[GRASS-SVN] r61519 - grass/trunk/vector/v.mkgrid
svn_grass at osgeo.org
Mon Aug 4 14:54:45 PDT 2014
Author: lucadelu
Date: 2014-08-04 14:54:45 -0700 (Mon, 04 Aug 2014)
New Revision: 61519
grass/trunk/vector/v.mkgrid/local_proto.h
grass/trunk/vector/v.mkgrid/main.c
grass/trunk/vector/v.mkgrid/write_grid.c
v.mkgrid: added support to lines output through -l flag (ticket #394)
Modified: grass/trunk/vector/v.mkgrid/local_proto.h
--- grass/trunk/vector/v.mkgrid/local_proto.h 2014-08-04 21:38:43 UTC (rev 61518)
+++ grass/trunk/vector/v.mkgrid/local_proto.h 2014-08-04 21:54:45 UTC (rev 61519)
@@ -2,6 +2,6 @@
void rotate(double *, double *, double, double, double);
/* write_grid.c */
-int write_grid(struct grid_description *, struct Map_info *, int);
+int write_grid(struct grid_description *, struct Map_info *, int, int);
int write_vect(double, double, double, double, struct Map_info *,
- struct line_pnts *);
+ struct line_pnts *, int);
Modified: grass/trunk/vector/v.mkgrid/main.c
--- grass/trunk/vector/v.mkgrid/main.c 2014-08-04 21:38:43 UTC (rev 61518)
+++ grass/trunk/vector/v.mkgrid/main.c 2014-08-04 21:54:45 UTC (rev 61519)
@@ -6,8 +6,10 @@
* Upgrade to 5.7 Radim Blazek 10/2004
* Hamish Bowman <hamish_b yahoo.com>,
* Jachym Cepicky <jachym les-ejk.cz>, Markus Neteler <neteler itc.it>
+ * Ivan Shevlakov: points support -p
+ * Luca Delucchi: lines support -l
* PURPOSE:
- * COPYRIGHT: (C) 1999-2009 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2014 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -47,8 +49,8 @@
struct Map_info Map;
struct Option *vectname, *grid, *coord, *box, *angle, *position_opt, *breaks;
struct GModule *module;
- struct Flag *points_fl;
- int points_p;
+ struct Flag *points_fl, *line_fl;
+ int points_p, line_p, output_type;
char *desc;
struct line_pnts *Points;
@@ -132,9 +134,20 @@
points_fl->description =
_("Create grid of points instead of areas and centroids");
+ line_fl = G_define_flag();
+ line_fl->key = 'l';
+ line_fl->description =
+ _("Create grid as lines, instead of areas");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ line_p = line_fl->answer;
+ if (line_p) {
+ output_type = GV_LINE;
+ } else {
+ output_type = GV_BOUNDARY;
points_p = points_fl->answer;
@@ -256,58 +269,63 @@
if (!points_p) {
/* create areas */
- write_grid(&grid_info, &Map, nbreaks);
+ write_grid(&grid_info, &Map, nbreaks, output_type);
/* Create a grid of label points at the centres of the grid cells */
G_verbose_message(_("Creating centroids..."));
/* Write out centroids and attributes */
- db_begin_transaction(Driver);
- attCount = 0;
- for (i = 0; i < grid_info.num_rows; ++i) {
- for (j = 0; j < grid_info.num_cols; ++j) {
- double x, y;
- const int point_type = points_p ? GV_POINT : GV_CENTROID;
+ /* If the output id is lines it skips to add centroids and attributes
+ TODO decide what to write in the attribute table
+ if (!line_p) {
+ db_begin_transaction(Driver);
+ attCount = 0;
+ for (i = 0; i < grid_info.num_rows; ++i) {
+ for (j = 0; j < grid_info.num_cols; ++j) {
+ double x, y;
+ const int point_type = points_p ? GV_POINT : GV_CENTROID;
- x = grid_info.origin_x + (0.5 + j) * grid_info.length;
- y = grid_info.origin_y + (0.5 + i) * grid_info.width;
+ x = grid_info.origin_x + (0.5 + j) * grid_info.length;
+ y = grid_info.origin_y + (0.5 + i) * grid_info.width;
- rotate(&x, &y, grid_info.origin_x, grid_info.origin_y,
- grid_info.angle);
+ rotate(&x, &y, grid_info.origin_x, grid_info.origin_y,
+ grid_info.angle);
- Vect_reset_line(Points);
- Vect_reset_cats(Cats);
+ Vect_reset_line(Points);
+ Vect_reset_cats(Cats);
- Vect_append_point(Points, x, y, 0.0);
- Vect_cat_set(Cats, 1, attCount + 1);
- Vect_write_line(&Map, point_type, Points, Cats);
+ Vect_append_point(Points, x, y, 0.0);
+ Vect_cat_set(Cats, 1, attCount + 1);
+ Vect_write_line(&Map, point_type, Points, Cats);
- sprintf(buf, "insert into %s values ", Fi->table);
- if (db_set_string(&sql, buf) != DB_OK)
- G_fatal_error(_("Unable to fill attribute table"));
+ sprintf(buf, "insert into %s values ", Fi->table);
+ if (db_set_string(&sql, buf) != DB_OK)
+ G_fatal_error(_("Unable to fill attribute table"));
- if (grid_info.num_rows < 27 && grid_info.num_cols < 27) {
- sprintf(buf,
- "( %d, %d, %d, '%c', '%c' )",
- attCount + 1, grid_info.num_rows - i,
- j + 1, 'A' + grid_info.num_rows - i - 1, 'A' + j);
- else {
- sprintf(buf, "( %d, %d, %d )",
- attCount + 1, i + 1, j + 1);
- if (db_append_string(&sql, buf) != DB_OK)
+ if (grid_info.num_rows < 27 && grid_info.num_cols < 27) {
+ sprintf(buf,
+ "( %d, %d, %d, '%c', '%c' )",
+ attCount + 1, grid_info.num_rows - i,
+ j + 1, 'A' + grid_info.num_rows - i - 1, 'A' + j);
+ else {
+ sprintf(buf, "( %d, %d, %d )",
+ attCount + 1, i + 1, j + 1);
+ if (db_append_string(&sql, buf) != DB_OK)
- G_debug(3, "SQL: %s", db_get_string(&sql));
+ G_debug(3, "SQL: %s", db_get_string(&sql));
- if (db_execute_immediate(Driver, &sql) != DB_OK) {
- G_fatal_error(_("Unable to insert new record: %s"),
- db_get_string(&sql));
- attCount++;
+ if (db_execute_immediate(Driver, &sql) != DB_OK) {
+ G_fatal_error(_("Unable to insert new record: %s"),
+ db_get_string(&sql));
+ attCount++;
db_commit_transaction(Driver);
Modified: grass/trunk/vector/v.mkgrid/write_grid.c
--- grass/trunk/vector/v.mkgrid/write_grid.c 2014-08-04 21:38:43 UTC (rev 61518)
+++ grass/trunk/vector/v.mkgrid/write_grid.c 2014-08-04 21:54:45 UTC (rev 61519)
@@ -5,7 +5,7 @@
#include "grid_structs.h"
#include "local_proto.h"
-int write_grid(struct grid_description *grid_info, struct Map_info *Map, int nbreaks)
+int write_grid(struct grid_description *grid_info, struct Map_info *Map, int nbreaks, int out_type)
int i, k, j;
@@ -65,7 +65,7 @@
angle);
rotate(&next_x, &dum, grid_info->origin_x,
grid_info->origin_y, angle);
- write_vect(x, y, next_x, dum, Map, Points);
+ write_vect(x, y, next_x, dum, Map, Points, out_type);
y = sy;
x = next_x = snext_x;
@@ -95,7 +95,7 @@
rotate(&dum, &next_y, grid_info->origin_x, grid_info->origin_y,
angle);
- write_vect(x, y, dum, next_y, Map, Points);
+ write_vect(x, y, dum, next_y, Map, Points, out_type);
x = sx;
y = next_y = snext_y;
@@ -117,7 +117,7 @@
#define NUM_POINTS 2
int write_vect(double x1, double y1, double x2, double y2,
- struct Map_info *Map, struct line_pnts *Points) /* new with Vlib */
+ struct Map_info *Map, struct line_pnts *Points, int out_type)
static struct line_cats *Cats = NULL;
@@ -132,8 +132,7 @@
if (0 > Vect_copy_xyz_to_pnts(Points, xarray, yarray, NULL, NUM_POINTS))
G_fatal_error(_("Out of memory"));
+ Vect_write_line(Map, out_type, Points, Cats);
- Vect_write_line(Map, GV_BOUNDARY, Points, Cats);
return 0;
