[GRASS-SVN] r61662 - grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata
svn_grass at osgeo.org
Sat Aug 16 03:15:58 PDT 2014
Author: krejcmat
Date: 2014-08-16 03:15:58 -0700 (Sat, 16 Aug 2014)
New Revision: 61662
grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.html
fix syntax
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.html
--- grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.html 2014-08-16 06:32:28 UTC (rev 61661)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.html 2014-08-16 10:15:58 UTC (rev 61662)
@@ -30,7 +30,7 @@
items stored in GRASS native metadata format and INSPIRE profile. The
intersect (subset) includes all available GRASS metadata. Metadata
which cannot be assigned to ISO based attributes are stored in
-metadata attribute <em>abstract</em>. The <i>inspire</i> profile
+metadata attribute s<em>abstract</em>. The <i>inspire</i> profile
fulfills the criteria of INSPIRE profile. Values which are not able to
get from native GRASS metadata are filled by text
string <tt>'$NULL'</tt>. This rule applies for both profiles.
@@ -42,12 +42,13 @@
<h4>Metadata map editor </h4>
-The product of this editor mode is similar to product of r|v.info.iso. After selection of map, the editor convert native metadata of map to ISO based. By exported xml file is metadata editor initialized.
-<li> basic
-<li> inspire
-<li> load custom - this option allows to load metadata profile from file. For example in case of using predefined template. The intersection of GRASS Basic profile(all available metadata for selected map) and loaded custom profile will proced with this selection.
+The basis of this editor mode is similar to r|v.info.iso. After selection of map, the editor convert native metadata of map to ISO based. By exported xml file is metadata editor initialized.
+There are three options to select:
+<b>basic</b>,
+<b>inspire</b> or <b>load custom</b>. Last one allows to load metadata profile from file. For example in case of using predefined template. The intersection of GRASS Basic profile(all available metadata for selected map) and loaded custom profile will proced with this selection.
<h4> External metadata editor</h4>
This editor mode allows to load own template and xml file for editing. This option does not support any connection with GRASS maps metadata.
