[GRASS-SVN] r59706 - grass/branches/releasebranch_7_0/mswindows
svn_grass at osgeo.org
Sun Apr 13 05:15:54 PDT 2014
Author: hellik
Date: 2014-04-13 05:15:54 -0700 (Sun, 13 Apr 2014)
New Revision: 59706
grass/branches/releasebranch_7_0/mswindows/GRASS-Installer.nsi.tmpl
wingrass-R: remove unused hardcoded path to R as path to R is loaded now dynamically to path (merged from trunk)
Modified: grass/branches/releasebranch_7_0/mswindows/GRASS-Installer.nsi.tmpl
--- grass/branches/releasebranch_7_0/mswindows/GRASS-Installer.nsi.tmpl 2014-04-13 12:08:09 UTC (rev 59705)
+++ grass/branches/releasebranch_7_0/mswindows/GRASS-Installer.nsi.tmpl 2014-04-13 12:15:54 UTC (rev 59706)
@@ -200,17 +200,11 @@
Var /GLOBAL MESSAGE_2_
Var /GLOBAL MESSAGE_3_
-; Var /GLOBAL R_HKLM_INSTALL_PATH
-; Var /GLOBAL R_HKCU_INSTALL_PATH
ReadRegStr $UNINSTALL_STRING HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString"
ReadRegStr $INSTALL_PATH HKLM "Software\${GRASS_BASE}" "InstallPath"
ReadRegStr $INSTALLED_VERSION_NUMBER HKLM "Software\${GRASS_BASE}" "VersionNumber"
ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "SvnRevision"
-; ReadRegStr $R_HKLM_INSTALL_PATH HKLM "Software\R-core\R" "InstallPath"
-; ReadRegStr $R_HKCU_INSTALL_PATH HKCU "Software\R-core\R" "InstallPath"
${If} $INSTALLED_SVN_REVISION == ""
ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "Revision"
${EndIf}
@@ -692,14 +686,6 @@
FileWrite $0 '$\r$\n'
FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
-; ${If} $R_HKLM_INSTALL_PATH != ""
-; FileWrite $0 'set PATH=$R_HKLM_INSTALL_PATH\bin;%PATH%$\r$\n'
-; FileWrite $0 '$\r$\n'
-; ${EndIf}
-; ${If} $R_HKCU_INSTALL_PATH != ""
-; FileWrite $0 'set PATH=$R_HKCU_INSTALL_PATH\bin;%PATH%$\r$\n'
-; ${EndIf}
FileWrite $0 'call "%GISBASE%\etc\env.bat"$\r$\n'
FileWrite $0 'cd "%USERPROFILE%"'
@@ -731,14 +717,6 @@
; FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
; FileWrite $0 'set GRASS_SH=%GISBASE%\msys\bin\sh.exe$\r$\n'
-; ${EndIf}
-; ${EndIf}
; FileWrite $0 'call "%GISBASE%\etc\env.bat"$\r$\n'
; FileWrite $0 'cd "%USERPROFILE%"'
