[GRASS-SVN] r61709 - grass/trunk/vector/v.generalize
svn_grass at osgeo.org
Thu Aug 21 06:47:07 PDT 2014
Author: neteler
Date: 2014-08-21 06:47:07 -0700 (Thu, 21 Aug 2014)
New Revision: 61709
grass/trunk/vector/v.generalize/v.generalize.html
v.generalize manual: examples added
Modified: grass/trunk/vector/v.generalize/v.generalize.html
--- grass/trunk/vector/v.generalize/v.generalize.html 2014-08-20 20:55:14 UTC (rev 61708)
+++ grass/trunk/vector/v.generalize/v.generalize.html 2014-08-21 13:47:07 UTC (rev 61709)
@@ -95,6 +95,7 @@
</pre></div>
is that 'out' contains approximately only 30% of points of 'in'.
<h3>SMOOTHING</h3>
The following smoothing algorithms are implemented in <em>v.generalize</em>:
@@ -213,7 +214,6 @@
The lines affected by the algorithm can be specified by the <b>layer</b>,
<b>cats</b> and <b>where</b> parameters.
-<!-- TODO: example(s) -->
<h3>NETWORK GENERALIZATION</h3>
@@ -253,22 +253,68 @@
<p>Also, the outputed network may not be connected if the value of
<b>betweeness_thresh</b> is too large.
+<h2>EXAMPLES</h2>
+<h3>Simplification</h3>
+Simplification of county boundaries with DP method (North Carolina sample dataset):
+<div class="code"><pre>
+v.generalize input=boundary_county output=boundary_county_dp20 \
+ method=douglas threshold=20 error=boundary_county_dp20_leftover
+</pre></div>
+<h3>Smoothing</h3>
+Smoothing of road network with Chaiken method (North Carolina sample dataset):
+v.generalize input=roads output=roads_chaiken method=chaiken \
+ threshold=1 error=roads_chaiken_leftover
+</pre></div>
+<!-- TODO:
+<h3>Displacement</h3>
+Displacement of ... (North Carolina sample dataset):
+v.generalize input=xxx output=xxx_yyy method=... \
+ ... error=xxx_eeee
+</pre></div>
+<h3>Network generalization</h3>
+Network generalization of ... (North Carolina sample dataset):
+</pre></div>
+<!-- TODO:
+<h2>REFERENCES</h2>
+<ul>
+<li>...</li>
+</ul>
<h2>SEE ALSO</h2>
<em>
<a href="v.clean.html">v.clean</a>,
<a href="v.dissolve.html">v.dissolve</a>
</em>
-<br><br>
-<a href="http://grasswiki.osgeo.org/wiki/V.generalize_tutorial">v.generalize Tutorial</a> (from GRASS-Wiki)
+<p>
+<a href="http://grasswiki.osgeo.org/wiki/V.generalize_tutorial">v.generalize Tutorial</a> (GRASS-Wiki)
<h2>AUTHORS</h2>
Daniel Bundala, Google Summer of Code 2007, Student<br>
-Wolf Bergenheim, Mentor
+Wolf Bergenheim, Mentor<br>
+Fixes: Markus Metz
-<!-- TODO: references -->
<p><i>Last changed: $Date$</i>
