[GRASS-SVN] r61538 - in sandbox/krejcmat/src: . templates
Tue Aug 5 15:04:09 PDT 2014
Author: krejcmat
Date: 2014-08-05 15:04:08 -0700 (Tue, 05 Aug 2014)
New Revision: 61538
   sandbox/krejcmat/src/editor3.py
   sandbox/krejcmat/src/g.gui.metadata.py
   sandbox/krejcmat/src/mdgrass.py
   sandbox/krejcmat/src/mdutil.py
   sandbox/krejcmat/src/templates/grassGRASSTemplateFinal.xml
   sandbox/krejcmat/src/templates/grassInspireTemplateFinal.xml
fix dynamic removing of keywords widgets. etc
Modified: sandbox/krejcmat/src/editor3.py
--- sandbox/krejcmat/src/editor3.py	2014-08-05 21:45:19 UTC (rev 61537)
+++ sandbox/krejcmat/src/editor3.py	2014-08-05 22:04:08 UTC (rev 61538)
@@ -18,11 +18,11 @@
 import copy
 import re
 import os
-import string
 import logging
 from core.gcmd import RunCommand, GError, GMessage
 from gui_core.widgets import IntegerValidator, NTCValidator,SimpleValidator,\
-                            TimeISOValidator, EmailValidator,EmptyValidator
+                            TimeISOValidator, EmailValidator#,EmptyValidator
 import sys
 import mdutil
@@ -35,7 +35,7 @@
     def __init__(self, pathToXml=None):
         self.path = pathToXml
         self.owslibInfo = None
     def initMD(self, path=None):
         if path is None:
             self.md = MD_Metadata(md=None)
@@ -44,13 +44,12 @@
             io=open(path,'r')
             str1=''
             for line in io.readlines():
-                str1+=self._removeNonAscii(line)
+                str1+=mdutil.removeNonAscii(line)
             io.close()
             io1=open(path,'w')
             io1.write(str1)
             io1.close()
-            #mdutil
             try:
                 tree = ET.parse(path)
                 root = tree.getroot()
@@ -61,13 +60,7 @@
             except  Exception, e:
                 GError('Error loading xml:\n'+str(e))
-    def _removeNonAscii(self,s):
-        s= filter(lambda x: x in string.printable, s)
-        return s
-    def saveToXML(self, md,owsTagList, jinjaPath, outPath=None, xmlOutName=None):
+    def saveToXML(self, md,owsTagList, jinjaPath, outPath=None, xmlOutName=None,msg=True):
          # if  output file name is None, use map name and add postfix
         self.dirpath = os.path.dirname(os.path.realpath(__file__))
         self.md = md
@@ -88,7 +81,7 @@
         str1=''
         for line in xml.readlines():
-            line=self._removeNonAscii(line)
+            line==mdutil.removeNonAscii(line)
             str1+=line
         xml.close
         io=open(jinjaPath,'w')
@@ -111,10 +104,13 @@
             xml_file = open(outPath, "w")
             xml_file.write(iso_xml)
             xml_file.close()
-            GMessage('File exported to: %s'% outPath)
+            if msg:
+                GMessage('File exported to: %s'% outPath)
+            return outPath
                 GError('Error writing xml:\n'+str(e))
-        return outPath
 # CREATE BOX (staticbox+button(optional)
@@ -125,11 +121,7 @@
         wx.Panel.__init__(self, parent=parent, id=wx.ID_ANY)
         self.label = label
         self.mdItems = list()
-        self.stbox = wx.StaticBox(
-            self,
-            label=label,
-            id=ID_ANY,
-            style=wx.RAISED_BORDER)
+        self.stbox = wx.StaticBox(self,label=label,id=ID_ANY,style=wx.RAISED_BORDER)
         self.stbox.SetForegroundColour((0, 0, 0))
         self.stbox.SetBackgroundColour((200, 200, 200))
         self.stbox.SetFont(wx.Font(12, wx.NORMAL, wx.NORMAL, wx.NORMAL))
@@ -159,60 +151,45 @@
             self.stBoxSizer.AddSpacer(5, 5, 1, wx.EXPAND)
         if multi:
-            self.addBoxButt = wx.Button(
-                self,
-                id=ID_ANY,
-                size=(
-                    30,
-                    30),
-                label='+')
+            self.addBoxButt = wx.Button(self,id=ID_ANY,size=(30,30),label='+')
             self.boxButtonSizer.Add(self.addBoxButt, 0)
             self.addBoxButt.Bind(EVT_BUTTON, self.duplicateBox)
         if rmMulti:
-            self.rmBoxButt = wx.Button(
-                self,
-                id=ID_ANY,
-                size=(
-                    30,
-                    30),
-                label='-')
+            self.rmBoxButt = wx.Button(self,id=ID_ANY,size=(30,30),label='-')
             self.boxButtonSizer.Add(self.rmBoxButt, 0)
             self.rmBoxButt.Bind(EVT_BUTTON, self.removeBox)
     def addDuplicatedItem(self, item, id):
-        self.mdItems.append(item)
+        #self.mdItems.append(item)
         self.stBoxSizer.Add(item, flag=wx.EXPAND, proportion=1)
-        # self.SetSizerAndFit(self.stBoxSizer)
+        #w, h = self.GetParent().GetClientSize()
+        self.GetParent().Layout()
+        #self.GetParent().SetSize((w+1, h+1))
-        # self.stbox.Fit()
-        w, h = self.GetParent().GetClientSize()
-        self.GetParent().SetSize((w + 1, h + 1))
-        # self.stbox.SetSize()
     def getCtrlID(self):
         return self.GetId()
     def removeBox(self, evt):
         for item in self.mdItems:
-            # remove from MdDescritpion()
             item.mdDescription.removeMdItem(item)
         self.GetParent().removeBox(self)
     def removeMdItem(self, mdDes, items):
         mdDes.mdDescription.removeMdItem(mdDes)
-        #self.stBoxSizer.Remove(mdDes)
-        #self.stbox.Refresh()
         for item in items:
-            item.Destroy()
-        #mdDes.Destroy()
-        #self.panelSizer.Fit()
-        #self.SetSizerAndFit(self.panelSizer)
-        #self.SetSizerAndFit(self.stBoxSizer)
+            try:
+                item.Destroy()
+            except:
+                pass
+        self.stBoxSizer.RemovePos(-1)
+        self.stBoxSizer.Remove(mdDes)
+        #self.stbox.Layout()
+        #self.stBoxSizer.Layout()
+        #self.panelSizer.Layout()
     def duplicateBox(self, evt):
         parent = self.GetParent()
@@ -227,20 +204,26 @@
         if boxlabel:
             itemList = list()
             self.mdBox = MdBox(parent, boxlabel)
-            for i in mdItems:
-                i = i.mdDescription
-                mdItem1 = MdItem(self.mdBox, i)
-                # mdItem1.setValue('')
+            for i in mdItems:#check if item has multiple button
+                try:
+                    i.addItemButt.GetLabel()
+                    multi=True
+                except:
+                    multi=False
+                i = i.mdDescription
+                mdItem1 = MdItem(parent=self.mdBox,item= i,multiplicity=multi,isFirstNum=1)
                 itemList.append(mdItem1)
                 i.addMdItem(mdItem1)
-                # #print i.mdItem
             self.mdBox.addItems(itemList, False, True)
         else:
-            self.mdItem = MdItem(parent, mdItems, False, True)
+            self.mdItem = MdItem(parent=parent,
+                                item= mdItems,
+                                multiplicity=False,
+                                rmMulti=True,
+                                isFirstNum=-1)
             if mdItems.inbox is not None:
-                #print 'here------------1'
                 mdItems.addMdItem(self.mdItem, mdItemOld)
             else:
                 mdItems.addMdItem(self.mdItem)
@@ -251,7 +234,6 @@
 # ADD METADATA ITEM (label+ctrlText+button(optional)
 class MdItem(wx.BoxSizer):
     def __init__(self,parent,item,multiplicity=None,rmMulti=False,isFirstNum=-1,chckBox=False):
@@ -259,7 +241,9 @@
         self.isValid=False
         self.isChecked=False
         self.mdDescription = item
+        self.chckBox=chckBox
+        self.multiple=multiplicity
         if multiplicity is None:
             self.multiple = item.multiplicity
@@ -271,7 +255,7 @@
         self.tagText = wx.StaticText(parent=parent, id=ID_ANY, label=item.name)
-        if chckBox ==False:
+        if self.chckBox ==False:
             if item.multiline is True:
                 self.valueCtrl = wx.TextCtrl(parent, id=ID_ANY, size=(0, 55),
                                              validator=self.validators(item.type),
@@ -305,19 +289,18 @@
             self.rmItemButt = wx.Button(parent, -1, size=(30, 30), label='-')
             self.rmItemButt.Bind(EVT_BUTTON, self.removeItem)
-        if chckBox:
-            self.chckBox=wx.CheckBox(parent, -1, size=(30, 30))
-            self.chckBox.Bind(wx.EVT_CHECKBOX,self.onChangeChckBox)
-            self.chckBox.SetValue(True)
+        if self.chckBox:
+            self.chckBoxEdit=wx.CheckBox(parent, -1, size=(30, 30))
+            self.chckBoxEdit.Bind(wx.EVT_CHECKBOX,self.onChangeChckBox)
+            self.chckBoxEdit.SetValue(True)
             self.isChecked=True
             self.valueCtrl.Disable()
         self.createInfo()
         self.tip = wx.ToolTip(self.infoTip)
-        self._addItemLay(item.multiline, rmMulti,chckBox)
+        self._addItemLay(item.multiline, rmMulti)
     def validators(self,validationStyle):
         if validationStyle=='email':
@@ -336,7 +319,7 @@
         return SimpleValidator('')
     def onChangeChckBox(self,evt):
-        self.isChecked=self.chckBox.GetValue()
+        self.isChecked=self.chckBoxEdit.GetValue()
         if self.isChecked:
         else:
@@ -348,26 +331,25 @@
     def createInfo(self):
         string = ''
         if self.mdDescription.ref is not None:
-            string += self.mdDescription.ref + '\n\n'
+            string += self.mdDescription.ref+'\n\n'
         if self.mdDescription.name is not None:
-            string += 'NAME: \n' + self.mdDescription.name + '\n\n'
+            string += 'NAME: \n'+self.mdDescription.name+'\n\n'
         if self.mdDescription.desc is not None:
-            string += 'DESCRIPTION: \n' + self.mdDescription.desc + '\n\n'
+            string += 'DESCRIPTION: \n'+self.mdDescription.desc+'\n\n'
         if self.mdDescription.example is not None:
-            string += 'EXAMPLE: \n' + self.mdDescription.example + '\n\n'
+            string += 'EXAMPLE: \n'+self.mdDescription.example+'\n\n'
         if self.mdDescription.type is not None:
-            string += 'DATA TYPE: \n' + self.mdDescription.type + '\n\n'
-        string += '- -'*30 + '\n'
+            string += 'DATA TYPE: \n'+self.mdDescription.type+'\n\n'
+        string += '- -'*30+'\n'
         if self.mdDescription.statements is not None:
-            string += 'Jinja template info: \n' + self.mdDescription.statements + '\n'
+            string += 'Jinja template info: \n'+self.mdDescription.statements+'\n'
         if self.mdDescription.statements1 is not None:
-            string +=  self.mdDescription.statements1 + '\n'
-        string += 'OWSLib info:\n' + self.mdDescription.tag
+            string +=  self.mdDescription.statements1+'\n'
+        string += 'OWSLib info:\n'+self.mdDescription.tag
         self.infoTip = string
     def removeItem(self, evt):
-        # remove widgets from
         list = [self.valueCtrl, self.tagText]
         try:
             list.append(self.rmItemButt)
@@ -375,7 +357,6 @@
             pass
         try:
             list.append(self.chckBox)
         except:
             pass
         self.valueCtrl.GetParent().removeMdItem(self, list)
@@ -387,10 +368,7 @@
         parent = self.valueCtrl.GetParent()
         # if parent box
         if self.mdDescription.inbox:
-            duplicator = MdWxDuplicator(
-                mdItems=self.mdDescription,
-                parent=parent,
-                mdItemOld=self)
+            duplicator = MdWxDuplicator( mdItems=self.mdDescription,parent=parent,mdItemOld=self)
         else:
             duplicator = MdWxDuplicator(self.mdDescription, parent)
@@ -401,16 +379,24 @@
             self.valueCtrl.GetId())
     def setValue(self, value):
-        ##print "value ",value
         if value is None or value is '':
-            self.valueCtrl.SetBackgroundColour((245,204,230))#red
+            if self.chckBox:
+                self.chckBoxEdit.SetValue(False)
+                self.isChecked=False
+                self.valueCtrl.SetBackgroundColour((245,204,230))#red
             self.valueCtrl.SetValue('')
+            self.valueCtrl.Enable()
-        elif value=='$NULL':
+        elif self.chckBox and value=='$NULL':
             self.valueCtrl.SetBackgroundColour((255,255,82))#yellow
+            if self.chckBox:
+        elif value=='$NULL':
+            self.valueCtrl.SetValue('')
         else:
             value=value.replace('"','')
             value=value.replace("'",'')
@@ -419,7 +405,6 @@
     def getValue(self):
         return mdutil.replaceXMLReservedChar(self.valueCtrl.GetValue())
@@ -431,7 +416,7 @@
         else:
             return None
-    def _addItemLay(self, multiline, rmMulti, chckBox):
+    def _addItemLay(self, multiline, rmMulti):
         self.textFieldSizer = wx.BoxSizer(wx.HORIZONTAL)
         if multiline is True:
             self.textFieldSizer.Add(self.valueCtrl,proportion=1,flag=wx.EXPAND)
@@ -439,19 +424,16 @@
             self.textFieldSizer.Add(self.valueCtrl, proportion=1)
         if self.multiple:
-                self.textFieldSizer.Add(self.addItemButt, 0)
+            self.textFieldSizer.Add(self.addItemButt, 0)
         if rmMulti:
-                self.textFieldSizer.Add(self.rmItemButt, 0)
+            self.textFieldSizer.Add(self.rmItemButt, 0)
-        if chckBox:
-                self.textFieldSizer.Add(self.chckBox, 0)
+        if self.chckBox:
+            self.textFieldSizer.Add(self.chckBoxEdit, 0)
         self.Add(item=self.tagText, proportion=0)
         self.Add(item=self.textFieldSizer, proportion=0, flag=wx.EXPAND)
 # ADD NOTEBOOK PAGE
@@ -470,7 +452,6 @@
         self.SetSizer(self.mainSizer)
     def _getIndex(self):
         self.sizerIndex += 1
         return self.sizerIndex
@@ -487,7 +468,6 @@
                     self.sizerIndexDict[i.getCtrlID()] = self._getIndex()
                     self.mainSizer.Add(i, proportion=0, flag=wx.EXPAND)
         else:
             self.sizerIndexDict[item.getCtrlID()] = self._getIndex()
             self.mainSizer.Add(item, proportion=0, flag=wx.EXPAND)
@@ -609,16 +589,9 @@
             for c in range(self.max):
                 if '|length' in str(tagStringLst[c]):
                     a = tagStringLst[c]
-                    a = a.replace(
-                            '|length',
-                            ')').replace(
-                            'if ',
-                            'if len(self.')
+                    a = a.replace('|length',')').replace('if ','if len(self.')
                     tagStringLst[c] = a
                 if 'zip(' in tagStringLst[c]:
                     sta = tagStringLst[c]
                     tagStringLst[c] = sta.replace('md.', 'self.md.')
@@ -635,7 +608,6 @@
                 tab1='\t'
                 staTMP=staTMP.replace('\t','')+":\n"+tab+'self.isValidS=True'
-            #print staTMP
             try:#if loop for in for
                 self.executeStr(staTMP, False)
             except:
@@ -648,11 +620,10 @@
             else:
                 return tab1+'for n in range(1)'
-        def inBlock():  # function in def initCreatorMD(self):   !!!
+        def inBlock():
             @note:
-            ##print 'c--' , self.c
             IFStatements = False
             statements = tagStringLst[self.c - 1]
             if 'if' in statements.split():
@@ -662,17 +633,15 @@
             str2 = 'numOfSameBox=0\n'
             str2 += looptmp
             str2 += ':\n'
-            str2 += '\t' + 'self.ItemList=list()\n'  # initialize list
-            str2 += '\t' + 'numOfSameBox+=1\n'
+            str2 += '\t'+'self.ItemList=list()\n'  # initialize list
+            str2 += '\t'+'numOfSameBox+=1\n'
             box = False
             if self.mdDescription[self.c].inbox:
                 box = True
-                str2 += '\t' + \
-                    'box=MdBox(self.nbPage,mdDescrObj[' + str(self.c) + '].inbox)\n'  # add box
+                str2 += '\t'+'box=MdBox(self.nbPage,mdDescrObj['+str(self.c)+'].inbox)\n'  # add box
             str1 = str2
             itemCounter=1
@@ -684,31 +653,27 @@
                           and 'if' not in str(tagStringLst[self.c]).split():
                     value = str(self.mdOWSTagStrList[self.c])
-                    str1 += '\t' + \
-                        'self.mdDescription[' + str(self.c) + "].addStatements('" + loop + "')\n"
+                    str1 +='\t'+'self.mdDescription['+str(self.c)+"].addStatements('"+loop+"')\n"
                     if box:
-                        str1 += '\t' + \
-                            'it=MdItem(parent=box,item=mdDescrObj[' + str(self.c) + '],isFirstNum=numOfSameBox,chckBox=self.templateEditor)\n'
+                        str1 +=     '\t'+'it=MdItem(parent=box,item=mdDescrObj['+str(self.c)+'],isFirstNum=numOfSameBox,chckBox=self.templateEditor)\n'
                     else:
-                        str1 += '\t' + \
-                            'it=MdItem(parent=self.nbPage,item=mdDescrObj[' + str(self.c) + '],isFirstNum=numOfSameBox,chckBox=self.templateEditor)\n'
+                        str1 +=     '\t'+ 'it=MdItem(parent=self.nbPage,item=mdDescrObj['+str(self.c)+'],isFirstNum=numOfSameBox,chckBox=self.templateEditor)\n'
                     if self.isValidS: #if metatdata are loaded to owslib
                         if IFStatements:
-                            str1 += '\t' + 'it.setValue(self.' + str(value) + ')\n'
+                            str1 += '\t'+'it.setValue(self.'+str(value)+')\n'
                         else:
-                            str1 += '\t' + 'it.setValue(' + str(value) + ')\n'
+                            str1 += '\t'+'it.setValue('+str(value)+')\n'
                     else:
                         if IFStatements:
-                            str1 += '\t' + 'it.setValue("")\n'
+                            str1 += '\t'+'it.setValue("")\n'
                         else:
-                    str1 += '\t' + \
-                        'self.mdDescription[' + str(self.c) + '].addMdItem(it)\n'
-                    str1 += '\t' + 'self.ItemList.append(it)\n'
-                    tab = '\t'
+                    str1 +=         '\t'+'self.mdDescription['+str(self.c)+'].addMdItem(it)\n'
+                    str1 +=         '\t'+'self.ItemList.append(it)\n'
+                    tab =           '\t'
                     self.plusC()
                 else:  # if statements in statements
@@ -718,13 +683,13 @@
                     if '["keywords"]' in statements:
                         keyword = True
-                        str2 += '\t' + 'self.keywordsList=[]\n'
+                        str2 += '\t'+'self.keywordsList=[]\n'
-                    str2 += '\t' + 'numOfSameItem=0\n'
+                    str2 += '\t'+'numOfSameItem=0\n'
                     loop2=statements.replace(' md.', ' self.md.')
                     looptmp1=chckIfJumpToLoop(loop2)
                     #print '============'*5
-                    str2 += looptmp1 + ':\n'
+                    str2 += looptmp1+':\n'
                     self.plusC()
                     str1 += str2
                     itemCounter+=1
@@ -732,46 +697,35 @@
                         itemCounter+=1
                         # save information about loops
-                        str1 += '\t\t' + 'numOfSameItem+=1\n'
-                        str1 += '\t\t' + \
-                            'self.mdDescription[' + str(self.c) + "].addStatements1('" + loop2 + "')\n"
+                        str1 += '\t\t'+'numOfSameItem+=1\n'
+                        str1 += '\t\t'+'self.mdDescription['+str(self.c)+"].addStatements('"+loop+"')\n"
+                        str1 += '\t\t'+'self.mdDescription['+str(self.c)+"].addStatements1('"+loop2+"')\n"
                         if box:
-                                'it=MdItem(parent=box,item=mdDescrObj[' + str(self.c) + '],isFirstNum=numOfSameItem,chckBox=self.templateEditor)\n'
+                            str1 += '\t\t'+'it=MdItem(parent=box,item=mdDescrObj['+str(self.c)+'],isFirstNum=numOfSameItem,chckBox=self.templateEditor)\n'
                         else:
-                                'it=MdItem(self.nbPage,mdDescrObj[' + str(self.c) + '],isFirstNum=numOfSameItem,chckBox=self.templateEditor)\n'
+                            str1 += '\t\t'+'it=MdItem(self.nbPage,mdDescrObj['+str(self.c)+'],isFirstNum=numOfSameItem,chckBox=self.templateEditor)\n'
                         if self.isValidS:
-                            str1 += '\t\t' + 'it.setValue(' + str(value) + ')\n'
+                            str1 += '\t\t'+'it.setValue('+str(value)+')\n'
                         else:
-                            str1 += '\t\t' + 'it.setValue("")\n'
+                            str1 += '\t\t'+'it.setValue("")\n'
-                        str1 += '\t\t' + 'self.ItemList.append(it)\n'
+                        str1 +=     '\t\t'+'self.ItemList.append(it)\n'
                         if keyword:
-                            str1 += '\t\t' + 'self.keywordsList.append(it)\n'
-                            str1 += '\t' + \
-                                'self.mdDescription[' + str(self.c) + '].addMdItem(self.keywordsList)\n'
+                            str1 += '\t\t'+'self.keywordsList.append(it)\n'
+                            str1 += '\t' +'self.mdDescription['+str(self.c)+'].addMdItem(self.keywordsList)\n'
                         else:
+                            str1 += '\t\t'+'self.mdDescription['+str(self.c)+'].addMdItem(it)\n'
                         tab = '\t\t'
                         self.plusC()
-            ##print '-' * 80
-            ##print mdDescrObj[self.c].inboxmulti
             if box:
-                str1 += tab + \
+                str1 += tab+\
                     'box.addItems(items=self.ItemList,multi=mdDescrObj[self.c].inboxmulti,isFirstNum=numOfSameBox)\n'
-                str1 += tab + 'self.nbPage.addItem(box)\n'
+                str1 += tab+'self.nbPage.addItem(box)\n'
             else:
-                str1 += tab + 'self.nbPage.addItem(self.ItemList)\n'
+                str1 += tab+'self.nbPage.addItem(self.ItemList)\n'
             self.executeStr(str1, mdDescrObj)
@@ -801,34 +755,21 @@
             # if starting the statements
             if '\t' in tagStringLst[self.c]and self.stop is False:
-                #print '-'*50
                 inBlock()
-                #print '-'*50
             # if just singe item without statements
             elif 'for' not in str(tagStringLst[self.c]).split() and 'if' not in str(tagStringLst[self.c]).split():
-                #print '-'*50
                 it = MdItem(parent=self.nbPage, item=mdDescrObj[self.c],chckBox=self.templateEditor)
-                ##print 'hodnota--', mdDescrObj[self.c].tag
-                value = 'self.' + \
-                    str(self.mdOWSTagStrList[self.c]).replace('\n', '')
+                value = 'self.'+str(self.mdOWSTagStrList[self.c]).replace('\n', '')
                 value = eval(value)
                 if value is None:
                     value=''
                 it.setValue(value)
                 self.mdDescription[self.c].addMdItem(it)
                 self.nbPage.addItem(it)
                 self.plusC()
-                #print '-'*50
             else:
                 self.plusC()
 #----------------------------------------------------------- GUI GENERATOR END
     def defineTemplate(self):
         try:
@@ -842,25 +783,20 @@
         forST=0
         ifST=0
         forSTS=False
-        ifSTS=False
+        ifSTS=False
         for line in template.readlines():
             if '{% for' in line:
-               #print'===='*50
-               #printline
                 forSTS=True
                 forST+=1
-               #print'for ----', forST
-               #print'===='*50
             if '{% if' in line:
-                #print'===='*50
                  ifSTS=True
                  ifST+=1
-                #print'if ----', ifST
-                #print'===='*50
             for r,item in enumerate(self.mdDescription):
                 str1=item.selfInfoString
                 if str1 in line:            #owslib definition in line
                     try:
                         if item.mdItem[0].isChecked==True:
@@ -880,66 +816,57 @@
                                 except:
                                     pass
                     if chcked:      #chckbox in gui
-                        #print 'if chcked-----'
                         if forSTS:
                             forSTS=False
                             forST-=1
                         if ifSTS:
                             ifSTS=False
                             ifST-=1
-                        #print str1
                         owsTagList.append(str1)
                         templateStr= '{{ owsTagList['+str(indexowsTagList)+'] }}'
-                        indexowsTagList+=1
-                        finalTemplate+=line.replace(str1,templateStr)
+                        indexowsTagList+=1
+                        line=line.replace(str1,templateStr)
+                        tag='{{ '+item.tag+' }}'
+                        line=line.replace(tag,templateStr)
+                        finalTemplate+=line
                         continue
             if chcked==False:
                     if '{% endfor -%}' in line and forST==0:
-                       #print'===='*50
-                       #print'{% endfor -%}'
-                       #printstr1
-                       #printline
-                       #print'===='*50
                         str1='{% endfor -%}'
                         indexowsTagList+=1
-                        #forST-=1
+                        tag='{{'+item.tag+'}}'
                     elif '{% endif -%}' in line and ifSTS==0:
-                       #print'===='*50
-                       #printstr1
-                       #printline
-                       #print'{% endif -%}'
-                       #print'===='*50
                         str1= '{% endif -%}'
                         indexowsTagList+=1
-                        #ifSTS-=1
                     else:
                         finalTemplate+=line
             chcked=False
-                #print line
-                #print '-*****----****----'
         head, tail = os.path.split(self.templatePath)
         tail='EXPT'+tail
         self.templatePath=os.path.join(head,tail)
         templateOut=open(self.templatePath,'w')
         templateOut.write(finalTemplate)
         templateOut.close()
-       ##print'defineTemplate 4'
-        #print finalTemplate
-        #print self.templatePath
         return owsTagList
 #----------------------------------------- FILL OWSLib BY EDITED METADATA IN GUI
@@ -952,7 +879,7 @@
         '''Fill owslib by metadata from gui
         def chckEnd():
-            if (self.c + 1) == self.max:
+            if (self.c+1) == self.max:
                 self.stop = True
         def prepareStatements():
@@ -962,32 +889,20 @@
                 if '|length' in str(mdDes[c].tag):
                     a = mdDes[c].tag
-                    a = a.replace(
-                        '|length',
-                        ')').replace(
-                        'if ',
-                        'if len(self.')
                     mdDes[c].tag = a
                 if '|length' in str(mdDes[c].statements):
                     a = mdDes[c].statements
-                    a = a.replace(
-                        '|length',
-                        ')').replace(
-                        'if ',
-                        'if len(self.')
                     mdDes[c].statements = a
                 if '|length' in str(mdDes[c].statements1):
                     a = mdDes[c].statements1
-                    a = a.replace(
-                        '|length',
-                        ')').replace(
-                        'if ',
-                        'if len(self.')
                     mdDes[c].statements1 = a
         def chckIf1Statements():
             try:
-                if md[self.c + 1].statement:
+                if md[self.c+1].statement:
                     return True
                 else:
                     return False
@@ -996,11 +911,10 @@
         def chckIf2xStatements():
             if 'if'in mdDes[
-                    self.c].tag.split() or 'for' in mdDes[
-                    self.c].tag.split():
+                    self.c].tag.split() or 'for' in mdDes[ self.c].tag.split():
                 try:
-                    if 'if'in  mdDes[self.c + 1].tag.split()  or\
-                            'for'in mdDes[self.c + 1].tag.split():
+                    if 'if'in  mdDes[self.c+1].tag.split()  or \
+                        'for'in mdDes[self.c+1].tag.split():
                         return True
                     else:
                         return False
@@ -1012,16 +926,12 @@
             str1 = ''
             for wxCtrl in mdDes[self.c].mdItem:
-                #print "item"
                 if wxCtrl.getValue() is not None:
-                    str1 += 'self.' + \
-                        mdDes[self.c].tag + '="' + str(wxCtrl.getValue()) + '"\n'
+                    str1 += 'self.'+ mdDes[self.c].tag+'="'+str(wxCtrl.getValue())+'"\n'
                     self.executeStr1(str1, mdDes[self.c])
                     str1 = ''
             self.plusC()
-        #def add
         def inStatements():
             '''possible combinations of statements
             (1)    IF
@@ -1036,32 +946,27 @@
             cTmp = self.c
             tag = str(mdDes[cTmp].tag).split()
-            tag1 = 'self.' + str(tag[-1])
-            tag = 'self.' + str(tag[-1]) + '.append(self.val)\n'
+            tag1 = 'self.'+str(tag[-1])
+            tag = 'self.'+str(tag[-1])+'.append(self.val)\n'
             self.plusC()
             # statements of current item
             stat = mdDes[self.c].statements
             str1 = ''
-            # how many MdItem() is in object
             leng = len(mdDes[self.c].mdItem)
             # (2.1) IF NECESSARY TO INITIALIZE OWSLIB OBJECT
             if mdDes[cTmp].object and 'if' not in mdDes[cTmp].tag.split():
-                #print 'init owslib'
-                # self.val=CI_ResponsibleParty()
-                objStr = 'self.val=' + mdDes[cTmp].object + '\n'
-                ##print 'c--po',self.c
+                objStr = 'self.val='+mdDes[cTmp].object+'\n'
                 for n in range(leng):
                     numOfItems = 0
                     str1 += objStr
-                    # #print self.c, 'pred'
                     while mdDes[self.c].statements == stat and self.stop is False:
                         metadata = re.split(r'[.]', mdDes[self.c].tag)
                         metadata[0] = 'self.val.'
-                        str1 += ''.join(metadata) + "='"\
-                            + str(mdDes[self.c].mdItem[n].getValue()) + "'\n"
+                        str1 += ''.join(metadata)+"='"\
+                           +str(mdDes[self.c].mdItem[n].getValue())+"'\n"
                         self.plusC()
                         numOfItems += 1
@@ -1069,9 +974,7 @@
                     self.executeStr1(str1, False)
                     str1 = ''
                     self.minusC(numOfItems)
                 self.plusC(numOfItems)
             # (2.2)
             elif 'for' in mdDes[cTmp].tag.split() and mdDes[cTmp].object is None and ' zip(' in mdDes[cTmp].tag:
                 #print 'no init and py ZIP'
@@ -1082,10 +985,10 @@
                     numOfItems = 0
-                            tag1[numOfItems] + ".append('" + mdDes[self.c].mdItem[n].getValue() + "')\n"
+                        str1 += 'self.'+tag1[numOfItems]+".append('"+mdDes[self.c].mdItem[n].getValue()+"')\n"
                         self.plusC()
                         numOfItems += 1
                     str1 = ''
@@ -1099,10 +1002,10 @@
                     numOfItems = 0
-                        str1 += tag1 + \
-                            ".append('" + mdDes[self.c].mdItem[n].getValue() + "')\n"
+                        str1 += tag1+".append('"+mdDes[self.c].mdItem[n].getValue()+"')\n"
                         self.plusC()
                         numOfItems += 1
                     str1 = ''
@@ -1110,15 +1013,14 @@
             # (1)
             elif 'if' in mdDes[cTmp].tag.split():
                 #print 'no init IF'
-                objStr = mdDes[cTmp].tag.replace(' md.', ' self.md.') + ':\n'
+                objStr = mdDes[cTmp].tag.replace(' md.', ' self.md.')+':\n'
                     numOfItems = 0
-                        metadata = 'self.' + mdDes[self.c].tag
+                        metadata = 'self.'+mdDes[self.c].tag
                         self.plusC()
                         numOfItems += 1
@@ -1144,45 +1046,45 @@
             prepareStatements()
             cTmp = self.c
-            cTmp1 = self.c + 1
+            cTmp1 = self.c+1
             tag1 = str(mdDes[cTmp1].tag).split()
-            stat = mdDes[self.c + 2].statements
+            stat = mdDes[self.c+2].statements
-            append = 'self.' + str(tag1[-1]) + '.append(self.val)\n'
-            appendNoInit = 'self.' + str(tag1[-1])
+            append = 'self.'+str(tag1[-1])+'.append(self.val)\n'
+            appendNoInit = 'self.'+str(tag1[-1])
             # (1)
             # if 'if' in jinja=skip and do single loop
             if 'if' in tag and 'for' in tag1:
                 #print 'iffor'
-                leng = len(mdDes[self.c + 2].mdItem)
-                ##print mdDes[self.c + 2].tag
+                leng = len(mdDes[self.c+2].mdItem)
+                ##print mdDes[self.c+2].tag
                 # (1.1)
                 if mdDes[cTmp1].object:
                     #print "if and for with init object"
                     condition = mdDes[cTmp].tag.replace(
                         ' md.',
-                        ' self.md.') + ':\n'
-                    object = '\t' + 'self.val=' + mdDes[cTmp1].object + '\n'
-                    condition2 = '\t' + \
-                        mdDes[cTmp1].tag.replace(' md.', ' self.md.') + ':\n'
+                        ' self.md.')+':\n'
+                    object = '\t'+'self.val='+mdDes[cTmp1].object+'\n'
+                    condition2 = '\t'+mdDes[cTmp1].tag.replace(' md.', ' self.md.')+':\n'
                     self.plusC()
                     self.plusC()
                         numOfItems = 0
-                        str1 = condition + '\n'
-                        str1 += condition2 + '\n'
-                        str1 += '\t' + object + '\n'
+                        str1 = condition+'\n'
+                        str1 += condition2+'\n'
+                        str1 += '\t'+object+'\n'
                             metadata[0] = '\t\tself.val'
-                            str1 += ''.join(metadata) + "='" + \
-                                str(mdDes[self.c].mdItem[n].getValue()) + "'\n"
+                            str1 += ''.join(metadata)+"='"+ str(mdDes[self.c].mdItem[n].getValue())+"'\n"
                             self.plusC()
                             numOfItems += 1
-                        str1 += '\t\t' + append
+                        str1 += '\t\t'+append
                         str1 = ''
@@ -1197,10 +1099,10 @@
                     for n in range(size):
                         numOfItems = 0
                         str1 = ''
-                            str1 += appendNoInit + \
-                                '.append("' + mdDes[self.c].mdItem[n].getValue() + '")\n'
+                            str1 += appendNoInit+'.append("'+mdDes[self.c].mdItem[n].getValue()+'")\n'
                             self.plusC()
                             numOfItems += 1
@@ -1209,38 +1111,39 @@
             # (2) only keywords  (dict)
             elif 'for' in tag and 'for' in tag1:  #
-                #print 'for-for statement'
                 self.plusC()  # skip staementes 2x
                 self.plusC()
                 loop2 = mdDes[self.c].statements1
                 loop1 = mdDes[self.c].statements
-                # var=loop2.find('[')
-                # var=loop2[var:].strip(' ')
-                numOfkwGroup = len(mdDes[self.c + 1].mdItem)
+               # print len(mdDes[self.c+1].mdItem)
+                numOfkwGroup=len(mdDes[self.c+1].mdItem)
                 for n in range(numOfkwGroup):
                     kw = {}
                     kw['keywords'] = []
+                    print'-----'
+                    print mdDes[self.c].mdItem
-                    ##print mdDes[self.c].mdItem[n]
-                    ##print '---'
-                    for k in range(len(mdDes[self.c].mdItem[n])):
-                        kw['keywords'].append(
-                                mdDes[
-                                self.c].mdItem[n][k].getValue() )
-                        ##print mdDes[self.c].mdItem[n][k].getValue()
+                    print mdDes[self.c].mdItem[0]
+                    try:
+                        keyWordLen=len(mdDes[self.c].mdItem[n])
+                        for k in range(keyWordLen):
+                                print mdDes[self.c].mdItem[n][k].getValue()
+                                kw['keywords'].append(mdDes[self.c].mdItem[n][k].getValue() )
+                    except:
+                        print mdDes[self.c].mdItem[n].getValue()
+                        kw['keywords'].append(mdDes[self.c].mdItem[n].getValue() )
                     kw['type'] = None
                     kw['thesaurus'] = {}
-                    kw['thesaurus']['title'] =  mdDes[self.c + 1].mdItem[n].getValue()
-                    # #print  mdDes[self.c+1].mdItem[n].getValue()
-                    kw['thesaurus']['date'] = mdDes[self.c + 2].mdItem[n].getValue()
-                    # #print  mdDes[self.c+2].mdItem[n].getValue()
-                    kw['thesaurus']['datetype'] =  mdDes[self.c + 3].mdItem[n].getValue()
-                    # #print  mdDes[self.c+3].mdItem[n].getValue()
+                    kw['thesaurus']['title'] =  mdDes[self.c+1].mdItem[n].getValue()
+                    print  mdDes[self.c+1].mdItem[n].getValue()
+                    kw['thesaurus']['date'] = mdDes[self.c+2].mdItem[n].getValue()
+                    print  mdDes[self.c+2].mdItem[n].getValue()
+                    kw['thesaurus']['datetype'] =  mdDes[self.c+3].mdItem[n].getValue()
+                    print  mdDes[self.c+3].mdItem[n].getValue()
                     self.md.identification.keywords.append(kw)
-                    # #print '---'
                 self.plusC()
                 self.plusC()
@@ -1263,70 +1166,26 @@
         self.c = 0
         self.stop = False
         self.max = len(self.mdDescription)
         mdDes = self.mdDescription
         while self.stop is False:
             # if no statements
             if mdDes[self.c].statements is None\
                     and 'if' not in mdDes[self.c].tag.split()\
                     and 'for' not in mdDes[self.c].tag.split():
-                #print '0x statements'
-                #print mdDes[self.c].tag
-                #print mdDes[self.c].statements
-                #print mdDes[self.c].mdItem
                 noneStatements()
                 chckEnd()
-                #print '+' * 80
-                #print 'next'
-                #print mdDes[self.c].statements1
-                #print '+-' * 80
             # if 2x statements
             elif chckIf2xStatements():
-                #print '-+' * 80
-                #print '2x statements'
-                #print '+' * 80
                 in2Statements()
                 chckEnd()
-                #print '+' * 80
-                #print 'next'
-                #print '+-' * 80
-                # break
             elif chckIf1Statements:  # if 1x statements
-                #print '-+' * 80
-                #print '1x statements'
-                #print '+' * 80
                 inStatements()
                 chckEnd()
-                #print '+' * 80
-                #print 'next'
-                #print '+-' * 80
-            # #print mdDes[self.c].statements
-            # self.plusC()
-            #print '==' * 50
+        return self.md
 #------------------------------------ END- FILL OWSLib BY EDITED METADATA IN GUI
 #------------------------------------------------------------------------ LAYOUT
     def _layout(self):
@@ -1338,16 +1197,16 @@
         self.mainSizer.Add(self.notebook, proportion=1, flag=wx.EXPAND)
         self.Show()
-    def exportToXml(self, jinjaPath, outPath, xmlOutName):
+    def exportToXml(self, jinjaPath, outPath, xmlOutName,msg):
         #print '=' * 50
         self.createNewMD()
-        self.mdo.saveToXML(self.md,None, jinjaPath, outPath, xmlOutName)
+        self.mdo.saveToXML(self.md,None, jinjaPath, outPath, xmlOutName,msg)
-    def exportTemlate(self, jinjaPath, outPath, xmlOutName):
+    def exportTemplate(self, jinjaPath, outPath, xmlOutName):
         self.templatePath=jinjaPath
         owsTagList=self.defineTemplate()
         self.createNewMD()
-        self.mdo.saveToXML(self.md,owsTagList, self.templatePath, outPath, xmlOutName)
+        self.mdo.saveToXML(self.md,owsTagList, self.templatePath, outPath, xmlOutName,msg=True)
 if __name__ == "__main__":
     app = wx.App(False)
Modified: sandbox/krejcmat/src/g.gui.metadata.py
--- sandbox/krejcmat/src/g.gui.metadata.py	2014-08-05 21:45:19 UTC (rev 61537)
+++ sandbox/krejcmat/src/g.gui.metadata.py	2014-08-05 22:04:08 UTC (rev 61538)
@@ -5,7 +5,7 @@
 AUTHOR(S): Matej Krejci <matejkrejci gmail.com>
-PURPOSE:   Module for editing metadata based on ISO
+PURPOSE:   Module for editing metadata based on EN ISO 19115 and EN ISO 19119
 COPYRIGHT: (C) 2014 Matej Krejci, and by the GRASS Development Team
@@ -15,11 +15,14 @@
 from lxml import etree as et
-from wx.lib.splitter import MultiSplitterWindow
 import wx
+#from wx.lib.splitter import MultiSplitterWindow
 from wx.lib.buttons import ThemedGenBitmapTextButton as BitmapBtnTxt
 from wx import SplitterWindow, EVT_BUTTON
+from wx.lib.pubsub import setupkwargs
+from wx.lib.pubsub import pub
 from editor3 import MdMainFrame as mainEditor
 import glob
@@ -34,133 +37,7 @@
 import mdutil
-class MDHelp(wx.Panel):
-    class MyHtmlPanel inherits wx.Panel and adds a button and HtmlWindow
-    def __init__(self, parent ):
-        # default pos is (0, 0) and size is (-1, -1) which fills the frame
-        wx.Panel.__init__(self, parent=parent, id=wx.ID_ANY)
-        self.html1 = wx.html.HtmlWindow(self, id=wx.ID_ANY)
-        try:
-            self.html1.LoadFile('help/help.html')
-            #self.html1.LoadPage('http://inspire-geoportal.ec.europa.eu/EUOSME_GEOPORTAL/userguide/eurlex_en.htm')
-        except:
-            pass
-        self.mainSizer = wx.BoxSizer(wx.VERTICAL)
-        self.SetSizer(self.mainSizer)
-        self.mainSizer.Add(self.html1,proportion=1, flag=wx.EXPAND)
-# NOTEBOOK ON THE RIGHT SIDE-xml browser+validator
-class NotebookRight(wx.Notebook):
-    def __init__(self, parent, path):
-        wx.Notebook.__init__(self, parent=parent, id=wx.ID_ANY)
-        # first panel
-        self.notebook_panel0 = wx.Panel(self, wx.ID_ANY)
-        self.validator = InspireValidator(self.notebook_panel0)
-        self.buttValidate = wx.Button(
-                                    self.notebook_panel0,
-                                    id=wx.ID_ANY,
-                                    size=(
-                                        70,
-                                        50),
-                                    label='validate')
-        self.notebook_panel1 = wx.Panel(self, wx.ID_ANY)
-        self.tree = TreeEditor(self.notebook_panel1, path)
-        self.buttRefresh = wx.Button(
-                                    self.notebook_panel1,
-                                    id=wx.ID_ANY,
-                                    size=(
-                                        70,
-                                        50),
-                                    label='refresh')
-        self.AddPage(self.notebook_panel0, "Validator")
-        self.AddPage(self.notebook_panel1, "Tree browser")
-        #self.AddPage(self.notebook_panel2, "Help")
-        self.buttValidate.Bind(wx.EVT_BUTTON, self.validate)
-        self.buttRefresh.Bind(wx.EVT_BUTTON, self.refresh)
-        self._layout()
-    def onActive(self):
-        pass
-    def refresh(self,evt):
-        pass
-    def validate(self, evt):
-        self.GetParent().GetParent().editor.createNewMD()
-        md = self.GetParent().GetParent().editor.md
-        self.validator.validate_inspire(md)
-    def _layout(self):
-        panelSizer0 = wx.BoxSizer(wx.VERTICAL)
-        self.notebook_panel0.SetSizer(panelSizer0)
-        panelSizer0.Add(self.validator, flag=wx.EXPAND, proportion=1)
-        panelSizer0.Add(self.buttValidate)
-        panelSizer1 = wx.BoxSizer(wx.VERTICAL)
-        self.notebook_panel1.SetSizer(panelSizer1)
-        panelSizer1.Add(self.tree, flag=wx.EXPAND, proportion=1)
-        panelSizer1.Add(self.buttRefresh)
-        panelSizer2 = wx.BoxSizer(wx.VERTICAL)
-        #self.notebook_panel2.SetSizer(panelSizer2)
-        #panelSizer2.Add(self.notebook_panel2,flag=wx.EXPAND, proportion=1)
-# CONFIGURATION PANEL ON THE LEFT SIDE
-class MdEditConfigPanel(wx.Panel):
-    def __init__(self, parent):
-        wx.Panel.__init__(self, parent, id=wx.ID_ANY)
-        self.SetMinSize((240, -1))
-        self.mapGrassEdit = True
-        self.rbGrass = wx.RadioButton(self, id=wx.ID_ANY, label='Metadata map editor', style=wx.RB_GROUP)
-        self.rbExternal = wx.RadioButton(self, id=wx.ID_ANY, label='Metadata external editor')
-        self.comboBoxProfile = wx.ComboBox(self, choices=['INSPIRE', 'GRASS BASIC', 'Load Custom'])
-        self.comboBoxProfile.SetStringSelection('GRASS BASIC')
-        self.Bind(wx.EVT_RADIOBUTTON, self.onSetRadioType, id=self.rbGrass.GetId())
-        self.Bind(wx.EVT_RADIOBUTTON, self.onSetRadioType, id=self.rbExternal.GetId())
-        # self.SetVal(True)
-        self._layout()
-    def SetVal(self, event):
-        state1 = str()
-        state2 = str(self.rb2.GetValue())
-        self.statusbar.SetStatusText(state1, 0)
-        self.statusbar.SetStatusText(state2, 1)
-    def onSetRadioType(self, evt=None):
-        self.mapGrassEdit = self.rbGrass.GetValue()
-        if self.mapGrassEdit == False:
-            self.comboBoxProfile.Hide()
-        else:
-            self.comboBoxProfile.Show()
-        self.GetParent().GetParent().editingMode(self.mapGrassEdit)
-        self.mainsizer = wx.BoxSizer(wx.VERTICAL)
-        self.SetSizer(self.mainsizer)
-        self.mainsizer.Add(self.rbGrass)
-        self.mainsizer.Add(self.rbExternal)
-        self.mainsizer.Add(self.comboBoxProfile)
 # MAIN
 class MainFrame(wx.Frame):
@@ -180,78 +57,146 @@
         self.sb = self.CreateStatusBar()
         self.secondMultiEdit=False
         self.cres=0 #resizeFrame
-        self.initEditor()
+        self.onInitEditor()
+        self.batch=False
+        pub.subscribe(self.onCreateNewMD, 'NEW_MD.create')
+        pub.subscribe(self.onEditingMode, 'EDITING_MODE.update')
+        pub.subscribe(self.onSetStatusbarText, 'STATUS_BAR_TEXT.update')
+        pub.subscribe(self.onExportTemplate,'EXPORT_TEMPLATE.create')
+        pub.subscribe(self.onExportXML,'EXPORT_XML.create')
+        pub.subscribe(self.onEditMapMetadata,'EDIT_MAP_METADATA.create')
+        pub.subscribe(self.onInitEditor,'INIT_EDITOR.create')
+        pub.subscribe(self.onTemplateEditor,'TEMPLATE_EDITOR_STATUS.update')
+        pub.subscribe(self.onHideLeftPanel,'HIDE_LEFT_PANEL.update')
+        pub.subscribe(self.onExportXMLforRefreshTreeBrowser,'REFRESH_TREE_BROWSER.update')
+        pub.subscribe(self.onChangeEditMapProfile,'ISO_PROFILE.update')
+        pub.subscribe(self.onUpdateGrassMetadata,'GRASS_METADATA.update')
+    def onUpdateGrassMetadata(self):
+        md=self.editor.createNewMD()
+        self.mdCreator.updateGrassMd(md)
+        GMessage('Grass metadata has been updated')
+    def onChangeEditMapProfile(self):
+        self.templateChoice=self.configPanelLeft.comboBoxProfile.GetValue()
+        self.ntbRight.profile=self.templateChoice
+    def onExportTemplate(self,outPath,outFileName):
+            self.editor.exportTemplate(self.jinjaPath,
+                                outPath=outPath,
+                                xmlOutName=outFileName)
+    def onExportXML(self,outPath,outFileName):
+        if outPath is None and outFileName is None:
+            XMLhead, XMLtail = os.path.split(self.xmlPath)
+            self.editor.exportToXml(self.jinjaPath,
+                                outPath=XMLhead,
+                                xmlOutName=XMLtail,
+                                msg=False)
+        else:
+                                outPath=outPath,
+                                xmlOutName=outFileName,
+                                msg=True)
+    def onExportXMLforRefreshTreeBrowser(self):
+         path=os.path.dirname(os.path.realpath(__file__))
+         name='refreshTreeBrowser.xml'
+         print 'refresh1'
+                                outPath=path,
+                                xmlOutName=name,
+                                msg=False)
+         pathName=os.path.join(path,name)
+         self.ntbRight.refreshXmlBrowser(pathName)
+         os.remove(pathName)
+    def onSetStatusbarText(self,text):
+        self.sb.SetStatusText(text)
+    def onTemplateEditor(self,value):
+        self.templateEditor=value
+    def onCreateNewMD(self):
+        self.editor.createNewMD()
+        self.ntbRight.md=self.editor.md
     def resizeFrame(self, x1=1, y1=0):
-            self.cres+=1
-            if (self.cres%2==0) and x1==1 and y1==0:
-                x1=-1
-            x, y = self.GetSize()
-            self.SetSize((x + x1, y + y1))
+        self.cres+=1
+        if (self.cres%2==0) and x1==1 and y1==0:
+            x1=-1
+        x, y = self.GetSize()
+        self.SetSize((x + x1, y + y1))
-    def hideLeftPanel(self):
-            self.toolbar.bttNew.Enable()
-            self.Hsizer.Remove(self.leftPanel)
-            self.Hsizer.Layout()
-            self.leftPanel.SetSize((1, 1))
-            self.splitter.Refresh()
-            self.splitter.SetSashGravity(0.7)
+    def onHideLeftPanel(self):
+        self.toolbar.bttNew.Enable()
+        self.Hsizer.Remove(self.leftPanel)
+        self.Hsizer.Layout()
+        self.leftPanel.SetSize((1, 1))
+        #self.splitter.Refresh()
+        #self.splitter.SetSashGravity(0.7)
-    def editMapMetadata(self,multipleEditing=False):
+    def onEditMapMetadata(self,multipleEditing=False):
         if not multipleEditing:
-            self.hideLeftPanel()
+            self.onHideLeftPanel()
             self.ListOfMapTypeDict=self.MdDataCatalogPanelLeft.ListOfMapTypeDict
-        templeteChoice=self.configPanelLeft.comboBoxProfile.GetValue()
         self.numOfMap=len(self.ListOfMapTypeDict)
+        #if editing just one map
         if  self.numOfMap==1 and multipleEditing is False:
-                mdCreator = mdgrass.GrassMD(self.ListOfMapTypeDict[-1][ self.ListOfMapTypeDict[-1].keys()[0] ],
+                self.mdCreator = mdgrass.GrassMD(self.ListOfMapTypeDict[-1][ self.ListOfMapTypeDict[-1].keys()[0] ],
                                              self.ListOfMapTypeDict[-1].keys()[0])
-                if templeteChoice == 'INSPIRE':
-                    mdCreator.createGrassInspireISO()
-                    self.jinjaPath = mdCreator.templatePathAbs
-                    self.xmlPath = mdCreator.saveXML()
-                    self.initEditor()
+                if self.templateChoice == 'INSPIRE':
+                    self.mdCreator.createGrassInspireISO()
+                    self.jinjaPath = self.mdCreator.templatePathAbs
+                    self.xmlPath = self.mdCreator.saveXML()
-                elif templeteChoice == 'GRASS BASIC':
-                    mdCreator.createGrassBasicISO()
-                    self.initEditor()
-        if templeteChoice == 'Load Custom' and self.numOfMap!=0:
+                elif self.templateChoice == 'GRASS BASIC':
+                    self.mdCreator.createGrassBasicISO()
+        #if editing multiple maps or just one but with loading own custom template
+        if self.templateChoice == 'Load Custom' and self.numOfMap!=0:
+            #load template. a) for just one map 2) for multiple editing
             if multipleEditing is False:
-                dlg = wx.FileDialog(
-                            self,
-                            "Choose a template",
-                            os.getcwd(),
-                            "*.xml",
-                            wx.OPEN)
+                dlg = wx.FileDialog(self,"Choose a template", os.getcwd(),"","*.xml",wx.OPEN)
                 if dlg.ShowModal() == wx.ID_OK:
                         self.jinjaPath = dlg.GetPath()
+                        #if multiple map are selected
                         if self.numOfMap>1:
+                            self.toolbar.xmlPath=self.xmlPath
+                            self.toolbar.jinjaPath=self.jinjaPath
+                            self.batch=True
                             self.ListOfMapTypeDict.pop()
                             self.initMultipleEditor()
                         else:
-                            self.initEditor()
                 else:#do nothing
-                    self.initEditor()
-                    return False
-            else:
+                    return False#not continue
+            else:#
@@ -259,23 +204,28 @@
         if self.numOfMap==0 and  multipleEditing is True:
             self.toolbar.onNewSession(None)
-            GMessage('All choosen maps are edited')
+            GMessage('All selected maps are edited')
             self.secondMultiEdit=True
-            self.xmlPath=None
-            self.jinjaPath=None
+            #self.batch=False
         elif self.numOfMap==0:
              GMessage('Select map in data catalog...')
-        if self.numOfMap>1 and  templeteChoice != 'Load Custom':
-             GMessage('For multiple editing metadata of maps is necessary to define template and use "Load Custom" option. See manual... ')
-             self.toolbar.onNewSession(None)
+        # if self.numOfMap>1 and  self.templateChoice != 'Load Custom':
+        #      GMessage('For multiple editing metadata of maps is necessary to define template and use "Load Custom" option. See manual... ')
+        #      self.toolbar.onNewSession(None)
+        if self.batch and multipleEditing :
+            self.batch=yesNo(self, 'Do you want to save metadata of : %s without editing ? '%XMLtail)
+            if self.batch:
+                self.toolbar.batch=True
+                self.toolbar.onSaveXML()
         return True
-    def editingMode(self, editStatus):
+    def onEditingMode(self, editStatus):
         self.resizeFrame()
         self.Layout()
@@ -297,6 +247,10 @@
            #print 'def initMultipleEditor(self):'
             if self.firstAfterChoice and not self.secondMultiEdit:
                    #print 'if self.firstAfterChoice:'
+                    self.splitter = SplitterWindow(self, style=wx.SP_3D |
+                                                wx.SP_LIVE_UPDATE|wx.SP_BORDER)
+                    self.Hsizer.Add(self.splitter, proportion=1, flag=wx.EXPAND)
                     self.firstAfterChoice = False
                     self.secondAfterChoice = True
                     self.toolbar.bttsave.SetLabel('next')
@@ -308,43 +262,42 @@
                                             self.xmlPath,
                     self.ntbRight = NotebookRight(self.splitter, self.xmlPath)
-                    self.splitter.SplitVertically(self.editor, self.ntbRight, sashPosition=0.6)
-                    self.splitter.SetSashGravity(0.9)
+                    self.splitter.SplitVertically(self.editor, self.ntbRight, sashPosition=0.65)
+                    self.splitter.SetSashGravity(0.65)
                     self.resizeFrame()
                     self.Show()
             elif self.secondAfterChoice or self.secondMultiEdit:
-                   #print 'elif self.secondAfterChoice or self.secondMultiEdit:'
                     if self.secondMultiEdit:
                         self.toolbar.hideMultipleEdit()
-                        #self.secondMultiEdit= False
-                        #self.second = True
                     self.second=False
                     self.secondAfterChoice=True
-                    self.initEditor()
-    def initEditor(self):
+            return
+    def onInitEditor(self):
             if self.first:
-               #print 'if self.first:'
                 self.first = False
                 self.firstAfterChoice = True
                #print "first-----"
-                self.toolbar = MdToolbar(self)
+                self.toolbar = MdToolbar(self,self.jinjaPath,self.xmlPath,self.sb)
                 self.leftPanel = wx.Panel(self, id=wx.ID_ANY)
                 self.configPanelLeft = MdEditConfigPanel(self.leftPanel)
                 self.MdDataCatalogPanelLeft = MdDataCatalog(self.leftPanel)
-                self.splitter = SplitterWindow(
-                                                  self,
-                                                  style=wx.SP_3D | wx.SP_LIVE_UPDATE|wx.SP_BORDER)
+                self._layout()
                 self.Show()
-                self._layout()
             elif self.firstAfterChoice:
-                   #print 'elif self.firstAfterChoice:'
-                #f self.jinjaPath and self.xmlPath:
                     self.second = True
@@ -354,8 +307,10 @@
                                             self.xmlPath,
+                    self.splitter.SizeWindows()
                     self.resizeFrame()
                     self.Show()
@@ -367,13 +322,10 @@
                 self.toolbar.bttNew.Disable()
                 self.toolbar.bttsave.Disable()
-                self.Hsizer.Insert(0, self.leftPanel, proportion=0.5, flag=wx.EXPAND)
+                self.Hsizer.Insert(0, self.leftPanel, proportion=1, flag=wx.EXPAND)
                 self.resizeFrame()
             elif self.secondAfterChoice:
-                   #print 'elif self.secondAfterChoice:aa'
-                #if self.jinjaPath and self.xmlPath:
-                   #print 'secondAfterChoice'
                     self.secondAfterChoice = False
                     self.second = True
                     self.splitter.Show()
@@ -399,8 +351,10 @@
                     self.splitter.SetSashGravity(0.35)
             else:
-            #self.toolbar.bttsave.SetLabel('XML')
     def _layout(self):
@@ -413,21 +367,19 @@
             self.leftPanelSizer = wx.BoxSizer(wx.VERTICAL)
             self.leftPanel.SetSizer(self.leftPanelSizer)
-            self.leftPanelSizer.Add(self.configPanelLeft, proportion=0.2, flag=wx.EXPAND)
+            self.leftPanelSizer.Add(self.configPanelLeft, proportion=0, flag=wx.EXPAND)
             self.leftPanelSizer.AddSpacer(5, 5, 1, wx.EXPAND)
             self.leftPanelSizer.Add(self.MdDataCatalogPanelLeft, proportion=1, flag=wx.EXPAND)
             self.Hsizer = wx.BoxSizer(wx.HORIZONTAL)
             self.mainSizer.Add(self.Hsizer, proportion=1, flag=wx.EXPAND)
-            self.Hsizer.Add(self.leftPanel, proportion=0.5, flag=wx.EXPAND)
-            self.Layout()
+            self.Hsizer.Add(self.leftPanel, proportion=1, flag=wx.EXPAND)
-            self.Hsizer.Add(self.splitter, proportion=1, flag=wx.EXPAND)
-            self.splitter.SetSashGravity(0.35)
-            self.splitter.SizeWindows()
             self.resizeFrame(300, 0)
+            self.Layout()
 # DATA CATALOG
@@ -471,73 +423,160 @@
                     MapTypeDict[mapType]  = map
                     self.ListOfMapTypeDict.append(MapTypeDict)
-                self.GetParent().GetParent().toolbar.bttEdit.Enable()
-                self.GetParent().GetParent().toolbar.bttCreateTemplate.Enable()
+                pub.sendMessage('bttEdit.enable')
+                pub.sendMessage('bttCreateTemplate.enable')
             else:
                 self.Unselect()
                 GMessage('Please select map.')
             if len(maps)==0:
-                self.GetParent().GetParent().toolbar.bttEdit.Disable()
-                self.GetParent().GetParent().toolbar.bttCreateTemplate.Disable()
+                pub.sendMessage('bttEdit.disable')
+                pub.sendMessage('bttCreateTemplate.disable')
             str1=''
             for map in maps:
                 str1+=map+'  '
             if len(maps)>1:
-                self.GetParent().GetParent().configPanelLeft.comboBoxProfile.SetStringSelection('Load Custom')
-                self.GetParent().GetParent().configPanelLeft.comboBoxProfile.Disable()
+                pub.sendMessage('SET_PROFILE.update',profile='Load Custom')
+                pub.sendMessage('comboBoxProfile.disable')
             else:
-                self.GetParent().GetParent().configPanelLeft.comboBoxProfile.Enable()
-            self.GetParent().GetParent().sb.SetStatusText(str1)
-        def _popupMenuLayer(self):
-            """Create popup menu for layers"""
-            pass
+                pub.sendMessage('comboBoxProfile.enable')
+            pub.sendMessage('STATUS_BAR_TEXT.update',text=str1)
-        def _popupMenuMapset(self):
-            """Create popup menu for mapsets"""
-            pass
+# NOTEBOOK ON THE RIGHT SIDE-xml browser+validator
+class NotebookRight(wx.Notebook):
-class RandomPanel(wx.Panel):
+    def __init__(self, parent, path):
+        wx.Notebook.__init__(self, parent=parent, id=wx.ID_ANY)
+        # first panel
+        self.notebookValidator = wx.Panel(self, wx.ID_ANY)
+        self.validator = MdValidator(self.notebookValidator)
+        self.xmlPath=path
+        self.profile=None
+        self.buttValidate = wx.Button(
+                                    self.notebookValidator,
+                                    id=wx.ID_ANY,
+                                    size=(
+                                        70,
+                                        50),
+                                    label='validate')
-    def __init__(self, parent, color):
-        wx.Panel.__init__(self, parent)
-        self.SetBackgroundColour(color)
+        self.notebook_panel1 = wx.Panel(self, wx.ID_ANY)
+        self.tree = TreeEditor(self.notebook_panel1, self.xmlPath)
+        self.buttRefresh = wx.Button(
+                                    self.notebook_panel1,
+                                    id=wx.ID_ANY,
+                                    size=(
+                                        70,
+                                        50),
+                                    label='refresh')
+        self.AddPage(self.notebookValidator, "Validator")
+        self.AddPage(self.notebook_panel1, "Tree browser")
+        #self.AddPage(self.notebook_panel2, "Help")
+        self.buttValidate.Bind(wx.EVT_BUTTON, self.validate)
+        self.buttRefresh.Bind(wx.EVT_BUTTON, self.onRefreshXmlBrowser)
+        self._layout()
+    def onActive(self):
+        pass
+    def onRefreshXmlBrowser(self,evt=None):
+        pub.sendMessage( 'REFRESH_TREE_BROWSER.update')
+    def refreshXmlBrowser(self,path):
+        treeBCK=self.tree
+        self.tree=TreeEditor(self.notebook_panel1,path)
+        self.panelSizer1.Replace(treeBCK, self.tree)
+        #self.panelSizer1.Add(self.tree, flag=wx.EXPAND, proportion=1)
+        self.panelSizer1.Layout()
+        treeBCK.Destroy()
+    def validate(self, evt):
+        self.md=None
+        pub.sendMessage('NEW_MD.create')
+        pub.sendMessage('ISO_PROFILE.update')
+        self.validator.validate(self.md,self.profile)
+    def _layout(self):
+        panelSizer0 = wx.BoxSizer(wx.VERTICAL)
+        self.notebookValidator.SetSizer(panelSizer0)
+        panelSizer0.Add(self.validator, flag=wx.EXPAND, proportion=1)
+        panelSizer0.Add(self.buttValidate)
+        self.panelSizer1 = wx.BoxSizer(wx.VERTICAL)
+        self.notebook_panel1.SetSizer(self.panelSizer1)
+        self.panelSizer1.Add(self.tree, flag=wx.EXPAND, proportion=1)
+        self.panelSizer1.Add(self.buttRefresh)
+        panelSizer2 = wx.BoxSizer(wx.VERTICAL)
+        #self.notebook_panel2.SetSizer(panelSizer2)
+        #panelSizer2.Add(self.notebook_panel2,flag=wx.EXPAND, proportion=1)
+# HELP
+class MDHelp(wx.Panel):
+    class MyHtmlPanel inherits wx.Panel and adds a button and HtmlWindow
+    def __init__(self, parent ):
+        # default pos is (0, 0) and size is (-1, -1) which fills the frame
+        wx.Panel.__init__(self, parent=parent, id=wx.ID_ANY)
+        self.html1 = wx.html.HtmlWindow(self, id=wx.ID_ANY)
+        try:
+            self.html1.LoadFile('help/help.html')
+            #self.html1.LoadPage('http://inspire-geoportal.ec.europa.eu/EUOSME_GEOPORTAL/userguide/eurlex_en.htm')
+        except:
+            pass
+        self.mainSizer = wx.BoxSizer(wx.VERTICAL)
+        self.SetSizer(self.mainSizer)
+        self.mainSizer.Add(self.html1,proportion=1, flag=wx.EXPAND)
 # TREE EDITOR
 class TreeEditor(wx.TreeCtrl):
-    def __init__(self, parent, xmlPath):
-        wx.TreeCtrl.__init__(
-            self,
-            parent=parent,
-            id=wx.ID_ANY,
-            style=wx.TR_HAS_BUTTONS|wx.TR_FULL_ROW_HIGHLIGHT)
-        self.parent = parent
-        self.fpath = xmlPath
-        self.xml = et.parse(self.fpath)
+    def __init__(self, parent, xmlPath=False,xmlEtree=False):
+        wx.TreeCtrl.__init__(self,parent=parent,id=wx.ID_ANY,
+                             style=wx.TR_HAS_BUTTONS|wx.TR_FULL_ROW_HIGHLIGHT)
+        tree=self
+        if xmlPath:
+            xml = et.parse(xmlPath)
+            self.xml=xml.getroot()
+            self.root = tree.AddRoot( self.xml.tag)
+        else:
+            self.xml=xmlEtree
+            self.root = xmlEtree.getroot()
-        # wx.TreeCtrl(parent=self.parent,
-        root = self.fillmeup()
+        root = self.fillTree()
         self.Expand(root)
         # self.Bind(wx.EVT_CLOSE, self.OnClose)
         # self.Bind(wx.EVT_TREE_END_LABEL_EDIT, self.OnEdit)
         self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK, self.OnRClickAllChildren)
-    def fillmeup(self):
-        xml = self.xml.getroot()
-        tree = self
-        root = tree.AddRoot(xml.tag)
+    def fillTree(self):
+        root=self.root
+        xml=self.xml
+        tree=self
         def add(parent, elem):
-            # count=0 # do not make empty field after  <appointment> or <item>
-            # etc
             for e in elem:
                 if str(e).find("<!--") != -1:  # skip comments
                     continue
@@ -576,13 +615,129 @@
             self.ExpandAllChildren(evt.Item)
         else:
             self.CollapseAllChildren(evt.Item)
-class MdToolbar(wx.Panel):
+# INSPIRE VALIDATOR PANEL
+class MdValidator(wx.Panel):
+        self.text = wx.TextCtrl(parent, id=wx.ID_ANY, size=(0, 55),
+                                style=wx.VSCROLL |
+                                wx.TE_MULTILINE | wx.TE_NO_VSCROLL |
+                                wx.TAB_TRAVERSAL | wx.RAISED_BORDER | wx.HSCROLL)
+        self._layout()
+        self.mainSizer.Add(self.text, proportion=1, flag=wx.EXPAND)
+    def validate(self, md,profile):
+            print profile
+            if profile=='INSPIRE' or profile=='Load Custom':
+                result=mdutil.isnpireValidator(md)
+                str1 = 'INSPIRE VALIDATOR\n'
+            if profile == 'GRASS BASIC':
+                result=mdutil.grassProfileValidator(md)
+                str1 = 'GRASS BASIC PROFILE VALIDATOR\n'
+            print result
+            str1 += 'Status of validation: ' + result["status"] + '\n'
+            str1 += 'Numbers of errors: ' + result["num_of_errors"] + '\n'
+            if result["status"] != 'succeded':
+                str1 += 'Errors:\n'
+                for item in result["errors"]:
+                    str1 += '\t' + str(item) + '\n'
+            self.text.SetValue(str1)
+# CONFIGURATION PANEL ON THE LEFT SIDE
+class MdEditConfigPanel(wx.Panel):
+    def __init__(self, parent):
-        self.jinjaFile = None
-        self.xmlPath = None
+        self.SetMinSize((240, -1))
+        self.mapGrassEdit = True
+        self.rbGrass = wx.RadioButton(self, id=wx.ID_ANY, label='Metadata map editor', style=wx.RB_GROUP)
+        self.rbExternal = wx.RadioButton(self, id=wx.ID_ANY, label='Metadata external editor')
+        self.comboBoxProfile = wx.ComboBox(self, choices=['INSPIRE', 'GRASS BASIC', 'Load Custom'])
+        pub.subscribe(self.onComboboxDisable, "comboBoxProfile.disable")
+        pub.subscribe(self.onComboboxEnable, "comboBoxProfile.enable")
+        pub.subscribe(self.onSetProfile, "SET_PROFILE.update")
+        self.comboBoxProfile.SetStringSelection('GRASS BASIC')
+        self.Bind(wx.EVT_RADIOBUTTON, self.onSetRadioType, id=self.rbGrass.GetId())
+        self.Bind(wx.EVT_RADIOBUTTON, self.onSetRadioType, id=self.rbExternal.GetId())
+        self.comboBoxProfile.Bind(wx.EVT_COMBOBOX,self.onChangeComboBoxProfile )
+        #self.onChangeComboBoxProfile(None)
+        self._layout()
+    def onChangeComboBoxProfile(self,evt):
+        #pub.sendMessage('ISO_PROFILE.update')
+        pass
+    def onComboboxDisable(self):
+        self.comboBoxProfile.Disable()
+    def onComboboxEnable(self):
+        self.comboBoxProfile.Enable()
+    def onSetProfile(self,profile):
+        self.comboBoxProfile.SetStringSelection(profile)
+    def SetVal(self, event):
+        state1 = str()
+        state2 = str(self.rb2.GetValue())
+        self.statusbar.SetStatusText(state1, 0)
+        self.statusbar.SetStatusText(state2, 1)
+    def onSetRadioType(self, evt=None):
+        self.mapGrassEdit = self.rbGrass.GetValue()
+        if self.mapGrassEdit == False:
+            self.comboBoxProfile.Hide()
+        else:
+            self.comboBoxProfile.Show()
+        pub.sendMessage('EDITING_MODE.update',editStatus=self.mapGrassEdit)
+        self.mainsizer = wx.BoxSizer(wx.VERTICAL)
+        self.SetSizer(self.mainsizer)
+        self.mainsizer.Add(self.rbGrass)
+        self.mainsizer.Add(self.rbExternal)
+        self.mainsizer.Add(self.comboBoxProfile)
+# TOOLBAR
+class MdToolbar(wx.Panel):
+    def __init__(self, parent,jinjaPath,xmlPath,sb):
+        wx.Panel.__init__(self, parent, id=wx.ID_ANY)
+        self.batch=False
+        self.jinjaPath = jinjaPath
+        self.statusBar=sb
+        self.xmlPath = xmlPath
         self.toolbar = wx.ToolBar(self, 1, wx.DefaultPosition, (-1, -1))
+        bitmapSave = wx.Image(
+            os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'save.png'),
+            wx.BITMAP_TYPE_PNG).ConvertToBitmap()
+        bitmapNew = wx.Image(
+            os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'create.png'),
+        bitmapLoad = wx.Image(
+            os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'open.png'),
 #-------------------------------------------------------------------- EDIT
         self.toolbar.AddSeparator()
         bitmapEdit = wx.Image(
@@ -595,79 +750,130 @@
 #-------------------------------------------------------------------- NEW SESION
-        bitmapNew = wx.Image(
-            os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'create.png'),
-            wx.BITMAP_TYPE_PNG).ConvertToBitmap()
         self.bttNew = BitmapBtnTxt(
             self.toolbar, -1,bitmapNew,'session')
         self.toolbar.AddControl(control=self.bttNew)
         self.bttNew.Disable()
 #-------------------------------------------------------------------------- SAVE
-        bitmapSave = wx.Image(
-            os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'save.png'),
-        self.bttsave = BitmapBtnTxt(
-            self.toolbar, -1, bitmapSave, "XML")
+        self.bttsave = BitmapBtnTxt(self.toolbar, -1, bitmapSave, "XML")
         self.bttsave.Disable()
         self.toolbar.AddControl(control=self.bttsave)
 #----------------------------------------------------------------- OPEN TEMPLATE
-        bitmapLoad = wx.Image(
-            os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'open.png'),
-        self.bttLoad = BitmapBtnTxt(
-            self.toolbar, -1, bitmapLoad, "template", size=(100, -1))
+        self.bttLoad = BitmapBtnTxt(self.toolbar, -1, bitmapLoad, "template", size=(100, -1))
         self.toolbar.AddControl(control=self.bttLoad)
         self.bttLoad.Disable()
 #---------------------------------------------------------------------- OPEN XML
-        bitmapLoadXml = wx.Image(
-        self.bttLoadXml = BitmapBtnTxt(
-            self.toolbar, -1, bitmapLoad, "XML")
+        self.bttLoadXml = BitmapBtnTxt(self.toolbar, -1, bitmapLoad, "XML")
         self.toolbar.AddControl(control=self.bttLoadXml)
         self.bttLoadXml.Disable()
-        #self.toolbar.SetMargins((500,500))
 #-------------------------------------------------------------------- NEW TEMPLATE
-        bitmapCreateTemplate = wx.Image(
-        self.bttCreateTemplate = BitmapBtnTxt(
-            self.toolbar, -1, bitmapCreateTemplate, "template", size=(100, -1))
+        self.bttCreateTemplate = BitmapBtnTxt(self.toolbar, -1, bitmapNew, "template", size=(100, -1))
         self.toolbar.AddControl(control=self.bttCreateTemplate)
         self.bttCreateTemplate.Disable()
-        bitmapSaveTemplate = wx.Image(
-        self.bttSaveTemplate = BitmapBtnTxt(
-            self.toolbar, -1, bitmapSaveTemplate, "template", size=(100, -1))
+        self.bttSaveTemplate = BitmapBtnTxt(self.toolbar, -1, bitmapSave, "template", size=(100, -1))
         self.bttSaveTemplate.Disable()
         self.toolbar.AddControl(control=self.bttSaveTemplate)
-        self.toolbar.AddSeparator()
+#-------------------------------------------------------------------------- SAVE
+        self.bttUpdateGRASS = BitmapBtnTxt(self.toolbar, -1, bitmapSave, "GRASS", size=(100, -1))
+        self.bttUpdateGRASS.Disable()
+        self.toolbar.AddControl(control=self.bttUpdateGRASS)
+        self.toolbar.AddSeparator()
+        #self.toolbar.AddSeparator()
         self.toolbar.Realize()
         self._layout()
-        self.bttLoad.Bind(wx.EVT_BUTTON, self.OnOpenTemplate)
+        self.bttLoad.Bind(wx.EVT_BUTTON, self.OnLoadTemplate)
+        pub.subscribe(self.onBttSaveEnable, "bttLoad.enable")
+        pub.subscribe(self.onBttSaveDisable, "bttLoad.disable")
         self.bttsave.Bind(wx.EVT_BUTTON, self.onSaveXML)
+        pub.subscribe(self.onBttLoadEnable, "bttSave.enable")
+        pub.subscribe(self.onBttLoadDisable, "bttSave.disable")
         self.bttLoadXml.Bind(wx.EVT_BUTTON, self.onLoadXml)
+        pub.subscribe(self.onBttLoadXmlEnable, "bttLoadXml.enable")
+        pub.subscribe(self.onBttLoadXmlDisable, "bttLoadXml.disable")
         self.bttNew.Bind(wx.EVT_BUTTON, self.onNewSession)
-        self.bttEdit.Bind(wx.EVT_BUTTON, self.onClickEdit)
+        pub.subscribe(self.onBttNewEnable, "bttNew.enable")
+        pub.subscribe(self.onBttNewDisable, "bttNew.disable")
+        self.bttEdit.Bind(wx.EVT_BUTTON, self.onEdit)
+        pub.subscribe(self.onBtEditEnable, "bttEdit.enable")
+        pub.subscribe(self.onBttEditDisable, "bttEdit.disable")
         self.bttCreateTemplate.Bind(wx.EVT_BUTTON, self.onCreateTemplate)
+        pub.subscribe(self.onBttCreateTemplateEnable, "bttCreateTemplate.enable")
+        pub.subscribe(self.onBttCreateTemplateDisable, "bttCreateTemplate.disable")
         self.bttSaveTemplate.Bind(wx.EVT_BUTTON,self.onSaveTemplate)
+        pub.subscribe(self.onBttSaveTemplateEnable, "bttSaveTemplate.enable")
+        pub.subscribe(self.onBttSaveTemplateDisable, "bttSaveTemplate.disable")
+        self.bttUpdateGRASS.Bind(wx.EVT_BUTTON,self.onUpdateGRASS)
+        pub.subscribe(self.onBttUpdateGRASSEnable, "bttSaveTemplate.enable")
+        pub.subscribe(self.onBttUpdateGRASSDisable, "bttSaveTemplate.disable")
+    def onBttSaveDisable(self):
+        self.bttSave.Disable()
+    def onBttSaveEnable(self):
+        self.bttSave.Enable()
+    def onBttLoadDisable(self):
+        self.bttLoad.Disable()
+    def onBttLoadEnable(self):
+        self.bttLoad.Enable()
+    def onBttLoadXmlDisable(self):
+        self.bttLoadXml.Disable()
+    def onBttLoadXmlEnable(self):
+        self.bttLoadXml.Enable()
+    def onBttNewDisable(self):
+        self.bttNew.Disable()
+    def onBttNewEnable(self):
+        self.bttNew.Enable()
+    def onBttEditDisable(self):
+        self.bttEdit.Disable()
+    def onBtEditEnable(self):
+        self.bttEdit.Enable()
+    def onBttCreateTemplateDisable(self):
+        self.bttCreateTemplate.Disable()
+    def onBttCreateTemplateEnable(self):
+        self.bttCreateTemplate.Enable()
+    def onBttSaveTemplateDisable(self):
+        self.bttSaveTemplate.Disable()
+    def onBttSaveTemplateEnable(self):
+        self.bttSaveTemplate.Enable()
+    def onBttUpdateGRASSDisable(self):
+    def onBttUpdateGRASSEnable(self):
+        self.bttUpdateGRASS.Enable()
+    def onUpdateGRASS(self,evt):
+        pub.sendMessage('GRASS_METADATA.update')
     def onSaveTemplate(self,evt=None):
                             self,
@@ -678,13 +884,10 @@
                             wx.SAVE)
-            if self.jinjaFile is None:
-                self.jinjaFile = self.GetParent().jinjaPath
-            self.GetParent().editor.exportTemlate(
-                                self.jinjaFile,
-                                outPath=dlg.GetDirectory(),
-                                xmlOutName=dlg.GetFilename())
+            pub.sendMessage('EXPORT_TEMPLATE.create',outPath=dlg.GetDirectory(),
+                                                    outFileName=dlg.GetFilename())
     def hideMultipleEdit(self):
         self.bttLoad.Hide()
         self.bttLoadXml.Hide()
@@ -692,6 +895,7 @@
         self.bttEdit.Hide()
         self.bttCreateTemplate.Hide()
         self.bttSaveTemplate.Hide()
+        self.bttUpdateGRASS.Hide()
     def showMultipleEdit(self):
         self.bttLoad.Show()
@@ -699,44 +903,55 @@
         self.bttNew.Show()
         self.bttEdit.Show()
         self.bttCreateTemplate.Show()
-        self.bttSaveTemplate.Show()
+        self.bttSaveTemplate.Show()
+        self.bttUpdateGRASS.Show()
     def onCreateTemplate(self,evt):
-        self.GetParent().templateEditor=True
-        self.onClickEdit()
+        pub.sendMessage('TEMPLATE_EDITOR_STATUS.update',value=True)
+        self.onEdit()
+        #pub.sendMessage('TEMPLATE_EDITOR_STATUS.update',value=False)
-    def onClickEdit(self, evt=None):
-        if self.GetParent().configPanelLeft.rbGrass:
-            ok=self.GetParent().editMapMetadata()
+    def onEdit(self, evt=None):
+        if self.GetParent().configPanelLeft.rbGrass:
+            ok=self.GetParent().onEditMapMetadata()
             if not ok:
                 return
         else:
-            self.GetParent().initEditor()
+            pub.sendMessage('INIT_EDITOR.create')
         self.bttsave.Enable()
+        if self.GetParent().numOfMap>1:
+        if self.batch:
+            self.onSaveXML()
     def onNewSession(self, evt):
+        pub.sendMessage('TEMPLATE_EDITOR_STATUS.update',value=False)
         if self.GetParent().configPanelLeft.rbGrass is False:
-        #self.bttCreateTemplate.Enable()
+        self.jinjaPath=None
+        self.xmlPath=None
         self.bttsave.SetLabel('XML')
         self.showMultipleEdit()
     def onChangeXmlorTemplate(self, evt=None):
-        if self.jinjaFile is not None and self.xmlPath is not None:
-            #self.GetParent().initEditor()
-            self.GetParent().hideLeftPanel()
+        if self.jinjaPath is not None and self.xmlPath is not None:
+            pub.sendMessage('HIDE_LEFT_PANEL.update')
@@ -750,50 +965,14 @@
                             wx.OPEN)
             self.xmlPath = dlg.GetPath()
-            self.GetParent().xmlPath = self.xmlPath
-            tx=self.GetParent().sb.GetStatusText()
-            self.GetParent().sb.SetStatusText(tx+'  Selected XML: '+ self.xmlPath )
+            #self.GetParent().xmlPath = self.xmlPath
+            tx=self.statusBar.GetStatusText()
+            self.statusBar.SetStatusText(tx + '  Selected XML: '+ self.xmlPath )
             self.onChangeXmlorTemplate()
             dlg.Destroy()
-        else:
-            dlg.Destroy()
-    def onSaveXML(self, evt=None):
-                                self,
-                                "Set output file",
-                                os.getcwd(),
-                                "*.xml",
-                                wx.SAVE)
-            if dlg.ShowModal() == wx.ID_OK:
-                self.GetParent().editor.exportToXml(
-                                    self.jinjaFile,
-                if self.bttsave.GetLabelText() =='next':
-                    self.GetParent().editMapMetadata(True)
-                os.remove(self.GetParent().xmlPath)
-            else:
-                    ask=yesNo(self,'Metadata are not saved. Do you want to save it? ')
-                    if ask:
-                        self.onSaveXML()
-                else:
-                        GMessage('Metadata are not saved.' )
-            dlg.Destroy()
-    def OnOpenTemplate(self, evt):
+    def OnLoadTemplate(self, evt):
                                 self,
                                 "Choose template",
@@ -803,67 +982,61 @@
                                 wx.OPEN)
-                    self.jinjaFile = dlg.GetPath()
-                    self.GetParent().jinjaPath = self.jinjaFile
-                    self.GetParent().sb.SetStatusText(tx+' Selected template: '+ self.jinjaFile)
+                    self.jinjaPath = dlg.GetPath()
+                    tx= self.statusBar.GetStatusText()
+                    self.statusBar.SetStatusText(tx+' Selected template: '+ self.jinjaPath)
-            dlg.Destroy()
+            dlg.Destroy()
+    def onSaveXML(self, evt=None):
+            self.XMLhead, self.XMLtail = os.path.split(self.xmlPath)
+            if not self.batch:#if normal saving with user-task-dialog
+                dlg = wx.FileDialog(self,message="Set output file",
+                                defaultDir=self.XMLhead,defaultFile=self.XMLtail,wildcard="*.xml",
+                                style=wx.SAVE|wx.FD_OVERWRITE_PROMPT)
+                if dlg.ShowModal() == wx.ID_OK:
+                    pub.sendMessage('EXPORT_XML.create',outPath=dlg.GetDirectory(),outFileName=dlg.GetFilename())
+                    if self.bttsave.GetLabelText() =='next':
+                        print 'next'
+                        pub.sendMessage('EDIT_MAP_METADATA.create',multipleEditing=True)
+                else:
+                        ask=yesNo(self,'File is not saved. Do you want to save it? ')
+                        if ask:
+                            self.onSaveXML()
+                    else:
+                        GMessage('Metadata are not saved.' )
+                dlg.Destroy()
+            else:
+                print '6---'
+                pub.sendMessage('EXPORT_XML.create',outPath=None,outFileName=None)
     def _layout(self):
         self.mainsizer = wx.BoxSizer(wx.HORIZONTAL)
         self.mainsizer.Add(self.toolbar)
 def yesNo(parent, question, caption = 'Yes or no?'):
     dlg = wx.MessageDialog(parent, question, caption, wx.YES_NO | wx.ICON_QUESTION)
     result = dlg.ShowModal() == wx.ID_YES
     dlg.Destroy()
-    return result
-class InspireValidator(wx.Panel):
+    return result
-        self.text = wx.TextCtrl(parent, id=wx.ID_ANY, size=(0, 55),
-                                style=wx.VSCROLL |
-                                wx.TE_MULTILINE | wx.TE_NO_VSCROLL |
-                                wx.TAB_TRAVERSAL | wx.RAISED_BORDER | wx.HSCROLL)
-        self._layout()
-        self.mainSizer.Add(self.text, proportion=1, flag=wx.EXPAND)
-    def validate_grassProfile(self, md):
-        '''function for validation INSPIRE XML file'''
-        pass
-    def validate_inspire(self, md):
-            result,errors=mdutil.isnpireValidator(md)
-            if errors > 0:
-                result["status"] = "failed"
-                result["num_of_errors"] = str(errors)
-            str1 = 'INSPIRE VALIDATOR\n'
-            str1 += 'Status of validation: ' + result["status"] + '\n'
-            str1 += 'Numbers of errors: ' + result["num_of_errors"] + '\n'
-            if result["status"] != 'succeded':
-                str1 += 'Errors:\n'
-                for item in result["errors"]:
-                    str1 += '\t' + str(item) + '\n'
-           #str1 = 'Metadata loading error'
-            self.text.SetValue(str1)
     app = wx.App(False)
Modified: sandbox/krejcmat/src/mdgrass.py
--- sandbox/krejcmat/src/mdgrass.py	2014-08-05 21:45:19 UTC (rev 61537)
+++ sandbox/krejcmat/src/mdgrass.py	2014-08-05 22:04:08 UTC (rev 61538)
@@ -2,11 +2,11 @@
 # -*- coding: utf-8
-MODULE:    v.info.iso, r.info.iso
+MODULE:    v.info.iso, r.info.iso, g.gui.metadata
-PURPOSE:   Module for creating metadata based on ISO
+PURPOSE:   Module for creating metadata based on EN ISO 19115 and EN ISO 19119
@@ -34,6 +34,7 @@
 import StringIO
 import subprocess as sub
 import uuid
+import mdutil
 import mdutil
 class GrassMD():
@@ -90,6 +91,7 @@
                         flags='get',
                         quiet=True,
                         stdout_=PIPE)
         self.md_grass = parse_key_val(vinfo.outputs.stdout)
         # parse md from v.info flag h (history of map in grass)
@@ -99,6 +101,7 @@
                         flags='h',
                         quiet=True,
                         stdout_=PIPE)
         md_h_grass = rinfo_h.outputs.stdout
         buf = StringIO.StringIO(md_h_grass)
         line = buf.readline().splitlines()
@@ -117,9 +120,7 @@
            if the format of date is different to grass-generated format - use them and print warning  '''
         try:
-            date = datetime.strptime(
-                self.md_grass[key],
-                '%a %b %d %H:%M:%S %Y')
+            date = datetime.strptime(self.md_grass[key],'%a %b %d %H:%M:%S %Y')
             self.md_grass['dateofcreation'] = date.strftime('%Y-%m-%d')
         except:
             grass.warning('date of creation: unknown date format')
@@ -143,12 +144,12 @@
         # create abstract
         if self.md_grass['description'] != '""':
-            self.md_abstract = self.md_grass['description'] + '\\n'
+            self.md_abstract = self.md_grass['description']+'; '
         if self.md_grass['source1'] != '""':
-            self.md_abstract += self.md_grass['source1'] + '\\n'
+            self.md_abstract += self.md_grass['source1'] +'; '
         if self.md_grass['source2'] != '""':
-            self.md_abstract += self.md_grass['source2'] + '\\n'
-        self.md_abstract += 'Total cells: ' + self.md_grass['cells']
+            self.md_abstract += self.md_grass['source2'] +'; '
+        self.md_abstract += 'Total cells: ' + self.md_grass['cells']+'; '
         self.md_abstract += 'A range of values: min: ' + \
             self.md_grass['min'] + '  max: ' + self.md_grass['max']
         self.md_abstract.translate(None, """&<>"'""")
@@ -158,7 +159,7 @@
         - unknown values are filling by n = '$NULL'
         try:
-            self.md_grass['comments']=self.md_grass['comments'].replace('\n','\\n')
+            self.md_grass['comments']=self.md_grass['comments'].replace('\n','; ')
         except:
             pass
@@ -188,8 +189,6 @@
         self.md.identification.title = mdutil.replaceXMLReservedChar(self.md_grass['title'])
         self.md.datestamp = mdutil.replaceXMLReservedChar(date.today().isoformat())
         # Identification/Resource Type
         self.md.identification.identtype = 'dataset'
@@ -225,17 +224,14 @@
         if self.type == 'cell':
             # Identification/Resource Abstract
             self.md.identification.abstract = mdutil.replaceXMLReservedChar(self.md_abstract)
             # Geographic/resolution
             self.md.identification.distance.append(mdutil.replaceXMLReservedChar(self.md_grass['nsres']))  # TODO for discuss
             # Quality/Lineage
             try:
                 self.md.dataquality.lineage = mdutil.replaceXMLReservedChar(mdutil.replaceXMLReservedChar(self.md_grass['comments']))
             except:
-                grass.warning('Native metadata *comments* not found, dataquality.lineage filled by $NULL')
+                grass.warning('Native metadata *flag=comments* not found, dataquality.lineage filled by $NULL')
                 self.md.dataquality.lineage = n
             # Organisation/Responsible Party:
@@ -256,6 +252,7 @@
             val.organization = self.md_grass['creator']
             val.role = 'owner'
             self.md.identification.contact.append(val)
         self.templatePathAbs=os.path.join(self.dirpath,self.template)
@@ -275,6 +272,7 @@
             self.template = template
         n = '$NULL'
         self.md.datestamp = n
         if len(self.md.identification.distance)==0:
             self.md.identification.distance.append(n)#TODO
@@ -303,6 +301,7 @@
         val = CI_OnlineResource()
         val.url = n
         self.md.distribution.online.append(val)
         # Conformity/Date
         self.md.dataquality.conformancedate.append(n)
         self.md.dataquality.conformancedatetype.append(n)
@@ -322,7 +321,7 @@
         self.md.identification.temporalextent_end = n
+        print self.templatePathAbs
     def saveXML(self, path=None, xml_out_name=None):
         ''' Save custom record to ISO XML file'''
@@ -363,243 +362,141 @@
         return path
     def validate_inspire(self):
-        result = {}
-        result["status"] = "succeded"
-        result["errors"] = []
-        result["num_of_errors"] = "0"
-        errors = 0
-        if self.md.identification is None:
-            result["errors"].append(
-                "gself.md:CI_ResponsibleParty: Organization missing")
-                "gself.md:CI_ResponsibleParty: E-mail missing")
-                "gself.md:CI_ResponsibleParty: Role missing")
-                "gself.md:self.md_DataIdentification: Title is missing")
-                "gself.md:self.md_DataIdentification: Abstract is missing")
-                "gself.md:self.md_ScopeCode: Resource Type is missing")
-                "gself.md:language: Resource Language is missing")
-                "gself.md:RS_Identifier: Unique Resource Identifier is missing")
-                "gself.md:topicCategory: TopicCategory is missing")
-                "gself.md:self.md_Keywords: Keywords are missing")
-                "gself.md:thesaurusName: Thesaurus Title is missing")
-                "gself.md:thesaurusName: Thesaurus Date is missing")
-                "gself.md:thesaurusName: Thesaurus Date Type is missing")
-                "gself.md:EX_Extent: extent element is missing")
-                "gself.md:EX_GeographicBoundingBox: bbox is missing")
-                "Both gself.md:EX_TemporalExtent and gself.md:CI_Date are missing")
-            result["errors"].append("gself.md:useLimitation is missing")
-            result["errors"].append("gself.md:accessConstraints is missing")
-            result["errors"].append("gself.md:otherConstraints is missing")
-            errors += 20
-        else:
-            if self.md.identification.contact is None or len(
-                    self.md.identification.contact) < 1:
-                errors += 3
-            else:
-                if self.md.identification.contact[0].organization is None:
-                    errors += 1
-                if self.md.identification.contact[0].email is None:
-                    errors += 1
-                if self.md.identification.contact[0].role is None:
-                    errors += 1
-            if self.md.identification.title is None:
-                errors += 1
-            if self.md.identification.abstract is None:
-                errors += 1
-            if self.md.identification.identtype is None:
-                errors += 1
-            if self.md.identification.resourcelanguage is None or len(
-                    self.md.identification.resourcelanguage) < 1:
-                errors += 1
-            if self.md.identification.uricode is None or len(
-                    self.md.identification.uricode) < 1:
-                errors += 1
-            if self.md.identification.topiccategory is None or len(
-                    self.md.identification.topiccategory) < 1:
-                errors += 1
-            if self.md.identification.keywords is None or len(
-                    self.md.identification.keywords) < 1:
-                errors += 4
-            else:
-                if self.md.identification.keywords[0]['keywords'] is None or len(
-                        self.md.identification.keywords[0]['keywords']) < 1:
-                    errors += 1
-                if self.md.identification.keywords[0]['thesaurus'] is None:
-                    errors += 3
-                else:
-                            0]['thesaurus']['title'] is None:
-                        errors += 1
-                            0]['thesaurus']['date'] is None:
-                        errors += 1
-                            'thesaurus']['datetype'] is None:
-                        errors += 1
-            if self.md.identification.extent is None:
-                errors += 1
-            else:
-                if self.md.identification.extent.boundingBox is None:
-                    errors += 1
-                else:
-                    if self.md.identification.extent.boundingBox.minx is None:
-                            "gself.md:westBoundLongitude: minx is missing")
-                        errors += 1
-                    if self.md.identification.extent.boundingBox.maxx is None:
-                            "gself.md:eastBoundLongitude: maxx is missing")
-                        errors += 1
-                    if self.md.identification.extent.boundingBox.miny is None:
-                            "gself.md:southBoundLatitude: miny is missing")
-                        errors += 1
-                    if self.md.identification.extent.boundingBox.maxy is None:
-                            "gself.md:northBoundLatitude: maxy is missing")
-                        errors += 1
-            if len(
-                    self.md.identification.date) < 1 and (
-                    self.md.identification.temporalextent_start is None or self.md.identification.temporalextent_end is None):
-                errors += 1
-            if len(self.md.identification.uselimitation) < 1:
-                errors += 1
-            if len(self.md.identification.accessconstraints) < 1:
-                    "gself.md:accessConstraints is missing")
-                errors += 1
-            if len(self.md.identification.otherconstraints) < 1:
-                errors += 1
-        if self.md.languagecode is None:
-                "gself.md:LanguageCode: Language code missing")
-            errors += 1
-        if self.md.datestamp is None:
-            result["errors"].append("gself.md:dateStamp: Date is missing")
-            errors += 1
-        if self.md.identifier is None:
-                "gself.md:identifier: Identifier is missing")
-            errors += 1
-        if self.md.dataquality is None:
-            result["errors"].append("gself.md:LI_Lineage is missing")
-                "gself.md:DQ_ConformanceResult: date is missing")
-                "gself.md:DQ_ConformanceResult: date type is missing")
-            # result["errors"].append("gself.md:DQ_ConformanceResult: degree is missing")
-                "gself.md:DQ_ConformanceResult: title is missing")
-            errors += 4
-        else:
-            if self.md.dataquality.lineage is None:
-                errors += 1
-            if len(self.md.dataquality.conformancedate) < 1:
-                errors += 1
-            if len(self.md.dataquality.conformancedatetype) < 1:
-                errors += 1
-            # if len(self.md.dataquality.conformancedegree) < 1:
-            #     errors += 1
-            if len(self.md.dataquality.conformancetitle) < 1:
-                errors += 1
-        if self.md.contact is None:
-                "gself.md:contact: Organization name is missing")
-            result["errors"].append("gself.md:contact: e-mail is missing")
-            errors += 2
-        else:
-            if self.md.contact[0].organization is None:
-                errors += 1
-            if self.md.contact[0].email is None:
-                errors += 1
-        if errors > 0:
+        mdutil.isnpireValidator(self.md)
         return result
+# class GrassMdUpdate():
+#     def __init__(self, md,map,mapType):
+#         self.md=md
+#         self.map=map
+#         self.mapType=mapType
+#         if maptype=='cell':
+#             self.updateRaster()
+#         if mapType=='vector':
+#             self.updateVector()
+    def updateGrassMd(self,md):
+        if self.type == "vector":
+            if len(md.contact)>0:
+                _org=''
+                for co in md.contact:
+                    if co.organization!='':
+                        _org+=co.organization+', '
+                    if co.email!='':
+                        _org+=co.email+', '
+                    if co.role!='':
+                        _org+=co.role+'; '
+                Module('v.support',
+                       map=self.map,
+                       organization=_org,
+                       flags='r')
+            if md.identification.date is not None:
+                if len(md.identification.date)>0:
+                    for d in md.identification.date:
+                        if d.type=='creation':
+                            _date=d.date
+                           map=self.map,
+                           date=_date,
+                           flags='r')
+            if md.identification.contact is not None:
+                if len(md.identification.contact)>0:
+                    _person=md.identification.contact.organization.pop()
+                           map=self.map,
+                           person=_person,
+                           flags='r')
+            if md.identification.title is not (None or ''):
+                _name=md.identification.title
+                       map=self.map,
+                       map_name=_name,
+                       flags='r')
+            if len( md.identification.denominators)>0:
+                _scale= md.identification.denominators.pop()
+                try:
+                    _scale=int(_scale)
+                           map=self.map,
+                           scale=_scale,
+                           flags='r')
+                except:
+                    pass
+            if md.identification.keywords is not None or len(md.identification.keywords) > 0:
+                _comments=''
+                for k in md.identification.keywords:
+                    for kw in k["keywords"]:
+                        if kw!='':
+                            _comments+=kw + ', '
+                    if k["thesaurus"]["title"]!='':
+                        _comments+= k["thesaurus"]["title"] +', '
+                    if k["thesaurus"]["date"]!='':
+                         _comments+= k["thesaurus"]["date"]+', '
+                    if k['thesaurus']['datetype']!='':
+                        _comments+= k['thesaurus']['datetype'] +';'
+                           map=self.map,
+                           comment=_comments,
+                           flags='r')
+#------------------------------------------------------------------------ RASTER
+        if self.type == "cell":
+                _title=md.identification.title
+                Module('r.support',
+                       map=self.map,
+                       title=_title,
+                       overwrite=True)
+            if md.dataquality.lineage is not (None or ''):
+                _history=md.dataquality.lineage
+                       map=self.map,#append
+                       history=_history)
+            _units=''
+            if len(md.identification.distance)>0:
+                _units+= md.identification.distance.pop()
+            if len(md.identification.uom)>0:
+                _units+=', '+md.identification.uom.pop()
+            if _units!='':
+                       map=self.map,
+                       units=_units,
+                       overwrite=True)
+                _comments=self.md_grass['description']
+                _comments+= ' | '
+                        if kw!='':
+                           map=self.map,
+                           description=_comments,
+                           overwrite=True)
Modified: sandbox/krejcmat/src/mdutil.py
--- sandbox/krejcmat/src/mdutil.py	2014-08-05 21:45:19 UTC (rev 61537)
+++ sandbox/krejcmat/src/mdutil.py	2014-08-05 22:04:08 UTC (rev 61538)
@@ -1,290 +1,349 @@
 #!/usr/bin/env python
 # -*- coding: utf-8
-# def strip_control_characters(input):
-#     if input:
-#         import re
-#         # unicode invalid characters
+# def strip_control_characters(input):
+#     if input:
+#         import re
+# unicode invalid characters
 #         RE_XML_ILLEGAL = u'([\u0000-\u0008\u000b-\u000c\u000e-\u001f\ufffe-\uffff])' +   \
 #                          u'|' + \
 #                          u'([%s-%s][^%s-%s])|([^%s-%s][%s-%s])|([%s-%s]$)|(^[%s-%s])' %   \
-#                           (unichr(0xd800),unichr(0xdbff),unichr(0xdc00),unichr(0xdfff),
-#                            unichr(0xd800),unichr(0xdbff),unichr(0xdc00),unichr(0xdfff),
-#         input = re.sub(RE_XML_ILLEGAL, "", input)
-#         # ascii control characters
-#         input = re.sub(r"[\x01-\x1F\x7F]", "", input)
+#                           (unichr(0xd800),unichr(0xdbff),unichr(0xdc00),unichr(0xdfff),
+#                            unichr(0xd800),unichr(0xdbff),unichr(0xdc00),unichr(0xdfff),
+#         input = re.sub(RE_XML_ILLEGAL, "", input)
+# ascii control characters
+#         input = re.sub(r"[\x01-\x1F\x7F]", "", input)
 #     return input
+import string
+def removeNonAscii(s):
+        s= filter(lambda x: x in string.printable, s)
+        return s
 def replaceXMLReservedChar(input):
-    if input:
-            import re
+    if input:
+        import re
-            input = re.sub('<', '<', input)
-            input = re.sub('>', '>', input)
-            input = re.sub('&', '&', input)
-            input = re.sub('%', '%', input)
+        input = re.sub('<', '<', input)
+        input = re.sub('>', '>', input)
+        input = re.sub('&', '&', input)
+        input = re.sub('%', '%', input)
     return input
-def isnpireValidator( md):
+def grassProfileValidator(md):
+    '''function for validation GRASS BASIC XML-OWSLib  file-object'''
-            result = {}
-            errors = 0
+    result = {}
+    result["status"] = "succeded"
+    result["errors"] = []
+    result["num_of_errors"] = "0"
+    errors = 0
-            if md.identification is (None or ''):
-                    "gmd:CI_ResponsibleParty: Organization missing")
-                    "gmd:CI_ResponsibleParty: E-mail missing")
-                    "gmd:CI_ResponsibleParty: Role missing")
-                    "gmd:md_DataIdentification: Title is missing")
-                    "gmd:md_DataIdentification: Abstract is missing")
-                    "gmd:md_ScopeCode: Resource Type is missing")
-                    "gmd:language: Resource Language is missing")
-                    "gmd:RS_Identifier: Unique Resource Identifier is missing")
-                    "gmd:topicCategory: TopicCategory is missing")
-                    "gmd:md_Keywords: Keywords are missing")
-                    "gmd:thesaurusName: Thesaurus Title is missing")
-                    "gmd:thesaurusName: Thesaurus Date is missing")
-                    "gmd:thesaurusName: Thesaurus Date Type is missing")
-                    "gmd:EX_Extent: extent element is missing")
-                    "gmd:EX_GeographicBoundingBox: bbox is missing")
-                    "Both gmd:EX_TemporalExtent and gmd:CI_Date are missing")
-                result["errors"].append("gmd:useLimitation is missing")
-                    "gmd:accessConstraints is missing")
-                result["errors"].append("gmd:otherConstraints is missing")
-                errors += 20
+    if md.identification is (None or ''):
+        result["errors"].append("gmd:CI_ResponsibleParty: Organization missing")
+        result["errors"].append("gmd:CI_ResponsibleParty: E-mail missing")
+        result["errors"].append("gmd:CI_ResponsibleParty: Role missing")
+        result["errors"].append("gmd:md_DataIdentification: Title is missing")
+        result["errors"].append("gmd:md_DataIdentification: Abstract is missing")
+        result["errors"].append("gmd:md_ScopeCode: Resource Type is missing")
+        result["errors"].append("gmd:RS_Identifier: Unique Resource Identifier is missing")
+        result["errors"].append("gmd:EX_Extent: extent element is missing")
+        result["errors"].append("gmd:EX_GeographicBoundingBox: bbox is missing")
+        result["errors"].append("Both gmd:EX_TemporalExtent and gmd:CI_Date are missing")
+        result["errors"].append("gmd:useLimitation is missing")
+        errors += 20
+    else:
+        if md.identification.contact is (None or '') or len(md.identification.contact) < 1:
+            errors += 3
+        else:
+            if md.identification.contact[0].organization is (None or ''):
+                errors += 1
+            if md.identification.contact[0].email is (None or ''):
+                errors += 1
+            if md.identification.contact[0].role is (None or ''):
+                errors += 1
+        if md.identification.title is (None or ''):
+            errors += 1
+        if md.identification.abstract is (None or ''):
+            errors += 1
+        if md.identification.identtype is (None or ''):
+            errors += 1
+        if md.identification.extent is (None or ''):
+            errors += 1
+        else:
+            if md.identification.extent.boundingBox is (None or ''):
+                errors += 1
             else:
-                if md.identification.contact is (None or '') or len(
-                        md.identification.contact) < 1:
-                    errors += 3
-                else:
-                    if md.identification.contact[0].organization is (None or '') :
-                        errors += 1
-                    if md.identification.contact[0].email is (None or ''):
-                        errors += 1
-                    if md.identification.contact[0].role is (None or ''):
-                        errors += 1
-                if md.identification.title is (None or ''):
+                if md.identification.extent.boundingBox.minx is (None or ''):
+                    result["errors"].append("gmd:westBoundLongitude: minx is missing")
                     errors += 1
-                if md.identification.abstract is (None or ''):
+                if md.identification.extent.boundingBox.maxx is (None or ''):
+                    result["errors"].append("gmd:eastBoundLongitude: maxx is missing")
                     errors += 1
-                if md.identification.identtype is (None or ''):
+                if md.identification.extent.boundingBox.miny is (None or ''):
+                    result["errors"].append("gmd:southBoundLatitude: miny is missing")
                     errors += 1
-                if md.identification.resourcelanguage is (None or '') or len(
-                        md.identification.resourcelanguage) < 1 or\
-                        md.identification.resourcelanguage[0] == '':
+                if md.identification.extent.boundingBox.maxy is (None or ''):
+                    result["errors"].append("gmd:northBoundLatitude: maxy is missing")
                     errors += 1
-                if md.identification.uricode is (None or '') or len(
-                        md.identification.uricode) < 1 or\
-                        md.identification.uricode[0] == '':
+        if len(md.identification.date) < 1 or (md.identification.temporalextent_start is (
+                None or '') or md.identification.temporalextent_end is (None or '')):
+            errors += 1
+    if md.datestamp is (None or ''):
+        result["errors"].append("gmd:dateStamp: Date is missing")
+        errors += 1
+    if md.identifier is (None or ''):
+        result["errors"].append("gmd:identifier: Identifier is missing")
+        errors += 1
+    if md.contact is (None or ''):
+        result["errors"].append("gmd:contact: Organization name is missing")
+        result["errors"].append("gmd:contact: e-mail is missing")
+        errors += 2
+    else:
+        if md.contact[0].organization is (None or ''):
+            errors += 1
+        if md.contact[0].email is (None or ''):
+            errors += 1
+        if md.contact[0].role is (None or ''):
+            result["errors"].append("gmd:role: role is missing")
+            errors += 1
+    if errors > 0:
+        result["status"] = "failed"
+        result["num_of_errors"] = str(errors)
+    return result
+def isnpireValidator(md):
+    '''function for validation INSPIRE  XML-OWSLib  file-object'''
+    result = {}
+    errors = 0
+        result["errors"].append("gmd:language: Resource Language is missing")
+        result["errors"].append("gmd:topicCategory: TopicCategory is missing")
+        result["errors"].append("gmd:md_Keywords: Keywords are missing")
+        result["errors"].append("gmd:thesaurusName: Thesaurus Title is missing")
+        result["errors"].append("gmd:thesaurusName: Thesaurus Date is missing")
+        result["errors"].append("gmd:thesaurusName: Thesaurus Date Type is missing")
+        result["errors"].append("gmd:accessConstraints is missing")
+        result["errors"].append("gmd:otherConstraints is missing")
+        errors += 20
+    else:
+                md.identification.contact) < 1:
+                "gmd:CI_ResponsibleParty: Organization missing")
+            errors += 3
+        else:
+                errors += 1
+                errors += 1
+                errors += 1
+                "gmd:md_DataIdentification: Title is missing")
+            errors += 1
+                "gmd:md_DataIdentification: Abstract is missing")
+            errors += 1
+                "gmd:md_ScopeCode: Resource Type is missing")
+            errors += 1
+        if md.identification.resourcelanguage is (None or '') or len(
+                md.identification.resourcelanguage) < 1 or\
+                md.identification.resourcelanguage[0] == '':
+                "gmd:language: Resource Language is missing")
+            errors += 1
+        if md.identification.uricode is (None or '') or len(
+                md.identification.uricode) < 1 or\
+                md.identification.uricode[0] == '':
+                "gmd:RS_Identifier: Unique Resource Identifier is missing")
+            errors += 1
+        if md.identification.topiccategory is (None or '') or len(
+                md.identification.topiccategory) < 1 or\
+                md.identification.topiccategory[0] == '':
+            errors += 1
+        if md.identification.keywords is None or len(md.identification.keywords) < 1:
+                result["errors"].append("gmd:MD_Keywords: Keywords are missing")
+                errors += 4
+        else:
+                if md.identification.keywords[0]['keywords'] is None or len(md.identification.keywords[0]['keywords']) < 1 \
+                                or str(md.identification.keywords[0]['keywords']) =="[u'']":
                     errors += 1
-                if md.identification.topiccategory is (None or '') or len(
-                        md.identification.topiccategory) < 1 or\
-                        md.identification.topiccategory[0] == '':
-                    errors += 1
-                if md.identification.keywords is (None or '') or len(
-                        md.identification.keywords) < 1 or\
-                        md.identification.keywords[0] == '':
-                    errors += 4
+                if md.identification.keywords[0]['thesaurus'] is None:
+                    errors += 3
                 else:
-                    if md.identification.keywords[0]['keywords'] is (None or '') or len(
-                            md.identification.keywords[0]['keywords']) < 1 :
+                    if md.identification.keywords[0]['thesaurus']['title'] is None \
+                            or len(md.identification.keywords[0]['thesaurus']['title'])<1:
                         errors += 1
-                    if md.identification.keywords[0]['thesaurus'] is (None or ''):
-                        errors += 3
-                    else:
-                                0]['thesaurus']['title'] is (None or ''):
-                            errors += 1
-                                0]['thesaurus']['date'] is (None or ''):
-                            errors += 1
-                                'thesaurus']['datetype'] is (None or ''):
-                            errors += 1
-                if md.identification.extent is (None or '') :
-                    errors += 1
-                else:
-                    if md.identification.extent.boundingBox is (None or ''):
+                    if md.identification.keywords[0]['thesaurus']['date'] is None \
+                            or len(md.identification.keywords[0]['thesaurus']['date'])<1:
                         errors += 1
-                    else:
-                        if md.identification.extent.boundingBox.minx is (None or ''):
-                                "gmd:westBoundLongitude: minx is missing")
-                            errors += 1
-                        if md.identification.extent.boundingBox.maxx is (None or ''):
-                                "gmd:eastBoundLongitude: maxx is missing")
-                            errors += 1
-                        if md.identification.extent.boundingBox.miny is (None or ''):
-                                "gmd:southBoundLatitude: miny is missing")
-                            errors += 1
-                        if md.identification.extent.boundingBox.maxy is (None or ''):
-                                "gmd:northBoundLatitude: maxy is missing")
-                            errors += 1
-                if len( md.identification.date) < 1 or (md.identification.temporalextent_start is (None or '') or md.identification.temporalextent_end is (None or '')):
-                    errors += 1
+                    if md.identification.keywords[0]['thesaurus']['datetype'] is None \
+                            or len(md.identification.keywords[0]['thesaurus']['datetype'])<1:
+                        errors += 1
-                if len(md.identification.uselimitation) < 1 or\
-                         md.identification.uselimitation[0] == '':
-                        "gmd:useLimitation is missing")
-                    errors += 1
-                if len(md.identification.accessconstraints) < 1 or\
-                        md.identification.accessconstraints[0] == '':
-                    errors += 1
-                if len(md.identification.otherconstraints) < 1 or\
-                        md.identification.otherconstraints[0] == '':
-                        "gmd:otherConstraints is missing")
-                    errors += 1
-            if md.languagecode is (None or ''):
+            errors += 1
+        else:
-                    "gmd:LanguageCode: Language code missing")
+                    "gmd:EX_GeographicBoundingBox: bbox is missing")
                 errors += 1
-            if md.datestamp is (None or ''):
-                result["errors"].append("gmd:dateStamp: Date is missing")
-                errors += 1
-            if md.identifier is (None or ''):
-                    "gmd:identifier: Identifier is missing")
-                errors += 1
-            if md.dataquality is (None or ''):
-                result["errors"].append("gmd:LI_Lineage is missing")
-                    "gmd:DQ_ConformanceResult: date is missing")
-                    "gmd:DQ_ConformanceResult: date type is missing")
-                # result["errors"].append("gmd:DQ_ConformanceResult: degree is missing")
-                    "gmd:DQ_ConformanceResult: title is missing")
-                errors += 4
             else:
-                if md.dataquality.lineage is (None or ''):
                     errors += 1
-                if len(md.dataquality.conformancedate) < 1 or \
-                    md.dataquality.conformancedate[0] == '':
                     errors += 1
-                if len(md.dataquality.conformancedatetype) < 1 or\
-                       md.dataquality.conformancedatetype[0] == '' :
                     errors += 1
-                # if len(md.dataquality.conformancedegree) < 1:
-                #     errors += 1
-                if len(md.dataquality.conformancetitle) < 1 or\
-                    md.dataquality.conformancetitle[0] == '':
                     errors += 1
-            if md.contact is (None or ''):
-                    "gmd:contact: Organization name is missing")
-                result["errors"].append("gmd:contact: e-mail is missing")
-                errors += 2
-            else:
+            errors += 1
+        if len(md.identification.uselimitation) < 1 or md.identification.uselimitation[0] == '':
+                "gmd:useLimitation is missing")
+            errors += 1
+        if len(md.identification.accessconstraints) < 1 or md.identification.accessconstraints[0] == '':
+                "gmd:accessConstraints is missing")
+            errors += 1
+        if len(md.identification.otherconstraints) < 1 or md.identification.otherconstraints[0] == '':
+                "gmd:otherConstraints is missing")
+            errors += 1
-                if md.contact[0].organization is (None or ''):
-                    errors += 1
-                if md.contact[0].email is (None or ''):
-                        "gmd:contact: e-mail is missing")
-                    errors += 1
-            return result,errors
\ No newline at end of file
+    if md.languagecode is (None or ''):
+        result["errors"].append("gmd:LanguageCode: Language code missing")
+        errors += 1
+        errors += 1
+        errors += 1
+    if md.dataquality is (None or ''):
+        result["errors"].append("gmd:LI_Lineage is missing")
+        result["errors"].append("gmd:DQ_ConformanceResult: date is missing")
+        result["errors"].append("gmd:DQ_ConformanceResult: date type is missing")
+        # result["errors"].append("gmd:DQ_ConformanceResult: degree is missing")
+        result["errors"].append("gmd:DQ_ConformanceResult: title is missing")
+        errors += 4
+    else:
+        if md.dataquality.lineage is (None or ''):
+            errors += 1
+        if len(md.dataquality.conformancedate) < 1 or md.dataquality.conformancedate[0] == '':
+            errors += 1
+        if len(md.dataquality.conformancedatetype) < 1 or md.dataquality.conformancedatetype[0] == '':
+            errors += 1
+        # if len(md.dataquality.conformancedegree) < 1:
+        #     errors += 1
+        if len(md.dataquality.conformancetitle) < 1 or md.dataquality.conformancetitle[0] == '':
+            errors += 1
+        errors += 3
+    else:
+            errors += 1
+            errors += 1
+            errors += 1
+    if errors > 0:
+    return result
Modified: sandbox/krejcmat/src/templates/grassGRASSTemplateFinal.xml
--- sandbox/krejcmat/src/templates/grassGRASSTemplateFinal.xml	2014-08-05 21:45:19 UTC (rev 61537)
+++ sandbox/krejcmat/src/templates/grassGRASSTemplateFinal.xml	2014-08-05 22:04:08 UTC (rev 61538)
@@ -24,7 +24,7 @@
                 </gmd:CI_Contact>
             </gmd:contactInfo>
             <gmd:role>
-                <gmd:CI_RoleCode codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_RoleCode" codeListValue="{{  co.role }}{# tag="co.role",name="Responsible party role",ref="Part B 9.2" , multi = 0,type = "CI_RoleCode", inboxmulti = 1,group = "Responsible party",object="CI_ResponsibleParty()", inbox="Metadata pointt of contact",example="custodian", desc="function performed by the responsible party" #}" codeSpace="ISOTC211/19115">{{  co.role }}</gmd:CI_RoleCode>
+                <gmd:CI_RoleCode codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_RoleCode" codeListValue="{{ co.role }}{# tag="co.role",name="Responsible party role",ref="Part B 9.2" , multi = 0,type = "CI_RoleCode", inboxmulti = 1,group = "Responsible party",object="CI_ResponsibleParty()", inbox="Metadata pointt of contact",example="custodian", desc="function performed by the responsible party" #}" codeSpace="ISOTC211/19115">{{ co.role }}</gmd:CI_RoleCode>
             </gmd:role>
         </gmd:CI_ResponsibleParty>
     </gmd:contact>
@@ -43,7 +43,7 @@
             <gmd:citation>
                 <gmd:CI_Citation>
                     <gmd:title>
-                        <gco:CharacterString>{{ md.identification.title }}{# tag="md.identification.title", ref="Part B 1.1", name ="Resource title", desc ="Name by which the cited resource is known.", example ="Image2000 Product 1 (nl2) MultispectB 10.1" , multi = 0, group ="Identification", type = "string", multiline=False #}</gco:CharacterString>
+                        <gco:CharacterString>{{ md.identification.title }}{# tag="md.identification.title", ref="Part B 1.1", name ="Resource title", desc ="Name by which the cited resource is known.", example ="Image2000 Product 1 (nl2) MultispectB 10.1" , multi = 0, group ="Identification", type = "string", multiline=True #}</gco:CharacterString>
                     </gmd:title>
           {% for d in md.identification.date -%}{# tag="for d in md.identification.date" ,name="",object="CI_Date()",group= "Temporal" , inbox= "Date of creation/publication/revision",  inboxmulti=1, multiline= False #}
                     <gmd:date>
@@ -87,10 +87,11 @@
       {% endfor -%}
       {% if md.identification.distance|length > 0 -%}{# tag="if md.identification.distance|length > 0", group = "Quality and Validity", inbox="Spatial resolution-distance",inboxmulti= 1 #}
       {% for (d,u) in zip(md.identification.distance, md.identification.uom) -%}{# tag="for (d,u) in zip(md.identification.distance, md.identification.uom", group = "Quality and Validity", inbox="Spatial resolution-distance",inboxmulti= 1 #}
-                    <gmd:spatialResolution>
+                     <gmd:spatialResolution>
                         <gmd:MD_Resolution>
                             <gmd:distance>
-                                <gco:Distance uom="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/uom/ML_gmxUom.xml#m">{{ d }}{# tag="d" , name="Distance" , ref= "Part B 6.2" , desc= "Ground sample distance" , example = "25" ,type = "integer", group = "Quality and Validity" ,inbox="Spatial resolution-dostance", multi=0 , inboxmulti=1, multiline= False #}</gco:Distance>
+                                <gco:Distance uom="{{ u }}{# tag="u" , name="Units" , ref= "Part B 6.2" , desc= "Ground sample distance" , example = "m" , type ="string" , group = "Quality and Validity" ,inbox="Spatial resolution-distance", multi=0 , inboxmulti=1, multiline= False #}">
+{{ d }}{# tag="d" , name="Resolution" , ref= "Part B 6.2" , desc= "Ground sample distance" , example = "25" , type ="integer" , group = "Quality and Validity" ,inbox="Spatial resolution-distance", multi=0 , inboxmulti=1, multiline= False #}</gco:Distance>
                             </gmd:distance>
                         </gmd:MD_Resolution>
                     </gmd:spatialResolution>
@@ -128,15 +129,4 @@
                     </gmd:distributionFormat>
                 </gmd:MD_Distribution>
             </gmd:distributionInfo>
-            <gmd:dataQualityInfo>
-                <gmd:DQ_DataQuality>
-                    <gmd:scope>
-                        <gmd:DQ_Scope>
-                            <gmd:level>
-                                <gmd:MD_ScopeCode codeListValue="{{ md.identification.identtype }}{# tag="md.identification.identtype", name ="Resource Type",type = "MD_ScopeCode", desc ="Scope to which metadata applies", example ="dataset", multi = 0, group = "Identification",multiline=True #}" codeList="http://www.isotc211.org/2005/resources/Codelist/ML_gmxCodelists.xml#MD_ScopeCode">{{ md.identification.identtype }}</gmd:MD_ScopeCode>
-                            </gmd:level>
-                        </gmd:DQ_Scope>
-                    </gmd:scope>
-                </gmd:DQ_DataQuality>
-            </gmd:dataQualityInfo>
         </gmd:MD_Metadata>
Modified: sandbox/krejcmat/src/templates/grassInspireTemplateFinal.xml
--- sandbox/krejcmat/src/templates/grassInspireTemplateFinal.xml	2014-08-05 21:45:19 UTC (rev 61537)
+++ sandbox/krejcmat/src/templates/grassInspireTemplateFinal.xml	2014-08-05 22:04:08 UTC (rev 61538)
@@ -46,7 +46,7 @@
             <gmd:citation>
                 <gmd:CI_Citation>
                     <gmd:title>
                     </gmd:title>
                     <gmd:date>
@@ -55,7 +55,7 @@
                                 <gco:DateTime>{{ d.date }}{# tag="d.date" , group= "Temporal" ,object="CI_Date()",type = "date", inbox= "Date of creation/publication/revision",  inboxmulti=1, multiline= False, name="Date of: type(below)",desc="reference date for the cited resource - publication/creation/revision",example="2007-09-15" #}</gco:DateTime>
                             </gmd:date>
                             <gmd:dateType>
-                                <gmd:CI_DateTypeCode codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_DateTypeCode" codeListValue="{{ d.type }}{# tag="d.type" , group= "Temporal" ,object="CI_Date()",type = "CI_DateTypeCode", inbox= "Date of creation/publication/revision",  inboxmulti=1, multiline= False, name="type: creation/publication/revision",desc="reference date for the cited resource - publication/creation/revision",example="creation" #}" codeSpace="ISOTC211/19115">{{ d.type }}</gmd:CI_DateTypeCode>
+                                <gmd:CI_DateTypeCode codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_DateTypeCode" codeListValue= "{{ d.type }}{# tag="d.type" , group= "Temporal" ,object="CI_Date()",type = "CI_DateTypeCode", inbox= "Date of creation/publication/revision",  inboxmulti=1, multiline= False, name="type: creation/publication/revision",desc="reference date for the cited resource - publication/creation/revision",example="creation" #}" codeSpace="ISOTC211/19115">{{ d.type }}</gmd:CI_DateTypeCode>
                             </gmd:dateType>
                         </gmd:CI_Date>
                     </gmd:date>
@@ -68,10 +68,10 @@
                                     <gmd:geographicIdentifier>
                                         <gmd:RS_Identifier>
                                             <gmd:code>
-                                                <gco:CharacterString>{{ cod }}{# tag="cod", inboxmulti=1, group = "Identification",inbox="Unique resource identifier" ,ref="Part B 1.5",  name ="Identifier- code", desc ="A value uniquely identifying the resource.The value domain of this metadata element is a mandatory character string code, generally assigned by the data owner, and a character string namespace uniquely identifying the context of the identifier code (for example, the data owner).", example ="http://image2000.jrc.it # image2000_1_nl2_multi", type = "string", multi = 0  #}</gco:CharacterString>
+                                                <gco:CharacterString>{{ cod }}{# tag="cod", inboxmulti=1, group = "Identification",inbox="Unique resource identifier" ,ref="Part B 1.5",  name ="Idetifier- code", desc ="A value uniquely identifying the resource.The value domain of this metadata element is a mandatory character string code, generally assigned by the data owner, and a character string namespace uniquely identifying the context of the identifier code (for example, the data owner).", example ="http://image2000.jrc.it # image2000_1_nl2_multi", type = "string", multi = 0  #}</gco:CharacterString>
                                             </gmd:code>
                                             <gmd:codeSpace>
-                                                <gco:CharacterString>{{ code }}{# tag="code", inboxmulti=1, group = "Identification",inbox="Unique resource identifier" ,ref="Part B 1.5",  name ="Identifier- code space", desc ="A value uniquely identifying the resource.The value domain of this metadata element is a mandatory character string code, generally assigned by the data owner, and a character string namespace uniquely identifying the context of the identifier code (for example, the data owner).", example ="http://image2000.jrc.it", type = "string", multi = 0 #}</gco:CharacterString>
+                                                <gco:CharacterString>{{ code }}{# tag="code", inboxmulti=1, group = "Identification",inbox="Unique resource identifier" ,ref="Part B 1.5",  name ="Idetifier- code space", desc ="A value uniquely identifying the resource.The value domain of this metadata element is a mandatory character string code, generally assigned by the data owner, and a character string namespace uniquely identifying the context of the identifier code (for example, the data owner).", example ="http://image2000.jrc.it", type = "string", multi = 0 #}</gco:CharacterString>
                                             </gmd:codeSpace>
                                         </gmd:RS_Identifier>
                                     </gmd:geographicIdentifier>
@@ -130,7 +130,7 @@
                                         <gco:Date>{{ k["thesaurus"]["date"] }}{# tag='k["thesaurus"]["date"]', name ="Reference date", desc ="This citation shall include at least the title a reference date(publication, revision, creation." , type = "date",inboxmulti=1, multi = 0, group = "Keywords", multiline=False, inbox="Free keywords" #}</gco:Date>
                                     </gmd:date>
                                     <gmd:dateType>
-                                        <gmd:CI_DateTypeCode codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_DateTypeCode" codeListValue="{{ k["thesaurus"]["datetype"] }}{{ k["thesaurus"]["datetype"] }}{# tag='k["thesaurus"]["datetype"]', type = "CI_DateTypeCode",name ="Date type",inboxmulti=1, desc ="Options Date of creation, Date of last revision, date of publication" , multi = 0, group = "Keywords", multiline=False, inbox="Free keywords" #}">{{ k["thesaurus"]["datetype"] }}</gmd:CI_DateTypeCode>
+                                        <gmd:CI_DateTypeCode codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_DateTypeCode" codeListValue= "{{ k["thesaurus"]["datetype"] }}{{ k["thesaurus"]["datetype"] }}{# tag='k["thesaurus"]["datetype"]', type = "CI_DateTypeCode",name ="Date type",inboxmulti=1, desc ="Options Date of creation, Date of last revision, date of publication" , multi = 0, group = "Keywords", multiline=False, inbox="Free keywords" #}" >{{ k["thesaurus"]["datetype"] }}</gmd:CI_DateTypeCode>
                                     </gmd:dateType>
                                 </gmd:CI_Date>
                             </gmd:date>
@@ -179,10 +179,11 @@
       {% endif -%}
                         <gmd:MD_Resolution>
                             <gmd:distance>
-                                <gco:Distance uom="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/uom/ML_gmxUom.xml#m">{{ d }}{# tag="d" , name="Distance" , ref= "Part B 6.2" , desc= "Ground sample distance" , example = "25" , type ="integer" , group = "Quality and Validity" ,inbox="Spatial resolution-dostance", multi=0 , inboxmulti=1, multiline= False #}</gco:Distance>
                             </gmd:distance>
@@ -264,7 +265,7 @@
             <gmd:scope>
                 <gmd:DQ_Scope>
                     <gmd:level>
-                        <gmd:MD_ScopeCode codeListValue="{{ md.identification.identtype }}{# tag="md.identification.identtype", name ="Resource Type", desc ="Scope to which metadata applies", example ="dataset", type = "string", multi = 0, group = "Identification",multiline=True #}" codeList="http://www.isotc211.org/2005/resources/Codelist/ML_gmxCodelists.xml#MD_ScopeCode">{{ md.identification.identtype }}</gmd:MD_ScopeCode>
+                        <gmd:MD_ScopeCode codeListValue="{{ md.identification.identtype }}{# tag="md.identification.identtype", name ="Resource Type", desc ="Scope to which metadata applies", example ="dataset", type = "string", multi = 0, group = "Conformity",multiline=False #}" codeList="http://www.isotc211.org/2005/resources/Codelist/ML_gmxCodelists.xml#MD_ScopeCode">{{ md.identification.identtype }}</gmd:MD_ScopeCode>
                     </gmd:level>
                 </gmd:DQ_Scope>
             </gmd:scope>
