[GRASS-SVN] r59714 - in grass/branches/releasebranch_7_0: general/g.mapset general/g.region lib/db/dbmi_client lib/ogsf lib/proj lib/symbol raster/r.out.ppm raster/r.to.vect vector/v.surf.rst vector/v.to.3d
svn_grass at osgeo.org
Sun Apr 13 11:57:15 PDT 2014
Author: neteler
Date: 2014-04-13 11:57:15 -0700 (Sun, 13 Apr 2014)
New Revision: 59714
grass/branches/releasebranch_7_0/general/g.mapset/main.c
grass/branches/releasebranch_7_0/general/g.region/main.c
grass/branches/releasebranch_7_0/lib/db/dbmi_client/delete_tab.c
grass/branches/releasebranch_7_0/lib/ogsf/gvl_calc.c
grass/branches/releasebranch_7_0/lib/proj/get_proj.c
grass/branches/releasebranch_7_0/lib/symbol/read.c
grass/branches/releasebranch_7_0/raster/r.out.ppm/main.c
grass/branches/releasebranch_7_0/raster/r.to.vect/areas_io.c
grass/branches/releasebranch_7_0/vector/v.surf.rst/main.c
grass/branches/releasebranch_7_0/vector/v.to.3d/trans3.c
fix compiler warnings (contributed by Volker Froehlich)
Modified: grass/branches/releasebranch_7_0/general/g.mapset/main.c
--- grass/branches/releasebranch_7_0/general/g.mapset/main.c 2014-04-13 18:15:26 UTC (rev 59713)
+++ grass/branches/releasebranch_7_0/general/g.mapset/main.c 2014-04-13 18:57:15 UTC (rev 59714)
@@ -181,7 +181,7 @@
G_asprintf(&lock_prog, "%s/etc/lock", G_gisbase());
sprintf(path, "%s/.gislock", mapset_new_path);
- G_debug(2, path);
+ G_debug(2, "%s", path);
ret = G_spawn(lock_prog, lock_prog, path, gis_lock, NULL);
G_debug(2, "lock result = %d", ret);
Modified: grass/branches/releasebranch_7_0/general/g.region/main.c
--- grass/branches/releasebranch_7_0/general/g.region/main.c 2014-04-13 18:15:26 UTC (rev 59713)
+++ grass/branches/releasebranch_7_0/general/g.region/main.c 2014-04-13 18:57:15 UTC (rev 59714)
@@ -512,7 +512,7 @@
Vect_set_open_level(2);
if (2 > Vect_open_old(&Map, vect_name, mapset))
G_fatal_error(_("Unable to open vector map <%s> on topological level"),
- vect_name, mapset);
+ vect_name);
Vect_get_map_box(&Map, &box);
map_window = window;
Modified: grass/branches/releasebranch_7_0/lib/db/dbmi_client/delete_tab.c
--- grass/branches/releasebranch_7_0/lib/db/dbmi_client/delete_tab.c 2014-04-13 18:15:26 UTC (rev 59713)
+++ grass/branches/releasebranch_7_0/lib/db/dbmi_client/delete_tab.c 2014-04-13 18:57:15 UTC (rev 59714)
@@ -47,7 +47,7 @@
db_init_string(&sql);
db_set_string(&sql, "drop table ");
db_append_string(&sql, tblname);
- G_debug(3, db_get_string(&sql));
+ G_debug(3, "%s", db_get_string(&sql));
if (db_execute_immediate(driver, &sql) != DB_OK) {
G_warning(_("Unable to drop table: '%s'"),
Modified: grass/branches/releasebranch_7_0/lib/ogsf/gvl_calc.c
--- grass/branches/releasebranch_7_0/lib/ogsf/gvl_calc.c 2014-04-13 18:15:26 UTC (rev 59713)
+++ grass/branches/releasebranch_7_0/lib/ogsf/gvl_calc.c 2014-04-13 18:57:15 UTC (rev 59714)
@@ -746,7 +746,7 @@
G_debug(3,
- "gvl_write_char(): reallocate memory for pos : %d to : %d B",
+ "gvl_write_char(): reallocate memory for pos : %d to : %lu B",
pos, sizeof(char) * ((pos / BUFFER_SIZE) + 1) * BUFFER_SIZE);
Modified: grass/branches/releasebranch_7_0/lib/proj/get_proj.c
--- grass/branches/releasebranch_7_0/lib/proj/get_proj.c 2014-04-13 18:15:26 UTC (rev 59713)
+++ grass/branches/releasebranch_7_0/lib/proj/get_proj.c 2014-04-13 18:57:15 UTC (rev 59714)
@@ -232,7 +232,7 @@
sprintf(err, " +%s", opt_in[i]);
strcat(buffa, err);
- G_warning(buffa);
+ G_warning("%s", buffa);
G_warning(_("The error message: %s"), pj_strerrno(pj_errno));
return -1;
Modified: grass/branches/releasebranch_7_0/lib/symbol/read.c
--- grass/branches/releasebranch_7_0/lib/symbol/read.c 2014-04-13 18:15:26 UTC (rev 59713)
+++ grass/branches/releasebranch_7_0/lib/symbol/read.c 2014-04-13 18:57:15 UTC (rev 59714)
@@ -221,7 +221,7 @@
fclose(fp);
G_free(s); /* TODO: free all */
- G_warning(msg);
+ G_warning("%s", msg);
return NULL;
Modified: grass/branches/releasebranch_7_0/raster/r.out.ppm/main.c
--- grass/branches/releasebranch_7_0/raster/r.out.ppm/main.c 2014-04-13 18:15:26 UTC (rev 59713)
+++ grass/branches/releasebranch_7_0/raster/r.out.ppm/main.c 2014-04-13 18:57:15 UTC (rev 59714)
@@ -225,7 +225,7 @@
fclose(fp);
if (do_stdout)
- G_done_msg("");
+ G_done_msg("%s", "");
else
G_done_msg(_("File <%s> created"), ofile);
Modified: grass/branches/releasebranch_7_0/raster/r.to.vect/areas_io.c
--- grass/branches/releasebranch_7_0/raster/r.to.vect/areas_io.c 2014-04-13 18:15:26 UTC (rev 59713)
+++ grass/branches/releasebranch_7_0/raster/r.to.vect/areas_io.c 2014-04-13 18:57:15 UTC (rev 59714)
@@ -371,7 +371,7 @@
db_append_string(&sql, ")");
G_fatal_error(_("Cannot insert new row: %s"),
Modified: grass/branches/releasebranch_7_0/vector/v.surf.rst/main.c
--- grass/branches/releasebranch_7_0/vector/v.surf.rst/main.c 2014-04-13 18:15:26 UTC (rev 59713)
+++ grass/branches/releasebranch_7_0/vector/v.surf.rst/main.c 2014-04-13 18:57:15 UTC (rev 59714)
@@ -818,12 +818,12 @@
*tmpname = tmp = G_tempfile();
fp = fopen(tmp, "w+");
if (!fp)
- G_fatal_error(_("Unable to open temporary file <%s>"), tmpname);
+ G_fatal_error(_("Unable to open temporary file <%s>"), *tmpname);
for (i = 0; i < n_rows; i++) {
if (fwrite(zero_array_cell, sizeof(FCELL), n_cols, fp) != n_cols) {
clean();
- G_fatal_error(_("Error writing temporary file <%s>"), tmpname);
+ G_fatal_error(_("Error writing temporary file <%s>"), *tmpname);
Modified: grass/branches/releasebranch_7_0/vector/v.to.3d/trans3.c
--- grass/branches/releasebranch_7_0/vector/v.to.3d/trans3.c 2014-04-13 18:15:26 UTC (rev 59713)
+++ grass/branches/releasebranch_7_0/vector/v.to.3d/trans3.c 2014-04-13 18:57:15 UTC (rev 59714)
@@ -102,7 +102,7 @@
else if (Cats->n_cats > 1) {
G_warning(_("Feature id %d has more categories. "
- "Using category %d."), line, field, cat);
+ "Using category %d."), line, cat);
if (zcolumn && ltype == GV_POINT && cat > -1) {
