[GRASS-SVN] r59780 - grass/trunk/raster/r.li
svn_grass at osgeo.org
Thu Apr 17 14:31:10 PDT 2014
Author: neteler
Date: 2014-04-17 14:31:10 -0700 (Thu, 17 Apr 2014)
New Revision: 59780
Added:
grass/trunk/raster/r.li/r.li.testing_nc_asc.sh
grass/trunk/raster/r.li/r.li.testing_sp_mov.sh
grass/trunk/raster/r.li/TODO
r.li: test scripts added
Modified: grass/trunk/raster/r.li/TODO
--- grass/trunk/raster/r.li/TODO 2014-04-17 21:24:43 UTC (rev 59779)
+++ grass/trunk/raster/r.li/TODO 2014-04-17 21:31:10 UTC (rev 59780)
@@ -1,98 +1,68 @@
TODO list
-GRASS 7
+GRASS 7:
* r.li.daemon: Uses UNIX sockets, replace or figure out how
to use them on Windows
+ --> 4/2014: still an issue?
* r.li.setup: Shell scripts, Tcl/Tk, Xmonitors to be replaced
by Python + wxPython equivalents.
See Luca D's prototype in trunk/gui/wxpython/rlisetup
and http://grass.osgeo.org/grass70/manuals/g.gui.rlisetup.html
-Brute-force testing
-# TODO: change to/add 3x3 example
+# TODO: change the examples to North Carolina wherever possible:
-# 7x7 moving window test:
-# still Spearfish...
-# created as described in EXAMPLES, moving window, in gui/wxgui/rlisetup/g.gui.rlisetup.html:
-echo "SAMPLINGFRAME 0|0|1|1
-SAMPLEAREA -1|-1|0.015021459227467811|0.011058451816745656
-MOVINGWINDOW" > $HOME/.grass7/r.li/movwindow7
-export GRASS_OVERWRITE=1
+# Spearfish tests
g.region rast=landcover.30m -p
r.mapcalc "forests = if(landcover.30m >= 41 && landcover.30m <= 43,1,null())"
-MEASURE="dominance edgedensity mpa mps padcv padrange padsd patchdensity patchnum pielou richness shannon shape simpson"
-for mymeasure in $MEASURE ; do
- r.li.${mymeasure} input=forests conf=movwindow7 out=forests_${mymeasure}_mov7
- r.univar forests_${mymeasure}_mov7
-done
-# also alpha:
-r.li.renyi input=forests conf=movwindow7 out=forests_renyi_mov7_a06 alpha=0.6
-r.univar forests_renyi_mov7_a06
-echo "End of r.li tests"
-GRASS 7: North Carolina tests
-SAMPLEAREA 0.0|0.0|1.0|1.0" > $HOME/.grass7/r.li/landsat_test
-g.region rast=lsat7_2002_40 -p
-r.li.shannon input=lsat7_2002_40 conf=landsat_test out=landsat_shannon
---> Result written to ASCII file <$HOME/.grass7/r.li/output/landsat_shannon>
-GRASS 6
-TODO: backport all GRASS 7 fixes
-A few remaining things should be done soon:
-- add relevant references
-- use English variable names in C code
-Please change the examples to North Carolina wherever possible:
-# Spearfish
-g.region rast=landcover.30m -p
-r.mapcalc "forests = if(landcover.30m >= 41 && landcover.30m <= 43,1,null())"
d.mon wx0
d.rast forests
# g.gui.rlisetup:
-# created as described in EXAMPLES, moving window, in r.li.setup.html:
+# created as described in EXAMPLES, moving window, in g.gui.rlisetup.html:
-MOVINGWINDOW" > $HOME/.r.li/history/movwindow7
+MOVINGWINDOW" > $HOME/.grass7/r.li/movwindow7
-r.li.patchdensity forests conf=movwindow7 out=forests_p_dens7
+r.li.patchdensity forests conf=movwindow7 output=forests_p_dens7
d.rast.leg forests_p_dens7
-r.to.vect forests out=forests feature=area
+r.to.vect forests out=forests type=area
d.vect forests type=boundary
+######## TODO: CHECK THIS:
# MASK test
g.copy rast=fields,MASK
-r.li.patchdensity forests conf=movwindow7 out=forests_p_dens7mask --o
+r.li.patchdensity forests conf=movwindow7 output=forests_p_dens7mask --o
+d.erase
d.rast.leg forests_p_dens7mask
# -> no negative values! but MASK is respected
+# zero data test
+r.mapcalc "forests = 0"
+r.li.patchdensity forests conf=movwindow7 output=forests_p_dens7 --o
+d.erase
+d.rast.leg forests_p_dens7mask
+r.info -r forests_p_dens7
+min=0
+max=204.081632653061
+North Carolina tests
+# Tests with return an ASCII output file
+sh ./r.li.testing_nc_asc.sh
-Add example which results in an ASCII output file
+echo "SAMPLINGFRAME 0|0|1|1
+SAMPLEAREA 0.0|0.0|1.0|1.0" > $HOME/.grass7/r.li/landsat_test
+g.region rast=lsat7_2002_40 -p
+r.li.shannon input=lsat7_2002_40 conf=landsat_test output=landsat_shannon
+--> Result written to ASCII file <$HOME/.grass7/r.li/output/landsat_shannon>
Added: grass/trunk/raster/r.li/r.li.testing_nc_asc.sh
--- grass/trunk/raster/r.li/r.li.testing_nc_asc.sh (rev 0)
+++ grass/trunk/raster/r.li/r.li.testing_nc_asc.sh 2014-04-17 21:31:10 UTC (rev 59780)
@@ -0,0 +1,69 @@
+#!/bin/sh
+# North Carolina tests
+G_RLI=$HOME/.grass7/r.li
+SAMPLEAREA 0.0|0.0|1.0|1.0" > $G7RLI/landcover_whole_whole # GRASS7
+# North Carolina location:
+export GRASS_OVERWRITE=1
+g.region rast=landclass96 -p
+RASTER_MAP=landclass96
+#r.to.vect in=basin_50K output=basin_50K feature=area
+echo "-------------------------"
+r.li.dominance $RASTER_MAP conf=landcover_whole_whole output=forests_dominance_whole
+cat $G_RLI/output/forests_dominance_whole
+r.li.edgedensity $RASTER_MAP conf=landcover_whole_whole output=forests_edgedens_whole
+cat $G_RLI/output/forests_edgedens_whole
+r.li.mpa $RASTER_MAP conf=landcover_whole_whole output=forests_mpa_whole
+cat $G_RLI/output/forests_mpa_whole
+r.li.mps $RASTER_MAP conf=landcover_whole_whole output=forests_mps_whole
+cat $G_RLI/output/forests_mps_whole
+r.li.padcv $RASTER_MAP conf=landcover_whole_whole output=forests_padcv_whole
+cat $G_RLI/output/forests_padcv_whole
+r.li.padrange $RASTER_MAP conf=landcover_whole_whole output=forests_padrange_whole
+cat $G_RLI/output/forests_padrange_whole
+r.li.padsd $RASTER_MAP conf=landcover_whole_whole output=forests_padsd_whole
+cat $G_RLI/output/forests_padsd_whole
+r.li.patchdensity $RASTER_MAP conf=landcover_whole_whole output=forests_p_dens_whole
+cat $G_RLI/output/forests_p_dens_whole
+r.li.patchnum $RASTER_MAP conf=landcover_whole_whole output=forests_patchnum_whole
+cat $G_RLI/output/forests_patchnum_whole
+r.li.pielou $RASTER_MAP conf=landcover_whole_whole output=forests_pielou_whole
+cat $G_RLI/output/forests_pielou_whole
+r.li.renyi $RASTER_MAP conf=landcover_whole_whole output=forests_renyi_whole7_a06 alpha=0.6
+cat $G_RLI/output/forests_renyi_whole7_a06
+r.li.richness $RASTER_MAP conf=landcover_whole_whole output=forests_richness_whole
+cat $G_RLI/output/forests_richness_whole
+r.li.shannon $RASTER_MAP conf=landcover_whole_whole output=forests_shannon_whole
+cat $G_RLI/output/forests_shannon_whole
+echo "====== End of r.li tests ========================"
Property changes on: grass/trunk/raster/r.li/r.li.testing_nc_asc.sh
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
+ text/x-sh
Added: svn:eol-style
+ native
Added: grass/trunk/raster/r.li/r.li.testing_sp_mov.sh
--- grass/trunk/raster/r.li/r.li.testing_sp_mov.sh (rev 0)
+++ grass/trunk/raster/r.li/r.li.testing_sp_mov.sh 2014-04-17 21:31:10 UTC (rev 59780)
@@ -0,0 +1,33 @@
+#!/bin/sh
+#Spearfish tests
+# 7x7 moving window test
+# Brute-force testing in a loop
+# TODO: change to/add 3x3 example
+# created conf file as described in EXAMPLES, moving window,
+# see gui/wxgui/rlisetup/g.gui.rlisetup.html
+SAMPLEAREA -1|-1|0.015021459227467811|0.011058451816745656
+g.region rast=landcover.30m -p
+r.mapcalc "forests = if(landcover.30m >= 41 && landcover.30m <= 43,1,null())"
+MEASURE="dominance edgedensity mpa mps padcv padrange padsd patchdensity patchnum pielou richness shannon shape simpson"
+for mymeasure in $MEASURE ; do
+ echo "====== $mymeasure: ========================"
+ r.li.${mymeasure} forests conf=movwindow7 output=forests_${mymeasure}_mov7
+ r.univar -g forests_${mymeasure}_mov7
+done
+# here also alpha:
+mymeasure=renyi
+echo "====== $mymeasure: ========================"
+r.li.renyi forests conf=movwindow7 output=forests_renyi_mov7_a06 alpha=0.6
+r.univar -g forests_renyi_mov7_a06
Property changes on: grass/trunk/raster/r.li/r.li.testing_sp_mov.sh
+ text/x-sh
+ native
