[GRASS-SVN] r61547 - in grass-addons/grass7/raster3d: . r3.gradient
Tue Aug 5 19:46:37 PDT 2014
Author: annakrat
Date: 2014-08-05 19:46:37 -0700 (Tue, 05 Aug 2014)
New Revision: 61547
Added:
   grass-addons/grass7/raster3d/r3.gradient/
   grass-addons/grass7/raster3d/r3.gradient/Makefile
   grass-addons/grass7/raster3d/r3.gradient/main.c
   grass-addons/grass7/raster3d/r3.gradient/r3.gradient.html
   grass-addons/grass7/raster3d/r3.gradient/r3gradient_structs.h
   grass-addons/grass7/raster3d/Makefile
r3.gradient added to addons
Modified: grass-addons/grass7/raster3d/Makefile
--- grass-addons/grass7/raster3d/Makefile	2014-08-05 22:54:57 UTC (rev 61546)
+++ grass-addons/grass7/raster3d/Makefile	2014-08-06 02:46:37 UTC (rev 61547)
@@ -1,7 +1,8 @@
 MODULE_TOPDIR = ..
 SUBDIRS = \
-	r3.flow
+	r3.flow \
+	r3.gradient
 include $(MODULE_TOPDIR)/include/Make/Dir.make
Added: grass-addons/grass7/raster3d/r3.gradient/Makefile
--- grass-addons/grass7/raster3d/r3.gradient/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.gradient/Makefile	2014-08-06 02:46:37 UTC (rev 61547)
@@ -0,0 +1,11 @@
+MODULE_TOPDIR = ../..
+PGM=r3.gradient
+LIBES = $(RASTER3DLIB) $(RASTERLIB) $(GISLIB) $(OMPLIB)
+DEPENDENCIES = $(RASTER3DDEP) $(RASTERDEP) $(GISDEP)
+EXTRA_CFLAGS = $(OMPCFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass7/raster3d/r3.gradient/main.c
--- grass-addons/grass7/raster3d/r3.gradient/main.c	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.gradient/main.c	2014-08-06 02:46:37 UTC (rev 61547)
@@ -0,0 +1,299 @@
+ * MODULE:       r3.gradient
+ * AUTHOR(S):    Anna Petrasova kratochanna <at> gmail <dot> com
+ * PURPOSE:      Computes gradient of a 3D raster map
+ * COPYRIGHT:    (C) 2014 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#if defined(_OPENMP)
+#include <omp.h>
+#endif
+#include <grass/raster3d.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "r3gradient_structs.h"
+int main(int argc, char *argv[])
+    struct Option *input_opt, *output_opt, *block_opt, *process_opt;
+    struct GModule *module;
+    RASTER3D_Region region;
+    RASTER3D_Map *input;
+    RASTER3D_Map *output[3];
+    struct Gradient_block *blocks;
+    int block_x, block_y, block_z;
+    int index_x, index_y, index_z;
+    int n_x, n_y, n_z;
+    int start_x, start_y, start_z;
+    int i, max_i, k, j, N;
+    double step[3];
+    int *bl_indices;
+    int *bl_overlap;
+    int r, c, d;
+    DCELL value;
+    module = G_define_module();
+    G_add_keyword(_("raster3d"));
+    G_add_keyword(_("voxel"));
+    G_add_keyword(_("gradient"));
+    module->description =
+	_("Computes gradient of a 3D raster map "
+	  "and outputs gradient components as three 3D raster maps.");
+    input_opt = G_define_standard_option(G_OPT_R3_INPUT);
+    /* TODO: define G_OPT_R3_OUTPUTS or use separate options for each map? */
+    output_opt = G_define_standard_option(G_OPT_R3_OUTPUT);
+    output_opt->multiple = YES;
+    output_opt->description = _("Name for output 3D raster map(s)");
+    block_opt = G_define_option();
+    block_opt->key = "block_size";
+    block_opt->multiple = TRUE;
+    block_opt->answer = "30,30,20"; /* based on testing */
+    block_opt->key_desc = "size_x,size_y,size_z";
+    block_opt->description = _("Size of blocks");
+    process_opt = G_define_option();
+    process_opt->key = "nprocs";
+    process_opt->type = TYPE_INTEGER;
+    process_opt->required = NO;
+    process_opt->description = _("Number of parallel processes");
+    process_opt->options = "1-100";
+    process_opt->answer = "1";
+    G_gisinit(argv[0]);
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    N = atoi(process_opt->answer);
+    omp_set_num_threads(N);
+#endif
+    Rast3d_init_defaults();
+    Rast3d_get_window(&region);
+    block_x = atoi(block_opt->answers[0]);
+    block_y = atoi(block_opt->answers[1]);
+    block_z = atoi(block_opt->answers[2]);
+    if (block_x < 3 || block_y < 3 || block_z < 3)
+	G_warning("block size too small, set to 3");
+    block_x = block_x < 3 ? 3 : block_x;
+    block_y = block_y < 3 ? 3 : block_y;
+    block_z = block_z < 3 ? 3 : block_z;
+    block_x = block_x > region.cols ? region.cols : block_x;
+    block_y = block_y > region.rows ? region.rows : block_y;
+    block_z = block_y > region.depths ? region.depths : block_z;
+    step[0] = region.ew_res;
+    step[1] = region.ns_res;
+    step[2] = region.tb_res;
+    input = Rast3d_open_cell_old(input_opt->answer,
+				 G_find_raster3d(input_opt->answer, ""),
+				 &region, RASTER3D_TILE_SAME_AS_FILE,
+				 RASTER3D_USE_CACHE_DEFAULT);
+    if (!input)
+	Rast3d_fatal_error(_("Unable to open 3D raster map <%s>"),
+			   input_opt->answer);
+    for (i = 0; i < 3; i++) {
+	output[i] =
+	    Rast3d_open_new_opt_tile_size(output_opt->answers[i],
+					  RASTER3D_USE_CACHE_DEFAULT,
+					  &region, DCELL_TYPE, 32);
+	if (!output[i]) {
+			       output_opt->answers[i]);
+    blocks = G_calloc(N, sizeof(struct Gradient_block));
+    if (!blocks)
+	G_fatal_error(_("Failed to allocate memory for blocks"));
+    for (i = 0; i < N; i++) {
+	blocks[i].input.array = G_malloc(((block_x + 2) * (block_y + 2)
+					  * (block_z + 2)) * sizeof(DCELL));
+	blocks[i].dx.array = G_malloc(((block_x + 2) * (block_y + 2)
+	blocks[i].dy.array = G_malloc(((block_x + 2) * (block_y + 2)
+	blocks[i].dz.array = G_malloc(((block_x + 2) * (block_y + 2)
+    bl_indices = G_calloc(N * 3, sizeof(int));
+    bl_overlap = G_calloc(N * 6, sizeof(int));
+    max_i = (int)ceil(region.cols / (float)block_x) *
+	(int)ceil(region.rows / (float)block_y) *
+	(int)ceil(region.depths / (float)block_z);
+    i = j = 0;
+    index_z = 0;
+    /* loop through the blocks */
+    while (index_z < region.depths) {
+	index_y = 0;
+	while (index_y < region.rows) {
+	    index_x = 0;
+	    while (index_x < region.cols) {
+		G_percent(i, max_i, 1);
+		/* generally overlap is 1 on both sides */
+		bl_overlap[j * 6 + 0] = bl_overlap[j * 6 + 2] =
+		    bl_overlap[j * 6 + 4] = 1;
+		bl_overlap[j * 6 + 1] = bl_overlap[j * 6 + 3] =
+		    bl_overlap[j * 6 + 5] = 1;
+		/* compute the starting index of the block and its size */
+		start_x = fmax(index_x - 1, 0);
+		n_x = fmin(index_x + block_x, region.cols - 1) - start_x + 1;
+		start_y = fmax(index_y - 1, 0);
+		n_y = fmin(index_y + block_y, region.rows - 1) - start_y + 1;
+		start_z = fmax(index_z - 1, 0);
+		n_z =
+		    fmin(index_z + block_z, region.depths - 1) - start_z + 1;
+		/* adjust offset on edges */
+		/* start offset */
+		if (index_x == 0)
+		    bl_overlap[j * 6 + 0] = 0;
+		if (index_y == 0)
+		    bl_overlap[j * 6 + 2] = 0;
+		if (index_z == 0)
+		    bl_overlap[j * 6 + 4] = 0;
+		/* end offset */
+		if (index_x + block_x >= region.cols)
+		    bl_overlap[j * 6 + 1] = 0;
+		if (index_y + block_y >= region.rows)
+		    bl_overlap[j * 6 + 3] = 0;
+		if (index_z + block_z >= region.depths)
+		    bl_overlap[j * 6 + 5] = 0;
+		/* adjust offset when the end block would be too small */
+		if (n_x <= 2) {
+		    start_x -= 1;
+		    n_x += 1;
+		    bl_overlap[j * 6 + 0] = 2;
+		if (n_y <= 2) {
+		    start_y -= 1;
+		    n_y += 1;
+		    bl_overlap[j * 6 + 2] = 2;
+		if (n_z <= 2) {
+		    start_z -= 1;
+		    n_z += 1;
+		    bl_overlap[j * 6 + 4] = 2;
+		/* store indices for later writing */
+		bl_indices[j * 3 + 0] = index_x;
+		bl_indices[j * 3 + 1] = index_y;
+		bl_indices[j * 3 + 2] = index_z;
+		blocks[j].input.sx = n_x;
+		blocks[j].input.sy = n_y;
+		blocks[j].input.sz = n_z;
+		blocks[j].dx.sx = blocks[j].dy.sx = blocks[j].dz.sx = n_x;
+		blocks[j].dx.sy = blocks[j].dy.sy = blocks[j].dz.sy = n_y;
+		blocks[j].dx.sz = blocks[j].dy.sz = blocks[j].dz.sz = n_z;
+		/* read */
+		Rast3d_get_block(input, start_x, start_y, start_z,
+				 n_x, n_y, n_z, blocks[j].input.array,
+				 DCELL_TYPE);
+		if ((j + 1) == N || i == max_i - 1) {
+		    /* compute gradient */
+		    #pragma omp parallel for schedule (static) private (k)
+		    for (k = 0; k <= j; k++) {
+			Rast3d_gradient_double(&(blocks[k].input), step,
+					       &(blocks[k].dx), &(blocks[k].dy),
+					       &(blocks[k].dz));
+		    /* write */
+			for (c = 0;c < blocks[k].input.sx - bl_overlap[k * 6 + 0] -
+			     bl_overlap[k * 6 + 1]; c++) {
+			    for (r = 0; r < blocks[k].input.sy - bl_overlap[k * 6 + 2] -
+				 bl_overlap[k * 6 + 3]; r++) {
+				for (d = 0; d < blocks[k].input.sz - bl_overlap[k * 6 + 4] -
+				     bl_overlap[k * 6 + 5]; d++) {
+				    value = RASTER3D_ARRAY_ACCESS(&(blocks[k].dx),
+					      c + bl_overlap[k * 6 + 0],
+					      r + bl_overlap[k * 6 + 2],
+					      d + bl_overlap[k * 6 + 4]);
+				    Rast3d_put_value(output[0],
+						     c + bl_indices[k * 3 + 0],
+						     r + bl_indices[k * 3 + 1],
+						     d + bl_indices[k * 3 + 2],
+						     &value, DCELL_TYPE);
+				    value = RASTER3D_ARRAY_ACCESS(&(blocks[k].dy),
+				    Rast3d_put_value(output[1],
+				    value = RASTER3D_ARRAY_ACCESS(&(blocks[k].dz),
+				    Rast3d_put_value(output[2],
+		    j = -1;
+		i++;
+		j++;
+		index_x += block_x;
+	    index_y += block_y;
+	index_z += block_z;
+    G_percent(1, 1, 1);
+	G_free(blocks[i].input.array);
+	G_free(blocks[i].dx.array);
+	G_free(blocks[i].dy.array);
+	G_free(blocks[i].dz.array);
+    G_free(blocks);
+    G_free(bl_indices);
+    G_free(bl_overlap);
+    G_message(_("Writing gradient 3D raster maps..."));
+    G_percent(0, 3, 1);
+    Rast3d_close(output[0]);
+    G_percent(1, 3, 1);
+    Rast3d_close(output[1]);
+    G_percent(2, 3, 1);
+    Rast3d_close(output[2]);
+    exit(EXIT_SUCCESS);
Property changes on: grass-addons/grass7/raster3d/r3.gradient/main.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:eol-style
   + native
Added: grass-addons/grass7/raster3d/r3.gradient/r3.gradient.html
--- grass-addons/grass7/raster3d/r3.gradient/r3.gradient.html	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.gradient/r3.gradient.html	2014-08-06 02:46:37 UTC (rev 61547)
@@ -0,0 +1,23 @@
+<h2>DESCRIPTION</h2>
+Module <em>r3.gradient</em> computes gradient from a 3D raster map.
+Results are three 3D raster maps describing the x, y, z components of the computed gradient field.
+<h2>EXAMPLES</h2>
+<div class="code"><pre>
+# create a 3D raster
+g.region s=0 n=100 w=0 e=100 b=0 t=100
+r3.mapcalc "test_gradient = sqrt(row()*row() +col()*col()+ depth()*depth())"
+# compute gradient
+r3.gradient input=test_gradient output=grad_x,grad_y,grad_z
+</pre></div>
+<h2>AUTHORS</h2>
+Anna Petrasova,  <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU OSGeoREL</a>, developed during GSoC 2014.
+<h2>SEE ALSO</h2>
+<em>
+<a href="http://grass.osgeo.org/grass71/manuals/r.slope.aspect.html">r.flow</a>
+</em>
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/raster3d/r3.gradient/r3.gradient.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass-addons/grass7/raster3d/r3.gradient/r3gradient_structs.h
--- grass-addons/grass7/raster3d/r3.gradient/r3gradient_structs.h	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.gradient/r3gradient_structs.h	2014-08-06 02:46:37 UTC (rev 61547)
@@ -0,0 +1,13 @@
+#ifndef R3GRADIENT_STRUCTS_H
+#define R3GRADIENT_STRUCTS_H
+struct Gradient_block {
+    RASTER3D_Array_double input;
+    RASTER3D_Array_double dx;
+    RASTER3D_Array_double dy;
+    RASTER3D_Array_double dz;
+#endif // R3GRADIENT_STRUCTS_H
Property changes on: grass-addons/grass7/raster3d/r3.gradient/r3gradient_structs.h
   + text/x-chdr
   + native
