[GRASS-SVN] r59709 - grass-addons/grass7/raster/r.basin
svn_grass at osgeo.org
Sun Apr 13 07:06:30 PDT 2014
Author: madi
Date: 2014-04-13 07:06:30 -0700 (Sun, 13 Apr 2014)
New Revision: 59709
grass-addons/grass7/raster/r.basin/r.basin.py
added snapping to stream network for outlet coordinates
Modified: grass-addons/grass7/raster/r.basin/r.basin.py
--- grass-addons/grass7/raster/r.basin/r.basin.py 2014-04-13 12:31:58 UTC (rev 59708)
+++ grass-addons/grass7/raster/r.basin/r.basin.py 2014-04-13 14:06:30 UTC (rev 59709)
@@ -109,6 +109,7 @@
r_mainchannel_dim = prefix+'_mainchannel_dim'
r_outlet = prefix+'_r_outlet'
v_outlet = prefix+'_outlet'
+ v_outlet_snap = prefix+'_outlet_snap'
v_basin = prefix+'_basin'
v_mainchannel = prefix+'_mainchannel'
v_mainchannel_dim = prefix+'_mainchannel_dim'
@@ -142,7 +143,7 @@
threshold = th,
d8cut = 1000000000,
mexp = 0,
- stream_rast = r_stream_e,
+ stream_rast = r_stream_e,
direction = r_drainage_e,
overwrite = True)
@@ -154,46 +155,87 @@
grass.fatal(_("The 'r.stream.basins' module was not found, install it first:") +
"\n" +
"g.extension r.stream.basins")
- grass.run_command('r.stream.basins', direction = r_drainage,
+ # Create outlet
+ grass.write_command('v.in.ascii', output = v_outlet,
+ input = "-",
+ sep = ",",
+ stdin = "%s,9999" % (coordinates),
+ overwrite = True)
+ # Snap outlet to stream network
+ grass.run_command('r.stream.snap', input = v_outlet,
+ output = v_outlet_snap,
+ radius = 30)
+ grass.run_command('v.to.rast', input = v_outlet_snap,
+ output = r_outlet,
+ use = 'cat',
+ type = 'point',
+ layer = 1,
+ value = 1,
+ rows = 4096,
+ overwrite = True)
+ grass.run_command('r.stream.basins', direction = r_drainage_e,
basins = r_basin,
- coordinates = '%s' % (coordinates),
- overwrite = True)
+ points = v_outlet_snap,
+ overwrite = True)
grass.message( "Delineation of basin done" )
# Mask and cropping
elevation_name = r_elevation = r_elevation.split('@')[0]
grass.mapcalc("$r_mask = $r_basin / $r_basin",
r_mask = r_mask,
r_basin = r_basin)
grass.mapcalc("tmp = $r_accumulation / $r_mask",
r_accumulation = r_accumulation,
r_mask = r_mask)
grass.run_command('g.remove', rast = r_accumulation, quiet = True)
grass.run_command('g.rename', rast = ('tmp',r_accumulation))
grass.mapcalc("tmp = $r_drainage / $r_mask",
r_drainage = r_drainage,
r_mask = r_mask)
grass.run_command('g.remove', rast = r_drainage, quiet = True)
grass.run_command('g.rename', rast = ('tmp', r_drainage))
grass.mapcalc("$r_elevation_crop = $r_elevation * $r_mask",
r_mask = r_mask,
r_elevation = r_elevation,
- r_elevation_crop = 'r_elevation_crop')
+ r_elevation_crop = 'r_elevation_crop',
+ overwrite = True)
grass.mapcalc("tmp = $r_drainage_e * $r_mask",
r_mask = r_mask,
r_drainage_e = r_drainage_e)
grass.run_command('g.remove', rast = r_drainage_e, quiet = True)
grass.run_command('g.rename', rast = ('tmp',r_drainage_e))
grass.mapcalc("tmp = $r_stream_e * $r_mask",
r_mask = r_mask,
r_stream_e = r_stream_e)
grass.run_command('g.remove', rast = r_stream_e, quiet = True)
+ #grass.run_command('g.rename', rast = (r_stream_e,'streams'))
grass.run_command('g.rename', rast = ('tmp',r_stream_e))
grass.run_command('r.thin', input = r_stream_e,
output = r_stream_e+'_thin',
overwrite = True)
grass.run_command('r.to.vect', input = r_stream_e+'_thin',
output = v_network,
type = 'line',
@@ -266,41 +308,24 @@
grass.message( "Creating %s" % r_hack )
grass.run_command('r.stream.order', stream_rast = r_stream_e,
- direction = r_drainage_e,
- strahler = r_strahler,
- shreve = r_shreve,
- horton = r_horton,
- hack = r_hack,
- overwrite = True)
- # Distance to outlet
- grass.write_command('v.in.ascii', output = v_outlet,
- input = "-",
- sep = ",",
- stdin = "%s,9999" % (coordinates),
- overwrite = True)
- grass.run_command('v.to.rast', input = v_outlet,
- output = r_outlet,
- use = 'cat',
- type = 'point',
- layer = 1,
- value = 1,
- rows = 4096,
- overwrite = True)
+ direction = r_drainage_e,
+ strahler = r_strahler,
+ shreve = r_shreve,
+ horton = r_horton,
+ hack = r_hack,
+ overwrite = True)
+ # Distance to outlet
grass.run_command('r.stream.distance', stream_rast = r_outlet,
- direction = r_drainage,
- flags = 'o',
- distance = r_distance,
- overwrite = True)
+ flags = 'o',
+ distance = r_distance,
+ overwrite = True)
# hypsographic curve
- grass.message( "##################################" )
+ grass.message( "------------------------------" )
#### check if r.hypso addon is installed
if not grass.find_program('r.hypso', '--help'):
@@ -310,11 +335,11 @@
grass.run_command('r.hypso', map = 'r_elevation_crop',
image = os.path.join(directory,prefix), flags = 'ab')
# Width Function
#### check if r.width.funct addon is installed
if not grass.find_program('r.width.funct', '--help'):
@@ -324,7 +349,7 @@
grass.run_command('r.width.funct', map = r_distance,
image = os.path.join(directory,prefix))
# Creation of map of hillslope distance to river network
@@ -360,8 +385,8 @@
# Centroid and mean slope
baricenter_slope_baricenter = grass.read_command("r.volume", input = r_slope,
- clump = r_basin,
- overwrite = True)
+ clump = r_basin,
+ overwrite = True)
grass.message("r.volume done")
@@ -421,9 +446,31 @@
type = 'line',
verbose = True,
overwrite = True)
+ # Get coordinates of the outlet (belonging to stream network)
+ grass.run_command('v.db.addtable', map = v_outlet_snap)
+ grass.run_command('v.db.addcolumn', map = v_outlet_snap,
+ columns="x double precision,y double precision" )
+ grass.run_command('v.to.db', map = v_outlet_snap,
+ option = "coor",
+ col = "x,y" )
+ namefile = os.path.join(directory, prefix + '_outlet_coors.txt')
+ grass.run_command('v.out.ascii', input = v_outlet_snap,
+ output = namefile,
+ cats = 1,
+ format = "point")
+ f = open(namefile)
+ east_o, north_o, z = f.readline().split('|')
param_mainchannel = grass.read_command('v.what', map = v_mainchannel,
- coordinates = '%s,%s' % (east,north),
+ coordinates = '%s,%s' % (east_o,north_o),
distance = 5 )
tmp = param_mainchannel.split('\n')[7]
mainchannel = float(tmp.split()[1]) / 1000 # km
@@ -462,6 +509,7 @@
input = v_mainchannel_dim+'_point').strip().split('\n')
nodi = zeros((len(vertex),4),float)
pendenze = []
for i in range(len(vertex)):
x, y = float(vertex[i].split('|')[0]) , float(vertex[i].split('|')[1])
vertice1 = grass.read_command('r.what', verbose = True,
@@ -469,10 +517,12 @@
coordinates = '%s,%s' % (x,y))
vertice = vertice1.replace('\n','').replace('||','|').split('|')
nodi[i,0],nodi[i,1], nodi[i,2] = float(vertice[0]), float(vertice[1]), float(vertice[2])
for i in range(0,len(vertex)-1,2):
dist = math.sqrt(math.fabs((nodi[i,0] - nodi[i+1,0]))**2 + math.fabs((nodi[i,1] - nodi[i+1,1]))**2)
deltaz = math.fabs(nodi[i,2] - nodi[i+1,2])
# Control to prevent float division by zero (dist=0)
try:
pendenza = deltaz / dist
pendenze.append(pendenza)
@@ -489,7 +539,7 @@
# Characteristic altitudes
height_basin_average = grass.read_command('r.what', map = r_height_average ,
cache = 500 ,
- coordinates = '%s,%s' % (east , north ))
+ coordinates = '%s,%s' % (east_o , north_o ))
height_basin_average = height_basin_average.replace('\n','')
height_basin_average = float(height_basin_average.split('|')[-1])
minmax_height_basin = grass.read_command('r.info', flags = 'r',
