[GRASS-SVN] r61737 - grass-addons
    svn_grass at osgeo.org
    Mon Aug 25 13:19:26 PDT 2014
Author: neteler
Date: 2014-08-25 13:19:26 -0700 (Mon, 25 Aug 2014)
New Revision: 61737
Removed:
   grass-addons/SUBMITTING_DOCS
   grass-addons/SUBMITTING_PYTHON
   grass-addons/SUBMITTING_SCRIPTS
   grass-addons/SUBMITTING_TCLTK
Addons SUBMITTING: moved to trac (trac #2104)
Modified: grass-addons/SUBMITTING
--- grass-addons/SUBMITTING	2014-08-25 20:14:28 UTC (rev 61736)
+++ grass-addons/SUBMITTING	2014-08-25 20:19:26 UTC (rev 61737)
@@ -1,444 +1 @@
-$Date: 2008-02-14 12:26:15 +0100 (Thu, 14 Feb 2008) $
-NOTE: Please improve this list!
-Dear (new) GRASS Developer,
-When submitting C code to GRASS SVN repository, please take care of
-following rules:
-[ see SUBMITTING_SCRIPTS for shell script hints ]
-[ see SUBMITTING_TCLTK for tcl and tk hints ]
-[ see SUBMITTING_DOCS for documentation ]
-[ see SUBMITTING_PYTHON for Python code hints ]
-1.  Get and read the GRASS 6 Programmer's Manual here:
-    http://download.osgeo.org/grass/grass6_progman/
-    or generate it from this source code (the programmer's manual is
-    integrated in the source code in doxygen style):
-      make htmldocs
-      make pdfdocs
-2.  Use the directory structure to place your module appropriately into
-    the source tree
-    	- libes go into lib/
-    	- raster goes into raster/
-    	- vector goes into vector/
-    Consider to take a look at "GNU Coding Standards"
-    http://www.gnu.org/prep/standards.html
-    In future, there will be a centralized contribution directory.
-3.  Add a header section to each file you submit and make sure you include
-    the copyright. The purpose section is meant to contain a general
-    overview of the code in the file to assist other programmers that will
-    need to make changes to your code.
-    Example (ficticious header for a file called color.c) :
- * MODULE:       d.rast (or new higher level module name (eg GRASS core)
- *               for 6.1)
- * AUTHOR(S):    Original author unknown - probably CERL
- *               John Doe - jdoe at some.where.org
- * PURPOSE:      To provide storage and manipulation of colors used for
- *               rendering the raster. The colors are stored in a doubly linked
- *               list which must be initialized with InitColors() before it can
- *               be used. Note that most linked list functionality (add,
- *               remove, get) is supported, but their is no sorting
- *               functionality.
- * COPYRIGHT:    (C) 2005 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *               License (>=v2). Read the file COPYING that comes with GRASS
- *               for details.
-    The copyright protects your rights according to GNU General Public
-    License (www.gnu.org).
-4.  - deleted.
-    We don't want the $ ID $ in source code any more as it causes problems
-    for the SVN branches.
-5.  To ensure that the software system continues to work, please include
-	#include <grass/config.h>
-    in your files and make use of the various system dependencies
-    contained therein.  As one example of this, see lib/gmath/fft.c.
-    Please refrain from declaring system functions within the
-    software; include the proper header files (conditionally dependent
-    on config.h macros if necessary) instead.
-6. Order of include headers
-    In general, headers should be included in the order:
-    1. Core system headers (stdio.h, ctype.h, ...)
-    2. Headers for non-core system components (X11, libraries).
-    3. Headers for core systems of the package being compiled (grass/gis.h, grass/glocale.h, ...)
-    4. Headers for the specific library/program being compiled (geodesic.h, ...)
-    Each class of header has an obligation to be compatible with those
-    above it in the list, but not those below it.
-7.  Always specify the return type for ALL functions including those that
-    return type "void", and insert return statements for ALL functions.
-    Also, use ANSI C prototypes to declare your functions.
-    For module return values, see "Exit status" below.
-    Examples:
-    void G_something(void);
-    int G_something_else(int, int);
-    	/* Snipped out code */
-	return;
-    int G_something_else(int x, int y)
-	return(0);
-8.  Module exit status is defined as EXIT_SUCCESS or EXIT_FAILURE, e.g.
-      if (G_parser (argc, argv))
-          exit (EXIT_FAILURE);
-      exit (EXIT_SUCCESS);
-9.  Use fprintf instead of printf. But:
-    For errors and warnings please use the G_fatal_error() and
-    G_warning() functions. General messages for the user should use
-    G_message() while debug messages should use G_debug() whenever
-    possible. There are two variants to G_message(): G_verbose_message()
-    which will only display the message if in verbose mode, and
-    G_important_message() which will always show the message unless
-    the module is running in --quiet mode. G_fatal_error() and
-    G_warning() will always be displayed regardless of verbosity setting.
-    Messages sent to any of these functions will be printed to stderr.
-    G_message() output is not expected to be sent to pipe or file.
-    Always use the gettext macros with _("") for user messages,
-    example:
-      G_fatal_error (_("Vector map <%s> not found"), name);
-    Pipe/file data output:
-    For data output redirected to pipe or file, please use fprintf() and
-    specify the stdout stream as follows:
-      fprintf(stdout, ...);
-      fflush(stdout);
-      fflush(stdout) always required when using fprintf(stdout, ...).
-10. Use the GRASS library function G_asprintf() instead of the
-    standard C functions asprintf(), vsnprintf() and snprintf(). These
-    functions are not portable or have other issues.  Example:
-    char *msg;
-    G_asprintf(&msg, "%s", parameters);
-    do_something_with_msg();
-    G_free(msg);
-    Note that you should free memory when G_asprintf() is used.
-11. Use the following GRASS library functions instead of the standard C
-    functions. The reason for this is that the following functions ensure
-    good programming practice (e.g. always checking if memory was allocated)
-    and/or improves portability. PLEASE refer to the programmers manual
-    for the proper use (e.g. determining if any casts are needed for arguments
-    or return values) of these library functions. They may perform a task
-    slightly different from their corresponding C library function, and thus,
-    their use may not be the same.
-    	G_malloc() instead of malloc()
-	G_calloc() instead of calloc()
-	G_realloc() instead of realloc()
-	G_free() instead of free()
-	G_getenv() instead of getenv()
-	G_setenv() instead of setenv()
-	G_unsetenv() instead of unsetenv()
-	G_sleep() instead of sleep()
-	Could somebody please add others (please verify that they are
-	useful and safe first)
-12. Use function names which fulfil the official GNU naming convention.
-    http://www.gnu.org/prep/standards/html_node/Names.html#Names
-    Instead of naming a function like: MyNewFunction() use underscores
-    for seperation and lower case letters: my_new_function().
-13. Don't use the C++ comment style! This confuses several compilers.
-    Use instead:
-       /* C-comments */
-    If you want to comment code portions, use
-       #ifdef notdef
-            portion_to_be_commented;
-       #endif
-    This is safe comparing to nested /* comments */
-    Functions in the library must be documented in doxygen style to
-    get them into the programmer's manual (generate with
-      make pdfdocs  or
-      make htmldocs
-    ). See lib/gis/*.c for examples.
-14. PLEASE take the time to add comments throughout your code explaining what
-    the code is doing. It will save a HUGE amount of time and frustration for
-    other programmers that may have to change your code in the future.
-15. To promote a consistent coding style, please use the "indent" program
-    on all new C modules using the following switches:
-     $ indent -nbad -bap -bbb -nbbo -nbc -br -bli1 -bls -cbi0 -ncdb -nce \
-        -ci4 -cli0 -ncs -d0 -di0 -fc1 -nfca -hnl -i4 -ip4 -l80 -lc80 -lp \
-	-npcs -pi4 -nprs -npsl -sbi0 -sc -nsob -ss -ts8  main.c
-    Existing code should not be re-indented except in extreme cases, as this
-    will make "diff" comparisons with older versions impossible. If indent is
-    needed, do not check in any changes other than the indentation in the same
-    commit! Do add the indent switches and any indent warning messages to the
-    SVN log. Any change or fix mixed in with an indent is very hard to track
-    making it hard for others to follow the change or fix any new bugs.
-16. Platform dependent code:
-    Do not remove #ifdef __CYGWIN__ and/or #ifndef __CYGWIN__ lines and
-    their encapsulated lines from source code (one example was that someone
-    removed drand48 definition.)
-17. Suggested compiler flags:
-    We suggest to use very strict compiler flags to capture errors
-    at the very beginning. Here our list of flags, please use them
-    to configure you development version of GRASS:
-    GNU/Linux:
-       MYCFLAGS="-g -Wall -Werror-implicit-function-declaration -fno-common"
-       MYCXXFLAGS="-g -Wall"
-       CFLAGS="$MYCFLAGS" CXXFLAGS="$MYCXXFLAGS" ./configure ...
-    MacOSX:     [to be suggested]
-    MS-Windows: [to be suggested]
-18. Make sure a new line is at the end of each file.
-19. When writing Makefiles, use the current standard.
-    If you have to use commands, please check for:
-            avoid     | use instead
-    make target       | $(MAKE) target
-    mkdir target      | $(MKDIR) target
-    cp  (executable)  | $(INSTALL) -m 755 file target
-    cp  (normal file) | $(INSTALL) -m 644 file target
-    ar                | $(AR)
-    rm: be VERY careful with recursive remove.
-    Examples: see below examples or others
-              raster/r.info/Makefile
-              vector/v.digit/Makefile
-    If you are unsure, please ask on the GRASS Developers list.
-20. Have a look at ./INSTALL
-21. Have a function included in your module which writes to the history
-    file of the map (e.g. command line, parameters etc.). See e.g.
-    raster/r.patch/main.c
-    (the same applies to vector and g3d modules!)
-22. Standard parser options: use G_define_standard_option() whenever possible
-    to define standard module command line options. This will save you time,
-    create fewer bugs, and make things easier on the translators.
-    See lib/gis/parser.c for details of the function definition.
-23. Add/update, if required the related GUI menus:
-     gui/tcltk/gis.m/gmmenu.tcl
-24. For consistency, use README rather than README.txt for any README files.
-25. GRASS/Environment variables:
-    If you add a new variable, please follow the naming convention.
-    All variables are described in
-    lib/init/variables.html
-26. Be sure to develop on top of the LATEST GRASS code (which is in SVN repository).
-    You can re-check before submission with 'svn diff':
-    Be sure to create unified ("diff -u") format. "Plain" diffs (the default
-    format) are risky, because they will apply without warning to code which
-    has been substantially changed; they are also harder to read than unified.
-    Such diffs should be made from the top-level directory, e.g.
-    "svn diff display/d.vect/main.c"; that way, the diff will
-    include the pathname rather than just "main.c".
-27. Try to use module names which describe shortly the intended purpose of the module.
-    The first letters for module name should be:
-	d. 	- display commands
-	db. 	- database commands
-	g. 	- general GIS management commands
-	i. 	- imagery commands
-	m.	- miscellaneous tool commands
-	ps. 	- postscript commands
-	r. 	- raster commands
-	r3. 	- raster3D commands
-	v. 	- vector commands
-    Some additional naming conventions
-    * export modules:     (type).out.(format) eg: r.out.arc,  v.out.ascii
-    * import module:      (type).in.(format)  eg: r.in.arc, v.in.ascii
-    * conversion modules: (type).to.(type)    eg: r.to.vect, v.to.rast, r3.to.rast
-    Avoid module names with more than two dots in the name.
-    Example:
-       instead of r.to.rast3.elev use r.to.rast3elev
-28. Use the grass test suite to test your modules.
-    http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite
-    You can easily write specific tests for your modules.
-    If your module is part of GRASS and you created some standard test
-    cases, please contact the developers to add your tests to the
-    default test suite.  This will automatize complex test scenarios
-    and assure to find bugs much faster, if changes were made to your
-    modules or to the grass library.
-    Consider to subscribe to the GRASS Quality Assessment System to
-    get immediate notification about the code quality:
-    http://lists.osgeo.org/mailman/listinfo/grass-qa
-29. When submitting new files to the repository set SVN properties,
-    usually for directory
-      svn:ignore : *.tmp.html
-      		   *OBJ*
-    or e.g. for C-file
-      svn:mime-type : text/x-csrc
-      svn:keywords : Author Date Id
-      svn:eol-style : native
-    See
-    http://svnbook.red-bean.com/en/1.4/svn.advanced.props.html
-30. Use doxygen style for source code documentation. It is required
-    for GRASS libraries, but also recommended for GRASS modules.
-    Do not use structural command inside documentation block since it
-    leads to some duplication of information (e.g. do not use \fn
-    command in comment blocks). The exception is \file command for
-    documenting a file, in this case structural command is required.
-    For files
-       \file snap.c
-       \brief Vector library - Clean vector map (snap lines)
-       (C) 2001-2008 by the GRASS Development Team
-       This program is free software under the
-       GNU General Public License (>=v2).
-       Read the file COPYING that comes with GRASS
-       for details.
-       \author Radim Blazek
-       \date 2001-2008
-    For functions
-       \brief Snap lines in vector map to existing vertex in threshold
-       For details see Vect_snap_lines_list()
-       \param[in] Map input vector map
-       \param[in] type type of lines to be snap
-       \param[in] thresh threshold value for snapping
-       \param[out] Err vector map where lines representing snap are written or NULL
-       \param[out] msgout file pointer where messages will be written or NULL
-       \return
-31. Tell the other developers about the new code using the following e-mail:
-    grass-dev at lists.osgeo.org
-    To subscribe to this mailing list, see
-    http://lists.osgeo.org/mailman/listinfo/grass-dev
-32. In case of questions feel free to contact the developers at the above
-    mailing list.
-    http://grass.osgeo.org/devel/index.php#submission
-[please add further hints if required]
+See http://trac.osgeo.org/grass/wiki/Submitting
Deleted: grass-addons/SUBMITTING_DOCS
--- grass-addons/SUBMITTING_DOCS	2014-08-25 20:14:28 UTC (rev 61736)
+++ grass-addons/SUBMITTING_DOCS	2014-08-25 20:19:26 UTC (rev 61737)
@@ -1,124 +0,0 @@
-$Date: 2009-03-20 04:42:27 -0800 (Fri, 20 Mar 2009) $
-Dear (new) GRASS GIS Developer,
-When submitting documentation to GRASS SVN repository, please take
-care of following rules:
-[ see SUBMITTING for C hints ]
-0. Introduction
-   There are two types of documentation
-   - Libraries programmers docs: we use doxygen and document the functions
-      directly in the source code. See lib/*/*.c and lib/*/*.dox for examples
-   - User manual: we write it in simple HTML, storing the manual in a
-      file "description.html" within the subdirectory of the module.
-      The file contains no header nor footer. The complete HTML file is
-      autogenerated during the compilation process (indeed, it is generated
-      in a virtual session directly after compilation of the module).
-      In this virtual session the module is called internally with
-      --html-description which generates the parameters/flags list in
-      HTML format, along with "description.html", HTML header and footer
-      the final HTML manual page is created and stored in the target
-      binaries directory. In a separate process the MAN format is
-      generated from the complete HTML files.
-1. Editing of HTML pages
-   To avoid insertion of too complicated HTML tags (see also below),
-   we strongly suggest to use a plain text editor rather than a
-   HTML editor for editing.
-2. Module manual page:
-   Place the documentation in HTML format into 'description.html'.
-   The easiest way to do this is to study an existing HTML page
-   (to get the page style, e.g. vector/v.to.db/v.to.db.html).
-   With a few exceptions, header and footer are NOT allowed.
-   You can add figures (PNG format); the figure name prefix should be the
-   module name. See raster/r.terraflow/r.terraflow.html for an example.
-   A number of major sections should be present in each help page.
-   * = Required
-   ! = Suggested
-   . = Optional
-   In recommended order
-   * <h2>DESCRIPTION</h2>
-   ! <h2>NOTE</H2>, <h2>NOTES</h2>
-   ! <h2>EXAMPLE</h2>, <h2>EXAMPLES</h2>
-   . <h2>TODO</h2>
-   . <h2>BUGS</h2>
-   . <h2>REFERENCE</h2>, <h2>REFERENCES</h2>
-   * <h2>SEE ALSO</h2>
-   * <h2>AUTHOR</h2>, <h2>AUTHORS</h2>
-   Note that the parameter information is auto-generated upon
-   compilation. This is done by running the module in a virtual session
-   after compilation (see the output of 'make'). To subsequently
-   verify the final HTML page, check the resulting HTML pages which
-   will be stored with the name of the module.
-   Examples (please add some) should be coded like this:
-   <div class="code"><pre>
-   v.to.db map=soils type=area option=area col=area_size unit=h
-   </pre></div>
-   The online WWW man pages is updated every Saturday (from SVN
-   repository).
-3. Usage of limited HTML tags
-   Since the MAN conversion of g.html2man is limited, please use
-   no other HTML tags than:
-   <a> <b> <blink> <body> <br> <code> <dd> <dl> <dt> <em>
-   <h2> <h3> <h4> <head> <header> <hr> <i> <img> <li> <ol> <p>
-   <pre> <sup> <table> <td> <th> <title> <tr> <ul>
-   Note that all tags has a closing tag except for <hr/>, <br/> and <p>.
-   Use lower case forms.
-   (The MAN converter is here: tools/g.html2man/)
-4. Suggested HTML markup protocol:
-   Module names (i.e., v.category) should be emphsized with <em>,
-   and boldface <b> for flags and parameter names. Shell commands,
-   names, values, etc. should use <tt>. Empahsized phrases should use
-   italics <i>. The SEE ALSO section of each page should also be
-   alphabetized.
-5. When submitting new files to the repository set SVN properties,
-   e.g. for HTML file
-       svn:mime-type : text/html
-   See
-   You can also simply use this script:
-   http://svn.osgeo.org/grass/grass-addons/tools/module_svn_propset.sh
-6. Compress PNG images with
-7. See also
-   http://grass.osgeo.org/wiki/Updating_GRASS_Documentation
-"Your attention to detail is appreciated."
Deleted: grass-addons/SUBMITTING_PYTHON
--- grass-addons/SUBMITTING_PYTHON	2014-08-25 20:14:28 UTC (rev 61736)
+++ grass-addons/SUBMITTING_PYTHON	2014-08-25 20:19:26 UTC (rev 61737)
@@ -1,109 +0,0 @@
-$Date: 2008-01-06 12:42:32 +0100 (Sun, 06 Jan 2008) $
-When submitting Python code to GRASS SVN repository, please take
-1.  Indentation
-    As Python determines nesting based upon indentation, it
-    isn't just a stylistic issue.
-    Please use 4-space indentation (GNU Emacs python-mode default).
-    See also "Python Style Guide" by Guido van Rossum
-    http://www.python.org/doc/essays/styleguide.html
-2.  Add a header section to the script you submit and make sure you
-    include the copyright. The purpose section is meant to contain a
-    general over view of the code in the file to assist other
-    programmers that will need to make changes to your code. For this
-    purpose use Python Docstring, see
-    http://epydoc.sourceforge.net/docstrings.html
-    Example (fictitious header for a script called r.myscript):
-MODULE:    r.myscript
-AUTHOR(S): Me <email AT some domain>
-PURPOSE:   Calculates univariate statistics from a GRASS raster map
-COPYRIGHT: (C) 2007 by the GRASS Development Team
-           This program is free software under the GNU General Public
-           License (>=v2). Read the file COPYING that comes with GRASS
-           for details.
-3.  - deleted.
-    for the branches.
-4. PLEASE take the time to add comments throughout your code explaining what
-5. Make sure a new line is at the end of each file.
-6. For consistency, use README rather than README.txt for any README files.
-7. Be sure to develop on top of the LATEST GRASS code (which is in SVN repository).
-   "svn diff gui/wxpython/wxgui.py"; that way, the diff will
-   include the pathname rather than just "wxgui.py".
-8. When submitting new files to the repository set SVN properties,
-      svn:ignore : *.pyc
-   or e.g. for Python file
-      svn:mime-type : text/python
-   See
-8. Tell the other developers about the new code using the following e-mail:
-9. In case of questions feel free to contact the developers at the above
-   mailing list.
Deleted: grass-addons/SUBMITTING_SCRIPTS
--- grass-addons/SUBMITTING_SCRIPTS	2014-08-25 20:14:28 UTC (rev 61736)
+++ grass-addons/SUBMITTING_SCRIPTS	2014-08-25 20:19:26 UTC (rev 61737)
@@ -1,248 +0,0 @@
-When submitting SHELL scripts to GRASS SVN repositiory,
-please take care of following rules:
-[ see SUBMITTING for C code hints ]
-0.  Instructions for the GRASS script parser can be found in the g.parser
-    module's help page.
-    http://grass.osgeo.org/grass63/manuals/html63_user/g.parser.html
-1.  Use the directory structure to place your script appropriately into
-    the source tree
-          etc.
-    Consider to take a look at [please suggest Shell tutorial].
-    Also add a Makefile and a description.html file into this directory.
-    See existing scripts for examples.
-2.  Add a header section to the script you submit and make sure you include
-    Example (ficticious header for a script called r.myscript) :
-#!/bin/sh
-# MODULE:       r.myscript
-# AUTHOR(S):    Me <email AT some domain>
-# PURPOSE:      Calculates univariate statistics from a GRASS raster map
-# COPYRIGHT:    (C) 2005 by the GRASS Development Team
-#               This program is free software under the GNU General Public
-#               License (>=v2). Read the file COPYING that comes with GRASS
-#               for details.
-    You can easily autogenerate the header and parameters from an existing
-    module using the --script flag. Example:
-     d.rast --script
-    Just select an existing module which is close to your application to save
-    efforts.
-3.  - deleted.
-    We don't want the $ ID $ in scripts any more as it
-    causes problems for the SVN branches.
-4.  As a general principle, shell variables should almost always be quoted.
-    Use only secure temp files, see g.tempfile and scripts/* for examples.
-5.  [This rule is currently under review]  If you search for a command in $PATH, do NOT
-    use the "which" command or the "type -p" command. Both commands are not
-    supported on all platforms, thus causing problems for some people. As an
-    alternative, please use code similar to the following shell script snippet
-    which will perform the same function. In this case, the path of the grass60
-    command is saved if grass60 is found in $PATH. This won't recognize aliased
-    command name.
-	# Search for grass5 command in user's path
-	for i in `echo $PATH | sed 's/^:/.:/
-    	    	    		    s/::/:.:/g
-				    s/:$/:./
-				    s/:/ /g'`
-	do
-	    if [ -f $i/grass5 ] ; then
-		# Save the path of the grass60 command
-		GRASS_PATH=$i/grass60
-		# Use the first one in user's path
-		break
-	    fi
-	done
-    If you must use "which", use as follows:
-	# check if we have awk
-	if [ ! -x "`which awk`" ] ; then
-	    g.message -e "awk required, please install awk or gawk first"
-	    exit 1
-	fi
-6.  Add a test to check if the user is in GRASS before starting main part
-    of script. Result of running the script is unpredicable otherwise.
-	if [ -z "$GISBASE" ] ; then
-	    echo "You must be in GRASS GIS to run this program." 1>&2
-	    exit 1
-	fi
-    This is the only case, where g.message module (see below) can not be used.
-    In all other cases, you should prefer it's usage over the 'echo' command.
-7.  Create and use secure temporary files and directories. Use the g.tempfile
-    module to do this. e.g.
-	# setup temporary file
-	TMP="`g.tempfile pid=$$`"
-	if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
-	    g.message -e "unable to create temporary files"
-	    exit 1
-	fi
-    For temportary directories remove the newly created file and mkdir using
-    the same name. Beware of commands like "rm -f ${TMP}*" as this becomes
-    "rm -f *" if $TMP is unset (hence the test above).
-8.  Testing the existence of variables. For portability, use
-	if [ -z "$VARIABLE" ] ; then
-    instead of
-	if [ "$VARIABLE" = "" ] ; then
-    and
-	if [ -n "$VARIABLE" ] ; then
-    instead of
-	if [ "$VARIABLE" != "" ] ; then
-9.  Internationalization proofing Awk: In some areas (e.g. some European
-    countries) the decimal place is held with a comma instead of a dot.
-    When scanning variables awk doesn't understand this, so scripts need to
-    temporarily discard locale settings before calling awk.
-	# set environment so that awk works properly in all languages
-	unset LC_ALL
-	LC_NUMERIC=C
-        export LC_NUMERIC
-	awk '{print $1}'
-10. Use g.findfile when there is a need to test if a map exists.
-	# test for input raster map
-	g.findfile element=cell file="$INPUT" > /dev/null
-	if [ $? -eq 0 ] ; then
-	  g.message -e "Raster map <$GIS_OPT_MAP> not found in mapset search path"
-	  exit 1
-	fi
-	# test for input vector map
-	eval `g.findfile element=vector file=$GIS_OPT_MAP`
-	if [ ! "$file" ] ; then
-	   g.message -e "Vector map <$GIS_OPT_MAP> not found in mapset search path"
-	   exit 1
-	fi
-    ... and so forth. See 'g.manual g.findfile' for details.
-11. For any informational output, use the g.message modul. This module should
-    be also used for error messages and warnings. You can also use it for
-    debugging purposes.
-	#normal message:
-	g.message "Done"
-	# warning:
-        g.message -w "No input values found, using default values"
-	# error:
-        g.message -e "No map found, exiting."
-	# debug output (use g.gisenv to enable/disable)
-        g.message -d "Our calculated value is: $value"
-    Try to omit any usage of the 'echo' command for informational output.
-12. For consistency, use README rather than README.txt for any README files.
-13. Be sure to develop on top of the LATEST GRASS code (which is in SVN).
-    You can re-check before submission with 'cvs diff':
-    diffs (the default format) are risky, because they will apply without
-    warning to code which has been substantially changed; they are also
-    harder to read than unified.
-    "cvs diff display/d.vect/main.c"; that way, the diff will
-14. For portability, scripts must work on any POSIX compliant shell, and
-    therefore may not include any Bashisms. Test with ash for errors:
-	ash -n scriptname
-15. When submitting new files to the repository set SVN properties,
-    or e.g. for script file
-      svn:executable : *
-      svn:mime-type : text/x-sh
-    See
-16. Tell the other developers about the new code using the following e-mail:
-17. In case of questions feel free to contact the developers at the above
-    mailing list.
Deleted: grass-addons/SUBMITTING_TCLTK
--- grass-addons/SUBMITTING_TCLTK	2014-08-25 20:14:28 UTC (rev 61736)
+++ grass-addons/SUBMITTING_TCLTK	2014-08-25 20:19:26 UTC (rev 61737)
@@ -1,281 +0,0 @@
-When submitting TCL and TK SCRIPTS to GRASS SVN repository,
-1.  Use the directory structure to place your program appropriately into
-    the source tree
-        - general grass tcl/tk libraries and reusable code go into lib/gtcltk
-        - user interfaces go in gui/tcltk
-        - scripts go in scripts/
-            Programs here must have a proper Makefile and description.html
-    Example (fictitious header for a script called r.myscript) :
-#               for details.
-3.  PLEASE take the time to add comments throughout your code explaining what
-    other programmers that need to change or understand your code in the future.
-    Many of the programmers working on grass are not heavily invested in tcl
-    and tk, so extra documentation and explanation are greatly appreciated.
-4.  Test your program with both tcl/tk 8.3 and tcl/tk 8.4.
-5.  Always use the gettext macros with [G_msg "..."] for user messages.
-    The string must be quoted using quotation marks, not braces, for
-    xgettext to find it. The string cannot include variable ($) or
-    command ([...]) substitutions. If you need substitutions use
-    [format ...].
-    Examples:
-    button .ok -text [G_msg "Ok"]
-    set statusbartext [format [G_msg "Monitor %d running"] $monitor_number]]
-    Use positional parameters if substitutions might be rearranged in another language:
-    format [G_msg "We produced %1\$d units in location %2\$s"] $num $city
-    format [G_msg "In location %2\$s we produced %1\$d units"] $num $city
-6.  Use "GRASS_TCLSH" and "GRASS_WISH" environment variables instead of
-    "tclsh" and "wish" at the start of Tcl/Tk scripts. This allows users to
-    override the default names, so that developers don't need worry about the
-    shell names.
-    Tcl script:
-    	#!/bin/sh
-	# the next line restarts using tclsh. Note the backslash: \
-	exec $GRASS_TCLSH "$0" "$@"
-    Tk script:
-    	#!/bin/sh
-	# the next line restarts using wish. Note the backslash: \
-	exec $GRASS_WISH "$0" "$@"
-7.  Do not source files that have already been sourced.
-        gui.tcl sources:
-            options.tcl
-            select.tcl
-            gronsole.tcl
-    If your code requires something to be sourced before it note so
-    in a comment at the top of the file.
-8.  Set tabstops in your editor to 8 spaces.
-    When modifying files use the indentation style that is already present.
-    Please use consistent indentation style in your new code. Whether you use
-    tabs or spaces to indent please be consistent. Where tabs and spaces are
-    mixed please remember that a tab is 8 spaces.
-9.  Use the tk options database to control the appearance of your user interface.
-    In general do not set options on tk widgets unless that option is truly
-    specific to that widget. It makes them harder to customize.
-    Example: Don't set options like -foreground or -background or -font
-    when creating widgets, unless there's a really _really_ specific reason to
-    have it that color (like it's demonstrating that color).
-    If you want something like a label to look different than everything else
-    of that class (other labels) give it a distinctive name, like
-    .moduletitlelabel . If you have a bunch of them give them all the same
-    distinctive name. This allows them to have their options controlled by the
-    options database.
-    You can put your options at the start of your script (before creating any
-    widgets) like this:
-    option add *modultitlelabel.background red
-    More examples are in lib/gtcltk/options.tcl
-    Many common options, like font, background and foreground colors,
-    highlighting, scrollbar colors, and help bubble appearance are controlled
-    by options.tcl. You can include it at the start of your script with:
-    source $env(GISBASE)/etc/gtcltk/options.tcl
-10. Avoid using global variables. Thay are a frequent source of bugs, make code
-    harder to understand, and make your program difficult to reuse. Additionally,
-    putting code into procs usually makes it run faster (it gets compiled).
-11. For consistency, use README rather than README.txt for any README files.
-12. Use of GRASS commands in shell wrapper.
-    Any GRASS program run in an xterm (those which do interactive query) needs
-    to use grass-run.sh, e.g.:
-    exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e $env(GISBASE)/etc/grass-run.sh g.proj ...
-    You should probably also use "-T g.proj -n g.proj" to set the title
-    back (otherwise it will be "grass-run.sh", which isn't particularly
-    informative).
-    The xterm will close as soon as the command completes (whether it
-    succeeds or fails). You can use the -hold switch to retain the xterm
-    window after the command completes, but you should only do that for
-    debugging; having to manually close the xterm window each time would
-    be annoying in normal use. Alternatively, redirect stdout/stderr to a
-    file, to catch any error messages.
-    SVN repository). You can re-check before submission with 'svn
-    diff':
-14. Tell the other developers about the new code using the following e-mail:
-15. In case of questions feel free to contact the developers at the above
-    mailing list.
-16. Try to evaluate things only once. Tcl compiles the program to bytecode which
-    can be interpreted fairly quickly. If there are strings that must still be
-    evaluated tcl must parse and either compile or interpret them
-    each time they are encountered. In general this means put braces around
-    expressions and especially regular expressions (Tcl also compiles regular
-    expressions). Multiple evaluation can also lead to bugs.
-    Expressions via expr command:
-    Slow:
-        set y [expr $a * $x + $b]
-    Fast:
-        set y [expr {$a * $x + $b}]
-    Expressions in conditions:
-    Slow:
-        if [...] {...
-    Fast:
-        if {[...]} {...
-    Regular expressions:
-    Very slow:
-        regex "x(\[0-9\]+).*not" $string trash number
-    Fast:
-        regex {x([0-9]+).*not} $string trash number
-    If you really want speed:
-    If a regular expression needs to be constructed from variables but used
-    multiple times store it in a variable that will not be destroyed or
-    changed between reuse. Tcl stores the compiled regex with the variable.
-17. You might want to decompose lists in a somewhat easy way:
-    Difficult and slow:
-    # Make x1 y1 x2 y2 the first four things in the list
-    set list [commandMakesList]
-    set x1 [lindex $list 0]
-    set y1 [lindex $list 1]
-    set x2 [lindex $list 2]
-    set y2 [lindex $list 3]
-    Easier and faster:
-    foreach {x1 y1 x2 y2} [commandMakesList] {break}
-    Be sure to include a comment as to what you are doing.
-18. Use the Tcl list functions (list, lappend etc) for manipulating lists.
-    For example, use:
-        set vals [list $foo $bar]
-    rather than:
-        set vals "$foo $bar"
-    The former will always create a list with two elements, adding braces
-    if necessary, while the latter will split $foo and $bar into multiple
-    elements if they contain spaces. Additionally the first is faster
-    because tcl is not internally converting between strings and lists.
-    A related issue is to remember that command lines (as used by exec and
-    open "|...") are lists. exec behaves like execl(), spawnl() etc, and
-    not like system().
-    Overlooking either of these points is likely to result in code which
-    fails when a command argument contains a space.
-19. Tcl C library:
-    Memory allocated with Tcl_Alloc (such as the result of Tcl_Merge)
-    must be freed with Tcl_Free. This means that the ->freeProc of
-    an interpreter when returning a string using Tcl_Merge should be
-    TCL_DYNAMIC. Incorrectly freeing memory with glibc free will
-    cause segfaults in Tcl 8.4 and later.
-20. When submitting new files to the repository set SVN properties,
-    e.g.
-      svn:mime-type : text/x-tcl
-    See
