[GRASS-SVN] r61638 - grass-addons/grass7/gui/wxpython/wx.metadata/mdlib
Thu Aug 14 12:10:24 PDT 2014
Author: krejcmat
Date: 2014-08-14 12:10:24 -0700 (Thu, 14 Aug 2014)
New Revision: 61638
   grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdgrass.py
path fix
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdgrass.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdgrass.py	2014-08-14 18:37:36 UTC (rev 61637)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdgrass.py	2014-08-14 19:10:24 UTC (rev 61638)
@@ -63,7 +63,8 @@
         # metadata object from OWSLIB ( for define md values)
         self.md = MD_Metadata(md=None)
         self.template = None  # path to file with xml templates
+        self.addonsPath=os.path.join(os.getenv('GRASS_ADDON_BASE'), 'etc', 'wx.metadata')
         if self.type == "cell":
             self.parseRast()
         elif self.type == "vector":
@@ -88,21 +89,21 @@
         # parse md from v.info flags=-g -e -t
         vinfo = Module(
-            'v.info',
-            self.map,
-            flags='get',
-            quiet=True,
-            stdout_=PIPE)
+                    'v.info',
+                    self.map,
+                    flags='get',
+                    quiet=True,
+                    stdout_=PIPE)
         self.md_grass = parse_key_val(vinfo.outputs.stdout)
         # parse md from v.info flag=h (history of map in grass)
         rinfo_h = Module(
-            'v.info',
-            self.map,
-            flags='h',
-            quiet=True,
-            stdout_=PIPE)
+                    'v.info',
+                    self.map,
+                    flags='h',
+                    quiet=True,
+                    stdout_=PIPE)
         md_h_grass = rinfo_h.outputs.stdout
         buf = StringIO.StringIO(md_h_grass)
@@ -130,8 +131,8 @@
     def parseRast(self):
         '''Read metadata from r.info
-        #self.md_grass       dictionary of metadata from v.info
-        #self.md_abstract    string created by merge information from 'description' and 'source'
+        @var self.md_grass       dictionary of metadata from v.info
+        @var self.md_abstract    string created by merge information from 'description' and 'source'
         rinfo = Module('r.info',
                        self.map,
@@ -168,7 +169,8 @@
         n = '$NULL'
         # jinja templates
         if template is None:
-            parentDir=os.path.abspath(os.path.join(self.dirpath, os.path.pardir))
+            parentDir=os.path.abspath(os.path.join(self.addonsPath, os.path.pardir))
             self.template = os.path.join(parentDir,'templates', 'basicTemplate.xml')
         else:
             self.template = template
@@ -263,7 +265,6 @@
     def createGrassInspireISO(self, template=None):
         '''Create valid INSPIRE profile and fill it as much as possible by GRASS metadata. Missing values is $NULL
-        -create basic md profile and add INSPIRE mandatory attributes
         self.schema_type = '_inspire.xml'
@@ -272,7 +273,7 @@
         self.createGrassBasicISO()
             self.template = os.path.join(parentDir,'templates', 'inspireTemplate.xml')
         else:
