[GRASS-SVN] r59712 - in grass/trunk/vector: v.build.polylines v.category v.edit v.external v.extract v.in.ascii v.in.db v.kernel v.lidar.correction v.lrs/v.lrs.segment v.lrs/v.lrs.where v.net.distance v.out.ascii v.out.ogr v.out.postgis v.out.pov v.overlay v.sample v.segment v.surf.idw v.voronoi v.what.rast3
svn_grass at osgeo.org
Sun Apr 13 11:08:20 PDT 2014
Author: marisn
Date: 2014-04-13 11:08:19 -0700 (Sun, 13 Apr 2014)
New Revision: 59712
grass/trunk/vector/v.build.polylines/main.c
grass/trunk/vector/v.category/main.c
grass/trunk/vector/v.edit/main.c
grass/trunk/vector/v.edit/select.c
grass/trunk/vector/v.external/list.c
grass/trunk/vector/v.extract/main.c
grass/trunk/vector/v.in.ascii/points.c
grass/trunk/vector/v.in.db/main.c
grass/trunk/vector/v.kernel/main.c
grass/trunk/vector/v.lidar.correction/main.c
grass/trunk/vector/v.lrs/v.lrs.segment/main.c
grass/trunk/vector/v.lrs/v.lrs.where/main.c
grass/trunk/vector/v.net.distance/main.c
grass/trunk/vector/v.out.ascii/main.c
grass/trunk/vector/v.out.ogr/main.c
grass/trunk/vector/v.out.postgis/main.c
grass/trunk/vector/v.out.pov/main.c
grass/trunk/vector/v.overlay/area_area.c
grass/trunk/vector/v.sample/main.c
grass/trunk/vector/v.segment/main.c
grass/trunk/vector/v.surf.idw/main.c
grass/trunk/vector/v.surf.idw/read_sites.c
grass/trunk/vector/v.voronoi/main.c
grass/trunk/vector/v.voronoi/sw_main.c
grass/trunk/vector/v.what.rast3/main.c
Enable plural forms for translatable messages of vector modules
Modified: grass/trunk/vector/v.build.polylines/main.c
--- grass/trunk/vector/v.build.polylines/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.build.polylines/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -223,9 +223,13 @@
polyline++;
- G_verbose_message(_("%d lines or boundaries found in input vector map"),
+ G_verbose_message(_n("%d line or boundaries found in input vector map",
+ "%d lines or boundaries found in input vector map",
+ nlines),
nlines, Vect_get_name(&map), Vect_get_mapset(&map));
- G_verbose_message(_("%d polylines stored in output vector map"),
+ G_verbose_message(_n("%d polyline stored in output vector map",
+ "%d polylines stored in output vector map",
+ polyline),
polyline, Vect_get_name(&Out), Vect_get_mapset(&Out));
/* Copy (all linked) tables if needed */
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.category/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -214,7 +214,9 @@
Clist->field = atoi(field_opt->answer);
ret = Vect_str_to_cat_list(id_opt->answer, Clist);
if (ret > 0) {
- G_warning(_("%d errors in id option"), ret);
+ G_warning(_n("%d error in id option",
+ "%d errors in id option",
+ ret), ret);
else {
@@ -373,7 +375,9 @@
new_centr++;
if (new_centr > 0)
- G_message(_("%d new centroids placed in output map"), new_centr);
+ G_message(_n("%d new centroid placed in output map",
+ "%d new centroids placed in output map",
+ new_centr), new_centr);
break;
@@ -774,7 +778,9 @@
for(i = 1; i < nfields; i++)
G_important_message(_("Categories copied from layer %d to layer %d"),
fields[0], fields[i]);
- G_done_msg(_("%d features modified."), nmodified);
+ G_done_msg(_n("%d feature modified.",
+ "%d features modified.",
+ nmodified), nmodified);
Vect_close(&In);
exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.edit/main.c
--- grass/trunk/vector/v.edit/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.edit/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -268,7 +268,9 @@
int iline;
struct ilist *List_added;
- G_message(_("%d features added"), ret);
+ G_message(_n("%d feature added",
+ "%d features added",
+ ret), ret);
List_added = Vect_new_list();
for (iline = num_lines + 1; iline <= Vect_get_num_lines(&Map); iline++)
@@ -286,14 +288,18 @@
int nclosed;
nclosed = close_lines(&Map, GV_BOUNDARY, thresh[THRESH_SNAP]);
- G_message(_("%d boundaries closed"), nclosed);
+ G_message(_n("%d boundary closed",
+ "%d boundaries closed",
+ nclosed), nclosed);
Vect_destroy_list(List_added);
break;
case MODE_DEL:
ret = Vedit_delete_lines(&Map, List);
- G_message(_("%d features deleted"), ret);
+ G_message(_n("%d feature deleted",
+ "%d features deleted",
+ ret), ret);
break;
case MODE_MOVE:
move_x = atof(params.move->answers[0]);
@@ -302,7 +308,9 @@
G_verbose_message(_("Threshold value for snapping is %.2f"),
ret = Vedit_move_lines(&Map, BgMap, nbgmaps, List, move_x, move_y, move_z, snap, thresh[THRESH_SNAP]);
- G_message(_("%d features moved"), ret);
+ G_message(_n("%d feature moved",
+ "%d features moved",
+ ret), ret);
break;
case MODE_VERTEX_MOVE:
@@ -311,15 +319,21 @@
ret = Vedit_move_vertex(&Map, BgMap, nbgmaps, List, coord, thresh[THRESH_COORDS], thresh[THRESH_SNAP], move_x, move_y, move_z, move_first, snap);
- G_message(_("%d vertices moved"), ret);
+ G_message(_n("%d vertex moved",
+ "%d vertices moved",
+ ret), ret);
break;
case MODE_VERTEX_ADD:
ret = Vedit_add_vertex(&Map, List, coord, thresh[THRESH_COORDS]);
- G_message(_("%d vertices added"), ret);
+ G_message(_n("%d vertex added",
+ "%d vertices added",
+ ret), ret);
break;
case MODE_VERTEX_DELETE:
ret = Vedit_remove_vertex(&Map, List, coord, thresh[THRESH_COORDS]);
- G_message(_("%d vertices removed"), ret);
+ G_message(_n("%d vertex removed",
+ "%d vertices removed",
+ ret), ret);
break;
case MODE_BREAK:
if (params.coord->answer) {
@@ -329,28 +343,38 @@
else {
ret = Vect_break_lines_list(&Map, List, NULL, GV_LINES, NULL);
- G_message(_("%d lines broken"), ret);
+ G_message(_n("%d line broken",
+ "%d lines broken",
+ ret), ret);
break;
case MODE_CONNECT:
ret = Vedit_connect_lines(&Map, List, thresh[THRESH_SNAP]);
- G_message(_("%d lines connected"), ret);
+ G_message(_n("%d line connected",
+ "%d lines connected",
+ ret), ret);
break;
case MODE_MERGE:
ret = Vedit_merge_lines(&Map, List);
- G_message(_("%d lines merged"), ret);
+ G_message(_n("%d line merged",
+ "%d lines merged",
+ ret), ret);
break;
case MODE_SELECT:
ret = print_selected(List);
break;
case MODE_CATADD:
ret = Vedit_modify_cats(&Map, List, layer, 0, Clist);
- G_message(_("%d features modified"), ret);
+ G_message(_n("%d feature modified",
+ "%d features modified",
+ ret), ret);
break;
case MODE_CATDEL:
ret = Vedit_modify_cats(&Map, List, layer, 1, Clist);
+ ret), ret);
break;
case MODE_COPY:
if (BgMap && BgMap[0]) {
@@ -365,7 +389,9 @@
else {
ret = Vedit_copy_lines(&Map, NULL, List);
- G_message(_("%d features copied"), ret);
+ G_message(_n("%d feature copied",
+ "%d features copied",
+ ret), ret);
break;
case MODE_SNAP:
@@ -374,7 +400,9 @@
break;
case MODE_FLIP:
ret = Vedit_flip_lines(&Map, List);
- G_message(_("%d lines flipped"), ret);
+ G_message(_n("%d line flipped",
+ "%d lines flipped",
+ ret), ret);
break;
case MODE_NONE:
break;
@@ -393,14 +421,18 @@
ret = Vedit_bulk_labeling(&Map, List,
x1, y1, x2, y2, start, step);
- G_message(_("%d lines labeled"), ret);
+ G_message(_n("%d line labeled",
+ "%d lines labeled",
+ ret), ret);
break;
case MODE_CHTYPE:
ret = Vedit_chtype_lines(&Map, List);
if (ret > 0) {
- G_message(_("%d features converted"), ret);
+ G_message(_n("%d feature converted",
+ "%d features converted",
+ ret), ret);
else {
G_message(_("No feature modified"));
@@ -417,7 +449,9 @@
ret += Vedit_delete_area_centroid(&Map, List->value[i]);
- G_message(_("%d areas removed"), ret);
+ G_message(_n("%d area removed",
+ "%d areas removed",
+ ret), ret);
break;
default:
Modified: grass/trunk/vector/v.edit/select.c
--- grass/trunk/vector/v.edit/select.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.edit/select.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -173,7 +173,10 @@
reverse_selection(Map, type, &List);
- G_message(_("%d of %d features selected from vector map <%s>"),
+ G_message(_n("%d of %d feature selected from vector map <%s>",
+ "%d of %d features selected from vector map <%s>",
+ Vect_get_num_lines(Map)
List->n_values,
Vect_get_num_lines(Map), Vect_get_full_name(Map));
Modified: grass/trunk/vector/v.external/list.c
--- grass/trunk/vector/v.external/list.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.external/list.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -176,7 +176,9 @@
ntables = PQntuples(res);
G_debug(3, " nrows = %d", ntables);
if (fd)
- G_message(_("PostGIS database <%s> contains %d feature table(s):"),
+ G_message(_n("PostGIS database <%s> contains %d feature table:",
+ "PostGIS database <%s> contains %d feature tables:",
+ ntables),
PQdb(conn), ntables);
/* report also schemas */
@@ -261,7 +263,9 @@
nlayers = OGR_DS_GetLayerCount(Ogr_ds);
if (fd)
- G_message(_("Data source <%s> (format '%s') contains %d layers:"),
+ G_message(_n("Data source <%s> (format '%s') contains %d layer:",
+ "Data source <%s> (format '%s') contains %d layers:",
+ nlayers),
dsn, OGR_Dr_GetName(OGR_DS_GetDriver(Ogr_ds)), nlayers);
Modified: grass/trunk/vector/v.extract/main.c
--- grass/trunk/vector/v.extract/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.extract/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -263,7 +263,9 @@
if (ncats == -1)
G_fatal_error(_("Unable select records from table <%s>"),
Fi->table);
- G_verbose_message(_("%d categories loaded"), ncats);
+ G_verbose_message(_n("%d category loaded",
+ "%d categories loaded",
+ ncats), ncats);
db_close_database(driver);
db_shutdown_driver(driver);
Modified: grass/trunk/vector/v.in.ascii/points.c
--- grass/trunk/vector/v.in.ascii/points.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.in.ascii/points.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -262,7 +262,9 @@
G_free(tmp_token);
if (region_flag)
- G_message(_("Skipping %d of %d rows falling outside of current region"),
+ G_message(_n("Skipping %d of %d row falling outside of current region",
+ "Skipping %d of %d rows falling outside of current region",
+ row - 1),
skipped, row - 1);
return 0;
Modified: grass/trunk/vector/v.in.db/main.c
--- grass/trunk/vector/v.in.db/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.in.db/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -301,7 +301,9 @@
Vect_build(&Map);
Vect_close(&Map);
- G_done_msg(_("%d points written to vector map."), count);
+ G_done_msg(_n("%d point written to vector map.",
+ "%d points written to vector map.",
+ count), count);
return (EXIT_SUCCESS);
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.kernel/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -91,6 +91,7 @@
CELL *mask = NULL;
DCELL *output_cell = NULL;
double sigma, dmax, segmax, netmax, multip;
+ char *tmpstr1, *tmpstr2;
double **coordinate;
double sigmaOptimal;
@@ -295,8 +296,13 @@
G_get_window(&window);
G_verbose_message(_("Standard deviation: %f"), sigma);
- G_verbose_message(_("Output raster map: res: %f\trows: %d\tcols: %d"),
- window.ew_res, window.rows, window.cols);
+ G_asprintf(&tmpstr1, _n("%d row", "%d rows", window.rows), window.rows);
+ G_asprintf(&tmpstr2, _n("%d column", "%d columns", window.cols), window.cols);
+ /* GTC First argument is resolution, second - number of rows as a text, third - number of columns as a text. */
+ G_verbose_message(_("Output raster map: resolution: %f\t%s\t%s"),
+ window.ew_res, tmpstr1, tmpstr2);
+ G_free(tmpstr1);
+ G_free(tmpstr2);
/* Open input vector */
Vect_set_open_level(2);
@@ -334,7 +340,9 @@
if (notreachable > 0)
- G_warning(_("%d points outside threshold"), notreachable);
+ G_warning(_n("%d point outside threshold",
+ "%d points outside threshold",
+ notreachable), notreachable);
else {
/* check and open the name of output map */
@@ -377,7 +385,9 @@
G_message(_("Number of input points: %d."), npoints);
- G_message(_("%d distances read from the map."), ndists);
+ G_message(_n("%d distance read from the map.",
+ "%d distances read from the map.",
+ ndists), ndists);
if (ndists == 0)
G_fatal_error(_("Distances between all points are beyond %e (4 * "
Modified: grass/trunk/vector/v.lidar.correction/main.c
--- grass/trunk/vector/v.lidar.correction/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.lidar.correction/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -271,8 +271,12 @@
P_get_edge(P_BILINEAR, &dims, stepE, stepN);
P_set_dim(&dims, stepE, stepN, &nsplx_adj, &nsply_adj);
- G_verbose_message(_("adjusted EW splines %d"), nsplx_adj);
- G_verbose_message(_("adjusted NS splines %d"), nsply_adj);
+ G_verbose_message(_n("adjusted EW spline %d",
+ "adjusted EW splines %d",
+ nsplx_adj), nsplx_adj);
+ G_verbose_message(_n("adjusted NS spline %d",
+ "adjusted NS splines %d",
+ nsply_adj), nsply_adj);
/* calculate number of subregions */
edgeE = dims.ew_size - dims.overlap - 2 * dims.edge_v;
Modified: grass/trunk/vector/v.lrs/v.lrs.segment/main.c
--- grass/trunk/vector/v.lrs/v.lrs.segment/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.lrs/v.lrs.segment/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -63,6 +63,7 @@
dbDriver *rsdriver;
dbHandle rshandle;
dbString rsstmt;
+ char *tmpstr1;
G_gisinit(argv[0]);
@@ -349,12 +350,30 @@
if (file_opt->answer)
fclose(in_file);
- G_message(_("[%d] points read from input"), points_read);
- G_message(_("[%d] points written to output map (%d lost)"),
- points_written, points_read - points_written);
- G_message(_("[%d] lines read from input"), lines_read);
- G_message(_("[%d] lines written to output map (%d lost)"),
- lines_written, lines_read - lines_written);
+ G_message(_n("[%d] point read from input",
+ "[%d] points read from input",
+ points_read), points_read);
+ G_asprintf(&tmpstr1, _n("%d lost", "%d lost",
+ points_read - points_written),
+ points_read - points_written);
+ /* GTC %s will be replaced with a message about lost points. */
+ G_message(_n("[%d] point written to output map (%s)",
+ "[%d] points written to output map (%s)",
+ points_written),
+ points_written, tmpstr1);
+ G_free(tmpstr1);
+ G_message(_n("[%d] line read from input",
+ "[%d] lines read from input",
+ lines_read), lines_read);
+ lines_read - lines_written),
+ lines_read - lines_written);
+ /* GTC %s will be replaced with a message about lost lines. */
+ G_message(_n("[%d] line written to output map (%s)",
+ "[%d] lines written to output map (%s)",
+ lines_written),
+ lines_written, tmpstr1);
+ G_free(tmpstr1);
exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.lrs/v.lrs.where/main.c
--- grass/trunk/vector/v.lrs/v.lrs.where/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.lrs/v.lrs.where/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -217,14 +217,24 @@
Vect_close(&LMap);
Vect_close(&PMap);
- G_message(_("[%d] points read from input"), n_points);
- G_message(_("[%d] positions found"), n_found);
+ n_points), n_points);
+ G_message(_n("[%d] position found",
+ "[%d] positions found",
+ n_found), n_found);
if (n_outside)
- G_message(_("[%d] points outside threshold"), n_outside);
+ G_message(_n("[%d] point outside threshold",
+ "[%d] points outside threshold",
+ n_outside), n_outside);
if (n_no_record)
- G_message(_("[%d] points - no record found"), n_no_record);
+ G_message(_n("[%d] point - no record found",
+ "[%d] points - no record found",
+ n_no_record), n_no_record);
if (n_many_records)
- G_message(_("[%d] points - too many records found"), n_many_records);
+ G_message(_n("[%d] point - too many records found",
+ "[%d] points - too many records found",
+ n_many_records), n_many_records);
exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.net.distance/main.c
--- grass/trunk/vector/v.net.distance/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.net.distance/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -351,7 +351,9 @@
G_free(prev);
if (from_nr)
- G_warning(_("%d 'from' features were not reachable"), from_nr);
+ G_warning(_n("%d 'from' feature was not reachable",
+ "%d 'from' features were not reachable",
+ from_nr), from_nr);
exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.out.ascii/main.c
--- grass/trunk/vector/v.out.ascii/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.out.ascii/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -104,7 +104,10 @@
G_fatal_error(_("Layer <%s> not found"), field_name);
ret = Vect_str_to_cat_list(cats, clist);
if (ret > 0)
- G_fatal_error(_("%d errors in <%s> option"), ret, "cats");
+ G_fatal_error(_n("%d error in <%s> option",
+ "%d errors in <%s> option",
+ ret),
+ ret, "cats");
if (strcmp(output, "-") != 0) {
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.out.ogr/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -288,39 +288,62 @@
/* check what users wants to export and what's present in the map */
if (Vect_get_num_primitives(&In, GV_POINT) > 0 && !(otype & GV_POINTS))
- G_warning(_("%d point(s) found, but not requested to be exported. "
- "Verify 'type' parameter."), Vect_get_num_primitives(&In,
- GV_POINT));
+ G_warning(_n("%d point found, but not requested to be exported. "
+ "Verify 'type' parameter.",
+ "%d points found, but not requested to be exported. "
+ Vect_get_num_primitives(&In, GV_POINT)),
+ Vect_get_num_primitives(&In, GV_POINT));
if (Vect_get_num_primitives(&In, GV_LINE) > 0 && !(otype & GV_LINES))
- G_warning(_("%d line(s) found, but not requested to be exported. "
- GV_LINE));
+ G_warning(_n("%d line found, but not requested to be exported. "
+ "%d line(s) found, but not requested to be exported. "
+ Vect_get_num_primitives(&In, GV_LINE)),
+ Vect_get_num_primitives(&In, GV_LINE));
if (Vect_get_num_primitives(&In, GV_BOUNDARY) > 0 &&
!(otype & GV_BOUNDARY) && !(otype & GV_AREA))
- G_warning(_("%d boundary(ies) found, but not requested to be exported. "
- GV_BOUNDARY));
+ G_warning(_n("%d boundary found, but not requested to be exported. "
+ "%d boundaries found, but not requested to be exported. "
+ Vect_get_num_primitives(&In, GV_BOUNDARY)),
+ Vect_get_num_primitives(&In, GV_BOUNDARY));
if (Vect_get_num_primitives(&In, GV_CENTROID) > 0 &&
!(otype & GV_CENTROID) && !(otype & GV_AREA))
- G_warning(_("%d centroid(s) found, but not requested to be exported. "
- GV_CENTROID));
+ G_warning(_n("%d centroid found, but not requested to be exported. "
+ "%d centroids found, but not requested to be exported. "
+ Vect_get_num_primitives(&In, GV_CENTROID)),
+ Vect_get_num_primitives(&In, GV_CENTROID));
if (Vect_get_num_areas(&In) > 0 && !(otype & GV_AREA))
- G_warning(_("%d area(s) found, but not requested to be exported. "
- "Verify 'type' parameter."), Vect_get_num_areas(&In));
+ G_warning(_n("%d area found, but not requested to be exported. "
+ "%d areas found, but not requested to be exported. "
+ Vect_get_num_areas(&In)),
+ Vect_get_num_areas(&In));
if (Vect_get_num_primitives(&In, GV_FACE) > 0 && !(otype & GV_FACE))
- G_warning(_("%d face(s) found, but not requested to be exported. "
- GV_FACE));
+ G_warning(_n("%d face found, but not requested to be exported. "
+ "%d faces found, but not requested to be exported. "
+ Vect_get_num_primitives(&In, GV_FACE)),
+ Vect_get_num_primitives(&In, GV_FACE));
if (Vect_get_num_volumes(&In) > 0 && !(otype & GV_VOLUME))
- G_warning(_("%d volume(s) found, but not requested to be exported. "
- "Verify 'type' parameter."), Vect_get_num_volumes(&In));
+ G_warning(_n("%d volume found, but not requested to be exported. "
+ "%d volumes found, but not requested to be exported. "
+ Vect_get_num_volumes(&In)),
+ Vect_get_num_volumes(&In));
/* warn and eventually abort if there is nothing to be exported */
num_to_export = 0;
@@ -665,7 +688,10 @@
/* Lines (run always to count features of different type) */
if (otype & (GV_POINTS | GV_LINES | GV_KERNEL | GV_FACE)) {
- G_message(_("Exporting %d features..."), Vect_get_num_primitives(&In, otype));
+ G_message(_n("Exporting %d feature...",
+ "Exporting %d features...",
+ Vect_get_num_primitives(&In, otype)),
+ Vect_get_num_primitives(&In, otype));
n_feat += export_lines(&In, field, otype, flags.multi->answer ? TRUE : FALSE,
donocat, ftype == GV_BOUNDARY ? TRUE : FALSE,
@@ -677,7 +703,9 @@
/* Areas (run always to count features of different type) */
if (Vect_get_num_areas(&In) > 0 && (otype & GV_AREA)) {
- G_message(_("Exporting %d areas (may take some time)..."),
+ G_message(_n("Exporting %d area (may take some time)...",
+ "Exporting %d areas (may take some time)...",
n_feat += export_areas(&In, field, flags.multi->answer ? TRUE : FALSE, donocat,
@@ -694,7 +722,10 @@
which output format would know the difference?
if (Vect_get_num_volumes(&In) > 0 && (otype & GV_VOLUME)) {
- G_message(_("Exporting %d volumes..."), Vect_get_num_volumes(&In));
+ G_message(_n("Exporting %d volume...",
+ "Exporting %d volumes...",
G_warning(_("Export of volumes not implemented yet. Skipping."));
@@ -712,13 +743,20 @@
/* Summary */
if (n_nocat > 0)
- G_important_message(_("%d features without category were written"), n_nocat);
+ G_important_message(_n("%d feature without category was written",
+ "%d features without category were written",
+ n_nocat), n_nocat);
if (n_noatt > 0)
- G_important_message(_("%d features without attributes were written"), n_noatt);
+ G_important_message(_n("%d feature without attributes was written",
+ "%d features without attributes were written",
+ n_noatt), n_noatt);
if (n_nocatskip > 0)
- G_warning(_("%d features without category were skipped. "
- "Features without category are written only when -%c flag is given."),
+ G_warning(_n("%d feature without category was skipped. "
+ "Features without category are written only when -%c flag is given.",
+ "%d features without category were skipped. "
+ n_nocatskip),
n_nocatskip, flags.cat->key);
/* Enable this? May be confusing that for area type are not
@@ -731,7 +769,9 @@
if (n_feat < 1)
G_warning(_("Output layer is empty, no features written"));
- G_done_msg(_("%d features (%s type) written to <%s> (%s format)."), n_feat,
+ G_done_msg(_n("%d feature (%s type) written to <%s> (%s format).",
+ "%d features (%s type) written to <%s> (%s format).",
+ n_feat), n_feat,
OGRGeometryTypeToName(wkbtype),
options.layer->answer, options.format->answer);
Modified: grass/trunk/vector/v.out.postgis/main.c
--- grass/trunk/vector/v.out.postgis/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.out.postgis/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -164,11 +164,15 @@
Vect_get_name(&Out));
if (!flags.topo->answer)
- G_done_msg(_("%d features (%s type) written to <%s>."),
+ G_done_msg(_n("%d feature (%s type) written to <%s>.",
+ "%d features (%s type) written to <%s>.",
+ Vect_sfa_get_num_features(&Out)),
Vect_sfa_get_num_features(&Out), Vect_get_finfo_geometry_type(&Out),
else
- G_done_msg(_("%d primitives written to <%s>."),
+ G_done_msg(_n("%d primitive written to <%s>.",
+ "%d primitives written to <%s>.",
+ Vect_get_num_lines(&Out)),
Vect_get_num_lines(&Out),
Modified: grass/trunk/vector/v.out.pov/main.c
--- grass/trunk/vector/v.out.pov/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.out.pov/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -214,7 +214,9 @@
Vect_close(&In);
/* Summary */
- G_done_msg(_("%d features written."), count);
+ G_done_msg(_n("%d feature written.",
+ "%d features written.",
+ count), count);
exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.overlay/area_area.c
--- grass/trunk/vector/v.overlay/area_area.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.overlay/area_area.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -96,7 +96,9 @@
Vect_destroy_boxlist(boxlist);
Vect_destroy_list(reflist);
- G_verbose_message(_("%d boundaries snapped"), snapped_lines);
+ G_verbose_message(_n("%d boundary snapped",
+ "%d boundaries snapped",
+ snapped_lines), snapped_lines);
/* same procedure like for v.in.ogr:
Modified: grass/trunk/vector/v.sample/main.c
--- grass/trunk/vector/v.sample/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.sample/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -147,7 +147,9 @@
if (nrecords < 0)
G_fatal_error(_("Unable to select data from table"));
- G_verbose_message(_("%d records selected from table"), nrecords);
+ G_verbose_message(_n("%d record selected from table",
+ "%d records selected from table",
+ nrecords), nrecords);
db_close_database_shutdown_driver(Driver);
Modified: grass/trunk/vector/v.segment/main.c
--- grass/trunk/vector/v.segment/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.segment/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -52,6 +52,7 @@
struct Map_info In, Out;
struct line_cats *LCats, *SCats;
struct line_pnts *LPoints, *SPoints, *PlPoints;
+ char *tmpstr1;
G_gisinit(argv[0]);
@@ -248,13 +249,29 @@
Vect_build(&Out);
- G_message(_("%d points read from input"), points_read);
- G_message(_("%d points written to output map (%d lost)"),
- G_message(_("%d lines read from input"), lines_read);
- G_message(_("%d lines written to output map (%d lost)"),
+ G_message(_n("%d point read from input",
+ "%d points read from input",
+ /* GTC Number of lost points */
+ G_asprintf(&tmpstr1, _n("%d lost", "%d lost", points_read - points_written), points_read - points_written);
+ /* GTC %s is replaced with message indicating number of lost points. */
+ G_message(_n("%d point written to output map (%s)",
+ "%d points written to output map (%s)",
+ points_written),
+ G_free(tmpstr1);
+ G_message(_n("%d line read from input",
+ "%d lines read from input",
+ /* GTC Number of lost lines */
+ G_asprintf(&tmpstr1, _n("%d lost", "%d lost", lines_read - lines_written), lines_read - lines_written);
+ /* GTC %s is replaced with message indicating number of lost lines. */
+ G_message(_n("%d line written to output map (%s)",
+ "%d lines written to output map (%s)",
+ lines_written),
+ G_free(tmpstr1);
/* Free, close ... */
Vect_close(&In);
Vect_close(&Out);
Modified: grass/trunk/vector/v.surf.idw/main.c
--- grass/trunk/vector/v.surf.idw/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.surf.idw/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -79,6 +79,7 @@
struct cell_list **search_list = NULL, **search_list_start = NULL;
int max_radius, radius;
int searchallpoints = 0;
G_gisinit(argv[0]);
@@ -254,8 +255,15 @@
fd = Rast_open_new(parm.output->answer, DCELL_TYPE);
- G_important_message(_("Interpolating raster map <%s> (%d rows, %d cols)... "),
- parm.output->answer, window.rows, window.cols);
+ /* GTC Count of window rows */
+ /* GTC Count of window columns */
+ /* GTC First argument is map name, second - message about number of rows, third - columns. */
+ G_important_message(_("Interpolating raster map <%s> (%s, %s)..."),
+ parm.output->answer, tmpstr1, tmpstr2);
+ G_free(tmpstr1);
+ G_free(tmpstr2);
north = window.north + window.ns_res / 2.0;
for (row = 0; row < window.rows; row++) {
Modified: grass/trunk/vector/v.surf.idw/read_sites.c
--- grass/trunk/vector/v.surf.idw/read_sites.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.surf.idw/read_sites.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -65,7 +65,7 @@
if (nrec < 0)
- G_verbose_message(_("%d records selected from table"), nrec);
+ G_verbose_message(_n("One record selected from table", "%d records selected from table", nrec), nrec);
@@ -118,5 +118,5 @@
Vect_set_release_support(&Map);
Vect_close(&Map);
- G_message(_("%ld points loaded"), npoints);
+ G_message(_n("%ld point loaded", "%ld points loaded", npoints), npoints);
Modified: grass/trunk/vector/v.voronoi/main.c
--- grass/trunk/vector/v.voronoi/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.voronoi/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -220,7 +220,9 @@
plot = 0;
debug = 0;
- G_message(_("Voronoi triangulation for %d points..."), nsites);
+ G_message(_n("Voronoi triangulation for %d point...",
+ "Voronoi triangulation for %d points...",
+ nsites), nsites);
voronoi(nextone);
G_message(_("Writing edges..."));
vo_write();
Modified: grass/trunk/vector/v.voronoi/sw_main.c
--- grass/trunk/vector/v.voronoi/sw_main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.voronoi/sw_main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -185,7 +185,9 @@
if (nsites < 2) {
const char *name = Vect_get_full_name(&In);
Vect_close(&In);
- G_fatal_error(_("Found %d points/centroids in <%s>, but at least 2 are needed"),
+ G_fatal_error(_n("Found %d point/centroid in <%s>, but at least 2 are needed",
+ "Found %d points/centroids in <%s>, but at least 2 are needed",
+ nsites),
nsites, name);
@@ -463,7 +465,9 @@
if (nsites < 2) {
Vect_close(&In);
- G_fatal_error(_("Found %d vertices in <%s>, but at least 2 are needed"),
+ G_fatal_error(_n("Found %d vertex in <%s>, but at least 2 are needed",
+ "Found %d vertices in <%s>, but at least 2 are needed",
+ nsites),
nsites, name);
Modified: grass/trunk/vector/v.what.rast3/main.c
--- grass/trunk/vector/v.what.rast3/main.c 2014-04-13 16:37:24 UTC (rev 59711)
+++ grass/trunk/vector/v.what.rast3/main.c 2014-04-13 18:08:19 UTC (rev 59712)
@@ -209,11 +209,14 @@
/* Report number of points not used */
if (outside_cnt)
- G_warning(_("%d points outside current region were skipped"),
- outside_cnt);
+ G_warning(_n("%d point outside current region was skipped",
+ "%d points outside current region were skipped",
+ outside_cnt), outside_cnt);
if (nocat_cnt)
- G_warning(_("%d points without category were skipped"), nocat_cnt);
+ G_warning(_n("%d point without category was skipped",
+ "%d points without category were skipped",
+ nocat_cnt), nocat_cnt);
/* Extract raster values from file and store in cache */
G_debug(1, "Extracting raster values");
@@ -320,15 +323,27 @@
db_free_string(&stmt);
/* Report */
- G_verbose_message(_("%d categories loaded from table"), select);
- G_verbose_message(_("%d categories loaded from vector"), point_cnt);
- G_verbose_message(_("%d categories from vector missing in table"), norec_cnt);
+ G_verbose_message(_n("%d category loaded from table",
+ "%d categories loaded from table",
+ select), select);
+ G_verbose_message(_n("%d category loaded from vector",
+ "%d categories loaded from vector",
+ point_cnt), point_cnt);
+ G_verbose_message(_n("%d category from vector missing in table",
+ "%d categories from vector missing in table",
+ norec_cnt), norec_cnt);
if (dupl_cnt > 0)
- G_message(_("%d duplicate categories in vector"), dupl_cnt);
+ G_message(_n("%d duplicate category in vector",
+ "%d duplicate categories in vector",
+ dupl_cnt), dupl_cnt);
if (upderr_cnt > 0)
- G_warning(_("%d update errors"), upderr_cnt);
+ G_warning(_n("%d update error",
+ "%d update errors",
+ upderr_cnt), upderr_cnt);
- G_done_msg(_("%d records updated."), update_cnt);
+ G_done_msg(_n("%d record updated.",
+ "%d records updated.",
+ update_cnt), update_cnt);
exit(EXIT_SUCCESS);
