[GRASS-SVN] r61618 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Thu Aug 14 05:21:41 PDT 2014
Author: martinl
Date: 2014-08-14 05:21:41 -0700 (Thu, 14 Aug 2014)
New Revision: 61618
grass/trunk/scripts/g.extension/g.extension.py
g.extension: -d -> message cosmetics
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2014-08-14 12:19:24 UTC (rev 61617)
+++ grass/trunk/scripts/g.extension/g.extension.py 2014-08-14 12:21:41 UTC (rev 61618)
@@ -393,7 +393,7 @@
if REMOVE_TMPDIR:
grass.try_rmdir(TMPDIR)
else:
- grass.message(_("Path to the source code:"))
+ grass.message("\n%s\n" % _("Path to the source code:"))
sys.stderr.write('%s\n' % os.path.join(TMPDIR, options['extension']))
# write out meta-file
@@ -769,9 +769,9 @@
if flags['d']:
- grass.message(_("To compile run:"))
+ grass.message("\n%s\n" % _("To compile run:"))
sys.stderr.write(' '.join(makeCmd) + '\n')
- grass.message(_("To install run:"))
+ grass.message("\n%s\n" % _("To install run:"))
sys.stderr.write(' '.join(installCmd) + '\n')
return 0
