[GRASS-SVN] r61642 - grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso
svn_grass at osgeo.org
Thu Aug 14 13:48:10 PDT 2014
Author: martinl
Date: 2014-08-14 13:48:10 -0700 (Thu, 14 Aug 2014)
New Revision: 61642
grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso/v.info.iso.py
wx.metadata: v.info.iso - use get_lib_path()
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso/v.info.iso.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso/v.info.iso.py 2014-08-14 20:44:49 UTC (rev 61641)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso/v.info.iso.py 2014-08-14 20:48:10 UTC (rev 61642)
@@ -33,12 +33,21 @@
import os
import sys
-sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'wx.metadata'))
-from grass.script import parser
-from mdgrass import *
+from grass.script import parser, fatal
+from grass.pygrass.functions import get_lib_path
+def load_mdlib():
+ path = get_lib_path(modname='wx.metadata', libname='mdgrass')
+ if path is not None:
+ fatal("Not able to find the metadata library directory")
+ sys.path.append(path)
def main():
+ # load metadata library
+ load_mdlib()
+ from mdgrass import GrassMD
if not options['output']:
destination = None
name = None
