[GRASS-SVN] r61543 - in grass/trunk: . doc
svn_grass at osgeo.org
Tue Aug 5 15:51:14 PDT 2014
Author: neteler
Date: 2014-08-05 15:51:14 -0700 (Tue, 05 Aug 2014)
New Revision: 61543
grass/trunk/INSTALL
grass/trunk/doc/debugging.txt
updated supporting docs
Modified: grass/trunk/INSTALL
--- grass/trunk/INSTALL 2014-08-05 22:21:54 UTC (rev 61542)
+++ grass/trunk/INSTALL 2014-08-05 22:51:14 UTC (rev 61543)
@@ -98,7 +98,10 @@
make
+Detailed Wiki notes for various operating systems:
+http://grasswiki.osgeo.org/wiki/Compile_and_Install
Note for Solaris users:
To configure GRASS correctly on a system which doesn't have a suitable
@@ -164,10 +167,11 @@
See the ReadMe.rtf in the ./macosx/ folder.
-(F) RUNNING GRASS
+(F) RUNNING GRASS GIS
Download a sample data package from the GRASS web site, see
-http://grass.osgeo.org/download/data.php
+http://grass.osgeo.org/download/sample-data/
Extract the data set and point "database" in the
GRASS startup menu to the directory.
@@ -260,8 +264,8 @@
CFLAGS="-g -Wall" ./configure
-See also the file
-./doc/debugging.txt
+See also the file ./doc/debugging.txt and the Wiki page
+http://grasswiki.osgeo.org/wiki/GRASS_Debugging
(K) LARGE FILE SUPPORT (for raster maps)
@@ -271,17 +275,18 @@
configure [...] --enable-largefile
you should be able to have raster and vector maps which are larger than 2GB.
-Individual programs may or may not work with large files - please report.
+While most code has been updated, individual programs may not yet work with
+large files - please report.
(L) SUPPORT
Note that this code is still actively being developed and errors inevitably
turn up. If you find a bug, please report it to the GRASS bug tracking system
-so we can fix it. See http://grass.osgeo.org/bugtracking/index.php
+so we can fix it. See http://grass.osgeo.org/development/bug-tracking/
If you are interested in helping to develop GRASS, please join the GRASS
-developers mailing list. See http://grass.osgeo.org/devel/index.php
+developers mailing list. See http://grass.osgeo.org/development/
(M) GRASS PROGRAMMER'S MANUAL
@@ -292,14 +297,15 @@
(N) CONTRIBUTING CODE AND PATCHES
-Please see ./SUBMITTING, ./SUBMITTING_DOCS, ./SUBMITTING_PYTHON,
-and ./SUBMITTING_SCRIPTS in this directory.
+Please see ./SUBMITTING in this directory, or better,
+http://trac.osgeo.org/grass/wiki/Submitting
(O) DRAFT TUTORIAL
-http://grass.osgeo.org/wiki/GRASS_6_Tutorial
+http://grass.osgeo.org/documentation/first-time-users/
-(C) 1999-2010 by The GRASS Development Team
-$Date$
+(C) 1999-2014 by The GRASS Development Team
+Last changed: $Date$
Modified: grass/trunk/doc/debugging.txt
--- grass/trunk/doc/debugging.txt 2014-08-05 22:21:54 UTC (rev 61542)
+++ grass/trunk/doc/debugging.txt 2014-08-05 22:51:14 UTC (rev 61543)
@@ -1,5 +1,9 @@
-GRASS Debugging:
+GRASS GIS Debugging:
+See also
At user level:
Print debugging message if variable DEBUG
@@ -140,3 +144,4 @@
Note that when 'make distclean' is run, the manual changes to
include/Make/Platform.make are also removed.
