[GRASS-SVN] r59942 - grass/branches/releasebranch_7_0/gui/wxpython/modules
svn_grass at osgeo.org
Fri Apr 25 06:03:15 PDT 2014
Author: martinl
Date: 2014-04-25 06:03:15 -0700 (Fri, 25 Apr 2014)
New Revision: 59942
grass/branches/releasebranch_7_0/gui/wxpython/modules/mcalc_builder.py
wxGUI/map_calc: fix selection
(merge r59941 from trunk)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/modules/mcalc_builder.py
--- grass/branches/releasebranch_7_0/gui/wxpython/modules/mcalc_builder.py 2014-04-25 13:01:30 UTC (rev 59941)
+++ grass/branches/releasebranch_7_0/gui/wxpython/modules/mcalc_builder.py 2014-04-25 13:03:15 UTC (rev 59942)
@@ -254,7 +254,8 @@
self.btn_save.Bind(wx.EVT_BUTTON, self.OnSaveExpression)
self.btn_load.Bind(wx.EVT_BUTTON, self.OnLoadExpression)
- self.mapselect.Bind(wx.EVT_TEXT, self.OnSelectTextEvt)
+ # self.mapselect.Bind(wx.EVT_TEXT, self.OnSelectTextEvt)
+ self.mapselect.Bind(wx.EVT_TEXT, self.OnSelect)
self.function.Bind(wx.EVT_COMBOBOX, self._return_funct)
self.function.Bind(wx.EVT_TEXT_ENTER, self.OnSelect)
self.newmaptxt.Bind(wx.EVT_TEXT, self.OnUpdateStatusBar)
@@ -267,7 +268,11 @@
def _return_funct(self,event):
i = event.GetString()
self._addSomething(self.funct_dict[i])
+ # reset
+ win = self.FindWindowById(event.GetId())
+ win.SetValue('')
def _layout(self):
sizer = wx.BoxSizer(wx.VERTICAL)
@@ -418,15 +423,17 @@
elif event.GetId() == self.btn['parenr'].GetId(): mark = ")"
self._addSomething(mark)
- def OnSelectTextEvt(self, event):
- """!Checks if user is typing or the event was emited by map selection.
- Prevents from changing focus.
- item = self.mapselect.GetValue().strip()
- if not (abs(len(item) - len(self.lastMapName)) == 1 and \
- self.lastMapName in item or item in self.lastMapName):
- self.OnSelect(event)
- self.lastMapName = item
+ ### unused
+ # def OnSelectTextEvt(self, event):
+ # """!Checks if user is typing or the event was emited by map selection.
+ # Prevents from changing focus.
+ # item = self.mapselect.GetValue().strip()
+ # if not (abs(len(item) - len(self.lastMapName)) == 1 and \
+ # self.lastMapName in item or item in self.lastMapName):
+ # self.OnSelect(event)
+ # self.lastMapName = item
def OnSelect(self, event):
"""!Gets raster map or function selection and send it to
@@ -435,11 +442,14 @@
Checks for characters which can be in raster map name but
the raster map name must be then quoted.
- item = self.FindWindowById(event.GetId()).GetValue().strip()
+ item = event.GetString().strip()
if any((char in item) for char in self.charactersToQuote):
item = '"' + item + '"'
self._addSomething(item)
+ win.ChangeValue('') # reset
def OnUpdateStatusBar(self, event):
"""!Update statusbar text"""
expr = self.text_mcalc.GetValue().strip().replace("\n", " ")
