[GRASS-SVN] r61527 - in grass/branches/releasebranch_7_0: . vector/v.outlier
svn_grass at osgeo.org
Tue Aug 5 00:02:35 PDT 2014
Author: neteler
Date: 2014-08-05 00:02:35 -0700 (Tue, 05 Aug 2014)
New Revision: 61527
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/vector/v.outlier/main.c
grass/branches/releasebranch_7_0/vector/v.outlier/v.outlier.html
v.outlier: standardized soe/son parameters to ew_step/ns_step (trac #2299); minor code/msg style sync with v.surf.bspline (trunk, r61526)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Deleted: svn:mergeinfo
- /grass/trunk:61481
Modified: grass/branches/releasebranch_7_0/vector/v.outlier/main.c
--- grass/branches/releasebranch_7_0/vector/v.outlier/main.c 2014-08-05 06:59:29 UTC (rev 61526)
+++ grass/branches/releasebranch_7_0/vector/v.outlier/main.c 2014-08-05 07:02:35 UTC (rev 61527)
@@ -1,36 +1,36 @@
- * MODULE: v.outlier *
- * AUTHOR(S): Roberto Antolin *
- * PURPOSE: Removal of data outliers *
- * COPYRIGHT: (C) 2006 by Politecnico di Milano - *
- * Polo Regionale di Como *
- * This program is free software under the *
- * GNU General Public License (>=v2). *
- * Read the file COPYING that comes with GRASS *
- * for details. *
+ * MODULE: v.outlier
+ * AUTHOR(S): Roberto Antolin
+ * PURPOSE: Removal of data outliers
+ * COPYRIGHT: (C) 2006 by Politecnico di Milano -
+ * Polo Regionale di Como
+ * This program is free software under the
+ * GNU General Public License (>=v2).
+ * Read the file COPYING that comes with GRASS
+ * for details.
- /*INCLUDES*/
+/* INCLUDES */
#include <stdlib.h>
#include <string.h>
#include <math.h>
#include "outlier.h"
- /* GLOBAL VARIABLES DEFINITIONS */
+/* GLOBAL VARIABLES */
int nsply, nsplx;
double stepN, stepE, Thres_Outlier;
int main(int argc, char *argv[])
- /* Variables' declarations */
+ /* Variables declarations */
int nsplx_adj, nsply_adj;
int nsubregion_col, nsubregion_row;
int subregion = 0, nsubregions = 0;
@@ -48,23 +48,23 @@
double *TN, *Q, *parVect; /* Interpolating and least-square vectors */
double **N, **obsVect; /* Interpolation and least-square matrix */
- /* Structs' declarations */
+ /* Structs declarations */
struct Map_info In, Out, Outlier, Qgis;
struct Option *in_opt, *out_opt, *outlier_opt, *qgis_opt, *stepE_opt,
*stepN_opt, *lambda_f_opt, *Thres_O_opt, *filter_opt;
struct Flag *spline_step_flag;
struct GModule *module;
+ struct Reg_dimens dims;
struct Cell_head elaboration_reg, original_reg;
- struct Reg_dimens dims;
struct bound_box general_box, overlap_box;
struct Point *observ;
dbDriver *driver;
- /* Options' declaration */
+ /* Options declaration */
module = G_define_module();
G_add_keyword(_("vector"));
G_add_keyword(_("statistics"));
@@ -97,20 +97,22 @@
qgis_opt->description = _("Name of vector map for visualization in QGIS");
stepE_opt = G_define_option();
- stepE_opt->key = "soe";
+ stepE_opt->key = "ew_step";
stepE_opt->type = TYPE_DOUBLE;
stepE_opt->required = NO;
stepE_opt->answer = "10";
stepE_opt->description =
- _("Interpolation spline step value in east direction");
+ _("Length of each spline step in the east-west direction");
+ stepE_opt->guisection = _("Settings");
stepN_opt = G_define_option();
- stepN_opt->key = "son";
+ stepN_opt->key = "ns_step";
stepN_opt->type = TYPE_DOUBLE;
stepN_opt->required = NO;
stepN_opt->answer = "10";
stepN_opt->description =
- _("Interpolation spline step value in north direction");
+ _("Length of each spline step in the north-south direction");
+ stepN_opt->guisection = _("Settings");
lambda_f_opt = G_define_option();
lambda_f_opt->key = "lambda_i";
@@ -118,6 +120,7 @@
lambda_f_opt->required = NO;
lambda_f_opt->description = _("Tykhonov regularization weight");
lambda_f_opt->answer = "0.1";
+ lambda_f_opt->guisection = _("Settings");
Thres_O_opt = G_define_option();
Thres_O_opt->key = "thres_o";
@@ -136,7 +139,6 @@
/* Parsing */
G_gisinit(argv[0]);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -187,8 +189,8 @@
db_close_database_shutdown_driver(driver);
- Vect_set_open_level(1);
/* Open input vector */
+ Vect_set_open_level(1); /* WITHOUT TOPOLOGY */
if (1 > Vect_open_old(&In, in_opt->answer, mapset))
G_fatal_error(_("Unable to open vector map <%s> at the topological level"),
in_opt->answer);
@@ -243,7 +245,7 @@
Vect_hist_command(&Qgis);
- /* Start driver and open db */
+ /* Open driver and database */
driver = db_start_driver_open_database(dvr, db);
if (driver == NULL)
G_fatal_error(_("No database connection for driver <%s> is defined. Run db.connect."),
@@ -274,7 +276,7 @@
/* Fixing parameters of the elaboration region */
- P_zero_dim(&dims);
+ P_zero_dim(&dims); /* Set dim struct to zero */
nsplx_adj = NSPLX_MAX;
nsply_adj = NSPLY_MAX;
@@ -285,8 +287,8 @@
P_get_edge(P_BILINEAR, &dims, stepE, stepN);
P_set_dim(&dims, stepE, stepN, &nsplx_adj, &nsply_adj);
- G_verbose_message(_("adjusted EW splines %d"), nsplx_adj);
- G_verbose_message(_("adjusted NS splines %d"), nsply_adj);
+ G_verbose_message(_("Adjusted EW splines %d"), nsplx_adj);
+ G_verbose_message(_("Adjusted NS splines %d"), nsply_adj);
/* calculate number of subregions */
edgeE = dims.ew_size - dims.overlap - 2 * dims.edge_v;
@@ -314,23 +316,24 @@
GENERAL_ROW);
if (elaboration_reg.north > original_reg.north) { /* First row */
P_set_regions(&elaboration_reg, &general_box, &overlap_box, dims,
FIRST_ROW);
if (elaboration_reg.south <= original_reg.south) { /* Last row */
LAST_ROW);
last_row = TRUE;
nsply =
- ceil((elaboration_reg.north - elaboration_reg.south) / stepN) +
- 0.5;
+ ceil((elaboration_reg.north -
+ elaboration_reg.south) / stepN) + 0.5;
- if (nsply > NSPLY_MAX) {
+ if (nsply > NSPLY_MAX)
nsply = NSPLY_MAX;
G_debug(1, "nsply = %d", nsply);
@@ -341,31 +344,31 @@
subregion++;
if (nsubregions > 1)
- G_message(_("subregion %d of %d"), subregion, nsubregions);
+ G_message(_("Processing subregion %d of %d..."), subregion, nsubregions);
else /* v.outlier -e will report mean point distance: */
- G_warning(_("No subregions found! Check values for 'soe' and 'son' parameters"));
+ G_warning(_("No subregions found! Check values for 'ew_step' and 'ns_step' parameters"));
GENERAL_COLUMN);
if (elaboration_reg.west < original_reg.west) { /* First column */
dims, FIRST_COLUMN);
if (elaboration_reg.east >= original_reg.east) { /* Last column */
dims, LAST_COLUMN);
last_column = TRUE;
nsplx =
- ceil((elaboration_reg.east - elaboration_reg.west) / stepE) +
- 0.5;
+ ceil((elaboration_reg.east -
+ elaboration_reg.west) / stepE) + 0.5;
- if (nsplx > NSPLX_MAX) {
+ if (nsplx > NSPLX_MAX)
nsplx = NSPLX_MAX;
G_debug(1, "nsplx = %d", nsplx);
@@ -380,7 +383,7 @@
nparameters = nsplx * nsply;
- /* Mean's calculation */
+ /* Mean calculation */
mean = P_Mean_Calc(&elaboration_reg, observ, npoints);
/* Least Squares system */
@@ -437,16 +440,16 @@
else {
G_free(observ);
G_warning(_("No data within this subregion. "
- "Consider changing the spline step."));
+ "Consider increasing spline step values."));
} /*! END WHILE; last_column = TRUE */
} /*! END WHILE; last_row = TRUE */
- /* Dropping auxiliar table */
+ /* Drop auxiliar table */
if (npoints > 0) {
- G_debug(1, "Dropping <%s>", table_name);
+ G_debug(1, "%s: Dropping <%s>", argv[0], table_name);
if (P_Drop_Aux_Table(driver, table_name) != DB_OK)
- G_fatal_error(_("Auxiliar table could not be dropped"));
+ G_fatal_error(_("Auxiliary table could not be dropped"));
@@ -462,4 +465,4 @@
G_done_msg(" ");
exit(EXIT_SUCCESS);
-} /*!END MAIN */
+} /*END MAIN */
Modified: grass/branches/releasebranch_7_0/vector/v.outlier/v.outlier.html
--- grass/branches/releasebranch_7_0/vector/v.outlier/v.outlier.html 2014-08-05 06:59:29 UTC (rev 61526)
+++ grass/branches/releasebranch_7_0/vector/v.outlier/v.outlier.html 2014-08-05 07:02:35 UTC (rev 61527)
@@ -44,7 +44,8 @@
<h3>North carolina location example</h3>
<div class="code"><pre>
-v.outlier --o --v input=elev_lid792_bepts at PERMANENT output=elev_lid792_bepts_nooutliers outlier=elev_lid792_bepts_outliers soe=5 son=5 thres_o=0.1
+v.outlier input=elev_lid792_bepts output=elev_lid792_bepts_nooutliers \
+ outlier=elev_lid792_bepts_outliers ew_step=5 ns_step=5 thres_o=0.1
</pre></div>
