[GRASS-SVN] r59793 - grass-addons/grass7/imagery/i.feo_tio2
Fri Apr 18 22:21:21 PDT 2014
Author: ychemin
Date: 2014-04-18 22:21:21 -0700 (Fri, 18 Apr 2014)
New Revision: 59793
Added:
   grass-addons/grass7/imagery/i.feo_tio2/clementine_mapplanet.c
   grass-addons/grass7/imagery/i.feo_tio2/i.feo_tio2.html
   grass-addons/grass7/imagery/i.feo_tio2/main.c
update with OMAT and new FeO equations for Clementine UVVIS
Added: grass-addons/grass7/imagery/i.feo_tio2/clementine_mapplanet.c
--- grass-addons/grass7/imagery/i.feo_tio2/clementine_mapplanet.c	                        (rev 0)
+++ grass-addons/grass7/imagery/i.feo_tio2/clementine_mapplanet.c	2014-04-19 05:21:21 UTC (rev 59793)
@@ -0,0 +1,33 @@
+#include<stdio.h>
+#include<math.h>
+double feolucey2000(double uvvis2, double uvvis4){
+	 //\cite{lucey2000lunar}
+	 return(17.427*(-atan2f(((uvvis4/uvvis2)-1.19)/(uvvis2-0.08)))-7.565);
+double feolawrence2002(double uvvis2, double uvvis4){
+	 //\cite{lawrence2002iron}
+	 return(5.7*((-0.147+0.372*(-(uvvis4/uvvis2-1.22)/(uvvis2-0.04))+(-0.036)*pow((-(uvvis4/uvvis2-1.22)/(uvvis2-0.04)),2)))+2.15);
+double feowilcox2005(double uvvis2, double uvvis4){
+	  //\cite{wilcox2005mapping}
+	  return(-137.97*((uvvis2*0.9834)+(uvvis4/uvvis2*0.1813))+57.46);
+double omatlucey2000(double uvvis2, double uvvis4){
+	 return(sqrtf(pow((uvvis2-0.08),2)+pow(((uvvis4/uvvis2)-1.19),2)));
+double omatwilcox2005(double uvvis2, double uvvis4){
+	 return((uvvis2*0.1813)-((uvvis4/uvvis2)*0.9834));
+double tio2lucey2000(double uvvis1, double uvvis2){
+	 return(3.708*pow((atan2f(((uvvis1/uvvis2)-0.42)/(uvvis2-0.0))),5.979));
Modified: grass-addons/grass7/imagery/i.feo_tio2/i.feo_tio2.html
--- grass-addons/grass7/imagery/i.feo_tio2/i.feo_tio2.html	2014-04-19 02:53:36 UTC (rev 59792)
+++ grass-addons/grass7/imagery/i.feo_tio2/i.feo_tio2.html	2014-04-19 05:21:21 UTC (rev 59793)
@@ -1,6 +1,7 @@
 <h2>DESCRIPTION</h2>
-<em>i.feo_tio2</em> calculates the FeO or TiO2 contents.
+<em>i.feo_tio2</em> calculates the FeO or TiO2 contents from Clementine data.
+Clementine UVVIS sensor has five bands, UVVIS1 = 415, UVVIS2 = 750, UVVIS3 = 900, UVVIS4 = 950 and UVVIS5 = 1000 nm.
 wt%TiO2 = 3.708 arctan ((R415/R750)-y0Ti)/(R750-s0Ti) (1)
@@ -8,6 +9,40 @@
 with theta = 1.3885 rad, the ‘average slope of the trends in the mare’ from Wilcox et al (2005).
+http://www.mapaplanet.org/explorer/help/index.html mentions this set of equations:
 <h2>NOTES</h2>
 Initially created for Clementine data.
@@ -17,6 +52,9 @@
 (2) Wilcox, B.B., Lucey, P.G., Gillis, J.J., 2005. Mapping iron in the lunar mare: An improved approach. J. Geophys. Res. 110(E11):2156-2202.
+(3) Lawrence, DJ and Feldman, WC and Elphic, RC and Little, RC and Prettyman, TH and Maurice, S and Lucey, PG and Binder, AB, 2002. Iron abundances on the lunar surface as measured by the Lunar Prospector gamma-ray and neutron spectrometers. Journal of Geophysical Research: Planets (1991--2012), 107(E12):13-1.
 <h2>AUTHORS</h2>
 Yann Chemin (B.Sc. student), Birkbeck, University of London.
Modified: grass-addons/grass7/imagery/i.feo_tio2/main.c
--- grass-addons/grass7/imagery/i.feo_tio2/main.c	2014-04-19 02:53:36 UTC (rev 59792)
+++ grass-addons/grass7/imagery/i.feo_tio2/main.c	2014-04-19 05:21:21 UTC (rev 59793)
@@ -4,7 +4,7 @@
  * MODULE:       i.feo_tio2
  * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
  * PURPOSE:      Calculate FeO or TiO2 content
- *               from various UVVIS bands
+ *               from various Clementine UVVIS bands
  * COPYRIGHT:    (C) 2014 by the GRASS Development Team
@@ -29,6 +29,7 @@
     struct Cell_head cellhd;	/*region+header info */
     int nrows, ncols;
     int row, col;
+    char *equationflag;		/*Switch for particular equation */
     struct GModule *module;
     struct Option *in0, *in1, *output, *param0, *param1;
     struct Flag *flag1;
@@ -52,19 +53,21 @@
     module = G_define_module();
     G_add_keyword(_("imagery"));
     G_add_keyword(_("Moon"));
+    G_add_keyword(_("Clementine"));
+    G_add_keyword(_("UVVIS"));
     G_add_keyword(_("FeO"));
     G_add_keyword(_("TiO2"));
     G_add_keyword(_("reflectance"));
-    module->description = _("Computes FeO (default) or TiO2 (-t) from various bands.");
+    module->description = _("Computes wt%FeO, OMAT or wt%TiO2 from various bands.");
     /* Define the different options */
     in0 = G_define_standard_option(G_OPT_R_INPUT);
     in0->key = "band0";
-    in0->description = _("reflectance band at 750 nm");
+    in0->description = _("reflectance band at 750 nm (UVVIS 2)");
     in1 = G_define_standard_option(G_OPT_R_INPUT);
     in1->key = "band1";
-    in1->description = _("reflectance band at 950 nm (FeO) or at 415 nm (TiO2)");
+    in1->description = _("reflectance band at 950 nm (UVVIS 4 for FeO/OMAT) or at 415 nm (UVVIS 1 for TiO2)");
     output = G_define_standard_option(G_OPT_R_OUTPUT);
@@ -82,6 +85,29 @@
     param1->description = _("Value of s0Ti (TiO2)");
     param1->guisection = _("Parameters");
+    opt.eqname = G_define_option();
+    opt.eqname->key = "eqname";
+    opt.eqname->type = TYPE_STRING;
+    opt.eqname->required = YES;
+    opt.eqname->description = _("Type of equation");
+    desc = NULL;
+    G_asprintf(&desc,
+	       "feolucey2000;%s;feolawrence2002;%s;feowilcox2005_setparam;%s;"
+	       "feowilcox2005;%s;omatlucey2000;%s;omatwilcox2005;%s;"
+	       "tio2lucey2000_setparam;%s;tio2lucey2000;%s",
+	       _("FeO (Lucey et al., 2000)"),
+	       _("FeO (lawrence et al., 2002)"),
+	       _("FeO (Wilcox et al., 2005) set parameter theta"),
+	       _("FeO (Wilcox et al., 2005)"),
+	       _("OMAT (Lucey et al., 2000)"),
+	       _("OMAT (Wilcox et al., 2005)"),
+	       _("TiO2 (Lucey et al., 2000) set parameters"),
+	       _("TiO2 (Lucey et al., 2000)"));
+    opt.eqname->descriptions = desc;
+    opt.eqname->options = "feolucey2000,feolawrence2002,feowilcox2005_setparam,feowilcox2005,omatlucey2000,omatwilcox2005,tio2lucey2000_setparam,tio2lucey2000";
+    opt.eqname->answer = "feolucey2000";
+    opt.eqname->key_desc = _("type");
     /* Define the different flags */
     flag1 = G_define_flag();
     flag1->key = 't';
@@ -89,13 +115,18 @@
     if (G_parser(argc, argv)) exit(EXIT_FAILURE);
-    if(param0->answer) param_0 = atof(param0->answer);
-    else if (!flag1->answer) param_0 = theta;
-    else G_fatal_error(_("Please define param0 for -t flag"));
+    if (!strcasecmp(equationflag, "feowilcox2005_setparam")){
+        if(param0->answer) param_0 = atof(param0->answer);
+        else G_fatal_error("Please set param0 Theta (FeO Wilcox 2005)");
-    if(param1->answer) param_1 = atof(param1->answer);
-    else if (flag1->answer) G_fatal_error(_("Please define param1 for -t flag"));
+    if (!strcasecmp(equationflag, "tio2lucey2000_setparam")){
+        else G_fatal_error("Please set param0 y0Ti (TiO2 Lucey 2000)");
+        if(param1->answer) param_1 = atof(param1->answer);
+        else G_fatal_error("Please set param1 s0Ti (TiO2 Lucey 2000)");
     /* Allocate input buffer */
     infd0 = Rast_open_old(in0->answer, "");
     Rast_get_cellhd(in0->answer, "", &cellhd);
@@ -115,28 +146,41 @@
     /* Process pixels */
     for (row = 0; row < nrows; row++) {
-	DCELL d0, d1;
+    DCELL d0, d1;
-	G_percent(row, nrows, 2);
+    G_percent(row, nrows, 2);
         Rast_get_d_row(infd0, inrast0, row);
         Rast_get_d_row(infd1, inrast1, row);
-	/*process the data */
-	for (col = 0; col < ncols; col++) {
-            d0 = (double)((DCELL *) inrast0)[col];
-            d1 = (double)((DCELL *) inrast1)[col];
+    /*process the data */
+    for (col = 0; col < ncols; col++) {
+            d0 = (double)((DCELL *) inrast0)[col];//UVVIS2
+            d1 = (double)((DCELL *) inrast1)[col];//UVVIS4 or 1
             if (Rast_is_d_null_value(&d0) ||
                 Rast_is_d_null_value(&d1)){
                 Rast_set_d_null_value(&outrast[col], 1);
             } else {
-                if (flag1->answer){
-                    outrast[col] = tio2(d0, d1, param_0, param_1);
-	        } else {
+                    outrast[col] = tio2(d1, d0, param_0, param_1);
                     outrast[col] = feo(d0, d1, param_0);
+                if (!strcasecmp(equationflag, "tio2lucey2000"))
+                    outrast[col] = tio2lucey2000(d1, d0);
+                if (!strcasecmp(equationflag, "feowilcox2005"))
+                    outrast[col] = feowilcox2005(d0, d1);
+                if (!strcasecmp(equationflag, "feolawrence2002"))
+                    outrast[col] = feolawrence2002(d0, d1);
+                if (!strcasecmp(equationflag, "feolucey2000"))
+                    outrast[col] = feolucey2000(d0, d1);
+                if (!strcasecmp(equationflag, "omatwilcox2005"))
+                    outrast[col] = omatwilcox2005(d0, d1);
+                if (!strcasecmp(equationflag, "omatlucey2000"))
+                    outrast[col] = omatlucey2000(d0, d1);
+                else
+                    G_fatal_error("Please enter an appropriate equation name");
-	Rast_put_d_row(outfd, outrast);
+        Rast_put_d_row(outfd, outrast);
     G_free(inrast0);
     G_free(inrast1);
@@ -148,7 +192,7 @@
     /* Color table from 0.0 to 1.0 */
     Rast_init_colors(&colors);
     val1 = 0;
-    val2 = 1;
+    val2 = 10;
     Rast_add_c_color_rule(&val1, 0, 0, 0, &val2, 255, 255, 255, &colors);
     /* Metadata */
     Rast_short_history(output->answer, "raster", &history);
