[GRASS-SVN] r61600 - grass/trunk/scripts/g.extension
Wed Aug 13 13:49:57 PDT 2014
Author: martinl
Date: 2014-08-13 13:49:57 -0700 (Wed, 13 Aug 2014)
New Revision: 61600
   grass/trunk/scripts/g.extension/g.extension.py
g.extension: produce full make command also for wxGUI extensions
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py	2014-08-13 20:48:17 UTC (rev 61599)
+++ grass/trunk/scripts/g.extension/g.extension.py	2014-08-13 20:49:57 UTC (rev 61600)
@@ -750,22 +750,17 @@
              'etc'     : os.path.join(TMPDIR, name, 'etc'),
-    if classchar != 'wx':
-        makeCmd = ['make',
-                   'MODULE_TOPDIR=%s' % gisbase.replace(' ', '\ '),
-                   'RUN_GISRC=%s' % os.environ['GISRC'],
-                   'BIN=%s' % dirs['bin'],
-                   'HTMLDIR=%s' % dirs['html'],
-                   'RESTDIR=%s' % dirs['rest'],
-                   'MANDIR=%s' % dirs['man'],
-                   'SCRIPTDIR=%s' % dirs['scripts'],
-                   'ETC=%s' % os.path.join(dirs['etc'], name)
-    else:
+    makeCmd = ['make',
+               'MODULE_TOPDIR=%s' % gisbase.replace(' ', '\ '),
+               'RUN_GISRC=%s' % os.environ['GISRC'],
+               'BIN=%s' % dirs['bin'],
+               'HTMLDIR=%s' % dirs['html'],
+               'RESTDIR=%s' % dirs['rest'],
+               'MANDIR=%s' % dirs['man'],
+               'SCRIPTDIR=%s' % dirs['scripts'],
+               'ETC=%s' % os.path.join(dirs['etc'], name)
     installCmd = ['make',
                   'MODULE_TOPDIR=%s' % gisbase,
                   'ARCH_DISTDIR=%s' % os.path.join(TMPDIR, name),
