[GRASS-SVN] r59662 - grass-promo/grassposter/2014_EGU_WD_Landscape
svn_grass at osgeo.org
Wed Apr 9 21:13:57 PDT 2014
Author: ychemin
Date: 2014-04-09 21:13:57 -0700 (Wed, 09 Apr 2014)
New Revision: 59662
grass-promo/grassposter/2014_EGU_WD_Landscape/Makefile
grass-promo/grassposter/2014_EGU_WD_Landscape/poster.tex
trying to add code highlighting
Modified: grass-promo/grassposter/2014_EGU_WD_Landscape/Makefile
--- grass-promo/grassposter/2014_EGU_WD_Landscape/Makefile 2014-04-10 03:45:08 UTC (rev 59661)
+++ grass-promo/grassposter/2014_EGU_WD_Landscape/Makefile 2014-04-10 04:13:57 UTC (rev 59662)
@@ -7,14 +7,14 @@
all: $(FILE).pdf
$(FILE).pdf: *.tex Makefile
- make pdf
- make pdf
+ make pdf
+ make pdf
@while grep Rerun $(FILE).log >/dev/null 2>&1 ; do \
make pdf; \
done
pdf: fig
- pdflatex $(FILE).tex
+ pdflatex -shell-escape $(FILE).tex
fig: $(SVGPDF)
Modified: grass-promo/grassposter/2014_EGU_WD_Landscape/poster.tex
--- grass-promo/grassposter/2014_EGU_WD_Landscape/poster.tex 2014-04-10 03:45:08 UTC (rev 59661)
+++ grass-promo/grassposter/2014_EGU_WD_Landscape/poster.tex 2014-04-10 04:13:57 UTC (rev 59662)
@@ -1,5 +1,6 @@
\documentclass[landscape,a0,final]{a0poster}
\usepackage[dvipsnames,svgnames]{xcolor}
+\usepackage{minted} %code highlighting, not working yet
\usepackage{tikzposter} % here most of the things are defined
% change parameters only after this line You can also start a new column with an arbitrary
% x-coordinate by specifying explicitly the coordinate of the new block node as follows:
@@ -132,7 +133,11 @@
\end{tabular}\newline
\end{center}
+%Minted version Not working (+ compile needs -shell-escape)
+%\begin{minted}[frame=single,linenos,mathescape,fontsize=\small]{sh}
+% i.group group=pca_group input=$(g.mlist type=rast pattern=*h28v07*EVI)
+% i.pca input=pca_group output_prefix=pca_ percent=99 --o
+%\end{minted}
