[GRASS-SVN] r59947 - grass/trunk/lib/python/pygrass/docs
svn_grass at osgeo.org
Sat Apr 26 06:59:08 PDT 2014
Author: neteler
Date: 2014-04-26 06:59:08 -0700 (Sat, 26 Apr 2014)
New Revision: 59947
grass/trunk/lib/python/pygrass/docs/Makefile
grass/trunk/lib/python/pygrass/docs/conf.py
grass/trunk/lib/python/pygrass/docs/raster.rst
pygrass docs: enable 'make html' in virtual GRASS session; update copyright year/version; fix progman link
Modified: grass/trunk/lib/python/pygrass/docs/Makefile
--- grass/trunk/lib/python/pygrass/docs/Makefile 2014-04-26 13:22:18 UTC (rev 59946)
+++ grass/trunk/lib/python/pygrass/docs/Makefile 2014-04-26 13:59:08 UTC (rev 59947)
@@ -1,5 +1,8 @@
# Makefile for Sphinx documentation
+MODULE_TOPDIR=../../../..
+include $(MODULE_TOPDIR)/include/Make/Vars.make
+include $(MODULE_TOPDIR)/include/Make/Rules.make
# You can set these variables from the command line.
SPHINXOPTS =
@@ -12,6 +15,8 @@
PAPER =
BUILDDIR = _build
+MYGISBASE = $(GISBASE)
# Internal variables.
PAPEROPT_a4 = -D latex_paper_size=a4
PAPEROPT_letter = -D latex_paper_size=letter
@@ -21,6 +26,8 @@
.PHONY: help clean html dirhtml singlehtml pickle json htmlhelp qthelp devhelp epub latex latexpdf text man changes linkcheck doctest gettext
+.DEFAULT_GOAL := help
help:
@echo "Please use \`make <target>' where <target> is one of"
@echo " html to make standalone HTML files"
@@ -47,38 +54,38 @@
-rm -rf $(BUILDDIR)/*
html:
- $(SPHINXBUILD) -b html $(ALLSPHINXOPTS) $(BUILDDIR)/html
+ $(call run_grass,$(SPHINXBUILD) -b html $(ALLSPHINXOPTS) $(BUILDDIR)/html)
@echo
- @echo "Build finished. The HTML pages are in $(BUILDDIR)/html."
+ @echo "Build finished. The HTML pages are in $(BUILDDIR)/html/"
dirhtml:
- $(SPHINXBUILD) -b dirhtml $(ALLSPHINXOPTS) $(BUILDDIR)/dirhtml
+ $(call run_grass,$(SPHINXBUILD) -b dirhtml $(ALLSPHINXOPTS) $(BUILDDIR)/dirhtml)
@echo
- @echo "Build finished. The HTML pages are in $(BUILDDIR)/dirhtml."
+ @echo "Build finished. The HTML pages are in $(BUILDDIR)/dirhtml/"
singlehtml:
- $(SPHINXBUILD) -b singlehtml $(ALLSPHINXOPTS) $(BUILDDIR)/singlehtml
+ $(call run_grass,$(SPHINXBUILD) -b singlehtml $(ALLSPHINXOPTS) $(BUILDDIR)/singlehtml)
@echo
- @echo "Build finished. The HTML page is in $(BUILDDIR)/singlehtml."
+ @echo "Build finished. The HTML page is in $(BUILDDIR)/singlehtml/"
pickle:
- $(SPHINXBUILD) -b pickle $(ALLSPHINXOPTS) $(BUILDDIR)/pickle
+ $(call run_grass,$(SPHINXBUILD) -b pickle $(ALLSPHINXOPTS) $(BUILDDIR)/pickle)
@echo
- @echo "Build finished; now you can process the pickle files."
+ @echo "Build finished; now you can process the pickle files in $(BUILDDIR)/pickle/."
json:
- $(SPHINXBUILD) -b json $(ALLSPHINXOPTS) $(BUILDDIR)/json
+ $(call run_grass,$(SPHINXBUILD) -b json $(ALLSPHINXOPTS) $(BUILDDIR)/json)
@echo
- @echo "Build finished; now you can process the JSON files."
+ @echo "Build finished; now you can process the JSON files in $(BUILDDIR)/json/"
htmlhelp:
- $(SPHINXBUILD) -b htmlhelp $(ALLSPHINXOPTS) $(BUILDDIR)/htmlhelp
+ $(call run_grass,$(SPHINXBUILD) -b htmlhelp $(ALLSPHINXOPTS) $(BUILDDIR)/htmlhelp)
@echo
@echo "Build finished; now you can run HTML Help Workshop with the" \
- ".hhp project file in $(BUILDDIR)/htmlhelp."
+ ".hhp project file in $(BUILDDIR)/htmlhelp/"
qthelp:
- $(SPHINXBUILD) -b qthelp $(ALLSPHINXOPTS) $(BUILDDIR)/qthelp
+ $(call run_grass,$(SPHINXBUILD) -b qthelp $(ALLSPHINXOPTS) $(BUILDDIR)/qthelp)
@echo
@echo "Build finished; now you can run "qcollectiongenerator" with the" \
".qhcp project file in $(BUILDDIR)/qthelp, like this:"
@@ -87,7 +94,7 @@
@echo "# assistant -collectionFile $(BUILDDIR)/qthelp/PyGrass.qhc"
devhelp:
- $(SPHINXBUILD) -b devhelp $(ALLSPHINXOPTS) $(BUILDDIR)/devhelp
+ $(call run_grass,$(SPHINXBUILD) -b devhelp $(ALLSPHINXOPTS) $(BUILDDIR)/devhelp)
@echo
@echo "Build finished."
@echo "To view the help file:"
@@ -96,63 +103,63 @@
@echo "# devhelp"
epub:
- $(SPHINXBUILD) -b epub $(ALLSPHINXOPTS) $(BUILDDIR)/epub
+ $(call run_grass,$(SPHINXBUILD) -b epub $(ALLSPHINXOPTS) $(BUILDDIR)/epub)
@echo
- @echo "Build finished. The epub file is in $(BUILDDIR)/epub."
+ @echo "Build finished. The epub file is in $(BUILDDIR)/epub/"
latex:
- $(SPHINXBUILD) -b latex $(ALLSPHINXOPTS) $(BUILDDIR)/latex
+ $(call run_grass,$(SPHINXBUILD) -b latex $(ALLSPHINXOPTS) $(BUILDDIR)/latex)
@echo
@echo "Build finished; the LaTeX files are in $(BUILDDIR)/latex."
@echo "Run \`make' in that directory to run these through (pdf)latex" \
"(use \`make latexpdf' here to do that automatically)."
latexpdf:
@echo "Running LaTeX files through pdflatex..."
$(MAKE) -C $(BUILDDIR)/latex all-pdf
- @echo "pdflatex finished; the PDF files are in $(BUILDDIR)/latex."
+ @echo "pdflatex finished; the PDF files are in $(BUILDDIR)/latex/"
text:
- $(SPHINXBUILD) -b text $(ALLSPHINXOPTS) $(BUILDDIR)/text
+ $(call run_grass,$(SPHINXBUILD) -b text $(ALLSPHINXOPTS) $(BUILDDIR)/text)
@echo
- @echo "Build finished. The text files are in $(BUILDDIR)/text."
+ @echo "Build finished. The text files are in $(BUILDDIR)/text/"
man:
- $(SPHINXBUILD) -b man $(ALLSPHINXOPTS) $(BUILDDIR)/man
+ $(call run_grass,$(SPHINXBUILD) -b man $(ALLSPHINXOPTS) $(BUILDDIR)/man)
@echo
- @echo "Build finished. The manual pages are in $(BUILDDIR)/man."
+ @echo "Build finished. The manual pages are in $(BUILDDIR)/man/"
texinfo:
- $(SPHINXBUILD) -b texinfo $(ALLSPHINXOPTS) $(BUILDDIR)/texinfo
+ $(call run_grass,$(SPHINXBUILD) -b texinfo $(ALLSPHINXOPTS) $(BUILDDIR)/texinfo)
@echo
@echo "Build finished. The Texinfo files are in $(BUILDDIR)/texinfo."
@echo "Run \`make' in that directory to run these through makeinfo" \
"(use \`make info' here to do that automatically)."
info:
@echo "Running Texinfo files through makeinfo..."
make -C $(BUILDDIR)/texinfo info
- @echo "makeinfo finished; the Info files are in $(BUILDDIR)/texinfo."
+ @echo "makeinfo finished; the Info files are in $(BUILDDIR)/texinfo/"
gettext:
- $(SPHINXBUILD) -b gettext $(I18NSPHINXOPTS) $(BUILDDIR)/locale
+ $(call run_grass,$(SPHINXBUILD) -b gettext $(I18NSPHINXOPTS) $(BUILDDIR)/locale)
@echo
- @echo "Build finished. The message catalogs are in $(BUILDDIR)/locale."
+ @echo "Build finished. The message catalogs are in $(BUILDDIR)/locale/"
changes:
- $(SPHINXBUILD) -b changes $(ALLSPHINXOPTS) $(BUILDDIR)/changes
+ $(call run_grass,$(SPHINXBUILD) -b changes $(ALLSPHINXOPTS) $(BUILDDIR)/changes)
@echo
- @echo "The overview file is in $(BUILDDIR)/changes."
+ @echo "The overview file is in $(BUILDDIR)/changes/"
linkcheck:
- $(SPHINXBUILD) -b linkcheck $(ALLSPHINXOPTS) $(BUILDDIR)/linkcheck
+ $(call run_grass,$(SPHINXBUILD) -b linkcheck $(ALLSPHINXOPTS) $(BUILDDIR)/linkcheck)
@echo
@echo "Link check complete; look for any errors in the above output " \
"or in $(BUILDDIR)/linkcheck/output.txt."
doctest:
- $(SPHINXBUILD) -b doctest $(ALLSPHINXOPTS) $(BUILDDIR)/doctest
+ $(call run_grass,$(SPHINXBUILD) -b doctest $(ALLSPHINXOPTS) $(BUILDDIR)/doctest)
@echo "Testing of doctests in the sources finished, look at the " \
"results in $(BUILDDIR)/doctest/output.txt."
Modified: grass/trunk/lib/python/pygrass/docs/conf.py
--- grass/trunk/lib/python/pygrass/docs/conf.py 2014-04-26 13:22:18 UTC (rev 59946)
+++ grass/trunk/lib/python/pygrass/docs/conf.py 2014-04-26 13:59:08 UTC (rev 59947)
@@ -43,14 +43,14 @@
# General information about the project.
project = u'PyGrass'
-copyright = u'2012, Pietro Zambelli'
+copyright = u'2012-2014, Pietro Zambelli'
# The version info for the project you're documenting, acts as replacement for
# |version| and |release|, also used in various other places throughout the
# built documents.
# The short X.Y version.
-version = '0.1'
+version = '0.2'
# The full version, including alpha/beta/rc tags.
release = 'alpha'
Modified: grass/trunk/lib/python/pygrass/docs/raster.rst
--- grass/trunk/lib/python/pygrass/docs/raster.rst 2014-04-26 13:22:18 UTC (rev 59946)
+++ grass/trunk/lib/python/pygrass/docs/raster.rst 2014-04-26 13:59:08 UTC (rev 59947)
@@ -392,7 +392,7 @@
.. autoclass:: pygrass.raster.category.Category
:members:
-.. _Raster library: http://grass.osgeo.org/programming7/rasterlib.html/
+.. _Raster library: http://grass.osgeo.org/programming7/rasterlib.html
.. _RowIO library: http://grass.osgeo.org/programming7/rowiolib.html
.. _Segmentation library: http://grass.osgeo.org/programming7/segmentlib.html
.. _numpy.memmap: http://docs.scipy.org/doc/numpy/reference/generated/numpy.memmap.html
