[GRASS-SVN] r59660 - grass/branches/releasebranch_6_4/raster/r.watershed/front
svn_grass at osgeo.org
Wed Apr 9 08:48:59 PDT 2014
Author: neteler
Date: 2014-04-09 08:48:59 -0700 (Wed, 09 Apr 2014)
New Revision: 59660
grass/branches/releasebranch_6_4/raster/r.watershed/front/main.c
r.watershed: standardize param description (compromise between trunk, delbr6 and existing msgs)
Modified: grass/branches/releasebranch_6_4/raster/r.watershed/front/main.c
--- grass/branches/releasebranch_6_4/raster/r.watershed/front/main.c 2014-04-09 15:46:35 UTC (rev 59659)
+++ grass/branches/releasebranch_6_4/raster/r.watershed/front/main.c 2014-04-09 15:48:59 UTC (rev 59660)
@@ -84,6 +84,8 @@
opt5 = G_define_standard_option(G_OPT_R_INPUT);
opt5->key = "blocking";
+ opt5->label =
+ _("Name of input raster map blocking overland surface flow");
opt5->description =
_("Input map: terrain blocking overland surface flow, for USLE");
opt5->required = NO;
@@ -91,6 +93,7 @@
opt8 = G_define_standard_option(G_OPT_R_OUTPUT);
opt8->key = "accumulation";
+ opt8->label = _("Name for output accumulation raster map");
opt8->description =
_("Output map: number of cells that drain through each cell");
opt8->required = NO;
@@ -105,7 +108,7 @@
opt10 = G_define_standard_option(G_OPT_R_OUTPUT);
opt10->key = "basin";
opt10->description =
- _("Output map: unique label for each watershed basin");
+ _("Output map: basins raster map");
opt10->required = NO;
opt10->guisection = _("Output_options");
@@ -118,7 +121,7 @@
opt12 = G_define_standard_option(G_OPT_R_OUTPUT);
opt12->key = "half.basin";
opt12->description =
- _("Output map: each half-basin is given a unique value");
+ _("Output map: half basins raster map");
opt12->required = NO;
opt12->guisection = _("Output_options");
@@ -131,6 +134,7 @@
opt14 = G_define_standard_option(G_OPT_R_OUTPUT);
opt14->key = "length.slope";
+ opt14->label = _("Name for output slope length raster map");
opt14->description =
_("Output map: slope length and steepness (LS) factor for USLE");
opt14->required = NO;
@@ -138,7 +142,8 @@
opt15 = G_define_standard_option(G_OPT_R_OUTPUT);
opt15->key = "slope.steepness";
- opt15->description = _("Output map: slope steepness (S) factor for USLE");
+ opt15->label = _("Name for output slope steepness raster map");
+ opt15->description = _("Output map: Slope steepness (S) factor for USLE");
opt15->required = NO;
opt15->guisection = _("Output_options");
