type_opt = G_define_standard_option(G_OPT_V_TYPE);
type_opt->options = "point,line,boundary,centroid,face,kernel";
type_opt->answer = "line,boundary,point,centroid";
@@ -79,7 +49,6 @@
_("<input_type1>,<output_type1>,<input_type2>,<output_type2>,...\n"
"\t\tExample1: line,boundary\n"
"\t\tExample2: line,boundary,point,centroid");
-#endif
G_gisinit(argv[0]);
@@ -87,60 +56,6 @@
exit(EXIT_FAILURE);
-#ifdef FOR_GRASS7
- if (!strcmp(from_opt->answer, to_opt->answer))
- G_fatal_error(_("Nothing to do"));
- switch (from_opt->answer[0]) {
- case 'p':
- from_type = GV_POINT;
- break;
- case 'l':
- from_type = GV_LINE;
- break;
- case 'b':
- from_type = GV_BOUNDARY;
- break;
- case 'c':
- from_type = GV_CENTROID;
- break;
- case 'f':
- from_type = GV_FACE;
- break;
- case 'k':
- from_type = GV_KERNEL;
- break;
- switch (to_opt->answer[0]) {
- case 'p':
- to_type = GV_POINT;
- break;
- case 'l':
- to_type = GV_LINE;
- break;
- case 'b':
- to_type = GV_BOUNDARY;
- break;
- case 'c':
- to_type = GV_CENTROID;
- break;
- case 'f':
- to_type = GV_FACE;
- break;
- case 'k':
- to_type = GV_KERNEL;
- break;
- /* check type compatibility */
- if (((from_type & (GV_POINT | GV_CENTROID | GV_KERNEL)) &&
- (to_type & (GV_LINE | GV_BOUNDARY | GV_FACE))
- ) || ((from_type & (GV_LINE | GV_BOUNDARY | GV_FACE)) &&
- (to_type & (GV_POINT | GV_CENTROID | GV_KERNEL))
- G_fatal_error(_("Incompatible types"));
-#else
i = 0;
j = 0;
while (type_opt->answers[i]) {
@@ -189,7 +104,6 @@
G_fatal_error(_("Odd number of types"));
ntypes = i;
-#endif
Vect_check_input_output_name(in_opt->answer, out_opt->answer,
GV_FATAL_EXIT);
@@ -216,17 +130,12 @@
Vect_hist_command(&Out);
while ((type = Vect_read_next_line(&In, Points, Cats)) > 0) {
-#ifdef FOR_GRASS7
- if (type == from_type)
- type = to_type;
-#else
for (i = 0; i < ntypes; i += 2) {
if (type == types[i]) {
type = types[i + 1];
break;
-#endif
Vect_write_line(&Out, type, Points, Cats);
