[GRASS-SVN] r59889 - grass/trunk/raster/r.stream.distance
Mon Apr 21 10:31:15 PDT 2014
Author: madi
Date: 2014-04-21 10:31:15 -0700 (Mon, 21 Apr 2014)
New Revision: 59889
   grass/trunk/raster/r.stream.distance/r.stream.distance.html
minor edit
Modified: grass/trunk/raster/r.stream.distance/r.stream.distance.html
--- grass/trunk/raster/r.stream.distance/r.stream.distance.html	2014-04-21 17:30:37 UTC (rev 59888)
+++ grass/trunk/raster/r.stream.distance/r.stream.distance.html	2014-04-21 17:31:15 UTC (rev 59889)
@@ -159,7 +159,7 @@
 # Calculate distance to and elevation above outlet
 r.stream.distance -o stream_rast=outlet direction=direction elevation=elevation \
-method=downstream distance=distance2outlet difference=difference2outlet
+  method=downstream distance=distance2outlet difference=difference2outlet
 </pre></div>
