[GRASS-SVN] r61525 - grass/branches/develbranch_6/display/d.legend
svn_grass at osgeo.org
Mon Aug 4 17:14:17 PDT 2014
Author: hamish
Date: 2014-08-04 17:14:17 -0700 (Mon, 04 Aug 2014)
New Revision: 61525
grass/branches/develbranch_6/display/d.legend/description.html
spelling (merge from trunk)
Modified: grass/branches/develbranch_6/display/d.legend/description.html
--- grass/branches/develbranch_6/display/d.legend/description.html 2014-08-05 00:13:28 UTC (rev 61524)
+++ grass/branches/develbranch_6/display/d.legend/description.html 2014-08-05 00:14:17 UTC (rev 61525)
@@ -28,7 +28,7 @@
create a horizontal legend by making the box wider than it is tall.
<p>
Raster maps based on floating point values will display smoothed, from greatest
-to smallest value, while categorial raster maps will display in order, from
+to smallest value, while categorical raster maps will display in order, from
top to bottom. Horizontal legends will always be smoothed. If the box is defined
with inverted y-values or an inverted <b>range</b>, the legend will automatically
flip. If this is not the desired result, the <b>-f</b> flag may be used to flip
