[GRASS-SVN] r61575 - in grass/trunk/vector: v.clean v.in.ogr
Sat Aug 9 04:24:34 PDT 2014
Author: neteler
Date: 2014-08-09 04:24:34 -0700 (Sat, 09 Aug 2014)
New Revision: 61575
   grass/trunk/vector/v.clean/main.c
   grass/trunk/vector/v.in.ogr/main.c
v.clean/v.in.ogr: tell user that degree is unit in LL locations
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c	2014-08-09 06:27:37 UTC (rev 61574)
+++ grass/trunk/vector/v.clean/main.c	2014-08-09 11:24:34 UTC (rev 61575)
@@ -196,6 +196,10 @@
     G_debug(1, "ntools = %d", ntools);
     threshs = (double *)G_malloc(ntools * sizeof(double));
+    /* TODO: threshold might be recalculated with optional geodesic support to meters */
+    if (G_projection() == PROJECTION_LL)
+        G_important_message(_("Note: In latitude-longitude coordinate system threshold in degree units"));
     /* Read thresholds */
     for (i = 0; i < ntools; i++)
 	threshs[i] = 0.0;
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2014-08-09 06:27:37 UTC (rev 61574)
+++ grass/trunk/vector/v.in.ogr/main.c	2014-08-09 11:24:34 UTC (rev 61575)
@@ -310,6 +310,10 @@
     G_begin_polygon_area_calculations();	/* Used in geom() */
     OGRRegisterAll();
     /* list supported formats */
