[GRASS-SVN] r61512 - in grass/trunk/lib/python/pygrass/modules/interface: . testsuite
Mon Aug 4 05:46:46 PDT 2014
Author: zarch
Date: 2014-08-04 05:46:46 -0700 (Mon, 04 Aug 2014)
New Revision: 61512
   grass/trunk/lib/python/pygrass/modules/interface/read.py
   grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_modules.py
pygrass: Substitute lambda with function to make Module instances pickable
Modified: grass/trunk/lib/python/pygrass/modules/interface/read.py
--- grass/trunk/lib/python/pygrass/modules/interface/read.py	2014-08-04 12:44:03 UTC (rev 61511)
+++ grass/trunk/lib/python/pygrass/modules/interface/read.py	2014-08-04 12:46:46 UTC (rev 61512)
@@ -8,34 +8,44 @@
                         with_statement, print_function, unicode_literals)
+def do_nothing(p):
+    return p
+def get_None(p):
+    return None
+def get_dict(p):
+    return dict(p.items())
+def get_values(p):
+    return [e.text.strip() for e in p.findall('value/name')]
+def read_text(p):
+    return p.text.strip()
 def read_keydesc(par):
     name = par.text.strip()
     items = [e.text.strip() for e in par.findall('item')]
     return name, tuple(items) if len(items) > 1 else None
-# this dictionary is used to extract the value of interest from the xml
-# the lambda experssion is used to define small simple functions,
-# is equivalent to: ::
-# def f(p):
-#     return p.text.strip()
-# and then we call f(p)
 GETFROMTAG = {
-    'description': lambda p: p.text.strip(),
+    'description': read_text,
     'keydesc': read_keydesc,
-    'gisprompt': lambda p: dict(p.items()),
-    'default': lambda p: p.text.strip(),
-    'values': lambda p: [e.text.strip() for e in p.findall('value/name')],
-    'value': lambda p: None,
-    'guisection': lambda p: p.text.strip(),
-    'label': lambda p: p.text.strip(),
-    'suppress_required': lambda p: None,
-    'keywords': lambda p: p.text.strip(),
-    'guidependency': lambda p: p.text.strip(),
+    'gisprompt': get_dict,
+    'default': read_text,
+    'values': get_values,
+    'value': get_None,
+    'guisection': read_text,
+    'label': read_text,
+    'suppress_required': get_None,
+    'keywords': read_text,
+    'guidependency': read_text,
 GETTYPE = {
@@ -44,7 +54,7 @@
     'float': float,
     'double': float,
     'file': str,
-    'all': lambda x: x,
+    'all': do_nothing,
Modified: grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_modules.py
--- grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_modules.py	2014-08-04 12:44:03 UTC (rev 61511)
+++ grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_modules.py	2014-08-04 12:46:46 UTC (rev 61512)
@@ -34,5 +34,15 @@
     __metaclass__ = TestModulesMeta
+class TestModulesPickability(TestCase):
+    def test_rsun(self):
+        """Test if a Module instance is pickable"""
+        import pickle
+        from StringIO import StringIO
+        out = StringIO()
+        pickle.dump(Module('r.sun'), out)
+        out.close()
 if __name__ == '__main__':
     test()
