[GRASS-SVN] r59864 - grass/trunk/general/g.gui
svn_grass at osgeo.org
Sun Apr 20 15:00:10 PDT 2014
Author: martinl
Date: 2014-04-20 15:00:07 -0700 (Sun, 20 Apr 2014)
New Revision: 59864
grass/trunk/general/g.gui/g.gui.html
grass/trunk/general/g.gui/main.c
g.gui: change option 'gui' to more suitable 'ui'
Modified: grass/trunk/general/g.gui/g.gui.html
--- grass/trunk/general/g.gui/g.gui.html 2014-04-20 21:53:28 UTC (rev 59863)
+++ grass/trunk/general/g.gui/g.gui.html 2014-04-20 22:00:07 UTC (rev 59864)
@@ -5,8 +5,8 @@
settings.
<p>GRASS 7 comes with wxPython-based GUI
-aka <em><a href="wxGUI.html">wxGUI</a></em> (<b>gui=wxpython</b>) and
-command line text-based UI (<b>gui=text</b>).
+aka <em><a href="wxGUI.html">wxGUI</a></em> (<b>ui=wxpython</b>) and
+command line text-based UI (<b>ui=text</b>).
<p>
The old <em>gis.m</em> and <em>d.m</em> Tcl/Tk-based GUIs from GRASS 6
@@ -17,7 +17,7 @@
If the <b>-u</b> update flag is given or the GRASS
<tt>GUI</tt> variable is missing, then the <tt>GUI</tt> variable is
-permanently changed and the selected <b>gui</b> will be used as the default
+permanently changed and the selected <b>ui</b> will be used as the default
UI from then on.
<p>
@@ -33,7 +33,7 @@
Set the command line text-based UI to be the default UI:
<div class="code"><pre>
-g.gui -u gui=text
+g.gui -u ui=text
</pre></div>
<h2>SEE ALSO</h2>
Modified: grass/trunk/general/g.gui/main.c
--- grass/trunk/general/g.gui/main.c 2014-04-20 21:53:28 UTC (rev 59863)
+++ grass/trunk/general/g.gui/main.c 2014-04-20 22:00:07 UTC (rev 59864)
@@ -8,7 +8,7 @@
* PURPOSE: Start GRASS GUI from command line.
- * COPYRIGHT: (C) 2008, 2010-2011 by the GRASS Development Team
+ * COPYRIGHT: (C) 2008-2014 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -35,14 +35,15 @@
module = G_define_module();
G_add_keyword(_("general"));
+ G_add_keyword(_("user interface"));
G_add_keyword(_("gui"));
module->description =
_("Launches a GRASS graphical user interface (GUI) session.");
type = G_define_option();
- type->key = "gui";
+ type->key = "ui";
type->type = TYPE_STRING;
- type->label = _("GUI type");
+ type->label = _("User interface");
type->description = _("Default value: GRASS_GUI if defined otherwise wxpython");
desc = NULL;
G_asprintf(&desc,
@@ -61,13 +62,13 @@
update = G_define_flag();
update->key = 'u';
- update->description = _("Update default GUI setting");
+ update->description = _("Update default user interface settings");
update->guisection = _("Default");
nolaunch = G_define_flag();
nolaunch->key = 'n';
nolaunch->description =
- _("Do not launch GUI after updating the default GUI setting");
+ _("Do not launch GUI after updating the default user interface settings");
nolaunch->guisection = _("Default");
if (G_parser(argc, argv))
