[GRASS-SVN] r59885 - grass/branches/releasebranch_7_0/raster/r.stream.distance
svn_grass at osgeo.org
Mon Apr 21 10:12:40 PDT 2014
Author: madi
Date: 2014-04-21 10:12:40 -0700 (Mon, 21 Apr 2014)
New Revision: 59885
grass/branches/releasebranch_7_0/raster/r.stream.distance/r.stream.distance.html
Added example
Modified: grass/branches/releasebranch_7_0/raster/r.stream.distance/r.stream.distance.html
--- grass/branches/releasebranch_7_0/raster/r.stream.distance/r.stream.distance.html 2014-04-21 17:11:11 UTC (rev 59884)
+++ grass/branches/releasebranch_7_0/raster/r.stream.distance/r.stream.distance.html 2014-04-21 17:12:40 UTC (rev 59885)
@@ -62,7 +62,8 @@
<em>r.watershed</em> or <em>r.stream.extract</em>. Since stream
network maps produced by <em>r.watershed</em> and <em>r.stream.extract</em> may
slightly differ in detail, it is required to use both stream and direction maps
-produced by the same module. Non-stream cell values must be set to NULL.</dd>
+produced by the same module. Non-stream cell values must be set to NULL.
+Alternatively, in <em>outlet</em> mode, it's the raster map of the outlet.</dd>
<dt><b>direction</b></dt>
<dd>Flow direction: name of input input raster map with flow direction,
@@ -137,30 +138,31 @@
<div class="code"><pre>
# Set the region to match with elevation map
-g.region -ap rast = elevation
+g.region -ap rast=elevation
# Calculate flow direction and stream network
-r.watershed elevation = elevation threshold = 10000 drainage = direction stream = streams
+r.watershed elevation=elevation threshold=10000 drainage=direction stream=streams
# Calculate elevation above and distance to stream network using downstream method
-r.stream.distance stream_rast = streams direction = direction elevation = elevation \
- method = downstream distance = distance_stream_downstream difference = difference_stream_downstream
+r.stream.distance stream_rast=streams direction=direction elevation=elevation \
+ method=downstream distance=distance_stream_downstream difference=difference_stream_downstream
# Calculate elevation above and distance to stream network using upstream method
- method = upstream distance = distance_stream_upstream difference = difference_stream_upstream
+ method=upstream distance=distance_stream_upstream difference=difference_stream_upstream
+# Create outlet
+echo "636645,218835" | v.in.ascii -n input=- output=outlet separator=","
-</pre></div>
+# Convert outlet to raster
+v.to.rast input=outlet output=outlet use=cat
+# Calculate distance to and elevation above outlet
+r.stream.distance -o stream_rast=outlet direction=direction elevation=elevation \
+method=downstream distance=distance2outlet difference=difference2outlet
-TODO : add the following examples:
-elevation above outlet
-distance to outlet
+</pre></div>
<h2>SEE ALSO</h2>
<em>
<a href="r.watershed.html">r.watershed</a>,
