[GRASS-SVN] r61532 - in grass/trunk: include include/defs lib/raster3d
svn_grass at osgeo.org
Tue Aug 5 11:43:31 PDT 2014
Author: annakrat
Date: 2014-08-05 11:43:31 -0700 (Tue, 05 Aug 2014)
New Revision: 61532
Added:
grass/trunk/lib/raster3d/gradient.c
grass/trunk/include/defs/raster3d.h
grass/trunk/include/raster3d.h
libraster3d: add gradient computation for r3.flow and r3.gradient developed during GSoC 2014
Modified: grass/trunk/include/defs/raster3d.h
--- grass/trunk/include/defs/raster3d.h 2014-08-05 15:10:58 UTC (rev 61531)
+++ grass/trunk/include/defs/raster3d.h 2014-08-05 18:43:31 UTC (rev 61532)
@@ -112,6 +112,11 @@
int Rast3d_init_copy_from_xdr(RASTER3D_Map *, int);
int Rast3d_copy_from_xdr(int, void *);
+/* gradient.c */
+void Rast3d_gradient_double(RASTER3D_Array_double *, double *,
+ RASTER3D_Array_double *, RASTER3D_Array_double *,
+ RASTER3D_Array_double *);
/* history.c */
int Rast3d_write_history(const char *, struct History *);
int Rast3d_read_history(const char *, const char *, struct History *);
Modified: grass/trunk/include/raster3d.h
--- grass/trunk/include/raster3d.h 2014-08-05 15:10:58 UTC (rev 61531)
+++ grass/trunk/include/raster3d.h 2014-08-05 18:43:31 UTC (rev 61532)
@@ -255,7 +255,19 @@
typedef int read_fn(int, void *, void *);
+/* for storing values of 3D raster block in a flat array */
+typedef struct
+ DCELL *array;
+ int sx;
+ int sy;
+ int sz;
+} RASTER3D_Array_double;
+#define RASTER3D_ARRAY_ACCESS(arr, x, y, z) \
+ ((arr)->array[(arr)->sx * (arr)->sy * (z) + (arr)->sx * (y) + (x)])
/*============================== Prototypes ================================*/
#include <grass/defs/raster3d.h>
Added: grass/trunk/lib/raster3d/gradient.c
--- grass/trunk/lib/raster3d/gradient.c (rev 0)
+++ grass/trunk/lib/raster3d/gradient.c 2014-08-05 18:43:31 UTC (rev 61532)
@@ -0,0 +1,96 @@
+ \file gradient.c
+ \brief Gradient computation
+ (C) 2014 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+ \author Anna Petrasova
+ Gradient computation (second order approximation)
+ using central differencing scheme (plus forward and backward
+ difference of second order approx.)
+ \param array pointer to RASTER3D_Array with input values
+ \param step array of x, y, z steps for gradient (resolution values)
+ \param[out] grad_x pointer to RASTER3D_Array_double with gradient in x direction
+ \param[out] grad_y pointer to RASTER3D_Array_double with gradient in y direction
+ \param[out] grad_z pointer to RASTER3D_Array_double with gradient in z direction
+#include <grass/raster3d.h>
+void Rast3d_gradient_double(RASTER3D_Array_double *array, double *step,
+ RASTER3D_Array_double *grad_x,
+ RASTER3D_Array_double *grad_y,
+ RASTER3D_Array_double *grad_z)
+ int col, row, depth;
+ for (depth = 0; depth < array->sz; depth++) {
+ for (row = 0; row < array->sy; row++) {
+ RASTER3D_ARRAY_ACCESS(grad_x, 0, row, depth) =
+ (-3 * RASTER3D_ARRAY_ACCESS(array, 0, row, depth) +
+ 4 * RASTER3D_ARRAY_ACCESS(array, 1, row, depth) -
+ RASTER3D_ARRAY_ACCESS(array, 2, row, depth)) / (2 * step[0]);
+ RASTER3D_ARRAY_ACCESS(grad_x, array->sx - 1, row, depth) =
+ (3 * RASTER3D_ARRAY_ACCESS(array, array->sx - 1, row, depth) -
+ 4 * RASTER3D_ARRAY_ACCESS(array, array->sx - 2, row, depth) +
+ RASTER3D_ARRAY_ACCESS(array, array->sx - 3, row, depth)) / (2 * step[0]);
+ for (col = 1; col < array->sx - 1; col++) {
+ RASTER3D_ARRAY_ACCESS(grad_x, col, row, depth) =
+ (RASTER3D_ARRAY_ACCESS(array, col + 1, row, depth) -
+ RASTER3D_ARRAY_ACCESS(array, col - 1, row, depth)) / (2 * step[0]);
+ for (col = 0; col < array->sx; col++) {
+ RASTER3D_ARRAY_ACCESS(grad_y, col, 0, depth) =
+ -(-3 * RASTER3D_ARRAY_ACCESS(array, col, 0, depth) +
+ 4 * RASTER3D_ARRAY_ACCESS(array, col, 1, depth) -
+ RASTER3D_ARRAY_ACCESS(array, col, 2, depth)) / (2 * step[1]);
+ RASTER3D_ARRAY_ACCESS(grad_y, col, array->sy - 1, depth) =
+ -(3 * RASTER3D_ARRAY_ACCESS(array, col, array->sy - 1, depth) -
+ 4 * RASTER3D_ARRAY_ACCESS(array, col, array->sy - 2, depth) +
+ RASTER3D_ARRAY_ACCESS(array, col, array->sy - 3, depth)) / (2 * step[1]);
+ for (row = 1; row < array->sy - 1; row++) {
+ RASTER3D_ARRAY_ACCESS(grad_y, col, row, depth) =
+ -(RASTER3D_ARRAY_ACCESS(array, col, row + 1, depth) -
+ RASTER3D_ARRAY_ACCESS(array, col, row - 1, depth)) / (2 * step[1]);
+ RASTER3D_ARRAY_ACCESS(grad_z, col, row, 0) =
+ (-3 * RASTER3D_ARRAY_ACCESS(array, col, row, 0) +
+ 4 * RASTER3D_ARRAY_ACCESS(array, col, row, 1) -
+ RASTER3D_ARRAY_ACCESS(array, col, row, 2)) / (2 * step[2]);
+ RASTER3D_ARRAY_ACCESS(grad_z, col, row, array->sz - 1) =
+ (3 * RASTER3D_ARRAY_ACCESS(array, col, row, array->sz - 1) -
+ 4 * RASTER3D_ARRAY_ACCESS(array, col, row, array->sz - 2) +
+ RASTER3D_ARRAY_ACCESS(array, col, row, array->sz - 3)) / (2 * step[2]);
+ for (depth = 1; depth < array->sz - 1; depth++) {
+ RASTER3D_ARRAY_ACCESS(grad_z, col, row, depth) =
+ (RASTER3D_ARRAY_ACCESS(array, col, row, depth + 1) -
+ RASTER3D_ARRAY_ACCESS(array, col, row, depth - 1)) / (2 * step[2]);
