[GRASS-SVN] r59915 - grass/trunk/lib/temporal/SQL
Wed Apr 23 15:14:10 PDT 2014
Author: huhabla
Date: 2014-04-23 15:14:10 -0700 (Wed, 23 Apr 2014)
New Revision: 59915
   grass/trunk/lib/temporal/SQL/stds_map_register_table_template.sql
   grass/trunk/lib/temporal/SQL/update_stds_spatial_temporal_extent_template.sql
   grass/trunk/lib/temporal/SQL/update_str3ds_metadata_template.sql
   grass/trunk/lib/temporal/SQL/update_strds_metadata_template.sql
   grass/trunk/lib/temporal/SQL/update_stvds_metadata_template.sql
Fix for #2264
Modified: grass/trunk/lib/temporal/SQL/stds_map_register_table_template.sql
--- grass/trunk/lib/temporal/SQL/stds_map_register_table_template.sql	2014-04-23 19:45:24 UTC (rev 59914)
+++ grass/trunk/lib/temporal/SQL/stds_map_register_table_template.sql	2014-04-23 22:14:10 UTC (rev 59915)
@@ -11,7 +11,7 @@
 -- GRASS_MAP is a placeholder for specific map type: raster, raster3d or vector
 -- This table stores the.ids of the GRASS_MAP maps registered in the current spacetime GRASS_MAP table
-CREATE TABLE  SPACETIME_NAME_GRASS_MAP_register (
+CREATE TABLE  SPACETIME_REGISTER_TABLE (
   id VARCHAR NOT NULL, -- This colum is a primary key storing the registered GRASS_MAP map.ids
   PRIMARY KEY (id)
Modified: grass/trunk/lib/temporal/SQL/update_stds_spatial_temporal_extent_template.sql
--- grass/trunk/lib/temporal/SQL/update_stds_spatial_temporal_extent_template.sql	2014-04-23 19:45:24 UTC (rev 59914)
+++ grass/trunk/lib/temporal/SQL/update_stds_spatial_temporal_extent_template.sql	2014-04-23 22:14:10 UTC (rev 59915)
@@ -7,7 +7,7 @@
 -- Author: Soeren Gebbert soerengebbert <at> googlemail <dot> com
--- SPACETIME_NAME is a placeholder for specific stds name (SQL compliant): name_mapset
+-- SPACETIME_REGISTER_TABLE is a placeholder for specific stds map register table name (SQL compliant)
 -- SPACETIME_ID is a placeholder for specific stds id: name at mapset
 -- STDS is a placeholder for specific space-time dataset type: strds, str3ds, stvds
@@ -16,52 +16,52 @@
 -- UPDATE STDS_base SET revision = (revision + 1) WHERE id = 'SPACETIME_ID';
 -- Number of registered maps
 UPDATE STDS_metadata SET number_of_maps =
-       (SELECT count(id) FROM SPACETIME_NAME_GRASS_MAP_register)
+       (SELECT count(id) FROM SPACETIME_REGISTER_TABLE)
 -- Update the temporal extent
 UPDATE STDS_absolute_time SET start_time =
        (SELECT min(start_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
-    		(SELECT id FROM SPACETIME_NAME_GRASS_MAP_register)
+    		(SELECT id FROM SPACETIME_REGISTER_TABLE)
 UPDATE STDS_absolute_time SET end_time =
        (SELECT max(end_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
 UPDATE STDS_relative_time SET start_time =
        (SELECT min(start_time) FROM GRASS_MAP_relative_time WHERE GRASS_MAP_relative_time.id IN
 UPDATE STDS_relative_time SET end_time =
        (SELECT max(end_time) FROM GRASS_MAP_relative_time WHERE GRASS_MAP_relative_time.id IN
 -- Update the spatial extent
 UPDATE STDS_spatial_extent SET north =
        (SELECT max(north) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
 UPDATE STDS_spatial_extent SET south =
        (SELECT min(south) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
 UPDATE STDS_spatial_extent SET east =
        (SELECT max(east) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
 UPDATE STDS_spatial_extent SET west =
        (SELECT min(west) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
 UPDATE STDS_spatial_extent SET top =
        (SELECT max(top) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
 UPDATE STDS_spatial_extent SET bottom =
        (SELECT min(bottom) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
 UPDATE STDS_spatial_extent SET proj =
        (SELECT min(proj) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
Modified: grass/trunk/lib/temporal/SQL/update_str3ds_metadata_template.sql
--- grass/trunk/lib/temporal/SQL/update_str3ds_metadata_template.sql	2014-04-23 19:45:24 UTC (rev 59914)
+++ grass/trunk/lib/temporal/SQL/update_str3ds_metadata_template.sql	2014-04-23 22:14:10 UTC (rev 59915)
@@ -4,49 +4,49 @@
 -- Update the min and max values
 UPDATE str3ds_metadata SET min_min =
        (SELECT min(min) FROM raster3d_metadata WHERE raster3d_metadata.id IN
-    		(SELECT id FROM SPACETIME_NAME_raster3d_register)
 UPDATE str3ds_metadata SET min_max =
        (SELECT max(min) FROM raster3d_metadata WHERE raster3d_metadata.id IN
 UPDATE str3ds_metadata SET max_min =
        (SELECT min(max) FROM raster3d_metadata WHERE raster3d_metadata.id IN
 UPDATE str3ds_metadata SET max_max =
        (SELECT max(max) FROM raster3d_metadata WHERE raster3d_metadata.id IN
 -- Update the resolution
 UPDATE str3ds_metadata SET nsres_min =
        (SELECT min(nsres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
 UPDATE str3ds_metadata SET nsres_max =
        (SELECT max(nsres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
 UPDATE str3ds_metadata SET ewres_min =
        (SELECT min(ewres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
 UPDATE str3ds_metadata SET ewres_max =
        (SELECT max(ewres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
 UPDATE str3ds_metadata SET tbres_min =
        (SELECT min(tbres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
 UPDATE str3ds_metadata SET tbres_max =
        (SELECT max(tbres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
Modified: grass/trunk/lib/temporal/SQL/update_strds_metadata_template.sql
--- grass/trunk/lib/temporal/SQL/update_strds_metadata_template.sql	2014-04-23 19:45:24 UTC (rev 59914)
+++ grass/trunk/lib/temporal/SQL/update_strds_metadata_template.sql	2014-04-23 22:14:10 UTC (rev 59915)
@@ -4,40 +4,40 @@
 UPDATE strds_metadata SET min_min =
        (SELECT min(min) FROM raster_metadata WHERE raster_metadata.id IN
-    		(SELECT id FROM SPACETIME_NAME_raster_register)
 UPDATE strds_metadata SET min_max =
        (SELECT max(min) FROM raster_metadata WHERE raster_metadata.id IN
 UPDATE strds_metadata SET max_min =
        (SELECT min(max) FROM raster_metadata WHERE raster_metadata.id IN
 UPDATE strds_metadata SET max_max =
        (SELECT max(max) FROM raster_metadata WHERE raster_metadata.id IN
 UPDATE strds_metadata SET nsres_min =
        (SELECT min(nsres) FROM raster_metadata WHERE raster_metadata.id IN
 UPDATE strds_metadata SET nsres_max =
        (SELECT max(nsres) FROM raster_metadata WHERE raster_metadata.id IN
 UPDATE strds_metadata SET ewres_min =
        (SELECT min(ewres) FROM raster_metadata WHERE raster_metadata.id IN
 UPDATE strds_metadata SET ewres_max =
        (SELECT max(ewres) FROM raster_metadata WHERE raster_metadata.id IN
Modified: grass/trunk/lib/temporal/SQL/update_stvds_metadata_template.sql
--- grass/trunk/lib/temporal/SQL/update_stvds_metadata_template.sql	2014-04-23 19:45:24 UTC (rev 59914)
+++ grass/trunk/lib/temporal/SQL/update_stvds_metadata_template.sql	2014-04-23 22:14:10 UTC (rev 59915)
@@ -5,55 +5,55 @@
 -- Update the vector features and topology
 UPDATE stvds_metadata SET points =
        (SELECT sum(points) FROM vector_metadata WHERE vector_metadata.id IN
-    		(SELECT id FROM SPACETIME_NAME_vector_register)
 UPDATE stvds_metadata SET lines =
        (SELECT sum(lines) FROM vector_metadata WHERE vector_metadata.id IN
 UPDATE stvds_metadata SET boundaries =
        (SELECT sum(boundaries) FROM vector_metadata WHERE vector_metadata.id IN
 UPDATE stvds_metadata SET centroids =
        (SELECT sum(centroids) FROM vector_metadata WHERE vector_metadata.id IN
 UPDATE stvds_metadata SET faces =
        (SELECT sum(faces) FROM vector_metadata WHERE vector_metadata.id IN
 UPDATE stvds_metadata SET kernels =
        (SELECT sum(kernels) FROM vector_metadata WHERE vector_metadata.id IN
 UPDATE stvds_metadata SET primitives =
        (SELECT sum(primitives) FROM vector_metadata WHERE vector_metadata.id IN
 UPDATE stvds_metadata SET nodes =
        (SELECT sum(nodes) FROM vector_metadata WHERE vector_metadata.id IN
 UPDATE stvds_metadata SET areas =
        (SELECT sum(areas) FROM vector_metadata WHERE vector_metadata.id IN
 UPDATE stvds_metadata SET islands =
        (SELECT sum(islands) FROM vector_metadata WHERE vector_metadata.id IN
 UPDATE stvds_metadata SET holes =
        (SELECT sum(holes) FROM vector_metadata WHERE vector_metadata.id IN
 UPDATE stvds_metadata SET volumes =
        (SELECT sum(volumes) FROM vector_metadata WHERE vector_metadata.id IN
-       ) WHERE id = 'SPACETIME_ID';
\ No newline at end of file
+       ) WHERE id = 'SPACETIME_ID';
