[GRASS-SVN] r61653 - in grass/trunk: raster/r.mapcalc/testsuite testsuite/raster
svn_grass at osgeo.org
Fri Aug 15 12:58:25 PDT 2014
Author: wenzeslaus
Date: 2014-08-15 12:58:25 -0700 (Fri, 15 Aug 2014)
New Revision: 61653
Added:
grass/trunk/raster/r.mapcalc/testsuite/const_map_test.sh
Removed:
grass/trunk/testsuite/raster/rmapcalc_test.sh
testing: move r.mapcalc test from root testsuite dir to r.mapcalc testsuite dir
Copied: grass/trunk/raster/r.mapcalc/testsuite/const_map_test.sh (from rev 61650, grass/trunk/testsuite/raster/rmapcalc_test.sh)
--- grass/trunk/raster/r.mapcalc/testsuite/const_map_test.sh (rev 0)
+++ grass/trunk/raster/r.mapcalc/testsuite/const_map_test.sh 2014-08-15 19:58:25 UTC (rev 61653)
@@ -0,0 +1,177 @@
+#!/bin/sh
+# Markus Neteler
+# Test cases for 2D raster data
+# Tests:
+# - generate 3x3 map, value 1/1.1
+# - calculate statistics
+# - compare with known results
+# TODO
+# - how big EPSILON?
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program."
+ exit 1
+fi
+#### check if we have awk
+if [ ! -x "`which awk`" ] ; then
+ echo "$PROG: awk required, please install first" 1>&2
+ exit 1
+fi
+# setting environment, so that awk works properly in all languages
+unset LC_ALL
+export LC_NUMERIC=C
+eval `g.gisenv`
+: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
+LOCATION=$GISDBASE/$LOCATION_NAME/$MAPSET
+# some definitions
+PIXEL=3
+# how big EPSILON?
+# epsilon for doubles in IEEE is 2.220446e-16
+EPSILON=22204460000000000
+PID=$$
+TMPNAME="`echo ${PID}_tmp_testmap | sed 's+\.+_+g'`"
+# some functions - keep order here
+cleanup()
+ echo "Removing temporary map"
+ g.remove rast=$TMPNAME > /dev/null
+# check if a MASK is already present:
+MASKTMP=mask.$TMPNAME
+USERMASK=usermask_${MASKTMP}
+if test -f $LOCATION/cell/MASK
+then
+ echo "A user raster mask (MASK) is present. Saving it..."
+ g.rename MASK,$USERMASK > /dev/null
+fi
+finalcleanup()
+ echo "Restoring user region"
+ g.region region=$TMPNAME
+ g.remove region=$TMPNAME > /dev/null
+ #restore user mask if present:
+ if test -f $LOCATION/cell/$USERMASK ; then
+ echo "Restoring user MASK"
+ g.remove rast=MASK > /dev/null
+ g.rename $USERMASK,MASK > /dev/null
+ fi
+check_exit_status()
+ if [ $1 -ne 0 ] ; then
+ echo "An error occurred."
+ cleanup ; finalcleanup
+ exit 1
+ fi
+########## test function goes here
+compare_result()
+ EXPECTED=$1
+ FOUND=$2
+ VALUENAME=$3
+ # test for NAN
+ if [ "$FOUND" = "nan" ] ; then
+ echo "ERROR. $VALUENAME: Expected=$EXPECTED | FOUND=$FOUND"
+ exit 1
+ fi
+ # check for difference + 1
+ DIFF=`echo $EXPECTED $FOUND $EPSILON | awk '{printf "%16f", ($1 - $2) * $3 }'`
+ #make absolute value
+ DIFF=`echo $DIFF | awk '{printf("%f", sqrt($1 * $1))}'`
+ #round to integer
+ DIFF=`echo $DIFF | awk '{printf("%20d", int($1+0.5))}'`
+ # check if difference > 0
+ if [ $DIFF -gt 0 ] ; then
+ exit 1
+ fi
+#check if a MASK is already present:
+then
+ check_exit_status $?
+fi
+echo "Saving current & setting test region."
+g.region save=$TMPNAME
+check_exit_status $?
+g.region s=0 n=$PIXEL w=0 e=$PIXEL res=1 tbres=1
+########### 2D raster INT tests ###########
+VALUE=1
+echo "INT/CELL test."
+r.mapcalc "$TMPNAME = 1"
+echo "Univariate statistics of INT/CELL test."
+eval `r.univar -g $TMPNAME`
+compare_result 9 $n n
+compare_result $VALUE $min min
+compare_result $VALUE $max max
+compare_result 0 $range range
+compare_result $VALUE $mean mean
+compare_result 0 $stddev stddev
+compare_result 0 $variance variance
+compare_result 0 $coeff_var coeff_var
+compare_result 9 $sum sum
+cleanup
+echo "INT/CELL univariate statistics test successful"
+echo "##################################"
+########### 2D raster FCELL tests ###########
+VALUE=1.1
+echo "FLOAT/FCELL test."
+r.mapcalc "$TMPNAME = $VALUE"
+echo "Univariate statistics of FLOAT/FCELL test."
+compare_result 9.9 $sum sum
+cleanup
+echo "FLOAT/FCELL univariate statistics test successful"
+# if we arrive here...
+finalcleanup
+echo "All tests successful. Congrats."
+exit 0
Deleted: grass/trunk/testsuite/raster/rmapcalc_test.sh
--- grass/trunk/testsuite/raster/rmapcalc_test.sh 2014-08-15 19:55:26 UTC (rev 61652)
+++ grass/trunk/testsuite/raster/rmapcalc_test.sh 2014-08-15 19:58:25 UTC (rev 61653)
@@ -1,177 +0,0 @@
-#!/bin/sh
-# Markus Neteler
-# Test cases for 2D raster data
-# Tests:
-# - generate 3x3 map, value 1/1.1
-# - calculate statistics
-# - compare with known results
-# TODO
-# - how big EPSILON?
-if [ -z "$GISBASE" ] ; then
- echo "You must be in GRASS GIS to run this program."
- exit 1
-fi
-#### check if we have awk
-if [ ! -x "`which awk`" ] ; then
- echo "$PROG: awk required, please install first" 1>&2
- exit 1
-fi
-# setting environment, so that awk works properly in all languages
-unset LC_ALL
-export LC_NUMERIC=C
-eval `g.gisenv`
-: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
-LOCATION=$GISDBASE/$LOCATION_NAME/$MAPSET
-# some definitions
-PIXEL=3
-# how big EPSILON?
-# epsilon for doubles in IEEE is 2.220446e-16
-EPSILON=22204460000000000
-PID=$$
-TMPNAME="`echo ${PID}_tmp_testmap | sed 's+\.+_+g'`"
-# some functions - keep order here
-cleanup()
- echo "Removing temporary map"
- g.remove rast=$TMPNAME > /dev/null
-# check if a MASK is already present:
-MASKTMP=mask.$TMPNAME
-USERMASK=usermask_${MASKTMP}
-if test -f $LOCATION/cell/MASK
-then
- echo "A user raster mask (MASK) is present. Saving it..."
- g.rename MASK,$USERMASK > /dev/null
-fi
-finalcleanup()
- echo "Restoring user region"
- g.region region=$TMPNAME
- g.remove region=$TMPNAME > /dev/null
- #restore user mask if present:
- if test -f $LOCATION/cell/$USERMASK ; then
- echo "Restoring user MASK"
- g.remove rast=MASK > /dev/null
- g.rename $USERMASK,MASK > /dev/null
- fi
-check_exit_status()
- if [ $1 -ne 0 ] ; then
- echo "An error occurred."
- cleanup ; finalcleanup
- exit 1
- fi
-########## test function goes here
-compare_result()
- EXPECTED=$1
- FOUND=$2
- VALUENAME=$3
- # test for NAN
- if [ "$FOUND" = "nan" ] ; then
- echo "ERROR. $VALUENAME: Expected=$EXPECTED | FOUND=$FOUND"
- exit 1
- fi
- # check for difference + 1
- DIFF=`echo $EXPECTED $FOUND $EPSILON | awk '{printf "%16f", ($1 - $2) * $3 }'`
- #make absolute value
- DIFF=`echo $DIFF | awk '{printf("%f", sqrt($1 * $1))}'`
- #round to integer
- DIFF=`echo $DIFF | awk '{printf("%20d", int($1+0.5))}'`
- # check if difference > 0
- if [ $DIFF -gt 0 ] ; then
- exit 1
- fi
-#check if a MASK is already present:
-then
- check_exit_status $?
-fi
-echo "Saving current & setting test region."
-g.region save=$TMPNAME
-check_exit_status $?
-g.region s=0 n=$PIXEL w=0 e=$PIXEL res=1 tbres=1
-########### 2D raster INT tests ###########
-VALUE=1
-echo "INT/CELL test."
-r.mapcalc "$TMPNAME = 1"
-echo "Univariate statistics of INT/CELL test."
-eval `r.univar -g $TMPNAME`
-compare_result 9 $n n
-compare_result $VALUE $min min
-compare_result $VALUE $max max
-compare_result 0 $range range
-compare_result $VALUE $mean mean
-compare_result 0 $stddev stddev
-compare_result 0 $variance variance
-compare_result 0 $coeff_var coeff_var
-compare_result 9 $sum sum
-cleanup
-echo "INT/CELL univariate statistics test successful"
-echo "##################################"
-########### 2D raster FCELL tests ###########
-VALUE=1.1
-echo "FLOAT/FCELL test."
-r.mapcalc "$TMPNAME = $VALUE"
-echo "Univariate statistics of FLOAT/FCELL test."
-compare_result 9.9 $sum sum
-cleanup
-echo "FLOAT/FCELL univariate statistics test successful"
-# if we arrive here...
-finalcleanup
-echo "All tests successful. Congrats."
-exit 0
