[GRASS-SVN] r61635 - grass/trunk/lib/python/gunittest
svn_grass at osgeo.org
Thu Aug 14 09:43:57 PDT 2014
Author: wenzeslaus
Date: 2014-08-14 09:43:57 -0700 (Thu, 14 Aug 2014)
New Revision: 61635
grass/trunk/lib/python/gunittest/reporters.py
gunittest: unified and more robust way of printing success rate
Modified: grass/trunk/lib/python/gunittest/reporters.py
--- grass/trunk/lib/python/gunittest/reporters.py 2014-08-14 15:34:43 UTC (rev 61634)
+++ grass/trunk/lib/python/gunittest/reporters.py 2014-08-14 16:43:57 UTC (rev 61635)
@@ -549,11 +549,8 @@
def finish(self):
super(GrassTestFilesHtmlReporter, self).finish()
- if self.total:
- pass_per = 100 * (float(self.successes) / self.total)
- pass_per = percent_to_html(pass_per)
- else:
- pass_per = self.unknown_number
+ pass_per = success_to_html_percent(total=self.total,
+ successes=self.successes)
tfoot = ('<tfoot>'
'<tr>'
'<td>Summary</td>'
@@ -597,7 +594,8 @@
super(GrassTestFilesHtmlReporter, self).end_file_test(
module=module, cwd=cwd, returncode=returncode,
stdout=stdout, stderr=stderr)
- # TODO: considering others accoring to total, OK?
+ # considering others accoring to total is OK when we more or less
+ # know that input data make sense (total >= errors + failures)
total = test_summary.get('total', None)
failures = test_summary.get('failures', 0)
errors = test_summary.get('errors', 0)
@@ -617,16 +615,16 @@
self.expected_failures += expected_failures
self.unexpected_success += unexpected_successes
- # TODO: should we test for zero?
+ # zero would be valid here
if total is not None:
# success are only the clear ones
# percentage is influenced by all
# but putting only failures to table
self.successes += successes
self.total += total
- pass_per = 100 * (float(successes) / total)
+ # this will handle zero
+ pass_per = success_to_html_percent(total=total,
+ successes=successes)
else:
total = successes = pass_per = self.unknown_number
bad_ones = failures + errors
