[GRASS-SVN] r59907 - in grass/trunk/lib/python/pygrass: . gis modules modules/grid modules/interface raster shell vector
Wed Apr 23 09:08:36 PDT 2014
Author: lucadelu
Date: 2014-04-23 09:08:36 -0700 (Wed, 23 Apr 2014)
New Revision: 59907
   grass/trunk/lib/python/pygrass/functions.py
   grass/trunk/lib/python/pygrass/gis/__init__.py
   grass/trunk/lib/python/pygrass/gis/region.py
   grass/trunk/lib/python/pygrass/modules/__init__.py
   grass/trunk/lib/python/pygrass/modules/grid/__init__.py
   grass/trunk/lib/python/pygrass/modules/grid/grid.py
   grass/trunk/lib/python/pygrass/modules/grid/split.py
   grass/trunk/lib/python/pygrass/modules/interface/__init__.py
   grass/trunk/lib/python/pygrass/modules/interface/flag.py
   grass/trunk/lib/python/pygrass/modules/interface/module.py
   grass/trunk/lib/python/pygrass/modules/interface/parameter.py
   grass/trunk/lib/python/pygrass/modules/shortcuts.py
   grass/trunk/lib/python/pygrass/raster/__init__.py
   grass/trunk/lib/python/pygrass/raster/abstract.py
   grass/trunk/lib/python/pygrass/raster/buffer.py
   grass/trunk/lib/python/pygrass/raster/category.py
   grass/trunk/lib/python/pygrass/raster/rowio.py
   grass/trunk/lib/python/pygrass/raster/segment.py
   grass/trunk/lib/python/pygrass/shell/__init__.py
   grass/trunk/lib/python/pygrass/vector/__init__.py
   grass/trunk/lib/python/pygrass/vector/abstract.py
   grass/trunk/lib/python/pygrass/vector/find.py
   grass/trunk/lib/python/pygrass/vector/geometry.py
   grass/trunk/lib/python/pygrass/vector/table.py
   grass/trunk/lib/python/pygrass/vector/vector_type.py
update doctest for pygrass, some should be fixed. please check #2261
Modified: grass/trunk/lib/python/pygrass/functions.py
--- grass/trunk/lib/python/pygrass/functions.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/functions.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -154,7 +154,7 @@
     True
     >>> is_clean_name('0census')
     True
-    >>> is_clean_name('census&')
+    >>> is_clean_name('census?')
     False
     >>> is_clean_name('cénsus')
     False
@@ -203,6 +203,7 @@
         >>> ele = RasterRow('elevation')
         >>> copy('schools','myschools','vect')
         >>> sch = VectorTopo('myschools')
+        >>> sch.open()
         >>> get_raster_for_points(sch, ele)               # doctest: +ELLIPSIS
         [(1, 633649.2856743174, 221412.94434781274, 145.06602)...
         >>> sch.table.columns.add('elevation','double precision')
@@ -211,7 +212,7 @@
         >>> get_raster_for_points(sch, ele, 'elevation')
         True
         >>> sch.table.filters.select('NAMESHORT','elevation')
-        Filters('SELECT NAMESHORT, elevation FROM myschools;')
+        Filters(u'SELECT NAMESHORT, elevation FROM myschools;')
         >>> cur = sch.table.execute()
         >>> cur.fetchall()                                # doctest: +ELLIPSIS
         [(u'SWIFT CREEK', 145.06602), ... (u'9TH GRADE CTR', None)]
@@ -293,19 +294,19 @@
     """Split a list in chunk.
     >>> for chunk in split_in_chunk(range(25)): print chunk
-    [0, 1, 2, 3, 4, 5, 6, 7, 8, 9]
-    [10, 11, 12, 13, 14, 15, 16, 17, 18, 19]
-    [20, 21, 22, 23, 24]
+    (0, 1, 2, 3, 4, 5, 6, 7, 8, 9)
+    (10, 11, 12, 13, 14, 15, 16, 17, 18, 19)
+    (20, 21, 22, 23, 24)
     >>> for chunk in split_in_chunk(range(25), 3): print chunk
-    [0, 1, 2]
-    [3, 4, 5]
-    [6, 7, 8]
-    [9, 10, 11]
-    [12, 13, 14]
-    [15, 16, 17]
-    [18, 19, 20]
-    [21, 22, 23]
-    [24]
+    (0, 1, 2)
+    (3, 4, 5)
+    (6, 7, 8)
+    (9, 10, 11)
+    (12, 13, 14)
+    (15, 16, 17)
+    (18, 19, 20)
+    (21, 22, 23)
+    (24,)
     it = iter(iterable)
     while True:
Modified: grass/trunk/lib/python/pygrass/gis/__init__.py
--- grass/trunk/lib/python/pygrass/gis/__init__.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/gis/__init__.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -4,7 +4,7 @@
 from __future__ import (nested_scopes, generators, division, absolute_import,
                         with_statement, print_function, unicode_literals)
 from os import listdir
-from os.path import join, exists, isdir
+from os.path import join, isdir
 import shutil
 import ctypes as ct
 import fnmatch
@@ -25,7 +25,6 @@
 import grass.lib.gis as libgis
 from grass.pygrass.functions import getenv
 from grass.pygrass.errors import GrassError
-from . import region
 #write dec to check if user have permissions or not
Modified: grass/trunk/lib/python/pygrass/gis/region.py
--- grass/trunk/lib/python/pygrass/gis/region.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/gis/region.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -19,8 +19,9 @@
             >>> default = Region(default=True)
+            >>> current_good = Region()
             >>> current = Region()
-            >>> current_good = Region()
+            >>> current.align('elevation')
             >>> default == current
             True
             >>> current.cols
Modified: grass/trunk/lib/python/pygrass/modules/__init__.py
--- grass/trunk/lib/python/pygrass/modules/__init__.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/modules/__init__.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -5,10 +5,10 @@
 @author: pietro
-from . import interface
-from .interface import Module, ParallelModuleQueue
+from grass.pygrass.modules import interface
+from grass.pygrass.modules.interface import Module, ParallelModuleQueue
-from . import grid
-from .grid.grid import GridModule
+from grass.pygrass.modules import grid
+from grass.pygrass.modules.grid.grid import GridModule
-from . import shortcuts
+from grass.pygrass.modules import shortcuts
Modified: grass/trunk/lib/python/pygrass/modules/grid/__init__.py
--- grass/trunk/lib/python/pygrass/modules/grid/__init__.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/modules/grid/__init__.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -4,8 +4,8 @@
 @author: pietro
-from . import split
-from . import patch
-from . import grid
-from .grid import GridModule
+from grass.pygrass.modules.grid import split
+from grass.pygrass.modules.grid import patch
+from grass.pygrass.modules.grid import grid
Modified: grass/trunk/lib/python/pygrass/modules/grid/grid.py
--- grass/trunk/lib/python/pygrass/modules/grid/grid.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/modules/grid/grid.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -105,11 +105,11 @@
         >>> copy_mapset(mset, path)
         Mapset('user1')
         >>> sorted(os.listdir(path))
-        ['PERMANENT', 'user1']
+        [u'PERMANENT', u'user1']
         >>> sorted(os.listdir(os.path.join(path, 'PERMANENT')))
-        ['DEFAULT_WIND', 'PROJ_INFO', 'PROJ_UNITS', 'VAR', 'WIND']
+        [u'DEFAULT_WIND', u'PROJ_INFO', u'PROJ_UNITS', u'VAR', u'WIND']
         >>> sorted(os.listdir(os.path.join(path, 'user1')))
-        ['CURGROUP', 'SEARCH_PATH', 'VAR', 'WIND']
+        [u'CURGROUP', u'SEARCH_PATH', u'VAR', u'WIND']
         >>> import shutil
         >>> shutil.rmtree(path)
@@ -139,7 +139,7 @@
         >>> import os
         >>> read_gisrc(os.environ['GISRC'])  # doctest: +ELLIPSIS
-        ('user1', ...)
+        (u'user1', ...)
     with open(gisrc, 'r') as gfile:
         gis = dict([(k.strip(), v.strip())
Modified: grass/trunk/lib/python/pygrass/modules/grid/split.py
--- grass/trunk/lib/python/pygrass/modules/grid/split.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/modules/grid/split.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -36,10 +36,10 @@
         1500
         >>> reg.rows
         1350
-        >>> split_region_tiles(region=reg, width=1000, height=700, overlap=0)
+        >>> split_region_tiles(region=reg, width=1000, height=700, overlap=0) # doctest: +NORMALIZE_WHITESPACE
         [[Bbox(1350.0, 650.0, 1000.0, 0.0), Bbox(1350.0, 650.0, 1500.0, 1000.0)],
          [Bbox(650.0, 0.0, 1000.0, 0.0), Bbox(650.0, 0.0, 1500.0, 1000.0)]]
-        >>> split_region_tiles(region=reg, width=1000, height=700, overlap=10)
+        >>> split_region_tiles(region=reg, width=1000, height=700, overlap=10) # doctest: +NORMALIZE_WHITESPACE
         [[Bbox(1350.0, 640.0, 1010.0, 0.0), Bbox(1350.0, 640.0, 1500.0, 990.0)],
          [Bbox(660.0, 0.0, 1010.0, 0.0), Bbox(660.0, 0.0, 1500.0, 990.0)]]
@@ -71,10 +71,10 @@
         1500
         >>> reg.rows
         1350
Modified: grass/trunk/lib/python/pygrass/modules/interface/__init__.py
--- grass/trunk/lib/python/pygrass/modules/interface/__init__.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/modules/interface/__init__.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -4,10 +4,10 @@
 @author: pietro
-from . import flag
-from . import parameter
-from . import module
-from . import typedict
-from . import read
+from grass.pygrass.modules.interface import flag
+from grass.pygrass.modules.interface import parameter
+from grass.pygrass.modules.interface import module
+from grass.pygrass.modules.interface import typedict
+from grass.pygrass.modules.interface import read
-from .module import Module, ParallelModuleQueue
+from grass.pygrass.modules.interface.module import Module, ParallelModuleQueue
Modified: grass/trunk/lib/python/pygrass/modules/interface/flag.py
--- grass/trunk/lib/python/pygrass/modules/interface/flag.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/modules/interface/flag.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -6,7 +6,7 @@
-from . import read
 class Flag(object):
Modified: grass/trunk/lib/python/pygrass/modules/interface/module.py
--- grass/trunk/lib/python/pygrass/modules/interface/module.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/modules/interface/module.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -13,38 +13,38 @@
 >>> region.flags["u"].value = True
 >>> region.flags["3"].value = True
 >>> region.get_bash()
-'g.region -p -u -3'
+u'g.region -p -3 -u'
 >>> new_region = copy.deepcopy(region)
 >>> new_region.inputs["res"].value = "10"
 >>> new_region.get_bash()
-'g.region res=10 -p -3'
+u'g.region res=10 -p -3 -u'
 >>> neighbors = pymod.Module("r.neighbors")
 >>> neighbors.inputs["input"].value = "mapA"
 >>> neighbors.outputs["output"].value = "mapB"
 >>> neighbors.inputs["size"].value = 5
 >>> neighbors.get_bash()
-'r.neighbors input=mapA method=average size=5 quantile=0.5 output=mapB'
+u'r.neighbors input=mapA method=average size=5 quantile=0.5 output=mapB'
 >>> new_neighbors1 = copy.deepcopy(neighbors)
 >>> new_neighbors1.inputs["input"].value = "mapD"
 >>> new_neighbors1.inputs["size"].value = 3
 >>> new_neighbors1.get_bash()
-'r.neighbors input=mapD method=average size=3 quantile=0.5 output=mapB'
+u'r.neighbors input=mapD method=average size=3 quantile=0.5 output=mapB'
 >>> new_neighbors2 = copy.deepcopy(neighbors)
 >>> new_neighbors2(input="mapD", size=3, run_=False)
 >>> new_neighbors2.get_bash()
-'r.neighbors method=average size=3 quantile=0.5'
+u'r.neighbors method=average size=3 quantile=0.5'
 >>> new_neighbors3 = copy.deepcopy(neighbors)
 >>> new_neighbors3(input="mapA", size=3, output="mapB", run_=False)
 >>> new_neighbors3.get_bash()
-'r.neighbors input=mapA method=average size=3 quantile=0.5 output=mapB'
+u'r.neighbors input=mapA method=average size=3 quantile=0.5 output=mapB'
 @endcode
@@ -61,10 +61,10 @@
 from grass.script.core import Popen, PIPE
 from grass.pygrass.errors import GrassError, ParameterError
-from .parameter import Parameter
-from .flag import Flag
-from .typedict import TypeDict
-from .read import GETFROMTAG, DOC
+from grass.pygrass.modules.interface.parameter import Parameter
+from grass.pygrass.modules.interface.flag import Flag
+from grass.pygrass.modules.interface.typedict import TypeDict
+from grass.pygrass.modules.interface.read import GETFROMTAG, DOC
 class ParallelModuleQueue(object):
@@ -242,7 +242,12 @@
     and keyword arguments to the grass module.
     def __init__(self, cmd, *args, **kargs):
-        self.name = cmd
+        if isinstance(cmd, unicode):
+            self.name = str(cmd)
+        elif isinstance(cmd, str):
+            self.name = cmd
+        else:
+            raise GrassError("Problem initializing the module {s}".format(s=cmd))
         try:
             # call the command with --interface-description
             get_cmd_xml = Popen([cmd, "--interface-description"], stdout=PIPE)
Modified: grass/trunk/lib/python/pygrass/modules/interface/parameter.py
--- grass/trunk/lib/python/pygrass/modules/interface/parameter.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/modules/interface/parameter.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -9,7 +9,7 @@
 import re
-from .read import GETTYPE, element2dict, DOC
+from grass.pygrass.modules.interface.read import GETTYPE, element2dict, DOC
 class Parameter(object):
@@ -116,7 +116,14 @@
                     raise ValueError(values_error % (self.name, self.values))
             else:
                 self._value = value
-        # was: elif self.type is str and isinstance(value, unicode):
+        elif self.type is str and isinstance(value, unicode):
+            if hasattr(self, 'values'):
+                if value in self.values:
+                    self._value = str(value)
+                else:
+                    raise ValueError(values_error % (self.name, self.values))
+            else:
         elif self.type is str and isinstance(value, str):
Modified: grass/trunk/lib/python/pygrass/modules/shortcuts.py
--- grass/trunk/lib/python/pygrass/modules/shortcuts.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/modules/shortcuts.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -10,7 +10,7 @@
 from grass.script.core import get_commands
 _CMDS = list(get_commands()[0])
 _CMDS.sort()
@@ -24,7 +24,7 @@
        >>> g_mlist.name
        'g.mlist'
        >>> g_mlist.required
-       [Parameter <type> (required:yes, type:string, multiple:yes)]
+       ['type']
        >>> g_mlist.inputs.type = 'rast'
        >>> g_mlist.stdout_ = -1
        >>> g_mlist.run()
Modified: grass/trunk/lib/python/pygrass/raster/__init__.py
--- grass/trunk/lib/python/pygrass/raster/__init__.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/raster/__init__.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -30,11 +30,11 @@
 # import raster classes
-from .abstract import RasterAbstractBase, Info
-from .raster_type import TYPE as RTYPE, RTYPE_STR
-from .buffer import Buffer
-from .segment import Segment
-from .rowio import RowIO
+from grass.pygrass.raster.abstract import RasterAbstractBase
+from grass.pygrass.raster.raster_type import TYPE as RTYPE, RTYPE_STR
+from grass.pygrass.raster.buffer import Buffer
+from grass.pygrass.raster.segment import Segment
+from grass.pygrass.raster.rowio import RowIO
 class RasterRow(RasterAbstractBase):
@@ -62,53 +62,42 @@
         True
         >>> elev.is_open()
         False
-        >>> elev.cols
+        >>> elev.info.cols
         >>> elev.open()
         >>> elev.is_open()
         True
-        >>> type(elev.cols)
+        >>> type(elev.info.cols)
         <type 'int'>
         >>> elev.has_cats()
         False
         >>> elev.mode
-        'r'
+        u'r'
         >>> elev.mtype
         'FCELL'
         >>> elev.num_cats()
         0
-        >>> elev.range
-        (55.578792572021484, 156.32986450195312)
+        >>> elev.info.range
+        (56, 156)
     Each Raster map have an attribute call ``cats`` that allow user
     to interact with the raster categories. ::
-        >>> land = RasterRow('landcover_1m')
+        >>> land = RasterRow('geology')
         >>> land.open()
-        >>> land.cats
-        >>> land.read_cats()
-        >>> land.cats
-        [('pond', 1, None),
-         ('forest', 2, None),
-         ('developed', 3, None),
-         ('bare', 4, None),
-         ('paved road', 5, None),
-         ('dirt road', 6, None),
-         ('vineyard', 7, None),
-         ('agriculture', 8, None),
-         ('wetland', 9, None),
-         ('bare ground path', 10, None),
-         ('grass', 11, None)]
+        >>> land.cats               # doctest: +ELLIPSIS +NORMALIZE_WHITESPACE
+        [('Zml', 1.0, None),
+         ('Tpyw', 1832.0, None)]
     Open a raster map using the *with statement*: ::
-        >>> with RasterRow('elevation') as elev:
+        >>> with RasterRow('elevation') as elev:
         ...     for row in elev[:3]:
-        ...         print row[:4]
+        ...         row[:4]
-        [ 141.99613953  141.27848816  141.37904358  142.29821777]
-        [ 142.90461731  142.39450073  142.68611145  143.59086609]
-        [ 143.81854248  143.54707336  143.83972168  144.59527588]
+        Buffer([ 141.99613953,  141.27848816,  141.37904358,  142.29821777], dtype=float32)
+        Buffer([ 142.90461731,  142.39450073,  142.68611145,  143.59086609], dtype=float32)
+        Buffer([ 143.81854248,  143.54707336,  143.83972168,  144.59527588], dtype=float32)
         >>> elev.is_open()
         False
@@ -484,20 +473,18 @@
     >>> elev.open()
     >>> elev[:5, :3]
     RasterNumpy([[ 141.99613953,  141.27848816,  141.37904358],
-       [ 142.90461731,  142.39450073,  142.68611145],
-       [ 143.81854248,  143.54707336,  143.83972168],
-       [ 144.56524658,  144.58493042,  144.86477661],
-       [ 144.99488831,  145.22894287,  145.57142639]], dtype=float32)
+           [ 142.90461731,  142.39450073,  142.68611145],
+           [ 143.81854248,  143.54707336,  143.83972168],
+           [ 144.56524658,  144.58493042,  144.86477661],
+           [ 144.99488831,  145.22894287,  145.57142639]], dtype=float32)
     >>> el = elev < 144
     >>> el[:5, :3]
-    RasterNumpy([[ True,  True,  True],
-       [ True,  True,  True],
-       [False, False, False],
-       [False, False, False]], dtype=bool)
+    RasterNumpy([[1, 1, 1],
+           [1, 1, 1],
+           [1, 1, 1],
+           [0, 0, 0],
+           [0, 0, 0]], dtype=int32)
     >>> el._write()
-    0
     def __new__(cls, name, mapset="", mtype='CELL', mode='r+',
                 overwrite=False):
@@ -581,7 +568,7 @@
             if kind in FLAGS[size]:
                 return size, FLAGS[size][kind]
             else:
-                raise ValueError(_('Invalid type {0}'.forma(kind)))
+                raise ValueError(_('Invalid type {0}'.format(kind)))
         else:
             raise ValueError(_('Invalid size {0}'.format(size)))
@@ -596,7 +583,6 @@
             for i in range(len(rst)):
                 self[i] = rst.get_row(i, buff)
     def _write(self):
         r.in.bin input=/home/pietro/docdat/phd/thesis/gis/north_carolina/user1/.tmp/eraclito/14325.0 output=new title='' bytes=1,anull='' --verbose --overwrite north=228500.0 south=215000.0 east=645000.0 west=630000.0 rows=1350 cols=1500
Modified: grass/trunk/lib/python/pygrass/raster/abstract.py
--- grass/trunk/lib/python/pygrass/raster/abstract.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/raster/abstract.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -27,9 +27,9 @@
-from .category import Category
-from .history import History
+from grass.pygrass.raster.category import Category
+from grass.pygrass.raster.history import History
 ## Define global variables to not exceed the 80 columns
@@ -182,7 +182,7 @@
             >>> ele = RasterAbstractBase('elevation')
             >>> ele.name
-            'elevation'
+            u'elevation'
             >>> ele.exist()
             True
             >>> ele.mapset
@@ -368,7 +368,7 @@
             >>> ele.name_mapset()
-            'elevation at PERMANENT'
+            u'elevation at PERMANENT'
         if name is None:
Modified: grass/trunk/lib/python/pygrass/raster/buffer.py
--- grass/trunk/lib/python/pygrass/raster/buffer.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/raster/buffer.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -4,7 +4,7 @@
 @author: pietro
 import ctypes
 import numpy as np
Modified: grass/trunk/lib/python/pygrass/raster/category.py
--- grass/trunk/lib/python/pygrass/raster/category.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/raster/category.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -11,7 +11,7 @@
 class Category(list):
@@ -54,7 +54,7 @@
     >>> import grass.lib.raster as libraster
     >>> import ctypes
     >>> import grass.pygrass as pygrass
-    >>> land = pygrass.raster.RasterRow('landcover_1m')
+    >>> land = pygrass.raster.RasterRow('geology')
     >>> cats = pygrass.raster.Category()
     >>> cats.read(land) # or with cats.read(land.name, land.mapset, land.mtype)
     >>> cats.labels()
Modified: grass/trunk/lib/python/pygrass/raster/rowio.py
--- grass/trunk/lib/python/pygrass/raster/rowio.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/raster/rowio.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -10,7 +10,7 @@
 CMPFUNC = ctypes.CFUNCTYPE(ctypes.c_int,
Modified: grass/trunk/lib/python/pygrass/raster/segment.py
--- grass/trunk/lib/python/pygrass/raster/segment.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/raster/segment.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -8,7 +8,7 @@
 import grass.lib.segment as libseg
 class Segment(object):
Modified: grass/trunk/lib/python/pygrass/shell/__init__.py
--- grass/trunk/lib/python/pygrass/shell/__init__.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/shell/__init__.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -5,6 +5,6 @@
 @author: pietro
-from . import conversion
-from . import show
+from grass.pygrass.shell import conversion
+from grass.pygrass.shell import show
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -5,7 +5,7 @@
 @author: pietro
 import grass.lib.vector as libvect
-from .vector_type import VTYPE
+from grass.pygrass.vector.vector_type import VTYPE
@@ -14,11 +14,11 @@
 from grass.pygrass.errors import GrassError, must_be_open
 from grass.pygrass.gis import Location
-from .geometry import GEOOBJ as _GEOOBJ
-from .geometry import read_line, read_next_line
-from .geometry import Area as _Area
-from .abstract import Info
-from .basic import Bbox, Cats, Ilist
+from grass.pygrass.vector.geometry import GEOOBJ as _GEOOBJ
+from grass.pygrass.vector.geometry import read_line, read_next_line
+from grass.pygrass.vector.geometry import Area as _Area
+from grass.pygrass.vector.abstract import Info
+from grass.pygrass.vector.basic import Bbox, Cats, Ilist
 _NUMOF = {"areas": libvect.Vect_get_num_areas,
Modified: grass/trunk/lib/python/pygrass/vector/abstract.py
--- grass/trunk/lib/python/pygrass/vector/abstract.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/vector/abstract.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -7,12 +7,12 @@
 import ctypes
 import datetime
-from .vector_type import MAPTYPE
+from grass.pygrass.vector.vector_type import MAPTYPE
 from grass.pygrass import functions
 from grass.pygrass.errors import GrassError, OpenError, must_be_open
-from .table import DBlinks, Link
-from .find import PointFinder, BboxFinder, PolygonFinder
+from grass.pygrass.vector.table import DBlinks, Link
+from grass.pygrass.vector.find import PointFinder, BboxFinder, PolygonFinder
 def is_open(c_mapinfo):
Modified: grass/trunk/lib/python/pygrass/vector/find.py
--- grass/trunk/lib/python/pygrass/vector/find.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/vector/find.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -8,8 +8,8 @@
 from grass.pygrass.errors import must_be_open
-from .basic import Ilist, BoxList
-from .geometry import read_line, Isle, Area, Point
+from grass.pygrass.vector.basic import Ilist, BoxList
+from grass.pygrass.vector.geometry import read_line, Isle, Area, Point
 class AbstractFinder(object):
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -15,8 +15,8 @@
-from .basic import Ilist, Bbox, Cats
-from . import sql
+from grass.pygrass.vector.basic import Ilist, Bbox, Cats
+from grass.pygrass.vector import sql
 WKT = {'POINT\((.*)\)': 'point',  # 'POINT\(\s*([+-]*\d+\.*\d*)+\s*\)'
@@ -211,7 +211,7 @@
            >>> schools.open('r')
            >>> school = schools[1]
            >>> attrs = Attrs(school.cat, schools.table)
-           >>> attrs.values()                             # doctest: +ELLIPSIS
+           >>> attrs.values()       # doctest: +ELLIPSIS +NORMALIZE_WHITESPACE
            (1,
            None)
@@ -230,10 +230,10 @@
            >>> schools.open('r')
            >>> school = schools[1]
-           >>> attrs.keys()                             # doctest: +ELLIPSIS
-           (u'cat',
+           >>> attrs.keys()         # doctest: +ELLIPSIS +NORMALIZE_WHITESPACE
+           [u'cat',
-           u'NOTES')
+           u'NOTES']
         return self.table.columns.names()
@@ -320,7 +320,7 @@
         >>> pnt
         Point(0.000000, 0.000000, 0.000000)
         >>> print(pnt)
-        POINT(0.000000, 0.000000, 0.000000)
+        POINT(0.000000 0.000000 0.000000)
Modified: grass/trunk/lib/python/pygrass/vector/table.py
--- grass/trunk/lib/python/pygrass/vector/table.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/vector/table.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -31,9 +31,8 @@
 from grass.script.db import db_table_in_vector
 from grass.script.core import warning
-from . import sql
 DRIVERS = ('sqlite', 'pg')
@@ -65,13 +64,13 @@
         >>> filter = Filters('table')
         >>> filter.get_sql()
-        'SELECT * FROM table;'
+        u'SELECT * FROM table;'
         >>> filter.where("area<10000").get_sql()
-        'SELECT * FROM table WHERE area<10000;'
+        u'SELECT * FROM table WHERE area<10000;'
         >>> filter.select("cat", "area").get_sql()
-        'SELECT cat, area FROM table WHERE area<10000;'
+        u'SELECT cat, area FROM table WHERE area<10000;'
         >>> filter.order_by("area").limit(10).get_sql()
-        'SELECT cat, area FROM table WHERE area<10000 ORDER BY area LIMIT 10;'
+        u'SELECT cat, area FROM table WHERE area<10000 ORDER BY area LIMIT 10;'
@@ -100,7 +99,7 @@
     def order_by(self, orderby):
         """Create the order by condition"""
-        if not isinstance(orderby, str):
+        if not isinstance(orderby, unicode):
             orderby = ', '.join(orderby)
         self._orderby = 'ORDER BY {orderby}'.format(orderby=orderby)
         return self
@@ -115,7 +114,7 @@
     def group_by(self, groupby):
         """Create the group by condition"""
-        if not isinstance(groupby, str):
+        if not isinstance(groupby, unicode):
             groupby = ', '.join(groupby)
         self._groupby = 'GROUP BY {groupby}'.format(groupby=groupby)
         return self
@@ -159,7 +158,7 @@
         >>> cols_sqlite = Columns('census',
         ...                       sqlite3.connect(get_path(path)))
         >>> cols_sqlite.tname
-        'census'
+        u'census'
     For a postgreSQL table: ::
@@ -265,7 +264,7 @@
             >>> cols_sqlite.sql_descr()                   # doctest: +ELLIPSIS
-            u'cat INTEGER, OBJECTID INTEGER, AREA DOUBLE PRECISION, ...'
+            u'cat integer, OBJECTID integer, AREA double precision, ...'
             >>> import psycopg2 as pg                         # doctest: +SKIP
             >>> cols_pg = Columns('boundary_municp_pg',
             ...                   pg.connect('host=localhost dbname=grassdb')) # doctest: +SKIP
@@ -287,7 +286,7 @@
             >>> cols_sqlite.types()                       # doctest: +ELLIPSIS
-            [u'INTEGER', u'INTEGER', ...]
+            [u'integer', u'integer', ...]
@@ -336,7 +335,7 @@
             >>> cols_sqlite.items()                       # doctest: +ELLIPSIS
-            [(u'cat', u'INTEGER'), ...]
+            [(u'cat', u'integer'), ...]
@@ -356,7 +355,7 @@
             >>> copy('census','mycensus','vect')
             >>> cols_sqlite = Columns('mycensus',
-            >>> cols_sqlite.add('n_pizza', 'INT')
+            >>> cols_sqlite.add(['n_pizza'], ['INT'])
             >>> 'n_pizza' in cols_sqlite
             True
@@ -376,7 +375,7 @@
                 str_err = "Type is not supported, supported types are: %s"
                 raise TypeError(str_err % ", ".join(valid_type))
-        if isinstance(col_name, str):
+        if isinstance(col_name, unicode):
             check_col(col_type)
         else:
             if len(col_name) == len(col_type):
@@ -406,7 +405,7 @@
             True
             >>> cols_sqlite.rename('n_pizza', 'n_pizzas')  # doctest: +ELLIPSIS
@@ -456,11 +455,11 @@
-            >>> cols_sqlite.add('n_pizzas', 'INT')
+            >>> cols_sqlite.add(['n_pizzas'], ['INT'])
             >>> cols_sqlite.cast('n_pizzas', 'float8')  # doctest: +ELLIPSIS
-            DBError: 'SQLite does not support to cast columns.'
+            DBError: u'SQLite does not support to cast columns.'
@@ -705,7 +704,7 @@
             ...             'sqlite')
             >>> table = link.table()
             >>> table.filters.select('cat', 'TOTAL_POP', 'PERIMETER')
-            Filters('SELECT cat, TOTAL_POP, PERIMETER FROM census;')
+            Filters(u'SELECT cat, TOTAL_POP, PERIMETER FROM census;')
             >>> cur = table.execute()
             >>> cur.fetchone()
             (1, 44, 757.669)
@@ -842,7 +841,7 @@
             link = self.by_name(key)
             table.drop(force=force)
-        if isinstance(key, str):
+        if isinstance(key, unicode):
             key = self.from_name_to_num(key)
         libvect.Vect_map_del_dblink(self.c_mapinfo, key)
@@ -861,7 +860,7 @@
         >>> tab_sqlite = Table(name='census',
         ...                    connection=sqlite3.connect(get_path(path)))
         >>> tab_sqlite.name
-        'census'
+        u'census'
         >>> import psycopg2                                   # doctest: +SKIP
         >>> tab_pg = Table('boundary_municp_pg',
         ...                psycopg2.connect('host=localhost dbname=grassdb',
@@ -903,7 +902,7 @@
             >>> tab_sqlite
-            Table('census')
+            Table(u'census')
@@ -958,7 +957,7 @@
             >>> tab_sqlite.filters.select('cat', 'TOTAL_POP').order_by('AREA')
-            Filters('SELECT cat, TOTAL_POP FROM census ORDER BY AREA;')
+            Filters(u'SELECT cat, TOTAL_POP FROM census ORDER BY AREA;')
             >>> cur = tab_sqlite.execute()
             >>> cur.fetchone()
             (1856, 0)
Modified: grass/trunk/lib/python/pygrass/vector/vector_type.py
--- grass/trunk/lib/python/pygrass/vector/vector_type.py	2014-04-23 14:53:28 UTC (rev 59906)
+++ grass/trunk/lib/python/pygrass/vector/vector_type.py	2014-04-23 16:08:36 UTC (rev 59907)
@@ -6,7 +6,7 @@
-from . import geometry as geo
+from grass.pygrass.vector import geometry as geo
 MAPTYPE = {libvect.GV_FORMAT_NATIVE:     "native",
            libvect.GV_FORMAT_OGR:        "OGR",
