[GRASS-SVN] r61552 - grass/trunk/vector/v.mkgrid
svn_grass at osgeo.org
Wed Aug 6 08:51:00 PDT 2014
Author: lucadelu
Date: 2014-08-06 08:51:00 -0700 (Wed, 06 Aug 2014)
New Revision: 61552
grass/trunk/vector/v.mkgrid/main.c
grass/trunk/vector/v.mkgrid/write_grid.c
v.mkgrid: added breaks for vertical lines (ticket #1686)
Modified: grass/trunk/vector/v.mkgrid/main.c
--- grass/trunk/vector/v.mkgrid/main.c 2014-08-06 13:53:09 UTC (rev 61551)
+++ grass/trunk/vector/v.mkgrid/main.c 2014-08-06 15:51:00 UTC (rev 61552)
@@ -6,9 +6,9 @@
* Upgrade to 5.7 Radim Blazek 10/2004
* Hamish Bowman <hamish_b yahoo.com>,
* Jachym Cepicky <jachym les-ejk.cz>, Markus Neteler <neteler itc.it>
- * Ivan Shevlakov: points support -p
- * Luca Delucchi: lines support -l
- * PURPOSE:
+ * Ivan Shevlakov: points support -p
+ * Luca Delucchi: lines support -l, vertical breaks
+ * PURPOSE:
* COPYRIGHT: (C) 1999-2014 by the GRASS Development Team
* This program is free software under the GNU General
@@ -125,7 +125,7 @@
breaks->type = TYPE_INTEGER;
breaks->required = NO;
breaks->description =
- _("Number of horizontal vertex points per grid cell");
+ _("Number of vertex points per grid cell");
breaks->options = "0-60";
breaks->answer = "3";
Modified: grass/trunk/vector/v.mkgrid/write_grid.c
--- grass/trunk/vector/v.mkgrid/write_grid.c 2014-08-06 13:53:09 UTC (rev 61551)
+++ grass/trunk/vector/v.mkgrid/write_grid.c 2014-08-06 15:51:00 UTC (rev 61552)
@@ -11,7 +11,7 @@
int i, k, j;
int rows, cols;
int num_v_rows, num_v_cols;
- double x, y, x_len;
+ double x, y, x_len, y_len;
double sx, sy;
double width, length;
double next_x, next_y;
@@ -36,10 +36,10 @@
* line is less than half way around the globe
x_len = length / (1. * nbreaks + 1);
+ y_len = width / (1. * nbreaks + 1);
/* write out all the vector lengths (x vectors) of the entire grid */
G_verbose_message(_("Writing out vector rows..."));
y = grid_info->origin_y;
for (i = 0; i < num_v_rows; ++i) {
double startx;
@@ -79,29 +79,37 @@
/* write out all the vector widths (y vectors) of the entire grid */
G_verbose_message(_("Writing out vector columns..."));
x = grid_info->origin_x;
- for (k = 0; k < num_v_cols; ++k) {
- y = grid_info->origin_y;
- G_percent(k, num_v_cols, 2);
+ for (i = 0; i < num_v_cols; ++i) {
+ double starty;
+ starty = grid_info->origin_y;
+ G_percent(i, num_v_cols, 2);
- i = 0;
- do {
- next_y = y + width;
+ for (k = 0; k < rows; k++) {
+ y = starty;
+ j = 0;
+ do {
+ if (j < nbreaks)
+ next_y = y + y_len;
+ else
+ next_y = starty + width;
- sx = x;
- sy = y;
- snext_y = next_y;
- dum = x;
- rotate(&x, &y, grid_info->origin_x, grid_info->origin_y, angle);
- rotate(&dum, &next_y, grid_info->origin_x, grid_info->origin_y,
- angle);
+ sx = x;
+ sy = y;
+ snext_y = next_y;
+ dum = x;
+ rotate(&x, &y, grid_info->origin_x, grid_info->origin_y, angle);
+ rotate(&dum, &next_y, grid_info->origin_x, grid_info->origin_y,
+ angle);
- write_vect(x, y, dum, next_y, Map, Points, out_type);
+ write_vect(x, y, dum, next_y, Map, Points, out_type);
- x = sx;
- y = next_y = snext_y;
- i++;
- } while (i < rows);
- /* To get exactly the same coordinates as above, x+=length is wrong */
+ x = sx;
+ y = next_y = snext_y;
+ j++;
+ } while (j <= nbreaks);
+ /* To get exactly the same coordinates as above, y+=width is wrong */
+ starty += width;
x += length;
