[GRASS-SVN] r59975 - grass-addons/grass6/vector/v.in.gshhs
svn_grass at osgeo.org
Wed Apr 30 03:23:09 PDT 2014
Author: hamish
Date: 2014-04-30 03:23:09 -0700 (Wed, 30 Apr 2014)
New Revision: 59975
grass-addons/grass6/vector/v.in.gshhs/description.html
grass-addons/grass6/vector/v.in.gshhs/gshhs.h
grass-addons/grass6/vector/v.in.gshhs/main.c
update to GSHHS (now renamed GSHHG) version 2.3.0
Modified: grass-addons/grass6/vector/v.in.gshhs/description.html
--- grass-addons/grass6/vector/v.in.gshhs/description.html 2014-04-29 20:39:19 UTC (rev 59974)
+++ grass-addons/grass6/vector/v.in.gshhs/description.html 2014-04-30 10:23:09 UTC (rev 59975)
@@ -25,7 +25,11 @@
full dataset is imported. With the -r flag, any line that falls into or
overlaps with the current region is imported. Lines are not cropped.
+<p>
+As of July 2012 GSHHS has been renamed GSHHG, as they provide more than
+just shorelines.
<h2>NOTES</h2>
The GSHHS shorelines are in files named <tt>gshhs_[f|h|i|l|c].b</tt> where
@@ -60,6 +64,7 @@
is currently not supported but works, just ignore the attribute table.
These world borders and rivers may be not very accurate.
<h2>SEE ALSO</h2>
<em>
@@ -68,6 +73,7 @@
<a href="v.type.html">v.type</a>,
</em>
<h2>REFERENCES</h2>
The processing and assembly of the GSHHS data is described in
@@ -75,7 +81,9 @@
Wessel, P., and W. H. F. Smith, 1996. A Global Self-consistent, Hierarchical,
High-resolution Shoreline Database. J. Geophys. Res., 101(B4), 8741-8743.
<h2>AUTHORS</h2>
The gshhstograss tool was written by Simon Cox and Paul Wessel.<br>
The original version of v.in.gshhs was written by Bob Covill based on gshhstograss.<br>
Modifications and updates by Markus Neteler and Markus Metz.
Modified: grass-addons/grass6/vector/v.in.gshhs/gshhs.h
--- grass-addons/grass6/vector/v.in.gshhs/gshhs.h 2014-04-29 20:39:19 UTC (rev 59974)
+++ grass-addons/grass6/vector/v.in.gshhs/gshhs.h 2014-04-30 10:23:09 UTC (rev 59975)
@@ -57,11 +57,11 @@
#define SEEK_CUR 1
#endif
-#define GSHHS_DATA_RELEASE 9 /* For v2.2.0 data set */
-#define GSHHS_DATA_VERSION "2.2.0" /* For v2.2.0 data set */
+#define GSHHS_DATA_RELEASE 13 /* For v2.3.0 data set */
+#define GSHHS_DATA_VERSION "2.3.0" /* For v2.3.0 data set */
#define GSHHS_PROG_VERSION "1.13"
-#define GSHHS_SCL 1.0e-6 /* COnvert micro-degrees to degrees */
+#define GSHHS_SCL 1.0e-6 /* Convert micro-degrees to degrees */
/* For byte swapping on little-endian systems (GSHHS is defined to be bigendian) */
Modified: grass-addons/grass6/vector/v.in.gshhs/main.c
--- grass-addons/grass6/vector/v.in.gshhs/main.c 2014-04-29 20:39:19 UTC (rev 59974)
+++ grass-addons/grass6/vector/v.in.gshhs/main.c 2014-04-30 10:23:09 UTC (rev 59975)
@@ -113,7 +113,7 @@
parm.input->required = YES;
parm.input->gisprompt = "old_file,file,gshhs";
parm.input->description =
- _("Name of GSHHS shoreline file: gshhs_[f|h|i|l|c].b");
+ _("Name of GSHHG/GSHHS shoreline file: gshhs_[f|h|i|l|c].b");
parm.output = G_define_standard_option(G_OPT_V_OUTPUT);
@@ -285,9 +285,11 @@
/* check version support */
if (version < 4) /* not sure if that check works... */
- G_fatal_error("Trying to import version %d, only GSHHS versions 4 to %d (2.2) are supported.", version, (int)GSHHS_DATA_RELEASE);
+ G_fatal_error("Trying to import version %d, only GSHHS versions 4 to %d (%s) are supported.",
+ version, (int)GSHHS_DATA_RELEASE, GSHHS_DATA_VERSION);
if (version > GSHHS_DATA_RELEASE)
- G_fatal_error("Import of version %d not yet supported, highest supported version is GSHHS version 7 (2.0).", version);
+ G_fatal_error("Import of version %d not yet supported, highest supported version is GSHHS version %d (%s).",
rewind(fp);
