[GRASS-SVN] r59926 - in grass/branches/releasebranch_7_0/raster: r.rescale r.rescale.eq
svn_grass at osgeo.org
Thu Apr 24 04:25:20 PDT 2014
Author: martinl
Date: 2014-04-24 04:25:20 -0700 (Thu, 24 Apr 2014)
New Revision: 59926
grass/branches/releasebranch_7_0/raster/r.rescale.eq/main.c
grass/branches/releasebranch_7_0/raster/r.rescale/main.c
Use the standard options (by hcho)
(merge r59917 from trunk)
Modified: grass/branches/releasebranch_7_0/raster/r.rescale/main.c
--- grass/branches/releasebranch_7_0/raster/r.rescale/main.c 2014-04-24 11:24:26 UTC (rev 59925)
+++ grass/branches/releasebranch_7_0/raster/r.rescale/main.c 2014-04-24 11:25:20 UTC (rev 59926)
@@ -52,11 +52,7 @@
/* Define the different options */
- parm.input = G_define_option();
- parm.input->key = "input";
- parm.input->type = TYPE_STRING;
- parm.input->required = YES;
- parm.input->gisprompt = "old,cell,raster";
+ parm.input = G_define_standard_option(G_OPT_R_INPUT);
parm.input->description = _("The name of the raster map to be rescaled");
parm.from = G_define_option();
@@ -67,11 +63,7 @@
parm.from->description =
_("The input data range to be rescaled (default: full range of input map)");
- parm.output = G_define_option();
- parm.output->key = "output";
- parm.output->type = TYPE_STRING;
- parm.output->required = YES;
- parm.output->gisprompt = "new,cell,raster";
+ parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
parm.output->description = _("The resulting raster map name");
parm.to = G_define_option();
Modified: grass/branches/releasebranch_7_0/raster/r.rescale.eq/main.c
--- grass/branches/releasebranch_7_0/raster/r.rescale.eq/main.c 2014-04-24 11:24:26 UTC (rev 59925)
+++ grass/branches/releasebranch_7_0/raster/r.rescale.eq/main.c 2014-04-24 11:25:20 UTC (rev 59926)
@@ -57,11 +57,7 @@
@@ -72,11 +68,7 @@
