[GRASS-SVN] r61628 - grass-addons/grass7/raster3d/r3.gradient
Thu Aug 14 07:20:55 PDT 2014
Author: annakrat
Date: 2014-08-14 07:20:55 -0700 (Thu, 14 Aug 2014)
New Revision: 61628
   grass-addons/grass7/raster3d/r3.gradient/Makefile
   grass-addons/grass7/raster3d/r3.gradient/main.c
r3.gradient: disable OpenMP
Modified: grass-addons/grass7/raster3d/r3.gradient/Makefile
--- grass-addons/grass7/raster3d/r3.gradient/Makefile	2014-08-14 14:19:07 UTC (rev 61627)
+++ grass-addons/grass7/raster3d/r3.gradient/Makefile	2014-08-14 14:20:55 UTC (rev 61628)
@@ -2,9 +2,8 @@
 PGM=r3.gradient
-LIBES = $(RASTER3DLIB) $(RASTERLIB) $(GISLIB) $(OMPLIB)
+LIBES = $(RASTER3DLIB) $(RASTERLIB) $(GISLIB)
 DEPENDENCIES = $(RASTER3DDEP) $(RASTERDEP) $(GISDEP)
-EXTRA_CFLAGS = $(OMPCFLAGS)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass-addons/grass7/raster3d/r3.gradient/main.c
--- grass-addons/grass7/raster3d/r3.gradient/main.c	2014-08-14 14:19:07 UTC (rev 61627)
+++ grass-addons/grass7/raster3d/r3.gradient/main.c	2014-08-14 14:20:55 UTC (rev 61628)
@@ -13,9 +13,6 @@
 #include <stdlib.h>
 #include <string.h>
 #include <math.h>
-#if defined(_OPENMP)
-#include <omp.h>
-#endif
 #include <grass/raster3d.h>
 #include <grass/gis.h>
@@ -25,7 +22,7 @@
 int main(int argc, char *argv[])
-    struct Option *input_opt, *output_opt, *block_opt, *process_opt;
+    struct Option *input_opt, *output_opt, *block_opt;
     struct GModule *module;
     RASTER3D_Region region;
     RASTER3D_Map *input;
@@ -65,6 +62,7 @@
     block_opt->key_desc = "size_x,size_y,size_z";
     block_opt->description = _("Size of blocks");
+    /* disabled - was there for openMP
     process_opt = G_define_option();
     process_opt->key = "nprocs";
     process_opt->type = TYPE_INTEGER;
@@ -72,15 +70,19 @@
     process_opt->description = _("Number of parallel processes");
     process_opt->options = "1-100";
     process_opt->answer = "1";
     G_gisinit(argv[0]);
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
+    N = 1;
     N = atoi(process_opt->answer);
     omp_set_num_threads(N);
 #endif
     Rast3d_init_defaults();
     Rast3d_get_window(&region);
@@ -218,7 +220,7 @@
 		if ((j + 1) == N || i == max_i - 1) {
 		    /* compute gradient */
-		    #pragma omp parallel for schedule (static) private (k)
+		    /* disabled openMP #pragma omp parallel for schedule (static) private (k) */
 		    for (k = 0; k <= j; k++) {
 			Rast3d_gradient_double(&(blocks[k].input), step,
 					       &(blocks[k].dx), &(blocks[k].dy),
