[GRASS-SVN] r59939 - grass-addons/grass6/raster/r.roughness
Thu Apr 24 14:58:28 PDT 2014
Author: neteler
Date: 2014-04-24 14:58:27 -0700 (Thu, 24 Apr 2014)
New Revision: 59939
Added:
   grass-addons/grass6/raster/r.roughness/r.roughness.window.area.sh
   grass-addons/grass6/raster/r.roughness/r.roughness.window.vector.sh
Removed:
   grass-addons/grass6/raster/r.roughness/Makefile
   grass-addons/grass6/raster/r.roughness/r.roughness.sh
r.roughness.window.vector: installation fix
Modified: grass-addons/grass6/raster/r.roughness/Makefile
--- grass-addons/grass6/raster/r.roughness/Makefile	2014-04-24 14:11:03 UTC (rev 59938)
+++ grass-addons/grass6/raster/r.roughness/Makefile	2014-04-24 21:58:27 UTC (rev 59939)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM=r.roughness.window.vector
+PGM=r.roughness.window.vector.sh
 include $(MODULE_TOPDIR)/include/Make/Script.make
Modified: grass-addons/grass6/raster/r.roughness/r.roughness.sh
--- grass-addons/grass6/raster/r.roughness/r.roughness.sh	2014-04-24 14:11:03 UTC (rev 59938)
+++ grass-addons/grass6/raster/r.roughness/r.roughness.sh	2014-04-24 21:58:27 UTC (rev 59939)
@@ -2,7 +2,7 @@
-# MODULE:	r.roughness
+# MODULE:	r.roughness.sh
 # AUTHOR(S):	Carlos H. Grohmann <carlos dot grohmann at gmail dot com >
 # PURPOSE:	Calculates surface roughness from DEMs. (uses r.surf.area)
 #		In this script surface roughness is used in the sense of
@@ -38,7 +38,7 @@
 #% key: map
 #% gisprompt: old,cell,raster
 #% type: string
-#% description: Input raster surface
+#% description: Input raster elevation map
 #% required : yes
 #%end
 #%option
@@ -85,7 +85,6 @@
     export CMDLINE
     exec g.parser "$0" "$@"
 fi
 PROG=`basename $0`
@@ -252,5 +251,6 @@
 else
     echo "Surface roughness map created and named [$ROUGHNESS]. Consider renaming."
 fi
 echo "Done."
 exit 0
Deleted: grass-addons/grass6/raster/r.roughness/r.roughness.window.area
--- grass-addons/grass6/raster/r.roughness/r.roughness.window.area	2014-04-24 14:11:03 UTC (rev 59938)
+++ grass-addons/grass6/raster/r.roughness/r.roughness.window.area	2014-04-24 21:58:27 UTC (rev 59939)
@@ -1,186 +0,0 @@
-#!/bin/sh
-# AUTHOR(S):	Carlos H. Grohmann <carlos dot grohmann at gmail dot com >
-# PURPOSE:	Calculates surface roughness from DEMs. (uses r.surf.area)
-#		In this script surface roughness is used in the sense of
-#		Hobson (1972), who describes it as the ratio between surface
-#		(real) area and flat (plan) area of square cells; in this
-#		approach, flat surfaces would present values close to 1,
-#		whilst in irregular ones the ratio shows a curvilinear
-#		relationship which asymptotically approaches infinity as the
-#		real areas increases.
-#		Reference:
-#		Hobson, R.D., 1972. Surface roughness in topography:
-#		quantitative approach. In: Chorley, R.J. (ed) Spatial
-#		analysis in geomorphology. Methuer, London, p.225-245.
-#		This script will create a map of surface area for each pixel
-#		using slope and trigonometry. A map of plan area is create as
-#		ns_res*ew_res. Using the specified moving window size, maps of
-#		the sum of areas are created, and then the ratio is calculated
-#		with r.mapcalc.
-#		If the user does not specify the output map name, it will be
-#		set to INPUT_MAP_roughness_NxN
-#		where N is the window size.
-# COPYRIGHT:	(C) 2007 by the GRASS Development Team
-#		This program is free software under the GNU General Public
-#		License (>=v2). Read the file COPYING that comes with GRASS
-#		for details.
-#%Module
-#% description: Calculates surface roughness with a moving-window approach
-#%End
-#%option
-#% key: map
-#% gisprompt: old,cell,raster
-#% type: string
-#% description: Input raster elevation map
-#% required : yes
-#%end
-#%option
-#% key: slope
-#% type: string
-#% description: Input raster slope map
-#% required : yes
-#%end
-#%option
-#% key: window
-#% type: integer
-#% description: Window size (3,5,7,...,25)
-#% required : no
-#% answer : 3
-#%end
-#%option
-#% key: rough
-#% type: string
-#% description: Output raster map
-#% required : no
-#%end
-if test "$GISBASE" = ""; then
- echo "You must be in GRASS GIS to run this program." >&2
- exit 1
-fi
-# save command line
-if [ "$1" != "@ARGS_PARSED@" ] ; then
-    CMDLINE="`basename $0`"
-    for arg in "$@" ; do
-        CMDLINE="$CMDLINE \"$arg\""
-    done
-    export CMDLINE
-    exec g.parser "$0" "$@"
-fi
-PROG=`basename $0`
-# setting environment, so that awk works properly in all languages
-unset LC_ALL
-LC_NUMERIC=C
-export LC_NUMERIC
-eval `g.gisenv`
-: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
-LOCATION=$GISDBASE/$LOCATION_NAME/$MAPSET
-program=`basename $0`
-map=$GIS_OPT_MAP
-slope=$GIS_OPT_SLOPE
-window=$GIS_OPT_WINDOW
-#check if input file exists
-eval `g.findfile element=cell file=$map`
-if [ -z "$name" ] ; then
-   g.message -e  "Map <$map> not found! Aborting."
-   exit 1
-fi
-eval `g.findfile element=cell file=$slope`
-   g.message -e  "Map <$slope> not found! Aborting."
-   exit 1
-fi
-if [ "$GIS_OPT_MAP" = "$GIS_OPT_ROUGH" ]; then
-	echo ""
-	echo "Input elevation map and output roughness map must have different names"
-	exit 1
-fi
-if [ -z "$GIS_OPT_ROUGH" ]; then
-    ROUGHNESS="${map%%@*}_area_ratio_${window}x${window}"
-else
-    ROUGHNESS="$GIS_OPT_ROUGH"
-fi
-# what to do in case of user break:
-exitprocedure()
- g.message -e 'User break!'
- #delete any TMP files:
- g.remove rast=$TMP1,$TMP2,$TMP3,$TMP4 > /dev/null
-# shell check for user break (signal list: trap -l)
-trap "exitprocedure" 2 3 15
-# get region resolution
-nsres="`g.region -p | grep nsres | sed -e s/.*:\ *//`"
-ewres="`g.region -p | grep ewres | sed -e s/.*:\ *//`"
-#make temp rasters:
-TMP1=surfarea_$$
-TMP2=planarea_$$
-TMP3=sum_surfarea_$$
-TMP4=sum_planarea_$$
-r.mapcalc $TMP1 = "$nsres*($nsres/cos($slope))"
-r.mapcalc $TMP2 = "$nsres*$ewres"
-r.neighbors -a input=$TMP1 output=$TMP3 method=sum size=$window
-r.neighbors -a input=$TMP2 output=$TMP4 method=sum size=$window
-r.mapcalc $ROUGHNESS = "$TMP3 / $TMP4"
-r.colors "$ROUGHNESS" color=rainbow
-# record metadata
-r.support "$ROUGHNESS" title="Relief roughness of \"$GIS_OPT_MAP\"" history=""
-r.support "$ROUGHNESS" history="grid size: $grid"
-#cleanup
-g.remove rast=$TMP1,$TMP2,$TMP3,$TMP4 > /dev/null
-echo ""
-if [ -n "$GIS_OPT_ROUGH" ] ; then
-    echo "Surface roughness map created and named [$ROUGHNESS]."
-else
-    echo "Surface roughness map created and named [$ROUGHNESS]. Consider renaming."
-fi
-echo "Done."
-exit 0
Copied: grass-addons/grass6/raster/r.roughness/r.roughness.window.area.sh (from rev 59870, grass-addons/grass6/raster/r.roughness/r.roughness.window.area)
--- grass-addons/grass6/raster/r.roughness/r.roughness.window.area.sh	                        (rev 0)
+++ grass-addons/grass6/raster/r.roughness/r.roughness.window.area.sh	2014-04-24 21:58:27 UTC (rev 59939)
@@ -0,0 +1,187 @@
+#!/bin/sh
+# MODULE:	roughness.window.area.sh
+# AUTHOR(S):	Carlos H. Grohmann <carlos dot grohmann at gmail dot com >
+# PURPOSE:	Calculates surface roughness from DEMs. (uses r.surf.area)
+#		In this script surface roughness is used in the sense of
+#		Hobson (1972), who describes it as the ratio between surface
+#		(real) area and flat (plan) area of square cells; in this
+#		approach, flat surfaces would present values close to 1,
+#		whilst in irregular ones the ratio shows a curvilinear
+#		relationship which asymptotically approaches infinity as the
+#		real areas increases.
+#		Reference:
+#		Hobson, R.D., 1972. Surface roughness in topography:
+#		quantitative approach. In: Chorley, R.J. (ed) Spatial
+#		analysis in geomorphology. Methuer, London, p.225-245.
+#		This script will create a map of surface area for each pixel
+#		using slope and trigonometry. A map of plan area is create as
+#		ns_res*ew_res. Using the specified moving window size, maps of
+#		the sum of areas are created, and then the ratio is calculated
+#		with r.mapcalc.
+#		If the user does not specify the output map name, it will be
+#		set to INPUT_MAP_roughness_NxN
+#		where N is the window size.
+# COPYRIGHT:	(C) 2007 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+#%Module
+#% description: Calculates surface roughness with a moving-window approach
+#%End
+#%option
+#% key: map
+#% gisprompt: old,cell,raster
+#% type: string
+#% required : yes
+#%end
+#%option
+#% key: slope
+#% type: string
+#% description: Input raster slope map
+#% required : yes
+#%end
+#%option
+#% key: window
+#% type: integer
+#% description: Window size (3,5,7,...,25)
+#% required : no
+#% answer : 3
+#%end
+#%option
+#% key: rough
+#% type: string
+#% description: Output raster map
+#% required : no
+#%end
+if test "$GISBASE" = ""; then
+ echo "You must be in GRASS GIS to run this program." >&2
+ exit 1
+fi
+# save command line
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+    CMDLINE="`basename $0`"
+    for arg in "$@" ; do
+        CMDLINE="$CMDLINE \"$arg\""
+    done
+    export CMDLINE
+    exec g.parser "$0" "$@"
+fi
+PROG=`basename $0`
+# setting environment, so that awk works properly in all languages
+unset LC_ALL
+LC_NUMERIC=C
+export LC_NUMERIC
+eval `g.gisenv`
+: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
+LOCATION=$GISDBASE/$LOCATION_NAME/$MAPSET
+program=`basename $0`
+map=$GIS_OPT_MAP
+slope=$GIS_OPT_SLOPE
+window=$GIS_OPT_WINDOW
+#check if input file exists
+eval `g.findfile element=cell file=$map`
+if [ -z "$name" ] ; then
+   g.message -e  "Map <$map> not found! Aborting."
+   exit 1
+fi
+eval `g.findfile element=cell file=$slope`
+   g.message -e  "Map <$slope> not found! Aborting."
+   exit 1
+fi
+if [ "$GIS_OPT_MAP" = "$GIS_OPT_ROUGH" ]; then
+	echo ""
+	echo "Input elevation map and output roughness map must have different names"
+	exit 1
+fi
+if [ -z "$GIS_OPT_ROUGH" ]; then
+    ROUGHNESS="${map%%@*}_area_ratio_${window}x${window}"
+else
+    ROUGHNESS="$GIS_OPT_ROUGH"
+fi
+# what to do in case of user break:
+exitprocedure()
+ g.message -e 'User break!'
+ #delete any TMP files:
+ g.remove rast=$TMP1,$TMP2,$TMP3,$TMP4 > /dev/null
+# shell check for user break (signal list: trap -l)
+trap "exitprocedure" 2 3 15
+# get region resolution
+nsres="`g.region -p | grep nsres | sed -e s/.*:\ *//`"
+ewres="`g.region -p | grep ewres | sed -e s/.*:\ *//`"
+#make temp rasters:
+TMP1=surfarea_$$
+TMP2=planarea_$$
+TMP3=sum_surfarea_$$
+TMP4=sum_planarea_$$
+r.mapcalc $TMP1 = "$nsres*($nsres/cos($slope))"
+r.mapcalc $TMP2 = "$nsres*$ewres"
+r.neighbors -a input=$TMP1 output=$TMP3 method=sum size=$window
+r.neighbors -a input=$TMP2 output=$TMP4 method=sum size=$window
+r.mapcalc $ROUGHNESS = "$TMP3 / $TMP4"
+r.colors "$ROUGHNESS" color=rainbow
+# record metadata
+r.support "$ROUGHNESS" title="Relief roughness of \"$GIS_OPT_MAP\"" history=""
+r.support "$ROUGHNESS" history="grid size: $grid"
+#cleanup
+g.remove rast=$TMP1,$TMP2,$TMP3,$TMP4 > /dev/null
+echo ""
+if [ -n "$GIS_OPT_ROUGH" ] ; then
+    echo "Surface roughness map created and named [$ROUGHNESS]."
+else
+    echo "Surface roughness map created and named [$ROUGHNESS]. Consider renaming."
+fi
+echo "Done."
+exit 0
Deleted: grass-addons/grass6/raster/r.roughness/r.roughness.window.vector
--- grass-addons/grass6/raster/r.roughness/r.roughness.window.vector	2014-04-24 14:11:03 UTC (rev 59938)
+++ grass-addons/grass6/raster/r.roughness/r.roughness.window.vector	2014-04-24 21:58:27 UTC (rev 59939)
@@ -1,308 +0,0 @@
-#!/bin/sh
-#		In this script surface roughness is taken as the dispersion
-#		of vectors normal to surface areas (pixels). Normal vectors
-#		are defined by slope and aspect.
-#		Reference:
-#		This script will create several temporary maps, for the
-#		directional cosines in each direction (x,y,z), for the sum
-#		of these cosines and vector strengh.
-#		set to INPUT_MAP_roughness_vector_NxN
-#		for details.
-#%Module
-#%End
-#%option
-#% key: map
-#% type: string
-#% required : yes
-#%end
-#%option
-#% key: slope
-#% type: string
-#% required : yes
-#%end
-#%option
-#% key: aspect
-#% type: string
-#% description: Input raster aspect map
-#% required : yes
-#%end
-#%option
-#% key: window
-#% type: integer
-#% required : no
-#% answer : 3
-#%end
-#%option
-#% key: strength
-#% type: string
-#% description: Output vector strength map
-#% required : no
-#%end
-#%option
-#% key: fisher
-#% type: string
-#% description: Output Fischer's K parameter map
-#% required : no
-#%end
-#%option
-#% key: compass
-#% type: string
-#% description: OPTIONAL: Compass aspect values (longitude)
-#% required : no
-#%end
-#%option
-#% key: colatitude
-#% type: string
-#% description: OPTIONAL: Colatitude values (90 - slope)
-#% required : no
-#%end
-#%option
-#% key: xcos
-#% type: string
-#% description: OPTIONAL: X directional cosine map
-#% required : no
-#%end
-#%option
-#% key: ycos
-#% type: string
-#% description: OPTIONAL: Y directional cosine map
-#% required : no
-#%end
-#%option
-#% key: zcos
-#% type: string
-#% description: OPTIONAL: Z directional cosine map
-#% required : no
-#%end
- exit 1
-fi
-    done
-    export CMDLINE
-fi
-PROG=`basename $0`
-unset LC_ALL
-LC_NUMERIC=C
-export LC_NUMERIC
-eval `g.gisenv`
-map=$GIS_OPT_MAP
-aspect=$GIS_OPT_ASPECT
-   exit 1
-fi
-   exit 1
-fi
-eval `g.findfile element=cell file=$aspect`
-   g.message -e  "Map <$aspect> not found! Aborting."
-   exit 1
-fi
-if [ -z "$GIS_OPT_STRENGTH" ]; then
-    STRENGTH="${map%%@*}_vector_strength_${window}x${window}"
-else
-    STRENGTH="$GIS_OPT_STRENGTH"
-fi
-if [ -z "$GIS_OPT_FISHER" ]; then
-    FISHER="${map%%@*}_fisher_K_${window}x${window}"
-else
-    FISHER="$GIS_OPT_FISHER"
-fi
-exitprocedure()
- g.remove rast=$TMP1,$TMP3,$TMP4,$TMP5,$TMP6,$TMP7,$TMP8 > /dev/null
-#some temp rasters:
-TMP6=sum_dir_cosine_x_$$
-TMP7=sum_dir_cosine_y_$$
-TMP8=sum_dir_cosine_z_$$
-#correct aspect angles from cartesian (GRASS default) to compass angles
-#   if(A==0,0,if(A < 90, 90-A, 360+90-A))
-if [ -z "$GIS_OPT_COMPASS" ]; then
-    echo "Calculating compass aspect values (longitude)"
-    TMP1=aspect_compass_$$
-    r.mapcalc $TMP1 = "if($aspect==0,0,if($aspect < 90, 90-$aspect, 360+90-$aspect))"
-else
-    echo "Using previous calculated compass aspect values (longitude)"
-    TMP1="$GIS_OPT_COMPASS"
-fi
-#Calculates colatitude (90-slope)
-if [ -z "$GIS_OPT_COLATITUDE" ]; then
-   echo "Calculating colatitude (90-slope)"
-   TMP2=normal_angle_$$
-   r.mapcalc $TMP2 = "90 - $slope"
-else
-    echo "Using previous calculated colatitude values"
-    TMP2="$GIS_OPT_COLATITUDE"
-fi
-#direction cosines relative to axis oriented north, east and up
-#direction cosine calculation according to McKean & Roering (2004), Geomorphology, 57:331-351.
-if [ -z "$GIS_OPT_XCOS" ]; then
-echo "Calculating X direction cosine"
-    TMP3=dir_cosine_x_$$
-    r.mapcalc $TMP3 = "sin($TMP2)*cos($TMP1)"
-else
-    echo "Using previous calculated X directional cosine values"
-    TMP3="$GIS_OPT_XCOS"
-fi
-if [ -z "$GIS_OPT_YCOS" ]; then
-echo "Calculating Y direction cosine"
-    TMP4=dir_cosine_y_$$
-    r.mapcalc $TMP4 = "sin($TMP2)*sin($TMP1)"
-else
-    echo "Using previous calculated Y directional cosine values"
-    TMP4="$GIS_OPT_YCOS"
-fi
-if [ -z "$GIS_OPT_ZCOS" ]; then
-echo "Calculating Z direction cosine"
-    TMP5=dir_cosine_z_$$
-    r.mapcalc $TMP5 = "cos($TMP2)"
-else
-    echo "Using previous calculated Z directional cosine values"
-    TMP5="$GIS_OPT_ZCOS"
-fi
-echo "Calculating sum of X direction cosines"
-r.neighbors input=$TMP3 output=$TMP6 method=sum size=$window --overwrite
-echo "Calculating sum of Y direction cosines"
-r.neighbors input=$TMP4 output=$TMP7 method=sum size=$window --overwrite
-echo "Calculating sum of Z direction cosines"
-r.neighbors input=$TMP5 output=$TMP8 method=sum size=$window --overwrite
-echo "Calculating vector strength"
-r.mapcalc $STRENGTH = "sqrt(exp($TMP6,2) + exp($TMP7,2) + exp($TMP8,2))"
-echo "Calculating Inverted Fisher's K parameter"
-# k=1/((N-1)/(N-R))
-r.mapcalc $FISHER = "($window * $window - $STRENGTH) / ($window * $window - 1)"
-#cleanup
-g.remove rast=$TMP6,$TMP7,$TMP8 > /dev/null
-g.remove rast=$TMP1 > /dev/null
-fi
-g.remove rast=$TMP2 > /dev/null
-fi
-g.remove rast=$TMP3 > /dev/null
-fi
-g.remove rast=$TMP4 > /dev/null
-fi
-g.remove rast=$TMP5 > /dev/null
-fi
-echo ""
-if [ -n "$GIS_OPT_STRENGTH" ] ; then
-    echo "Surface roughness map created and named [$STRENGTH]."
-else
-    echo "Surface roughness map created and named [$STRENGTH]. Consider renaming."
-fi
-echo ""
-if [ -n "$GIS_OPT_FISHER" ] ; then
-    echo "Surface roughness map created and named [$FISHER]."
-else
-    echo "Surface roughness map created and named [$FISHER]. Consider renaming."
-fi
-echo "Done."
-exit 0
Copied: grass-addons/grass6/raster/r.roughness/r.roughness.window.vector.sh (from rev 59870, grass-addons/grass6/raster/r.roughness/r.roughness.window.vector)
--- grass-addons/grass6/raster/r.roughness/r.roughness.window.vector.sh	                        (rev 0)
+++ grass-addons/grass6/raster/r.roughness/r.roughness.window.vector.sh	2014-04-24 21:58:27 UTC (rev 59939)
@@ -0,0 +1,305 @@
+#!/bin/sh
+# MODULE:	r.roughness.window.vector.sh
+#		In this script surface roughness is taken as the dispersion
+#		of vectors normal to surface areas (pixels). Normal vectors
+#		are defined by slope and aspect.
+#		Reference:
+#		This script will create several temporary maps, for the
+#		directional cosines in each direction (x,y,z), for the sum
+#		of these cosines and vector strengh.
+#		set to INPUT_MAP_roughness_vector_NxN
+#		for details.
+#%Module
+#%End
+#%option
+#% key: map
+#% type: string
+#% required : yes
+#%end
+#%option
+#% key: slope
+#% type: string
+#% required : yes
+#%end
+#%option
+#% key: aspect
+#% type: string
+#% description: Input raster aspect map
+#% required : yes
+#%end
+#%option
+#% key: window
+#% type: integer
+#% required : no
+#% answer : 3
+#%end
+#%option
+#% key: strength
+#% type: string
+#% description: Output vector strength map
+#% required : no
+#%end
+#%option
+#% key: fisher
+#% type: string
+#% description: Output Fischer's K parameter map
+#% required : no
+#%end
+#%option
+#% key: compass
+#% type: string
+#% description: OPTIONAL: Compass aspect values (longitude)
+#% required : no
+#%end
+#%option
+#% key: colatitude
+#% type: string
+#% description: OPTIONAL: Colatitude values (90 - slope)
+#% required : no
+#%end
+#%option
+#% key: xcos
+#% type: string
+#% description: OPTIONAL: X directional cosine map
+#% required : no
+#%end
+#%option
+#% key: ycos
+#% type: string
+#% description: OPTIONAL: Y directional cosine map
+#% required : no
+#%end
+#%option
+#% key: zcos
+#% type: string
+#% description: OPTIONAL: Z directional cosine map
+#% required : no
+#%end
+ exit 1
+fi
+    done
+    export CMDLINE
+fi
+PROG=`basename $0`
+unset LC_ALL
+LC_NUMERIC=C
+export LC_NUMERIC
+eval `g.gisenv`
+map=$GIS_OPT_MAP
+aspect=$GIS_OPT_ASPECT
+   exit 1
+fi
+   exit 1
+fi
+eval `g.findfile element=cell file=$aspect`
+   g.message -e  "Map <$aspect> not found! Aborting."
+   exit 1
+fi
+if [ -z "$GIS_OPT_STRENGTH" ]; then
+    STRENGTH="${map%%@*}_vector_strength_${window}x${window}"
+else
+    STRENGTH="$GIS_OPT_STRENGTH"
+fi
+if [ -z "$GIS_OPT_FISHER" ]; then
+    FISHER="${map%%@*}_fisher_K_${window}x${window}"
+else
+    FISHER="$GIS_OPT_FISHER"
+fi
+exitprocedure()
+ g.remove rast=$TMP1,$TMP3,$TMP4,$TMP5,$TMP6,$TMP7,$TMP8 > /dev/null
+#some temp rasters:
+TMP6=sum_dir_cosine_x_$$
+TMP7=sum_dir_cosine_y_$$
+TMP8=sum_dir_cosine_z_$$
+#correct aspect angles from cartesian (GRASS default) to compass angles
+#   if(A==0,0,if(A < 90, 90-A, 360+90-A))
+if [ -z "$GIS_OPT_COMPASS" ]; then
+    echo "Calculating compass aspect values (longitude)"
+    TMP1=aspect_compass_$$
+    r.mapcalc $TMP1 = "if($aspect==0,0,if($aspect < 90, 90-$aspect, 360+90-$aspect))"
+else
+    echo "Using previous calculated compass aspect values (longitude)"
+    TMP1="$GIS_OPT_COMPASS"
+fi
+#Calculates colatitude (90-slope)
+if [ -z "$GIS_OPT_COLATITUDE" ]; then
+   echo "Calculating colatitude (90-slope)"
+   TMP2=normal_angle_$$
+   r.mapcalc $TMP2 = "90 - $slope"
+else
+    echo "Using previous calculated colatitude values"
+    TMP2="$GIS_OPT_COLATITUDE"
+fi
+#direction cosines relative to axis oriented north, east and up
+#direction cosine calculation according to McKean & Roering (2004), Geomorphology, 57:331-351.
+if [ -z "$GIS_OPT_XCOS" ]; then
+echo "Calculating X direction cosine"
+    TMP3=dir_cosine_x_$$
+    r.mapcalc $TMP3 = "sin($TMP2)*cos($TMP1)"
+else
+    echo "Using previous calculated X directional cosine values"
+    TMP3="$GIS_OPT_XCOS"
+fi
+if [ -z "$GIS_OPT_YCOS" ]; then
+echo "Calculating Y direction cosine"
+    TMP4=dir_cosine_y_$$
+    r.mapcalc $TMP4 = "sin($TMP2)*sin($TMP1)"
+else
+    echo "Using previous calculated Y directional cosine values"
+    TMP4="$GIS_OPT_YCOS"
+fi
+if [ -z "$GIS_OPT_ZCOS" ]; then
+echo "Calculating Z direction cosine"
+    TMP5=dir_cosine_z_$$
+    r.mapcalc $TMP5 = "cos($TMP2)"
+else
+    echo "Using previous calculated Z directional cosine values"
+    TMP5="$GIS_OPT_ZCOS"
+fi
+echo "Calculating sum of X direction cosines"
+r.neighbors input=$TMP3 output=$TMP6 method=sum size=$window --overwrite
+echo "Calculating sum of Y direction cosines"
+r.neighbors input=$TMP4 output=$TMP7 method=sum size=$window --overwrite
+echo "Calculating sum of Z direction cosines"
+r.neighbors input=$TMP5 output=$TMP8 method=sum size=$window --overwrite
+echo "Calculating vector strength"
+r.mapcalc $STRENGTH = "sqrt(exp($TMP6,2) + exp($TMP7,2) + exp($TMP8,2))"
+echo "Calculating Inverted Fisher's K parameter"
+# k=1/((N-1)/(N-R))
+r.mapcalc $FISHER = "($window * $window - $STRENGTH) / ($window * $window - 1)"
+#cleanup
+g.remove rast=$TMP6,$TMP7,$TMP8 > /dev/null
+g.remove rast=$TMP1 > /dev/null
+fi
+g.remove rast=$TMP2 > /dev/null
+fi
+g.remove rast=$TMP3 > /dev/null
+fi
+g.remove rast=$TMP4 > /dev/null
+fi
+g.remove rast=$TMP5 > /dev/null
+fi
+echo ""
+if [ -n "$GIS_OPT_STRENGTH" ] ; then
+    echo "Surface roughness map created and named [$STRENGTH]."
+else
+    echo "Surface roughness map created and named [$STRENGTH]. Consider renaming."
+fi
+echo ""
+if [ -n "$GIS_OPT_FISHER" ] ; then
+    echo "Surface roughness map created and named [$FISHER]."
+else
+    echo "Surface roughness map created and named [$FISHER]. Consider renaming."
+fi
+echo "Done."
+exit 0
