[GRASS-SVN] r61534 - in grass/branches/releasebranch_7_0: . vector/v.distance
svn_grass at osgeo.org
Tue Aug 5 12:45:28 PDT 2014
Author: neteler
Date: 2014-08-05 12:45:28 -0700 (Tue, 05 Aug 2014)
New Revision: 61534
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/vector/v.distance/local_proto.h
grass/branches/releasebranch_7_0/vector/v.distance/main.c
grass/branches/releasebranch_7_0/vector/v.distance/print.c
v.distance: Added separator= for -p (trunk, r60986)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Added: svn:mergeinfo
+ /grass/trunk:60986
Modified: grass/branches/releasebranch_7_0/vector/v.distance/local_proto.h
--- grass/branches/releasebranch_7_0/vector/v.distance/local_proto.h 2014-08-05 18:48:33 UTC (rev 61533)
+++ grass/branches/releasebranch_7_0/vector/v.distance/local_proto.h 2014-08-05 19:45:28 UTC (rev 61534)
@@ -64,4 +64,4 @@
int geodesic);
/* print.c */
-int print_upload(NEAR *, UPLOAD *, int, dbCatValArray *, dbCatVal *);
+int print_upload(NEAR *, UPLOAD *, int, dbCatValArray *, dbCatVal *, char *);
Modified: grass/branches/releasebranch_7_0/vector/v.distance/main.c
--- grass/branches/releasebranch_7_0/vector/v.distance/main.c 2014-08-05 18:48:33 UTC (rev 61533)
+++ grass/branches/releasebranch_7_0/vector/v.distance/main.c 2014-08-05 19:45:28 UTC (rev 61534)
@@ -44,6 +44,7 @@
*from_field, *to_field;
struct Option *out, *max, *min, *table;
struct Option *upload, *column, *to_column;
+ struct Option *sep;
} opt;
struct {
struct Flag *print, *all;
@@ -76,6 +77,7 @@
struct bound_box fbox, box;
dbCatValArray cvarr;
dbColumn *column;
+ char *sep;
do_all = FALSE;
print_as_matrix = FALSE;
@@ -198,6 +200,9 @@
opt.table->description =
_("Name of table created when the 'distance to all' flag is used");
+ opt.sep = G_define_standard_option(G_OPT_F_SEP);
+ opt.sep->label = _("Field separator for printing output to stdout");
flag.print = G_define_flag();
flag.print->key = 'p';
flag.print->label =
@@ -286,6 +291,8 @@
if (Upload[i].upload != END)
G_fatal_error(_("Not enough column names"));
+ sep = G_option_to_separator(opt.sep);
/* Open 'from' vector */
Vect_set_open_level(2);
Vect_open_old2(&From, opt.from->answer, G_mapset(), opt.from_field->answer);
@@ -1244,10 +1251,10 @@
if (flag.print->answer) { /* print header */
fprintf(stdout, "from_cat");
if (do_all)
- fprintf(stdout, "|to_cat");
+ fprintf(stdout, "%sto_cat", sep);
i = 0;
while (Upload[i].upload != END) {
- fprintf(stdout, "|%s", Upload[i].column);
+ fprintf(stdout, "%s%s", sep, Upload[i].column);
i++;
fprintf(stdout, "\n");
@@ -1357,14 +1364,14 @@
for (j = 0; j < nfrom; j++) {
if (j == 0)
fprintf(stdout, " ");
- fprintf(stdout, "|%d", Near[j].to_cat);
+ fprintf(stdout, "%s%d", sep, Near[j].to_cat);
if (i % nfrom == 0) {
fprintf(stdout, "%d", Near[i].from_cat);
- print_upload(Near, Upload, i + j, &cvarr, catval);
+ print_upload(Near, Upload, i + j, &cvarr, catval, sep);
@@ -1372,8 +1379,8 @@
else {
if (do_all)
- fprintf(stdout, "|%d", Near[i].to_cat);
- print_upload(Near, Upload, i, &cvarr, catval);
+ fprintf(stdout, "%s%d", sep, Near[i].to_cat);
+ print_upload(Near, Upload, i, &cvarr, catval, sep);
Modified: grass/branches/releasebranch_7_0/vector/v.distance/print.c
--- grass/branches/releasebranch_7_0/vector/v.distance/print.c 2014-08-05 18:48:33 UTC (rev 61533)
+++ grass/branches/releasebranch_7_0/vector/v.distance/print.c 2014-08-05 19:45:28 UTC (rev 61534)
@@ -4,70 +4,70 @@
print out upload values
int print_upload(NEAR * Near, UPLOAD * Upload, int i,
- dbCatValArray * cvarr, dbCatVal * catval)
+ dbCatValArray * cvarr, dbCatVal * catval, char *sep)
int j;
j = 0;
while (Upload[j].upload != END) {
if (Near[i].count == 0) { /* no nearest found */
- fprintf(stdout, "|null");
+ fprintf(stdout, "%snull", sep);
else {
switch (Upload[j].upload) {
case CAT:
if (Near[i].to_cat >= 0)
else
break;
case DIST:
- fprintf(stdout, "|%.17g", Near[i].dist);
+ fprintf(stdout, "%s%.17g", sep, Near[i].dist);
break;
case FROM_X:
- fprintf(stdout, "|%.17g", Near[i].from_x);
+ fprintf(stdout, "%s%.17g", sep, Near[i].from_x);
break;
case FROM_Y:
- fprintf(stdout, "|%.17g", Near[i].from_y);
+ fprintf(stdout, "%s%.17g", sep, Near[i].from_y);
break;
case TO_X:
- fprintf(stdout, "|%.17g", Near[i].to_x);
+ fprintf(stdout, "%s%.17g", sep, Near[i].to_x);
break;
case TO_Y:
- fprintf(stdout, "|%.17g", Near[i].to_y);
+ fprintf(stdout, "%s%.17g", sep, Near[i].to_y);
break;
case FROM_ALONG:
- fprintf(stdout, "|%.17g", Near[i].from_along);
+ fprintf(stdout, "%s%.17g", sep, Near[i].from_along);
break;
case TO_ALONG:
- fprintf(stdout, "|%.17g", Near[i].to_along);
+ fprintf(stdout, "%s%.17g", sep, Near[i].to_along);
break;
case TO_ANGLE:
- fprintf(stdout, "|%f", Near[i].to_angle);
+ fprintf(stdout, "%s%f", sep, Near[i].to_angle);
break;
case TO_ATTR:
if (catval) {
switch (cvarr->ctype) {
case DB_C_TYPE_INT:
- fprintf(stdout, "|%d", catval->val.i);
+ fprintf(stdout, "%s%d", sep, catval->val.i);
break;
case DB_C_TYPE_DOUBLE:
- fprintf(stdout, "|%.17g", catval->val.d);
+ fprintf(stdout, "%s%.17g", sep, catval->val.d);
break;
case DB_C_TYPE_STRING:
- fprintf(stdout, "|%s", db_get_string(catval->val.s));
+ fprintf(stdout, "%s%s", sep, db_get_string(catval->val.s));
break;
case DB_C_TYPE_DATETIME:
/* TODO: formating datetime */
- fprintf(stdout, "|");
+ fprintf(stdout, "%s", sep);
break;
else {
break;
