[GRASS-SVN] r61521 - in grass/branches/releasebranch_7_0:	raster/r.resamp.bspline scripts/r.fillnulls vector/v.surf.bspline
    svn_grass at osgeo.org
    Mon Aug  4 15:08:05 PDT 2014
Author: neteler
Date: 2014-08-04 15:08:05 -0700 (Mon, 04 Aug 2014)
New Revision: 61521
   grass/branches/releasebranch_7_0/raster/r.resamp.bspline/crosscorr.c
   grass/branches/releasebranch_7_0/raster/r.resamp.bspline/main.c
   grass/branches/releasebranch_7_0/raster/r.resamp.bspline/r.resamp.bspline.html
   grass/branches/releasebranch_7_0/scripts/r.fillnulls/r.fillnulls.py
   grass/branches/releasebranch_7_0/vector/v.surf.bspline/crosscorr.c
   grass/branches/releasebranch_7_0/vector/v.surf.bspline/main.c
   grass/branches/releasebranch_7_0/vector/v.surf.bspline/v.surf.bspline.html
r.resamp.bspline/v.surf.bspline: standardized se/sn and sie/sin parameters to ew_step/ns_step (trac #2299); manual: r.resamp.bspline example added (trunk, r61520)
Modified: grass/branches/releasebranch_7_0/raster/r.resamp.bspline/crosscorr.c
--- grass/branches/releasebranch_7_0/raster/r.resamp.bspline/crosscorr.c	2014-08-04 22:01:28 UTC (rev 61520)
+++ grass/branches/releasebranch_7_0/raster/r.resamp.bspline/crosscorr.c	2014-08-04 22:08:05 UTC (rev 61521)
@@ -195,7 +195,7 @@
 	if (nparam_spl > 22900)
 	    G_fatal_error(_("Too many splines (%d x %d). "
-			    "Consider changing spline steps \"sn=\" \"se=\"."),
+			    "Consider changing spline steps \"ew_step=\" \"ns_step=\"."),
 			  nsplx, nsply);
 	BW = P_get_BandWidth(bilin, nsply);
Modified: grass/branches/releasebranch_7_0/raster/r.resamp.bspline/main.c
--- grass/branches/releasebranch_7_0/raster/r.resamp.bspline/main.c	2014-08-04 22:01:28 UTC (rev 61520)
+++ grass/branches/releasebranch_7_0/raster/r.resamp.bspline/main.c	2014-08-04 22:08:05 UTC (rev 61521)
@@ -100,7 +100,7 @@
     mask_opt->required = NO;
     stepE_opt = G_define_option();
-    stepE_opt->key = "se";
+    stepE_opt->key = "ew_step";
     stepE_opt->type = TYPE_DOUBLE;
     stepE_opt->required = NO;
     stepE_opt->description =
@@ -108,7 +108,7 @@
     stepE_opt->guisection = _("Settings");
     stepN_opt = G_define_option();
-    stepN_opt->key = "sn";
+    stepN_opt->key = "ns_step";
     stepN_opt->type = TYPE_DOUBLE;
     stepN_opt->required = NO;
     stepN_opt->description =
@@ -183,7 +183,7 @@
     if (stepE_opt->answer) {
 	stepE = atof(stepE_opt->answer);
 	if (stepE <= .0)
-	    G_fatal_error(_("se must be positive"));
+	    G_fatal_error(_("ew_step must be positive"));
     else
         stepE = src_reg.ew_res * 1.5;
@@ -191,7 +191,7 @@
     if (stepN_opt->answer) {
 	stepN = atof(stepN_opt->answer);
 	if (stepN <= .0)
-	    G_fatal_error(_("sn must be positive"));
+	    G_fatal_error(_("ns_step must be positive"));
     else
         stepN = src_reg.ns_res * 1.5;
@@ -363,7 +363,7 @@
 	else {
 	    G_debug(1, "Cross validation finished correctly");
-	    G_done_msg(_("Cross validation finished for se = %f and sn = %f"), stepE, stepN);
+	    G_done_msg(_("Cross validation finished for ew_step = %f and ns_step = %f"), stepE, stepN);
 	    segment_release(&in_seg);	/* release memory  */
 	    close(in_fd);
Modified: grass/branches/releasebranch_7_0/raster/r.resamp.bspline/r.resamp.bspline.html
--- grass/branches/releasebranch_7_0/raster/r.resamp.bspline/r.resamp.bspline.html	2014-08-04 22:01:28 UTC (rev 61520)
+++ grass/branches/releasebranch_7_0/raster/r.resamp.bspline/r.resamp.bspline.html	2014-08-04 22:08:05 UTC (rev 61521)
@@ -1,35 +1,39 @@
 <h2>DESCRIPTION</h2>
 <em>r.resamp.bspline</em> performs a bilinear/bicubic spline interpolation with
 Tykhonov regularization. The input is a raster surface map, e.g. elevation,
 temperature, precipitation etc. Output is a raster map. Optionally, only
 input NULL cells are interpolated, useful to fill NULL cells, an alternative
 to <em><a href="r.fillnulls.html">r.fillnulls</a></em>. Using the <b>-n</b> flag to only
 interpolate NULL cells will considerably speed up the module.
-<p>The input raster map is read at its native resolution, the output raster
+<p>
+The input raster map is read at its native resolution, the output raster
 map will be produced for the current computational region set with
 <em><a href="g.region.html">g.region</a></em>. Any MASK will be respected, masked
 values will be treated as NULL cells in both the input and the output map.
-<p>Spline step values <b>se</b> for the east-west direction and
-<b>sn</b> for the north-south direction should not be smaller than
+<p>Spline step values <b>ew_step</b> for the east-west direction and
+<b>ns_step</b> for the north-south direction should not be smaller than
 the east-west and north-south resolutions of the input map. For a raster
 map without NULL cells, 1 * resolution can be used, but check for
 undershoots and overshoots. For very large areas with missing values
 (NULL cells), larger spline step values may be required, but most of the
 time the defaults (1.5 x resolution) should be fine.
-<p>The Tykhonov regularization parameter (<b>lambda</b>) acts to
+<p>
+The Tykhonov regularization parameter (<b>lambda</b>) acts to
 smooth the interpolation. With a small <b>lambda</b>, the
 interpolated surface closely follows observation points; a larger value
 will produce a smoother interpolation. Reasonable values are 0.0001,
 0.001, 0.005, 0.01, 0.02, 0.05, 0.1 (needs more testing). For seamless
 NULL cell interpolation, a small value is required and default is set to 0.005.
-<p>From a theoretical perspective, the interpolating procedure takes place in two
+<p>
+From a theoretical perspective, the interpolating procedure takes place in two
 parts: the first is an estimate of the linear coefficients of a spline function;
 these are derived from the observation points using a least squares regression; the
 second is the computation of the interpolated surface (or interpolated vector
 points). As used here, the splines are 2D piece-wise non-zero polynomial
 functions calculated within a limited 2D area. The length of each spline step
-is defined by <b>se</b> for the east-west direction and
-<b>sn</b> for the north-south direction. For optimal performance, the
+is defined by <b>ew_step</b> for the east-west direction and
+<b>ns_step</b> for the north-south direction. For optimal performance, the
 spline step values should be no less than the east-west and north-south
 resolutions of the input map. Each non-NULL cell observation is modeled as a
 linear function of the non-zero splines in the area around the observation.
@@ -61,6 +65,7 @@
 <h3>Interpolation of NULL cells and patching</h3>
+General procedure:
 <div class="code"><pre>
 # set region to area with NULL cells, align region to input map
 g.region n=north s=south e=east w=west align=input -p
@@ -72,6 +77,36 @@
 r.patch input=input_raster,interpolated_nulls output=input_raster_gapfilled
 </pre></div>
+<h3>Interpolation of NULL cells and patching (NC data)</h3>
+In this example, the SRTM elevation map in the
+North Carolina sample dataset location is filtered for outlier
+elevation values; missing pixels are then re-interpolated to obtain
+a complete elevation map:
+<div class="code"><pre>
+g.region rast=elev_srtm_30m -p
+d.mon wx0
+d.histogram elev_srtm_30m
+r.univar -e elev_srtm_30m
+# remove too low elevations (esp. lakes)
+# Threshold: thresh = Q1 - 1.5 * (Q3 - Q1)
+r.mapcalc "elev_srtm_30m_filt = if(elev_srtm_30m < 50.0, null(), elev_srtm_30m)"
+# verify
+d.histogram elev_srtm_30m_filt
+d.erase
+d.rast elev_srtm_30m_filt
+r.resamp.bspline -n input=elev_srtm_30m_filt output=elev_srtm_30m_complete \
+  method=bicubic
+d.histogram elev_srtm_30m_complete
+d.rast elev_srtm_30m_complete
+</pre></div>
 <h3>Estimation of <b>lambda</b> parameter with a cross validation proccess</h3>
 A random sample of points should be generated first with
Modified: grass/branches/releasebranch_7_0/scripts/r.fillnulls/r.fillnulls.py
--- grass/branches/releasebranch_7_0/scripts/r.fillnulls/r.fillnulls.py	2014-08-04 22:01:28 UTC (rev 61520)
+++ grass/branches/releasebranch_7_0/scripts/r.fillnulls/r.fillnulls.py	2014-08-04 22:08:05 UTC (rev 61521)
@@ -8,13 +8,13 @@
 #               Updated to GRASS 6.0 by Markus Neteler
 #               Ring and zoom improvements by Hamish Bowman
 #               Converted to Python by Glynn Clements
-#               Add support to v.surf.bspline by Luca Delucchi
+#               Added support for r.resamp.bspline by Luca Delucchi
 #               Per hole filling with RST by Maris Nartiss
 #               Speedup for per hole filling with RST by Stefan Blumentrath
 # PURPOSE:      fills NULL (no data areas) in raster maps
 #               The script respects a user mask (MASK) if present.
-# COPYRIGHT:    (C) 2001-2012 by the GRASS Development Team
+# COPYRIGHT:    (C) 2001-2014 by the GRASS Development Team
 #               This program is free software under the GNU General Public
 #               License (>=v2). Read the file COPYING that comes with GRASS
@@ -349,12 +349,12 @@
         if usermask:
             grass.run_command('r.resamp.bspline', input = input, mask = usermask,
                 output = prefix + 'filled', method = method,
-                se = 3 * reg['ewres'], sn = 3 * reg['nsres'],
+                ew_step = 3 * reg['ewres'], ns_step = 3 * reg['nsres'],
                 _lambda = 0.01, flags = 'n')
         else:
     # restoring user's mask, if present:
Modified: grass/branches/releasebranch_7_0/vector/v.surf.bspline/crosscorr.c
--- grass/branches/releasebranch_7_0/vector/v.surf.bspline/crosscorr.c	2014-08-04 22:01:28 UTC (rev 61520)
+++ grass/branches/releasebranch_7_0/vector/v.surf.bspline/crosscorr.c	2014-08-04 22:08:05 UTC (rev 61521)
@@ -149,7 +149,7 @@
-			    "Consider changing spline steps \"sie=\" \"sin=\"."),
 			  nsplx, nsply);
Modified: grass/branches/releasebranch_7_0/vector/v.surf.bspline/main.c
--- grass/branches/releasebranch_7_0/vector/v.surf.bspline/main.c	2014-08-04 22:01:28 UTC (rev 61520)
+++ grass/branches/releasebranch_7_0/vector/v.surf.bspline/main.c	2014-08-04 22:08:05 UTC (rev 61521)
@@ -131,7 +131,7 @@
-    stepE_opt->key = "sie";
     stepE_opt->answer = "4";
@@ -140,7 +140,7 @@
-    stepN_opt->key = "sin";
     stepN_opt->answer = "4";
@@ -301,7 +301,7 @@
 	    Vect_close(&In);
-	    G_done_msg(_("Cross validation finished for sie = %f and sin = %f"), stepE, stepN);
 	    exit(EXIT_SUCCESS);
Modified: grass/branches/releasebranch_7_0/vector/v.surf.bspline/v.surf.bspline.html
--- grass/branches/releasebranch_7_0/vector/v.surf.bspline/v.surf.bspline.html	2014-08-04 22:01:28 UTC (rev 61520)
+++ grass/branches/releasebranch_7_0/vector/v.surf.bspline/v.surf.bspline.html	2014-08-04 22:08:05 UTC (rev 61521)
@@ -18,14 +18,14 @@
 of the interpolated surface (or interpolated vector points). As used
 here, the splines are 2D piece-wise non-zero polynomial functions
 calculated within a limited, 2D area. The length of each spline step
-is defined by <b>sie</b> for the east-west direction and
-<b>sin</b> for the north-south direction. For optimum performance, the
 length of spline step should be no less than the distance between observation
 points. Each vector point observation is modeled as a linear function of the
 non-zero splines in the area around the observation. The least squares
 regression predicts the the coefficients of these linear functions.
-Regularization, avoids the need to have one one observation and one coefficient
-for each spline (in order to avoid instability).
+Regularization, avoids the need to have one observation and one
+coefficient for each spline (in order to avoid instability).
 <p>With regularly distributed data points, a spline step corresponding
 to the maximum distance between two points in both the east and north
@@ -40,7 +40,7 @@
 account for some degree of anisotropy in the distribution of
 observation points. Short spline step lengths - especially spline step
 lengths that are less than the distance between observation points -
-can greatly increase processing time.
+can greatly increase the processing time.
 <p>Moreover, the maximum number of splines for each direction at each
 time is fixed, regardless of the spline step length. As the total
@@ -102,7 +102,7 @@
 <h3>Basic interpolation and raster output with a longer spline step</h3>
-v.surf.bspline input=point_vector raster=interpolate_surface sie=25 sin=25
+v.surf.bspline input=point_vector raster=interpolate_surface ew_step=25 ns_step=25
 </pre></div>
 A bilinear spline interpolation will be done with a spline step length
@@ -127,7 +127,8 @@
 <h3>Using attribute values instead z-coordinates</h3>
-v.surf.bspline input=point_vector raster=interpolate_surface layer=1 column=attrib_column
+v.surf.bspline input=point_vector raster=interpolate_surface layer=1 \
+  column=attrib_column
 </pre></div>
 The interpolation will be done using the values
@@ -136,7 +137,9 @@
 <h3>North carolina location example using z-coordinates for interpolation</h3>
-v.surf.bspline input=elev_lid792_bepts raster=elev_lid792_rast sie=5 sin=5 method=bicubic lambda_i=0.1
+g.region region=rural_1m res=2 -p
+v.surf.bspline input=elev_lid792_bepts raster=elev_lid792_rast \
+  ew_step=5 ns_step=5 method=bicubic lambda_i=0.1
 </pre></div>
