[GRASS-SVN] r59997 - grass/branches/develbranch_6
Wed Apr 30 11:16:30 PDT 2014
Author: neteler
Date: 2014-04-30 11:16:30 -0700 (Wed, 30 Apr 2014)
New Revision: 59997
   grass/branches/develbranch_6/config.guess
   grass/branches/develbranch_6/config.sub
autoconf support file update from git.savannah.gnu.org
Modified: grass/branches/develbranch_6/config.guess
--- grass/branches/develbranch_6/config.guess	2014-04-30 18:16:27 UTC (rev 59996)
+++ grass/branches/develbranch_6/config.guess	2014-04-30 18:16:30 UTC (rev 59997)
@@ -1,8 +1,8 @@
 #! /bin/sh
 # Attempt to guess a canonical system name.
-#   Copyright 1992-2013 Free Software Foundation, Inc.
+#   Copyright 1992-2014 Free Software Foundation, Inc.
-timestamp='2013-05-16'
+timestamp='2014-03-23'
 # This file is free software; you can redistribute it and/or modify it
 # under the terms of the GNU General Public License as published by
@@ -50,7 +50,7 @@
 GNU config.guess ($timestamp)
 Originally written by Per Bothner.
-Copyright 1992-2013 Free Software Foundation, Inc.
+Copyright 1992-2014 Free Software Foundation, Inc.
 This is free software; see the source for copying conditions.  There is NO
 warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
@@ -149,7 +149,7 @@
 	LIBC=gnu
 	#endif
 	EOF
-	eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^LIBC'`
+	eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^LIBC' | sed 's, ,,g'`
 esac
@@ -826,7 +826,7 @@
     *:MINGW*:*)
 	echo ${UNAME_MACHINE}-pc-mingw32
 	exit ;;
-    i*:MSYS*:*)
+    *:MSYS*:*)
 	echo ${UNAME_MACHINE}-pc-msys
 	exit ;;
     i*:windows32*:*)
@@ -969,10 +969,10 @@
 	eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep '^CPU'`
 	test x"${CPU}" != x && { echo "${CPU}-unknown-linux-${LIBC}"; exit; }
-    or1k:Linux:*:*)
-	echo ${UNAME_MACHINE}-unknown-linux-${LIBC}
+    openrisc*:Linux:*:*)
+	echo or1k-unknown-linux-${LIBC}
 	exit ;;
-    or32:Linux:*:*)
+    or32:Linux:*:* | or1k*:Linux:*:*)
 	exit ;;
     padre:Linux:*:*)
@@ -1260,16 +1260,26 @@
 	if test "$UNAME_PROCESSOR" = unknown ; then
 	    UNAME_PROCESSOR=powerpc
 	fi
-	if [ "$CC_FOR_BUILD" != 'no_compiler_found' ]; then
-	    if (echo '#ifdef __LP64__'; echo IS_64BIT_ARCH; echo '#endif') | \
-		(CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) | \
-		grep IS_64BIT_ARCH >/dev/null
-	    then
-		case $UNAME_PROCESSOR in
-		    i386) UNAME_PROCESSOR=x86_64 ;;
-		    powerpc) UNAME_PROCESSOR=powerpc64 ;;
-		esac
+	if test `echo "$UNAME_RELEASE" | sed -e 's/\..*//'` -le 10 ; then
+	    if [ "$CC_FOR_BUILD" != 'no_compiler_found' ]; then
+		if (echo '#ifdef __LP64__'; echo IS_64BIT_ARCH; echo '#endif') | \
+		    (CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) | \
+		    grep IS_64BIT_ARCH >/dev/null
+		then
+		    case $UNAME_PROCESSOR in
+			i386) UNAME_PROCESSOR=x86_64 ;;
+			powerpc) UNAME_PROCESSOR=powerpc64 ;;
+		    esac
+		fi
 	    fi
+	elif test "$UNAME_PROCESSOR" = i386 ; then
+	    # Avoid executing cc on OS X 10.9, as it ships with a stub
+	    # that puts up a graphical alert prompting to install
+	    # developer tools.  Any system running Mac OS X 10.7 or
+	    # later (Darwin 11 and later) is required to have a 64-bit
+	    # processor. This is not true of the ARM version of Darwin
+	    # that Apple uses in portable devices.
+	    UNAME_PROCESSOR=x86_64
 	fi
 	echo ${UNAME_PROCESSOR}-apple-darwin${UNAME_RELEASE}
 	exit ;;
@@ -1361,154 +1371,6 @@
 	exit ;;
 esac
-eval $set_cc_for_build
-cat >$dummy.c <<EOF
-#ifdef _SEQUENT_
-# include <sys/types.h>
-# include <sys/utsname.h>
-#endif
-main ()
-#if defined (sony)
-#if defined (MIPSEB)
-  /* BFD wants "bsd" instead of "newsos".  Perhaps BFD should be changed,
-     I don't know....  */
-  printf ("mips-sony-bsd\n"); exit (0);
-#else
-#include <sys/param.h>
-  printf ("m68k-sony-newsos%s\n",
-#ifdef NEWSOS4
-	"4"
-#else
-#endif
-	); exit (0);
-#endif
-#endif
-#if defined (__arm) && defined (__acorn) && defined (__unix)
-  printf ("arm-acorn-riscix\n"); exit (0);
-#endif
-#if defined (hp300) && !defined (hpux)
-  printf ("m68k-hp-bsd\n"); exit (0);
-#endif
-#if defined (NeXT)
-#if !defined (__ARCHITECTURE__)
-#define __ARCHITECTURE__ "m68k"
-#endif
-  int version;
-  version=`(hostinfo | sed -n 's/.*NeXT Mach \([0-9]*\).*/\1/p') 2>/dev/null`;
-  if (version < 4)
-    printf ("%s-next-nextstep%d\n", __ARCHITECTURE__, version);
-  else
-    printf ("%s-next-openstep%d\n", __ARCHITECTURE__, version);
-  exit (0);
-#endif
-#if defined (MULTIMAX) || defined (n16)
-#if defined (UMAXV)
-  printf ("ns32k-encore-sysv\n"); exit (0);
-#else
-#if defined (CMU)
-  printf ("ns32k-encore-mach\n"); exit (0);
-#else
-  printf ("ns32k-encore-bsd\n"); exit (0);
-#endif
-#endif
-#endif
-#if defined (__386BSD__)
-  printf ("i386-pc-bsd\n"); exit (0);
-#endif
-#if defined (sequent)
-#if defined (i386)
-  printf ("i386-sequent-dynix\n"); exit (0);
-#endif
-#if defined (ns32000)
-  printf ("ns32k-sequent-dynix\n"); exit (0);
-#endif
-#endif
-#if defined (_SEQUENT_)
-    struct utsname un;
-    uname(&un);
-    if (strncmp(un.version, "V2", 2) == 0) {
-	printf ("i386-sequent-ptx2\n"); exit (0);
-    if (strncmp(un.version, "V1", 2) == 0) { /* XXX is V1 correct? */
-	printf ("i386-sequent-ptx1\n"); exit (0);
-    printf ("i386-sequent-ptx\n"); exit (0);
-#endif
-#if defined (vax)
-# if !defined (ultrix)
-#  include <sys/param.h>
-#  if defined (BSD)
-#   if BSD == 43
-      printf ("vax-dec-bsd4.3\n"); exit (0);
-#   else
-#    if BSD == 199006
-      printf ("vax-dec-bsd4.3reno\n"); exit (0);
-#    else
-      printf ("vax-dec-bsd\n"); exit (0);
-#    endif
-#   endif
-#  else
-#  endif
-# else
-    printf ("vax-dec-ultrix\n"); exit (0);
-# endif
-#endif
-#if defined (alliant) && defined (i860)
-  printf ("i860-alliant-bsd\n"); exit (0);
-#endif
-  exit (1);
-EOF
-$CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null && SYSTEM_NAME=`$dummy` &&
-	{ echo "$SYSTEM_NAME"; exit; }
-# Apollos put the system type in the environment.
-test -d /usr/apollo && { echo ${ISP}-apollo-${SYSTYPE}; exit; }
-# Convex versions that predate uname can use getsysinfo(1)
-if [ -x /usr/convex/getsysinfo ]
-then
-    case `getsysinfo -f cpu_type` in
-    c1*)
-	echo c1-convex-bsd
-	exit ;;
-    c2*)
-	if getsysinfo -f scalar_acc
-	then echo c32-convex-bsd
-	else echo c2-convex-bsd
-	fi
-	exit ;;
-    c34*)
-	echo c34-convex-bsd
-	exit ;;
-    c38*)
-	echo c38-convex-bsd
-	exit ;;
-    c4*)
-	echo c4-convex-bsd
-	exit ;;
-    esac
-fi
 cat >&2 <<EOF
 $0: unable to guess system type
Modified: grass/branches/develbranch_6/config.sub
--- grass/branches/develbranch_6/config.sub	2014-04-30 18:16:27 UTC (rev 59996)
+++ grass/branches/develbranch_6/config.sub	2014-04-30 18:16:30 UTC (rev 59997)
@@ -1,8 +1,8 @@
 #! /bin/sh
 # Configuration validation subroutine script.
-timestamp='2013-04-24'
+timestamp='2014-04-03'
@@ -68,7 +68,7 @@
 version="\
 GNU config.sub ($timestamp)
@@ -257,7 +257,7 @@
 	| avr | avr32 \
 	| be32 | be64 \
 	| bfin \
-	| c4x | clipper \
+	| c4x | c8051 | clipper \
 	| d10v | d30v | dlx | dsp16xx \
 	| epiphany \
 	| fido | fr30 | frv \
@@ -265,6 +265,7 @@
 	| hexagon \
 	| i370 | i860 | i960 | ia64 \
 	| ip2k | iq2000 \
+	| k1om \
 	| le32 | le64 \
 	| lm32 \
 	| m32c | m32r | m32rle | m68000 | m68k | m88k \
@@ -295,8 +296,7 @@
 	| nds32 | nds32le | nds32be \
 	| nios | nios2 | nios2eb | nios2el \
 	| ns16k | ns32k \
-	| open8 \
-	| or1k | or32 \
+	| open8 | or1k | or1knd | or32 \
 	| pdp10 | pdp11 | pj | pjl \
 	| powerpc | powerpc64 | powerpc64le | powerpcle \
 	| pyramid \
@@ -324,7 +324,7 @@
 	c6x)
 		basic_machine=tic6x-unknown
-	m6811 | m68hc11 | m6812 | m68hc12 | m68hcs12x | picochip)
+	m6811 | m68hc11 | m6812 | m68hc12 | m68hcs12x | nvptx | picochip)
 		basic_machine=$basic_machine-unknown
 		os=-none
@@ -372,7 +372,7 @@
 	| be32-* | be64-* \
 	| bfin-* | bs2000-* \
 	| c[123]* | c30-* | [cjt]90-* | c4x-* \
-	| clipper-* | craynv-* | cydra-* \
+	| c8051-* | clipper-* | craynv-* | cydra-* \
 	| d10v-* | d30v-* | dlx-* \
 	| elxsi-* \
 	| f30[01]-* | f700-* | fido-* | fr30-* | frv-* | fx80-* \
@@ -381,6 +381,7 @@
 	| hexagon-* \
 	| i*86-* | i860-* | i960-* | ia64-* \
 	| ip2k-* | iq2000-* \
+	| k1om-* \
 	| le32-* | le64-* \
 	| lm32-* \
 	| m32c-* | m32r-* | m32rle-* \
@@ -413,6 +414,7 @@
 	| nios-* | nios2-* | nios2eb-* | nios2el-* \
 	| none-* | np1-* | ns16k-* | ns32k-* \
 	| open8-* \
+	| or1k*-* \
 	| orion-* \
 	| pdp10-* | pdp11-* | pj-* | pjl-* | pn-* | power-* \
 	| powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* \
@@ -794,7 +796,7 @@
 		os=-mingw64
 	mingw32)
-		basic_machine=i386-pc
+		basic_machine=i686-pc
 		os=-mingw32
 	mingw32ce)
@@ -830,7 +832,7 @@
 		basic_machine=`echo $basic_machine | sed -e 's/ms1-/mt-/'`
 	msys)
 		os=-msys
 	mvs)
@@ -1374,7 +1376,7 @@
 	      | -os2* | -vos* | -palmos* | -uclinux* | -nucleus* \
 	      | -morphos* | -superux* | -rtmk* | -rtmk-nova* | -windiss* \
 	      | -powermax* | -dnix* | -nx6 | -nx7 | -sei* | -dragonfly* \
-	      | -skyos* | -haiku* | -rdos* | -toppers* | -drops* | -es*)
+	      | -skyos* | -haiku* | -rdos* | -toppers* | -drops* | -es* | -tirtos*)
 	# Remember, each alternative MUST END IN *, to match a version number.
 	-qnx*)
@@ -1546,6 +1548,9 @@
 	c4x-* | tic4x-*)
 		os=-coff
+	c8051-*)
+		os=-elf
 	hexagon-*)
 		os=-elf
@@ -1589,9 +1594,6 @@
 	mips*-*)
 		os=-elf
-	or1k-*)
-		os=-elf
 	or32-*)
 		os=-coff
