[GRASS-SVN] r59990 - grass/branches/releasebranch_7_0/vector/v.buffer
svn_grass at osgeo.org
Wed Apr 30 08:38:24 PDT 2014
Author: neteler
Date: 2014-04-30 08:38:24 -0700 (Wed, 30 Apr 2014)
New Revision: 59990
grass/branches/releasebranch_7_0/vector/v.buffer/v.buffer.html
v.buffer manual: minor cleanup
Modified: grass/branches/releasebranch_7_0/vector/v.buffer/v.buffer.html
--- grass/branches/releasebranch_7_0/vector/v.buffer/v.buffer.html 2014-04-30 15:38:17 UTC (rev 59989)
+++ grass/branches/releasebranch_7_0/vector/v.buffer/v.buffer.html 2014-04-30 15:38:24 UTC (rev 59990)
@@ -8,8 +8,8 @@
<h2>NOTES</h2>
-Internal buffers for areas can be generated with negative distiance
-values (GRASS must be compiled with GEOS).
+Internal buffers for areas can be generated with negative distance
+values ("inward buffer" or "negative buffer").
<p>
Categories and attributes can be transferred with the <b>t</b> flag.
The resulting buffer areas can have multiple categories, and multiple
@@ -18,11 +18,15 @@
areas with category X (see example below).
<p>
-Buffers for lines and areas are generated using algorithm from GEOS
-library. If GRASS is not compiled with GEOS support or environmental
+Buffers for lines and areas are generated using the algorithms from
+the GEOS library.
+<!-- built-in buffer algorithm no longer desired, we use GEOS:
+If GRASS is not compiled with GEOS support or environmental
variable <tt>GRASS_VECTOR_BUFFER</tt> is defined, then GRASS generates
buffers using built-in buffering algorithm (which is still buggy for
some input data).
<h2>EXAMPLES</h2>
