[GRASS-SVN] r59909 - grass/trunk/vector/v.external.out
svn_grass at osgeo.org
Wed Apr 23 11:58:35 PDT 2014
Author: martinl
Date: 2014-04-23 11:58:35 -0700 (Wed, 23 Apr 2014)
New Revision: 59909
grass/trunk/vector/v.external.out/status.c
v.external.out: print dsn for PostgreSQL format
Modified: grass/trunk/vector/v.external.out/status.c
--- grass/trunk/vector/v.external.out/status.c 2014-04-23 17:48:48 UTC (rev 59908)
+++ grass/trunk/vector/v.external.out/status.c 2014-04-23 18:58:35 UTC (rev 59909)
@@ -61,11 +61,16 @@
G_fatal_error(_("OGR format not defined"));
else { /* PG */
+ char dsn_name[GNAME_MAX];
/* conninfo (required) */
p = G_find_key_value("conninfo", key_val);
if (!p)
G_fatal_error(_("PG connection info (conninfo) not defined"));
+ /* print also dsn for compatibility */
+ sprintf(dsn_name, "PG:%s", p);
+ G_set_key_value("dsn", dsn_name, key_val);
/* force format */
print_key_value("format", "PostgreSQL", shell);
