[GRASS-SVN] r61718 - grass/trunk/gui/wxpython/rlisetup
svn_grass at osgeo.org
Sat Aug 23 09:37:54 PDT 2014
Author: neteler
Date: 2014-08-23 09:37:54 -0700 (Sat, 23 Aug 2014)
New Revision: 61718
Added:
grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_1.png
grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_2.png
grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_3.png
grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_4.png
grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_5.png
grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_6.png
grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_7.png
grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_8.png
grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_sampleAreas.jpg
grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html
g.gui.rlisetup manual: screenshots and explanations added (yet incomplete)
Modified: grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html
--- grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html 2014-08-23 11:20:56 UTC (rev 61717)
+++ grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.html 2014-08-23 16:37:54 UTC (rev 61718)
@@ -5,20 +5,236 @@
The <b>g.gui.rlisetup</b> is a <em><a href="wxGUI.html">wxGUI</a></em>
component which allows the user to create a configuration file
for the analytical <em>r.li</em> modules. For a general introduction, see
-<a href="r.li.html">r.li</a>.
+the <a href="r.li.html">r.li</a> overview.
<br>
The configurations are raster map independent, it means that you can use
-a file created on a raster map for analyze any other you have. <br>
+a file created on a raster map for analyze any other you have.
+<br>
The program is completely interactive and uses a GUI to help you
in your choices.
+<h3>Analysis methods</h3>
+Definition of creation of sampling area:
+<ul>
+ <li> Whole map layer: use entire area selected above,</li>
+ <li> Regions: select one to many subareas via mouse,</li>
+ <li> Sample units: automated selection of sampling area (for details see below)
+ <ul>
+ <li> Random nonoverlapping,</li>
+ <li> Systematic contiguous,</li>
+ <li> Systematic noncontiguous,</li>
+ <li> Stratified random,</li>
+ <li> Centered over sites (vector points).</li>
+ </ul>
+ </li>
+ <li> Moving window: rectangular or circular with size</li>
+<!-- only in GRASS GIS 6 version
+ <li> Select areas from the overlaid vector map (for details see below)</li>
+</ul>
+<img src="g_gui_rlisetup_sampleAreas.jpg" alt="Sampling area definitions">
+Definition of region for analysis:
+<ul>
+ <li> Whole map layer: entire map (current region),</li>
+ <li> Keyboard setting: based on keyboard selection for region definition,</li>
+ <li> Draw the sampling frame: based on interactive region selection via mouse.</li>
+</ul>
+<h3>Usage details</h3>
+The startup window shows your configuration files, you can:
<p>
-TODO: merge in material from GRASS GIS 6 (raster/r.li/r.li.setup/r.li.setup.html)
+<font color="red"><b>TODO: description below needs further updates</b></font>
+<p>
+<ol>
+ <li><em><b>View/Edit</b></em> (Load a file) from the shown list: the
+ configuration is shown in a small text editor window.
+ <!-- only in GRASS GIS 6 version
+ is printed using rectangles with differents colors (green for the
+ raster map, red for the sample frame and blue for the sample areas),
+ and other notes (disposition of sample areas etc).
+ Configuration files are saved in the folder
+ <tt>C:\Users\userxy\.r.li\history\my_conf</tt> (MS-Windows) or
+ <tt>$HOME/.r.li/history/my_conf</tt> (GNU/Linux) (the file name can be
+ defined by the user). The output or an analysis can either be a new raster
+ map (in case of using a "moving window" analysis) or be an ASCII text file
+ (when not performing a "moving window" analysis) containing the result.
+ Such text file will be saved in the folder
+ <tt>C:\Users\userxy\AppData\Roaming\GRASS7\r.li\output\</tt>
+ (MS-Windows) or <tt>$HOME/.grass7/r.li/output/</tt> (GNU/Linux).
+ <br>
+ <!-- TODO: applies to all output or only ASCII output?? -->
+ All dimensions are percentages of raster rows or columns.</li>
+ <li><em><b>Create</b></em> a new configuration file: used for creating
+ a new configuration file in an interactive way, in three steps:
+ <ol>
+ <li> Choose file name and maps to use for setting:
+ <ul>
+ <li> <em>Name for new configuration file</em>(required): the name
+ of new configuration file</li>
+ <li> <em>Raster map name to use to select areas</em> (required):
+ the name of raster map used for selecting sampling areas</li>
+ <li> <em>Vector map to overlay</em> (optional): name of a
+ vector map used for selecting sampling areas</li>
+ </ul>
+ </li>
+ <li> Set the sampling frame. The sample frame is a rectangular area
+ which contains all the areas to analyze. It can be defined in three
+ ways:
+ <ul>
+ <li><em>Whole map layer</em>: the sample frame is the whole map</li>
+ <li><em>Keyboard setting</em>: the user enters the coordinates in
+ cells of upper left corner of sampling frame and its length in
+ rows and columns.</li>
+ <li><em>Draw the sample frame</em>: the user draws the sample frame
+ on map using mouse.</li>
+ </ul>
+ </li>
+ <li> Set the sample areas. The sample areas are simply the areas to
+ analyze. They can be defined in five ways (see the picture below):
+ <ul>
+ <li><em>Whole map layer</em>: the sample area is the whole sample
+ frame</li>
+ <li><em>Regions</em>: the user enters the number of areas and then
+ draws them using mouse.</li>
+ <li><em>Sample units</em>: they are areas of rectangular or circular
+ shape. The user can define them using keyboard or mouse.
+ <ul>
+ <li>keyboard: the user define the shape of sample unists and
+ their disposition:
+ <ul>
+ <li><em>Random non overlapping</em>: the user specifies
+ the number of sample units and they are placed in a
+ random way at runtime. It is guaranteed that the
+ areas do not intersect themselves.</li>
+ <li><em>Systematic contiguous</em>: the defined sample
+ is placed covering the sample frame, side by side
+ across rows.</li>
+ <li><em>Systematic non contiguous</em>: the same as above,
+ but here ever rectangle is spaced from another by
+ a specified number of cells.</li>
+ <li><em>Stratified random</em>: the sample frame is
+ divided in <i>n</i> strats of rows and <i>m</i> strats of columns
+ (<i>n</i> and <i>m</i> are given by user), then the specified
+ number of sample areas are placed in a random way,
+ one for every <i>m*n</i> areas defined by strats.</li>
+ <li><em>Centered over sites</em>: the sample areas
+ are placed into sample frame centering them on points
+ in site file.</li>
+ </ul>
+ </li>
+ <li>mouse: the user chooses the shape and then draws the
+ specified number of sample areas on map.</li>
+ </ul>
+ </li>
+ <li><em>Moving Window:</em> the user defines a rectangular or
+ circular area, it is moved over all the raster increasing only
+ of a cell for every move(in columns if possible, if not in rows).
+ It produces a new raster containing the result of all analysis.</li>
+ <li><em>Select areas from the overlaid vector map</em>:
+ the sample areas are defined by the vector map selected above.
+ For every cat in vector map, the procedure prompts the
+ user if he wants to include it as sample area.
+ The resulting configuration file can be used only with the
+ specified raster map, and the procedure can be used only if
+ whole map layer is selected as sampling frame.</li>
+ </ul>
+ </li>
+ </ol>
+ <li><em><b>Remove a file</b></em> the selected file is deleted from the
+ available configuration files.</li>
+ <li><em><b>Help</b></em>: open this help text.</li>
+ <li><em><b>Close</b></em> module window.</li>
+</ol>
<h2>NOTES</h2>
Configuration files are raster map independent because areas are saved using
relative coordinates.
+<p>
+Screenshots of the wizard window frames:
+<center>
+ <table border=1>
+ <tr>
+ <td align=center>
+ <img src="g_gui_rlisetup_1.png" alt="g.gui.rlisetup: First frame of wizard for selecting existing configuration files or creating a new one">
+ <br>
+ <font size="-1">
+ <i>g.gui.rlisetup: First frame of wizard for selecting <br>
+ existing configuration files or creating a new one</i>
+ </font>
+ </td>
+ <td align=center>
+ <img src="g_gui_rlisetup_2.png" alt="g.gui.rlisetup: Frame for selecting maps">
+ <br>
+ <font size="-1">
+ <i>g.gui.rlisetup: Frame for selecting maps</i>
+ </font>
+ </td>
+ </tr>
+ <tr>
+ <td align=center>
+ <img src="g_gui_rlisetup_3.png" alt="g.gui.rlisetup: Frame for inserting sampling areas">
+ <br>
+ <font size="-1">
+ <i>g.gui.rlisetup: Frame for inserting sampling areas</i>
+ </font>
+ </td>
+ <td align=center>
+ <img src="g_gui_rlisetup_4.png" alt="g.gui.rlisetup: Frame for defining rectangular moving window">
+ <br>
+ <font size="-1">
+ <i>g.gui.rlisetup: Frame for defining rectangular moving window</i>
+ </font>
+ </td>
+ </tr>
+ <tr>
+ <td align=center>
+ <img src="g_gui_rlisetup_5.png" alt="g.gui.rlisetup: Frame for defining circular moving window">
+ <br>
+ <font size="-1">
+ <i>g.gui.rlisetup: Frame for defining circular moving window</i>
+ </font>
+ </td>
+ <td align=center>
+ <img src="g_gui_rlisetup_6.png" alt="g.gui.rlisetup: Frame for choosing the sampling frame with keyboard">
+ <br>
+ <font size="-1">
+ <i>g.gui.rlisetup: Frame for choosing the sampling frame with keyboard</i>
+ </font>
+ </td>
+ </tr>
+ <tr>
+ <td align=center>
+ <img src="g_gui_rlisetup_7.png" alt="g.gui.rlisetup: Frame for drawing the sampling frame">
+ <br>
+ <font size="-1">
+ <i>g.gui.rlisetup: Frame for drawing the sampling frame</i>
+ </font>
+ </td>
+ <td align=center>
+ <img src="g_gui_rlisetup_8.png" alt="g.gui.rlisetup: Summary frame before saving">
+ <br>
+ <font size="-1">
+ <i>g.gui.rlisetup: Summary frame before saving</i>
+ </font>
+ </td>
+ </tr>
+ </table>
+</center>
<h2>EXAMPLES</h2>
<h3>Moving window analysis on full region</h3>
@@ -114,7 +330,7 @@
</em>
<p>
<em>
-<a href="http://grass.osgeo.org/gdp/landscape/r_le_manual5.pdf">Old r.le suite manual</a>
+<a href="http://grass.osgeo.org/gdp/landscape/r_le_manual5.pdf">Old r.le suite manual</a> (1992)
</em>
<p>
<em>
Added: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_1.png
(Binary files differ)
Property changes on: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_1.png
___________________________________________________________________
Added: svn:mime-type
+ image/png
Added: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_2.png
Property changes on: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_2.png
+ image/png
Added: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_3.png
Property changes on: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_3.png
+ image/png
Added: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_4.png
Property changes on: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_4.png
+ image/png
Added: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_5.png
Property changes on: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_5.png
+ image/png
Added: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_6.png
Property changes on: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_6.png
+ image/png
Added: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_7.png
Property changes on: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_7.png
+ image/png
Added: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_8.png
Property changes on: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_8.png
+ image/png
Copied: grass/trunk/gui/wxpython/rlisetup/g_gui_rlisetup_sampleAreas.jpg (from rev 61717, grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/sampleAreas.jpg)
