[GRASS-SVN] r59803 - grass/branches/releasebranch_7_0/gui/wxpython/dbmgr
Sat Apr 19 08:57:32 PDT 2014
Author: martinl
Date: 2014-04-19 08:57:32 -0700 (Sat, 19 Apr 2014)
New Revision: 59803
   grass/branches/releasebranch_7_0/gui/wxpython/dbmgr/sqlbuilder.py
winGRASS: fix SQLBuilder to get values on Windows
          (merge r59802 from trunk)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/dbmgr/sqlbuilder.py
--- grass/branches/releasebranch_7_0/gui/wxpython/dbmgr/sqlbuilder.py	2014-04-19 15:49:53 UTC (rev 59802)
+++ grass/branches/releasebranch_7_0/gui/wxpython/dbmgr/sqlbuilder.py	2014-04-19 15:57:32 UTC (rev 59803)
@@ -39,7 +39,7 @@
 from grass.pydispatch.signal import Signal
 from core.gcmd   import RunCommand, GError, GMessage
-from dbmgr.vinfo import CreateDbInfoDesc, VectorDBInfo
+from dbmgr.vinfo import CreateDbInfoDesc, VectorDBInfo, GetUnicodeValue
 import grass.script as grass
@@ -299,7 +299,7 @@
         data = grass.db_select(sql = "SELECT %s FROM %s" % (column, self.tablename),
                                database = self.database,
-                               driver = self.driver)
+                               driver = self.driver, sep = '{_sep_}')
         if not data:
             return
@@ -312,6 +312,8 @@
             if desc['type'] != 'character':
                 item = str(item)
+            else:
+                item = GetUnicodeValue(item)
             self.list_values.Append(item)
             i += 1
