[GRASS-SVN] r61616 - in grass-addons/grass7/vector: . v.to.lines
Thu Aug 14 04:57:33 PDT 2014
Author: neteler
Date: 2014-08-14 04:57:33 -0700 (Thu, 14 Aug 2014)
New Revision: 61616
Added:
   grass-addons/grass7/vector/v.to.lines/
   grass-addons/grass7/vector/v.to.lines/v.to.lines.html
   grass-addons/grass7/vector/v.to.lines/v.to.lines.py
Removed:
   grass-addons/grass7/vector/v.polytoline/
   grass-addons/grass7/vector/v.to.lines/v.polytoline.html
   grass-addons/grass7/vector/v.to.lines/v.polytoline.py
   grass-addons/grass7/vector/Makefile
   grass-addons/grass7/vector/v.to.lines/Makefile
Addons: v.polytoline renamed to v.to.lines; point support added
Modified: grass-addons/grass7/vector/Makefile
--- grass-addons/grass7/vector/Makefile	2014-08-14 11:16:25 UTC (rev 61615)
+++ grass-addons/grass7/vector/Makefile	2014-08-14 11:57:33 UTC (rev 61616)
@@ -9,6 +9,7 @@
 	v.link.precip \
 	v.median \
 	v.net.turntable \
+	v.to.lines \
 	v.out.ply \
 	v.surf.icw
Modified: grass-addons/grass7/vector/v.to.lines/Makefile
--- grass-addons/grass7/vector/v.polytoline/Makefile	2014-08-14 03:51:17 UTC (rev 61613)
+++ grass-addons/grass7/vector/v.to.lines/Makefile	2014-08-14 11:57:33 UTC (rev 61616)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM = v.polytoline
+PGM = v.to.lines
 include $(MODULE_TOPDIR)/include/Make/Script.make
Deleted: grass-addons/grass7/vector/v.to.lines/v.polytoline.html
--- grass-addons/grass7/vector/v.polytoline/v.polytoline.html	2014-08-14 03:51:17 UTC (rev 61613)
+++ grass-addons/grass7/vector/v.to.lines/v.polytoline.html	2014-08-14 11:57:33 UTC (rev 61616)
@@ -1,26 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>v.polytoline</em> is useful to convert polygonal vector to lines
-<h2>EXAMPLES</h2>
-<div class="code"><pre>
-v.polytoline input=boundary_municp output=boundary_municp_line
-</pre></div>
-<h2>SEE ALSO</h2>
-<em><a href="v.type.html">v.type</a></em>,
-<em><a href="v.edit.html">v.edit</a></em>,
-<em><a href="v.category.html">v.category</a></em>,
-<h2>AUTHOR</h2>
-Luca Delucchi, Fondazione Edmund Mach
-<p>
-<i>Last changed: $Date$</i>
Deleted: grass-addons/grass7/vector/v.to.lines/v.polytoline.py
--- grass-addons/grass7/vector/v.polytoline/v.polytoline.py	2014-08-14 03:51:17 UTC (rev 61613)
+++ grass-addons/grass7/vector/v.to.lines/v.polytoline.py	2014-08-14 11:57:33 UTC (rev 61616)
@@ -1,98 +0,0 @@
-#!/usr/bin/env python
-# -*- coding: utf-8 -*-
-# MODULE:       v.polytoline
-# AUTHOR(S):    Luca delucchi
-# PURPOSE:      Convert polygon to line
-# COPYRIGHT:    (C) 2013 by the GRASS Development Team
-#               This program is free software under the GNU General Public
-#               License (version 2). Read the file COPYING that comes with GRASS
-#               for details.
-#%module
-#% description: Convert polygon to line.
-#% keywords: vector
-#% keywords: geometry
-#%end
-#%option G_OPT_V_INPUT
-#%end
-#%option G_OPT_V_OUTPUT
-#%end
-import grass.script as grass
-import os
-def main():
-    # Get the options
-    input = options["input"]
-    output = options["output"]
-    overwrite = grass.overwrite()
-    quiet = True
-    if grass.verbosity() > 2:
-        quiet = False
-    in_info = grass.vector_info(input)
-    if in_info['areas'] == 0 and in_info['boundaries'] == 0:
-        grass.fatal(_("The input vector seems not to be polygon"))
-    pid = os.getpid()
-    out_type = '{inp}_type_{pid}'.format(inp=input, pid=pid)
-    input_tmp = '{inp}_tmp_{pid}'.format(inp=input, pid=pid)
-    remove_names = "%s,%s" % (out_type, input_tmp)
-    if 0 != grass.run_command('v.category', layer="2", type='boundary',
-                              option='add', input=input, out=input_tmp,
-                              quiet=quiet):
-        grass.run_command('g.remove', vect=input_tmp, quiet=quiet)
-        grass.fatal(_("Error creating layer 2"))
-    if 0 != grass.run_command('v.db.addtable', map=input_tmp, layer="2",
-                              columns="left integer,right integer",
-                              quiet=quiet):
-        grass.fatal(_("Error creating new table for layer 2"))
-    if 0 != grass.run_command('v.to.db', map=input_tmp, option="sides",
-                              columns="left,right", layer="2", quiet=quiet):
-        grass.fatal(_("Error populating new table for layer 2"))
-    if 0 != grass.run_command('v.type', input=input_tmp, output=out_type, \
-                              from_type='boundary', to_type='line', \
-                              quiet=quiet, layer="2"):
-        grass.run_command('g.remove', vect=remove_names, quiet=quiet)
-        grass.fatal(_("Error converting polygon to line"))
-    report = grass.read_command('v.category', flags='g', input=out_type,
-                                option='report', quiet=quiet).split('\n')
-    for r in report:
-        if r.find('centroid') != -1:
-            min_cat = report[0].split()[-2]
-            max_cat = report[0].split()[-1]
-            break
-    if 0 != grass.run_command('v.edit', map=out_type, tool='delete', \
-                              type='centroid', layer=2, quiet=quiet, \
-                              cats='{mi}-{ma}'.format(mi=min_cat, ma=max_cat)):
-        grass.fatal(_("Error removing centroids"))
-    if 0 != grass.run_command('v.db.droptable', map=out_type, layer=1,
-                              flags='f', quiet=quiet):
-        grass.fatal(_("Error removing table from layer 1"))
-    if 0 != grass.run_command('v.category', input=out_type, option='transfer',
-                              output=output, layer="2,1", quiet=quiet,
-                              overwrite=overwrite):
-        grass.fatal(_("Error adding categories"))
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    main()
Copied: grass-addons/grass7/vector/v.to.lines/v.to.lines.html (from rev 61613, grass-addons/grass7/vector/v.polytoline/v.polytoline.html)
--- grass-addons/grass7/vector/v.to.lines/v.to.lines.html	                        (rev 0)
+++ grass-addons/grass7/vector/v.to.lines/v.to.lines.html	2014-08-14 11:57:33 UTC (rev 61616)
@@ -0,0 +1,43 @@
+<h2>DESCRIPTION</h2>
+<em>v.to.lines</em> converts vector polygons (boundaries) to lines as well
+as vector points to lines via triangulations. This script is a wrapper
+script to <em>>v.category</em>, <em>v.delaunay</em>, and <em>v.edit</em>.
+<h2>NOTES</h2>
+<em>v.to.lines</em> is able to convert point data (via triangulation)
+and areas to lines (via boundary to line conversion).
+<h2>EXAMPLES</h2>
+The examples are for the North Carolina sample dataset location:
+<h3>Area to line conversion</h3>
+<div class="code"><pre>
+v.to.lines input=boundary_municp output=boundary_municp_lines
+</pre></div>
+v.to.lines input=geodetic_pts output=geodetic_pts_lines
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.category.html">v.category</a>,
+<a href="v.delaunay.html">v.delaunay</a>,
+<a href="v.edit.html">v.edit</a>,
+<a href="v.to.points.html">v.to.points</a>,
+<a href="v.type.html">v.type</a>
+</em>
+<h2>AUTHOR</h2>
+Luca Delucchi, Fondazione Edmund Mach
+<p>
+<i>Last changed: $Date$</i>
Copied: grass-addons/grass7/vector/v.to.lines/v.to.lines.py (from rev 61613, grass-addons/grass7/vector/v.polytoline/v.polytoline.py)
--- grass-addons/grass7/vector/v.to.lines/v.to.lines.py	                        (rev 0)
+++ grass-addons/grass7/vector/v.to.lines/v.to.lines.py	2014-08-14 11:57:33 UTC (rev 61616)
@@ -0,0 +1,113 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:       v.to.lines (former v.polytoline)
+# AUTHOR(S):    Luca Delucchi
+#               point support added by Markus Neteler
+# PURPOSE:      Converts polygons and points to lines
+# COPYRIGHT:    (C) 2013-2014 by the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (version 2). Read the file COPYING that comes with GRASS
+#               for details.
+# TODO
+#    support centroids (treat as points)?
+#%module
+#% description: Converts vector polygons or points to lines.
+#% keywords: vector
+#% keywords: geometry
+#%end
+#%option G_OPT_V_INPUT
+#%end
+#%option G_OPT_V_OUTPUT
+#%end
+import grass.script as grass
+import os, sys
+def main():
+    # Get the options
+    input = options["input"]
+    output = options["output"]
+    overwrite = grass.overwrite()
+    quiet = True
+    if grass.verbosity() > 2:
+        quiet = False
+    in_info = grass.vector_info(input)
+    # check for wild mixture of vector types
+    if in_info['points'] > 0 and in_info['boundaries'] > 0:
+        grass.fatal(_("The input vector map contains both polygons and points, cannot handle mixed types"))
+    # process points via triangulation, then exit
+    if in_info['points'] > 0:
+        layer=1 # hardcoded for now
+        grass.message(_("Processing point data (%d points found)...") % in_info['points'])
+        grass.run_command('v.delaunay', input=input, layer=layer, output=output)
+        sys.exit()
+    # process areas
+    if in_info['areas'] == 0 and in_info['boundaries'] == 0:
+        grass.fatal(_("The input vector map does not contain polygons"))
+    pid = os.getpid()
+    out_type = '{inp}_type_{pid}'.format(inp=input, pid=pid)
+    input_tmp = '{inp}_tmp_{pid}'.format(inp=input, pid=pid)
+    remove_names = "%s,%s" % (out_type, input_tmp)
+    grass.message(_("Processing area data (%d areas found)...") % in_info['areas'])
+    if 0 != grass.run_command('v.category', layer="2", type='boundary',
+                              option='add', input=input, out=input_tmp,
+                              quiet=quiet):
+        grass.run_command('g.remove', vect=input_tmp, quiet=quiet)
+        grass.fatal(_("Error creating layer 2"))
+    if 0 != grass.run_command('v.db.addtable', map=input_tmp, layer="2",
+                              columns="left integer,right integer",
+                              quiet=quiet):
+        grass.fatal(_("Error creating new table for layer 2"))
+    if 0 != grass.run_command('v.to.db', map=input_tmp, option="sides",
+                              columns="left,right", layer="2", quiet=quiet):
+        grass.fatal(_("Error populating new table for layer 2"))
+    if 0 != grass.run_command('v.type', input=input_tmp, output=out_type, \
+                              from_type='boundary', to_type='line', \
+                              quiet=quiet, layer="2"):
+        grass.run_command('g.remove', vect=remove_names, quiet=quiet)
+        grass.fatal(_("Error converting polygon to line"))
+    report = grass.read_command('v.category', flags='g', input=out_type,
+                                option='report', quiet=quiet).split('\n')
+    for r in report:
+        if r.find('centroid') != -1:
+            min_cat = report[0].split()[-2]
+            max_cat = report[0].split()[-1]
+            break
+    if 0 != grass.run_command('v.edit', map=out_type, tool='delete', \
+                              type='centroid', layer=2, quiet=quiet, \
+                              cats='{mi}-{ma}'.format(mi=min_cat, ma=max_cat)):
+        grass.fatal(_("Error removing centroids"))
+    if 0 != grass.run_command('v.db.droptable', map=out_type, layer=1,
+                              flags='f', quiet=quiet):
+        grass.fatal(_("Error removing table from layer 1"))
+    if 0 != grass.run_command('v.category', input=out_type, option='transfer',
+                              output=output, layer="2,1", quiet=quiet,
+                              overwrite=overwrite):
+        grass.fatal(_("Error adding categories"))
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
