[GRASS-SVN] r59771 - grass/branches/releasebranch_6_4/lib/vector/Vlib
svn_grass at osgeo.org
Thu Apr 17 11:17:24 PDT 2014
Author: mmetz
Date: 2014-04-17 11:17:23 -0700 (Thu, 17 Apr 2014)
New Revision: 59771
grass/branches/releasebranch_6_4/lib/vector/Vlib/poly.c
Vlib: fix linkm usage
Modified: grass/branches/releasebranch_6_4/lib/vector/Vlib/poly.c
--- grass/branches/releasebranch_6_4/lib/vector/Vlib/poly.c 2014-04-17 18:17:08 UTC (rev 59770)
+++ grass/branches/releasebranch_6_4/lib/vector/Vlib/poly.c 2014-04-17 18:17:23 UTC (rev 59771)
@@ -36,7 +36,7 @@
static int comp_double(double *, double *);
static int V__within(double, double, double);
int Vect__intersect_line_with_poly();
-static void destroy_links(struct Slink *);
+static void destroy_links(struct link_head *, struct Slink *);
static int Vect__divide_and_conquer(struct Slink *, struct line_pnts *,
struct link_head *, double *, double *,
int);
@@ -228,7 +228,7 @@
*Y = cent_y; /* pick line segment (x_min, cent_y) - (x_max, cent_y) */
ret = Vect__divide_and_conquer(Head, Points, Token, X, Y, 10);
- destroy_links(Head);
+ destroy_links(Token, Head);
if (ret < 0) {
G_warning("Vect_get_point_in_poly(): %s",
@@ -303,7 +303,7 @@
return Vect__divide_and_conquer(Head, Points, Token, X, Y, --levels);
-static void destroy_links(struct Slink *Head)
+static void destroy_links(struct link_head *Token, struct Slink *Head)
struct Slink *p, *tmp;
@@ -311,7 +311,7 @@
while (p != NULL) {
tmp = p->next;
- link_dispose((struct link_head *)Head, (VOID_T *) p);
+ link_dispose(Token, (VOID_T *) p);
p = tmp;
